Ea oledm128-6 i2c
There is the SCl, the data even chipselect, which was not used, is connected and is measured. However, nothing is shown on the display. According to the data sheet, it was connected https://www.mouser.com/datasheet/2/127/oledm128_6e-1388684.pdf for the I2C 0x78 (0x3C). Does anyone know a solution to what it could be that it doesn't work.
#include <Wire.h>
#define OLED_I2C_ADDRESS 0x3C  // I2C-Adresse des Displays
int cs = 7;
// the setup routine runs once when you press reset:
  pinMode(cs, OUTPUT);
  digitalWrite(cs, HIGH); // cs für Display auf 1
  delay(2);
  digitalWrite(cs, LOW); // cs für Display auf 0
  Wire.begin();        // I2C starten
  delay(400);
  init_OLEDM128();     // OLED initialisieren
// Befehl an das OLED senden
void send_command(uint8_t command) {
  Wire.beginTransmission(OLED_I2C_ADDRESS);
  Wire.write(command);
  Wire.endTransmission();
// Daten an das Display senden (z.B. Textanzeige)
void send_data(uint8_t data) {
  Wire.write(data);
void init_OLEDM128() {
send_command(0x40); //Set Display start line
send_command(0xA0); //Bottom View no Segment remap
send_command(0xC0); //Bottom View COM scan direction normal
send_command(0xA6); //Display normal (RAM)
send_command(0x81);
send_command(0xFF);
send_command(0xD5);
send_command(0x40); //Clock divider/Oscillator frequency
send_command(0xD9);
send_command(0x44); //Pre‐charge Period
send_command(0xAF); //Display on
// "Hello World!" auf das Display schreiben
void display_text(const char*text) {
  for (uint8_t i = 0; text[i] != '\0'; i++) {
    send_data(text[i]); // Zeichen senden
 display_text("Hello");
Your description is kind of hard to understand.
Try I2C-scanner to see if it detects your display.
https://playground.arduino.cc/Main/I2cScanner/
Would'n it be easier to start with some display library example code?
Is CS needed for something on your display on I2C?
CS is involved in this because it would not have received the data without it ...
CS shouldn't be needed for I2C, just connect it to GND.
You didn't answer for my question about ssd1306 library example...
Yes i tried and it didnt work with the library. And its not the same Display there i need the OLED ssd1306 or a similar.
I know this with this Display ssd1306 it works but with the oledm128 it doesnt work.
Oke the CS doesnt need it. After i changed the initalisation a little bit the display just flickers.
send_command(0xFF); //81
//send_command(0xFF);
send_command(0xD5);
//send_command(0x40); //Clock divider/Oscillator frequency
send_command(0xD9);
//send_command(0x44); //Pre‐charge Period
send_command(0xDB);
//send_command(0x20);
Your datasheet linked describes it has ssd1306.
Feel free to post your circuit, simple drawing or good photo.
btw nice picture! i love electronics so yeah everything like this... just wow!
Ugly photo. This circuit doesn't enjoy of spaghetti wiring, everything should be neat and short.
Do you have 12.5V VCC and 3V VDD?
