Help with oled 128x64
Recently bought a oled display from some website I dont remember. Cant figure out how to install it and which library to use.
Specs / name:
GME 12864-80
1.3" 4P White
IIC OLED CH1116G
(chinese character): 20626
I dont even know if its I2C.
Also it has VDD, GND, SCK (not SCL) and SDA
Try to connect it to i2c pins and test with i2c scanner IDE example
Here's a good writeup on the differences between the CH1116 and the SSD1309. Looks like you might have to adapt an existing library. Have fun!
Compatible Solution for SSD1309 and CH1116 IC
IIC is I2c.
You probably have seen this, putting it here for reference.
