Hello,
The goal is to load a binary file from the SD/TF card into flash memory and then execute that uploaded code.
I've been reading different approaches. The code for this purpose is below. It is divided on the following sections:
- find address where to write binary file with enough space -> calculate_flash_offset()
- write the binary to flash memory -> writeFromFileToFlash()
- launch the function -> runFile()
The code is able to find the partitions, to calculate the offset where the binary should be loaded but then fails on the message Failed to erase flash memory portion.
root:$ run app.bin
Running /app.bin
Maximum binary app size that can be loaded into partition: 1441792
Size of binary app to be loaded: 238336
Writing to address: 3288704
Failed to erase flash memory: ESP_ERR_INVALID_ARG
I'm not familiar with these libraries, would someone here know how to solve the invalid arguments? I've looked into options such as LittleFS but there seems to exist no way to get the offset where each file gets placed. Perhaps there is a way?
Many thanks in advance!
#include <SdFat.h>-
#include <esp_partition.h>
* Provides a safe offset for loading the binary from disk storage
uint32_t calculate_flash_offset(File32 file, Stream* response) {
const esp_partition_t* partition = esp_partition_find_first(ESP_PARTITION_TYPE_DATA, ESP_PARTITION_SUBTYPE_DATA_SPIFFS, NULL);
uint32_t max_binary_app_size = partition->size;
uint32_t file_size = file.size();
response->print("Maximum binary app size that can be loaded into partition: ");
response->println(max_binary_app_size);
response->print("Size of binary app to be loaded: ");
response->println(file_size);
// Check if file size is larger than available free memory
if (file_size > max_binary_app_size) {
response->println("File size is larger than available free memory");
return -1;
Ensure that the binary app is placed in a location
that is aligned with the memory requirements of the ESP32,
while also providing enough space for it to run reliably.
uint32_t offset = partition->address + ((max_binary_app_size - file_size) / 2);
return offset;
void writeFromFileToFlash(uint32_t address, File32 file, Stream* response) {
// Open file
if (!file) {
response->println("Failed to open app file");
return;
// Get file size
size_t fileSize = file.size();
// Find partition
if (!partition) {
response->println("Failed to find partition for writing");
file.close();
return;
// Erase flash memory
esp_err_t err = esp_partition_erase_range(partition, address, fileSize);
if (err != ESP_OK) {
response->print("Failed to erase flash memory: ");
response->println(esp_err_to_name(err));
file.close();
return;
// Allocate buffer for file data
byte* buffer = new byte[fileSize];
// Read file data into buffer
if (file.read(buffer, fileSize) != fileSize) {
response->println("Failed to read app file");
delete[] buffer;
file.close();
return;
// Write data to flash memory
err = esp_partition_write(partition, address, buffer, fileSize);
response->println("Failed to write data to flash memory");
delete[] buffer;
file.close();
return;
// Free buffer memory and close file
delete[] buffer;
file.close();
response->println("Data written to flash memory successfully");
* Runs a binary app.
* Returns false when something went wrong.
boolean runFile(File32 file, Stream* response) {
uint32_t address = calculate_flash_offset(file, response);
if (address == -1) {
response->println("Unable to load app from file");
return false;
response->print("Writing to address: ");
response->println(address);
writeFromFileToFlash(address, file, response);
// now run the app
void (*firmwareEntry)(void) = (void (*)())(address);
firmwareEntry();
return true;
