E-PAPER Partial Update, i don't know how.
Hello,
Finally i can write in all the display:
https://forum.arduino.cc/index.php?topic=548059.0
Now my new issue is the "partial update", i see all the examples about this feature in the GxEPD and GxEPD2_AVR libraries and only i can update one line, but if i want to update two or more i can't.
Anyway i don't understand the code for partial update, the code looks like different in both libraries for this feature.
Display: 2,13" B/W Waveshare.
This is my best try (for Arduino Mega and GxEPD2_AVR Library):
// Display Library example for SPI e-paper panels from Dalian Good Display and boards from Waveshare.
// Requires HW SPI and Adafruit_GFX. Caution: these e-papers require 3.3V supply AND data lines!
// based on Demo Example from Good Display: http://www.good-display.com/download_list/downloadcategoryid=34&isMode=false.html
// Author: Jean-Marc Zingg
// Version: see library.properties
// Library: https://github.com/ZinggJM/GxEPD2_AVR
// Supporting Arduino Forum Topics:
// Waveshare e-paper displays with SPI: http://forum.arduino.cc/index.php?topic=487007.0
// Good Dispay ePaper for Arduino : https://forum.arduino.cc/index.php?topic=436411.0
// mapping suggestion from Waveshare SPI e-Paper to Wemos D1 mini
// BUSY -> D2, RST -> D4, DC -> D3, CS -> D8, CLK -> D5, DIN -> D7, GND -> GND, 3.3V -> 3.3V
// mapping suggestion from Waveshare SPI e-Paper to generic ESP8266
// BUSY -> GPIO4, RST -> GPIO2, DC -> GPIO0, CS -> GPIO15, CLK -> GPIO14, DIN -> GPIO13, GND -> GND, 3.3V -> 3.3V
// mapping suggestion for ESP32, e.g. LOLIN32, see .../variants/.../pins_arduino.h for your board
// NOTE: there are variants with different pins for SPI ! CHECK SPI PINS OF YOUR BOARD
// BUSY -> 4, RST -> 16, DC -> 17, CS -> SS(5), CLK -> SCK(18), DIN -> MOSI(23), GND -> GND, 3.3V -> 3.3V
// new mapping suggestion for STM32F1, e.g. STM32F103C8T6 "BluePill"
// BUSY -> A1, RST -> A2, DC -> A3, CS-> A4, CLK -> A5, DIN -> A7
// mapping suggestion for AVR, UNO, NANO etc.
// BUSY -> 7, RST -> 9, DC -> 8, CS-> 10, CLK -> 13, DIN -> 11
#include <GxEPD2_AVR_BW.h>
//#include <GxEPD2_AVR_3C.h>
#include <Fonts/FreeMonoBold9pt7b.h>
// select only the bitmaps for your display to reduce code space used, or de-select all
//#include "bitmaps/Bitmaps200x200.h" // 1.54" b/w
#include "bitmaps/Bitmaps128x250.h" // 2.13" b/w
//#include "bitmaps/Bitmaps128x296.h" // 2.9"  b/w
//#include "bitmaps/Bitmaps176x264.h" // 2.7"  b/w
//#include "bitmaps/Bitmaps400x300.h" // 4.2"  b/w // does not work (code size)
//#include "bitmaps/Bitmaps640x384.h" // 7.5"  b/w // does not work (code size)
// 3-color
//#include "bitmaps/Bitmaps3c200x200.h" // 1.54" b/w/r
//#include "bitmaps/Bitmaps3c104x212.h" // 2.13" b/w/r
//#include "bitmaps/Bitmaps3c128x296.h" // 2.9"  b/w/r
//#include "bitmaps/Bitmaps3c176x264.h" // 2.7"  b/w/r
//#include "bitmaps/Bitmaps3c400x300.h" // 4.2"  b/w/r
// select one and adapt to your mapping
//GxEPD2_AVR_BW display(GxEPD2::GDEP015OC1, /*CS=*/ SS, /*DC=*/ 8, /*RST=*/ 9, /*BUSY=*/ 7);
GxEPD2_AVR_BW display(GxEPD2::GDE0213B1, /*CS=*/ SS, /*DC=*/ 9, /*RST=*/ 8, /*BUSY=*/ 7);
//GxEPD2_AVR_BW display(GxEPD2::GDEH029A1, /*CS=*/ SS, /*DC=*/ 8, /*RST=*/ 9, /*BUSY=*/ 7);
//GxEPD2_AVR_BW display(GxEPD2::GDEW027W3, /*CS=*/ SS, /*DC=*/ 8, /*RST=*/ 9, /*BUSY=*/ 7);
//GxEPD2_AVR_BW display(GxEPD2::GDEW042T2, /*CS=*/ SS, /*DC=*/ 8, /*RST=*/ 9, /*BUSY=*/ 7);
//GxEPD2_AVR_BW display(GxEPD2::GDEW075T8, /*CS=*/ SS, /*DC=*/ 8, /*RST=*/ 9, /*BUSY=*/ 7);
// 3-color e-papers
//GxEPD2_AVR_3C display(GxEPD2::GDEW0154Z04, /*CS=*/ SS, /*DC=*/ 8, /*RST=*/ 9, /*BUSY=*/ 7);
//GxEPD2_AVR_3C display(GxEPD2::GDEW0213Z16, /*CS=*/ SS, /*DC=*/ 8, /*RST=*/ 9, /*BUSY=*/ 7);
//GxEPD2_AVR_3C display(GxEPD2::GDEW029Z10, /*CS=*/ SS, /*DC=*/ 8, /*RST=*/ 9, /*BUSY=*/ 7);
//GxEPD2_AVR_3C display(GxEPD2::GDEW027C44, /*CS=*/ SS, /*DC=*/ 8, /*RST=*/ 9, /*BUSY=*/ 7);
//GxEPD2_AVR_3C display(GxEPD2::GDEW042Z15, /*CS=*/ SS, /*DC=*/ 8, /*RST=*/ 9, /*BUSY=*/ 7);
display.init();
  //display.init();
  helloWorld();
  delay(50);
  helloWorld2();
  delay(50);
  helloWorld3();
  delay(50);
void helloWorld()
  display.setRotation(2);
  display.setFont(&FreeMonoBold9pt7b);
  display.setTextColor(GxEPD_BLACK);
  display.firstPage();
  do
    display.fillScreen(GxEPD_WHITE);
    display.setCursor(15, 20);
    display.println(F("AAAAAAAAAA"));
    //delay(50);
    display.setCursor(15, 40);
    display.println(F("BBBBBBBBBB"));
    //delay(50);
    display.setCursor(15, 60);
    display.println(F("CCCCCCCCCC"));
    //delay(50);
    display.setCursor(15, 80);
    display.println(F("DDDDDDDDDD"));
    //delay(50);
    display.setCursor(15, 100);
    display.println(F("EEEEEEEEEE"));
    //delay(50);
  while (display.nextPage());
void helloWorld2()
  display.setPartialWindow(0, 20, 128, 25); // x,y,width,height
  do
    display.hasFastPartialUpdate();
    display.println(F("0000000000"));
    delay(50);
void helloWorld3()
  display.setPartialWindow(0, 90, 128, 25); // x,y,width,height
  do
    display.println(F("1111111111"));
    delay(50);
In the display, i want to change the 2nd line ("BBBBBBBBBB") to "00000000000" and last line ("EEEEEEEEEE") to "1111111111" but the 2nd line change from "BBBBBBBBBB" to "0000000000" one time and shows always "0000000000". Only the last line change and repeat from "EEEEEEEEEE" to "1111111111".
Some suggestion? or code example?
Thanks in advance.
Regards.
Ok, finally looks like works, but not completely.
This is the code for Arduino Mega and GxEPD2_AVR Library:
// 3-color
// 3-color e-papers
  display.init();
  helloWorld();
  delay(50);
  helloWorld2();
  helloWorld3();
void helloWorld()
  do
void helloWorld2()
  delay(50);
  display.nextPage();
void helloWorld3()
  do
    delay(50);
The problem is that i have not idea what i'm doing :roll_eyes: and i don't understand why, for example, i can't remove "do" instruction and other lines in "void helloWorld3()" function, etc.
Can someone show me the correct way of the code?.
Thanks in advance.
Regards.
It doesn't help if you post multiple topics with related questions; it is not pleasant to follow links to find out what you want to do.
You get a better chance of answers if you state which display you have and which Arduino board you use.
All code extracts should be "complete", should allow to be compiled. It is not pleasant to have to study your code to find out what you want to achieve.
With Arduino MEGA or any 5V Arduino, use at least series resistors on data lines.
Read the README.MD file of the library you use, and for GxEPD2_AVR follow the link to Oliver's explanation of paged drawing and picture loop.
The do{…} while (display.nextPage()); loop is needed so that all pages that may get changed by the contained code get drawn to the controller memory and updated to the screen in the last nextPage call.
Hello,
my apologies for that. Anyway i put the board model in the first post from the beginning, but not the library, sorry again por that. I was doubt about the same question.... write in the same post or open a new and i decide to open a new because i think it's different issue.
Anyway i edit the post with all the info, now you can see the display in the full code (2,13" B/W Waveshare) and yes, i have resistors for asure 3.3v.
Thanks for your understanding and help. I see all libraries info from the beginning and i don't understand anything about this issue, anyway i will check it again, meanwhile if you want/can add some info with my full edited information i apreciate a lot
I will check your suggestions.
Thanks for your attention.
Regards.
Hi nimio,
I will take a closer look and try your code later, but maybe I see the issue:
add setFullWindow(); to the beginning of HelloWorld();
The original state of the display class is full window. In my example HelloWorld() is called only once.
To use it again, you need to reset to full window.
I will modify the example (later).
Good Luck!
Hi nimio,
Maybe this is what you wanted to do:
// 3-color
//GxEPD2_AVR_BW display(GxEPD2::GDE0213B1, /*CS=*/ SS, /*DC=*/ 8, /*RST=*/ 9, /*BUSY=*/ 7);
// 3-color e-papers
  display.init();
  helloWorld();
  delay(50);
  helloWorld2();
  helloWorld3();
void helloWorld()
  display.setFullWindow();
  do
void helloWorld2()
  do
    //display.hasFastPartialUpdate(); // is a read method
    delay(50);
void helloWorld3()
  do
    delay(50);
Hello ZinggJM,
Firstly thanks to taking your time helping to me.
I read the Oliver's explanation, now i understand a little bit these code line.
I test your code but adding "display.setFullWindow();" refresh the display every time and only change the last line one time every refresh.
I want change, for example, the 2nd and last line, blinking from one text to other and repeat..., all time. Anyway i just want to know how to work with the display, i mean in this case, how update a partial area to update information in the display.
In "my best try" (2nd post) i can do this successfully (not perfectly), but i think that is not the best way.
Regards.
Maybe this is closer to what you want to achieve:
Note the call to HelloWorld() in setup(); one full refresh is needed for start.
// 3-color
// 3-color e-papers
  display.init();
  helloWorld();
  helloWorld1();
  delay(50);
  helloWorld2();
  helloWorld3();
void helloWorld()
  do
void helloWorld1()
  //display.setFullWindow();
  display.setPartialWindow(0, 0, display.width(), display.height());
  do
void helloWorld2()
  do
    delay(50);
void helloWorld3()
  do
    delay(50);
Now works!
I will play a little bit with the code
Thanks for your help ZinggJM.
Regards.
