Buenas,
Tengo un problemilla para controlar 4 matrices led WS2812B de 8*32
El caso es que quiero que cada matriz salga por un pin de datos diferente, para hacer que cada una sea random y no se parezca a la de al lado.
Espero haberme explicado.
#include "FastLED.h"
#include "timer.h"
#include "droplet.h"
#if FASTLED_VERSION < 3001000
#error "Requires FastLED 3.1 or later; check github for latest code."
#endif
#define ROW_MAJOR 1
#define COLUMN_MAJOR 2
#define SNAKE_HORIZONTAL 3
#define SNAKE_VERTICAL 4
/*** PROGRAM SETTINGS - ADAPT TO YOUR NEEDS! **********************************/
// Hardware definitions.
#define DATA_PIN 3
#define LED_TYPE WS2812B
#define COLOR_ORDER GRB
// Effect settings.
constexpr unsigned long REFRESH_PERIOD_MS = 20;
constexpr int MAX_BRIGHTNESS = 50;
constexpr unsigned long DROPLET_MIN_RESPAWN_DELAY_MS = 500;
constexpr unsigned long DROPLET_MAX_RESPAWN_DELAY_MS = 5000;
constexpr unsigned long DROPLET_MIN_FALL_DELAY_MS = 50;
constexpr unsigned long DROPLET_MAX_FALL_DELAY_MS = 150;
// "The Matrix" color scheme
const CRGB COLOR_INITIAL(MAX_BRIGHTNESS/2, MAX_BRIGHTNESS, 0);
const CRGB COLOR_REST(0, 0, 0);
const CRGB COLOR_DECAY(20, 1, 1);
// "Fire" color scheme
// const CRGB COLOR_INITIAL(MAX_BRIGHTNESS, MAX_BRIGHTNESS, 0);
// const CRGB COLOR_REST(0, 0, 0);
// const CRGB COLOR_DECAY(1, 5, 1);
// Matrix dimensions.
#define ORDERING SNAKE_HORIZONTAL
constexpr int ROWS = 32;
constexpr int COLS = 8;
constexpr int NUM_LEDS = ROWS * COLS;
constexpr int DROPLETS_PER_COLUMN = 3;
constexpr int NUM_DROPLETS = DROPLETS_PER_COLUMN * COLS;
/*** GLOBAL :( VARIABLES ******************************************************/
// Global array with all LEDs.
CRGB leds[NUM_LEDS];
// Auxiliary function to access LEDs as a matrix.
CRGB& matrix(unsigned int row, unsigned int col) {
unsigned int idx =
#if ORDERING==ROW_MAJOR
row * COLS + col;
#elif ORDERING==COLUMN_MAJOR
col * ROWS + row;
#elif ORDERING==SNAKE_HORIZONTAL
row * COLS + (row % 2 == 0 ? col : COLS - 1 - col);
#elif ORDERING==SNAKE_VERTICAL
// row * COLS + (row % 2 == 0 ? COLS - 1 - col : col);
col * ROWS + (col % 2 == 0 ? row : ROWS - 1 - row);
#else
#error "You must set the macro ORDERING to allow addressing LEDs as a matrix"
#endif
return leds[idx];
// Array with droplets.
Droplet* droplets[NUM_DROPLETS];
// Timer to "flush" colors when needed.
Timer global_timer(REFRESH_PERIOD_MS);
// Timer to dim colors - it has the same rate as the global one.
Timer dim_timer(REFRESH_PERIOD_MS);
/*** MAIN PROGRAM - NOTHING TO CHANGE HERE (IN THEORY!) ***********************/
// 3 seconds delay for recovery.
delay(3000);
// Tell FastLED about the LED strip configuration.
FastLED.addLeds<LED_TYPE,DATA_PIN,COLOR_ORDER>(leds, NUM_LEDS)
.setCorrection(TypicalLEDStrip)
.setDither(MAX_BRIGHTNESS < 255);
// Initialize droplets.
for(unsigned int i=0; i<NUM_DROPLETS; i++) {
droplets[i] = new Droplet(
i % COLS,
ROWS,
DROPLET_MIN_RESPAWN_DELAY_MS,
DROPLET_MAX_RESPAWN_DELAY_MS,
DROPLET_MIN_FALL_DELAY_MS,
animate_droplets();
if(global_timer.tictoc())
FastLED.show();
void animate_droplets() {
if(dim_timer.tictoc()) {
for(unsigned int i=0; i<NUM_LEDS; i++) {
leds[i] -= COLOR_DECAY;
leds[i] |= COLOR_REST;
if(droplets[i]->visible()) {
matrix(droplets[i]->row(), droplets[i]->col()) = COLOR_INITIAL;
droplets[i]->update();
matrix(droplets[i]->row(), droplets[i]->col()) = CRGB(MAX_BRIGHTNESS, MAX_BRIGHTNESS, MAX_BRIGHTNESS);
Este es el código inicial con una matriz, he probado con mil funciones e historias y la verdad estoy perdido.
Un saludo y gracias
