Hello Everybody.
I have been searching with no avail for way for turning the blacklit or force the whole display into sleep mode either via hardware modification but much better if via a software command.
It's installed as a shield so it vould be impossible ( I think) to drive the power on and off via a mosfet.
I hope somebody may provide some guidance here.
I am asking 'cause for an issue related to the SD card access on this forum I found an astounding and prompt support. I hope I can be that lucky once more.
Presently I am using the Elegoo libraries and not the Adafruit but that shouldn't be a limiting factor, isn't it?
Does it really have AMS1117-3.3 regulator ?
Does it have 74LVC245 buffers or 74HC245 buffers ?
The extra holes are seldom used. On a Uno all the GPIO is used for TFT and SD. Only A5 is spare and I don't think that A5 is routed to the "extra holes"
I confirm the AMS1117 and 2 x 74HC245A as fa I can see. I can post picture but I don't know whether it might be useful. From the back side I fail to locate any eventual connection from 5V to the backlight LED, Actually I cannot clearly spot the backlight LED at all
tft.writeRegister8(0x28, 0) //supposedly turns the backlight off
just to see whether it has any essect at all but writeRegister8() is set as private in Adafruit libraries on which Elegoo libraries seem to be based. How can I make it public?
