we doing our project according to this video. Motor was used to work but when we tried sometime later it didn't work again what could be the issue with it
Code is below
#include <util/atomic.h> // For the ATOMIC_BLOCK macro
#define ENCA 2 // YELLOW
#define ENCB 3 // WHITE
#define PWM 5
#define IN2 6
#define IN1 7
volatile int posi = 0; // specify posi as volatile: volatile - Arduino Reference
long prevT = 0;
float eprev = 0;
float eintegral = 0;
pinMode(ENCA,INPUT);
pinMode(ENCB,INPUT);
attachInterrupt(digitalPinToInterrupt(ENCA),readEncoder,RISING);
pinMode(PWM,OUTPUT);
pinMode(IN1,OUTPUT);
pinMode(IN2,OUTPUT);
Serial.println("target pos");
// set target position
//int target = 1200;
int target = 250*sin(prevT/1e6);
// PID constants
float kp = 1;
float kd = 0.025;
float ki = 0.0;
// time difference
long currT = micros();
float deltaT = ((float) (currT - prevT))/( 1.0e6 );
prevT = currT;
// Read the position in an atomic block to avoid a potential
// misread if the interrupt coincides with this code running
// see: volatile - Arduino Reference
int pos = 0;
ATOMIC_BLOCK(ATOMIC_RESTORESTATE) {
pos = posi;
// error
int e = pos - target;
// derivative
float dedt = (e-eprev)/(deltaT);
// integral
eintegral = eintegral + e*deltaT;
// control signal
float u = kpe + kddedt + ki*eintegral;
// motor power
float pwr = fabs(u);
if( pwr > 255 ){
pwr = 255;
// motor direction
int dir = 1;
if(u<0){
dir = -1;
// signal the motor
setMotor(dir,pwr,PWM,IN1,IN2);
// store previous error
eprev = e;
Serial.print(target);
Serial.print(pos);
void setMotor(int dir, int pwmVal, int pwm, int in1, int in2){
analogWrite(pwm,pwmVal);
if(dir == 1){
digitalWrite(in1,HIGH);
digitalWrite(in2,LOW);
else if(dir == -1){
digitalWrite(in1,LOW);
digitalWrite(in2,HIGH);
else{
void readEncoder(){
int b = digitalRead(ENCB);
if(b > 0){
posi++;
else{
posi--;
