Error camara index h, i tried anything and i have no solution,please help
Is the error message still the same?
I guess it has changed
What exactly is the name of the file ?
Is it esp_camera.h or esp_camara.h ?
It must match the filename in this line of code
#include "esp_camera.h"
I think all these files should be put in the sketch folder:
C:\Users\a25988\Documents\Arduino\pap_correta_apenas_um_erro\camara.ino:4:15: error: redefinition of 'const uint8_t index_ov2640_html_gz []'
4 | const uint8_t index_ov2640_html_gz[] = {
In file included from C:\Users\a25988\Documents\Arduino\pap_correta_apenas_um_erro\pap_correta_apenas_um_erro.ino:23:
C:\Users\a25988\Documents\Arduino\pap_correta_apenas_um_erro\camera_index.h:4:21: note: 'const unsigned char index_ov2640_html_gz [6578]' previously defined here
4 | const unsigned char index_ov2640_html_gz[] = {
C:\Users\a25988\Documents\Arduino\pap_correta_apenas_um_erro\camara.ino:435:15: error: redefinition of 'const uint8_t index_ov3660_html_gz []'
435 | const uint8_t index_ov3660_html_gz[] = {
C:\Users\a25988\Documents\Arduino\pap_correta_apenas_um_erro\camera_index.h:262:21: note: 'const unsigned char index_ov3660_html_gz [8636]' previously defined here
262 | const unsigned char index_ov3660_html_gz[] = {
C:\Users\a25988\Documents\Arduino\pap_correta_apenas_um_erro\camara.ino:997:15: error: redefinition of 'const uint8_t index_ov5640_html_gz []'
997 | const uint8_t index_ov5640_html_gz[] = {
C:\Users\a25988\Documents\Arduino\pap_correta_apenas_um_erro\camera_index.h:600:21: note: 'const unsigned char index_ov5640_html_gz [8880]' previously defined here
600 | const unsigned char index_ov5640_html_gz[] = {
exit status 1
Compilation error: redefinition of 'const uint8_t index_ov2640_html_gz []'
now it gives this error
It seems that you installed the library pap_correta_apenas_um_erro incorrectly.
If you are trying to replicate someone's project from YouTube - please read the description under the video more carefully. Apparently, you should have downloaded the library used by the author and installed it in Arduino IDE.
It seems that you do not have basic knowledge of the C language and the Arduino system. I recommend you start with the reading the help on installing libraries.
DUPLO
LEGO
MECCANO
Emergency room
no i dont have basic knowledge thats why im asking for help, and i need help , can you help me pls
i did what you said and now i have this error, what should i do;~
C:/Users/a25988/AppData/Local/Arduino15/packages/esp32/tools/esp-x32/2405/bin/../lib/gcc/xtensa-esp-elf/13.2.0/../../../../xtensa-esp-elf/bin/ld.exe: C:\Users\a25988\AppData\Local\arduino\sketches\BADCA892ECE901A3B02CA9F09861BF17\libraries\FPVCar\app_httpd.cpp.o:c:\Users\a25988\Documents\Arduino\libraries\FPVCar/app_httpd.cpp:50: multiple definition of camera_httpd'; C:\Users\a25988\AppData\Local\arduino\sketches\BADCA892ECE901A3B02CA9F09861BF17\sketch\pap_correta_apenas_um_erro.ino.cpp.o:C:\Users\a25988\Documents\Arduino\pap_correta_apenas_um_erro/pap_correta_apenas_um_erro.ino:55: first defined here C:/Users/a25988/AppData/Local/Arduino15/packages/esp32/tools/esp-x32/2405/bin/../lib/gcc/xtensa-esp-elf/13.2.0/../../../../xtensa-esp-elf/bin/ld.exe: C:\Users\a25988\AppData\Local\arduino\sketches\BADCA892ECE901A3B02CA9F09861BF17\libraries\FPVCar\app_httpd.cpp.o:c:\Users\a25988\Documents\Arduino\libraries\FPVCar/app_httpd.cpp:49: multiple definition of stream_httpd'; C:\Users\a25988\AppData\Local\arduino\sketches\BADCA892ECE901A3B02CA9F09861BF17\sketch\pap_correta_apenas_um_erro.ino.cpp.o:C:\Users\a25988\Documents\Arduino\pap_correta_apenas_um_erro/pap_correta_apenas_um_erro.ino:54: first defined here
C:/Users/a25988/AppData/Local/Arduino15/packages/esp32/tools/esp-x32/2405/bin/../lib/gcc/xtensa-esp-elf/13.2.0/../../../../xtensa-esp-elf/bin/ld.exe: C:\Users\a25988\AppData\Local\arduino\sketches\BADCA892ECE901A3B02CA9F09861BF17\libraries\FPVCar\app_httpd.cpp.o: in function startCameraServer()': c:\Users\a25988\Documents\Arduino\libraries\FPVCar/app_httpd.cpp:380: multiple definition of startCameraServer()'; C:\Users\a25988\AppData\Local\arduino\sketches\BADCA892ECE901A3B02CA9F09861BF17\sketch\pap_correta_apenas_um_erro.ino.cpp.o:C:\Users\a25988\Documents\Arduino\pap_correta_apenas_um_erro/pap_correta_apenas_um_erro.ino:385: first defined here
C:/Users/a25988/AppData/Local/Arduino15/packages/esp32/tools/esp-x32/2405/bin/../lib/gcc/xtensa-esp-elf/13.2.0/../../../../xtensa-esp-elf/bin/ld.exe: C:\Users\a25988\AppData\Local\arduino\sketches\BADCA892ECE901A3B02CA9F09861BF17\libraries\FPVCar\app_httpd.cpp.o: in function WheelAct(int, int, int, int)': c:\Users\a25988\Documents\Arduino\libraries\FPVCar/app_httpd.cpp:490: multiple definition of WheelAct(int, int, int, int)'; C:\Users\a25988\AppData\Local\arduino\sketches\BADCA892ECE901A3B02CA9F09861BF17\sketch\pap_correta_apenas_um_erro.ino.cpp.o:C:\Users\a25988\Documents\Arduino\pap_correta_apenas_um_erro/pap_correta_apenas_um_erro.ino:494: first defined here
collect2.exe: error: ld returned 1 exit status
exit status 1
Compilation error: exit status 1
i resolved the problem but know apperears this
C:\Users\a25988\Documents\Arduino\FPVCar__1_\pap\car.ino:58:8: error: 'ra_filter_t' does not name a type
58 | static ra_filter_t ra_filter_init(ra_filter_t filter, size_t sample_size) {
C:\Users\a25988\Documents\Arduino\FPVCar__1_\pap\car.ino:71:26: error: 'ra_filter_t' was not declared in this scope; did you mean 'ra_filter_run'?
71 | static int ra_filter_run(ra_filter_t filter, int value) {
| ra_filter_run
C:\Users\a25988\Documents\Arduino\FPVCar__1_\pap\car.ino:71:39: error: 'filter' was not declared in this scope
C:\Users\a25988\Documents\Arduino\FPVCar__1_\pap\car.ino:71:47: error: expected primary-expression before 'int'
C:\Users\a25988\Documents\Arduino\FPVCar__1_\pap\car.ino:71:56: error: expression list treated as compound expression in initializer [-fpermissive]
C:\Users\a25988\Documents\Arduino\FPVCar__1_\pap\car.ino:98:34: error: 'httpd_req_t' was not declared in this scope
98 | static esp_err_t capture_handler(httpd_req_t req) {
C:\Users\a25988\Documents\Arduino\FPVCar__1_\pap\car.ino:98:47: error: 'req' was not declared in this scope
C:\Users\a25988\Documents\Arduino\FPVCar__1_\pap\car.ino:129:33: error: 'httpd_req_t' was not declared in this scope
129 | static esp_err_t stream_handler(httpd_req_t req) {
C:\Users\a25988\Documents\Arduino\FPVCar__1_\pap\car.ino:129:46: error: 'req' was not declared in this scope
C:\Users\a25988\Documents\Arduino\FPVCar__1_\pap\car.ino:201:30: error: 'httpd_req_t' was not declared in this scope
201 | static esp_err_t cmd_handler(httpd_req_t req) {
C:\Users\a25988\Documents\Arduino\FPVCar__1_\pap\car.ino:201:43: error: 'req' was not declared in this scope
C:\Users\a25988\Documents\Arduino\FPVCar__1_\pap\car.ino:277:33: error: 'httpd_req_t' was not declared in this scope
277 | static esp_err_t status_handler(httpd_req_t req) {
C:\Users\a25988\Documents\Arduino\FPVCar__1_\pap\car.ino:277:46: error: 'req' was not declared in this scope
C:\Users\a25988\Documents\Arduino\FPVCar__1_\pap\car.ino:314:32: error: 'httpd_req_t' was not declared in this scope
314 | static esp_err_t index_handler(httpd_req_t req) {
C:\Users\a25988\Documents\Arduino\FPVCar__1_\pap\car.ino:314:45: error: 'req' was not declared in this scope
C:\Users\a25988\Documents\Arduino\FPVCar__1_\pap\car.ino:340:29: error: 'httpd_req_t' was not declared in this scope
340 | static esp_err_t go_handler(httpd_req_t req) {
C:\Users\a25988\Documents\Arduino\FPVCar__1_\pap\car.ino:340:42: error: 'req' was not declared in this scope
C:\Users\a25988\Documents\Arduino\FPVCar__1_\pap\car.ino:346:31: error: 'httpd_req_t' was not declared in this scope
346 | static esp_err_t back_handler(httpd_req_t req) {
C:\Users\a25988\Documents\Arduino\FPVCar__1_\pap\car.ino:346:44: error: 'req' was not declared in this scope
C:\Users\a25988\Documents\Arduino\FPVCar__1_\pap\car.ino:353:31: error: 'httpd_req_t' was not declared in this scope
353 | static esp_err_t left_handler(httpd_req_t req) {
C:\Users\a25988\Documents\Arduino\FPVCar__1_\pap\car.ino:353:44: error: 'req' was not declared in this scope
C:\Users\a25988\Documents\Arduino\FPVCar__1_\pap\car.ino:359:32: error: 'httpd_req_t' was not declared in this scope
359 | static esp_err_t right_handler(httpd_req_t req) {
C:\Users\a25988\Documents\Arduino\FPVCar__1_\pap\car.ino:359:45: error: 'req' was not declared in this scope
C:\Users\a25988\Documents\Arduino\FPVCar__1_\pap\car.ino:366:31: error: 'httpd_req_t' was not declared in this scope
366 | static esp_err_t stop_handler(httpd_req_t req) {
C:\Users\a25988\Documents\Arduino\FPVCar__1_\pap\car.ino:366:44: error: 'req' was not declared in this scope
C:\Users\a25988\Documents\Arduino\FPVCar__1_\pap\car.ino:373:32: error: 'httpd_req_t' was not declared in this scope
373 | static esp_err_t ledon_handler(httpd_req_t req) {
C:\Users\a25988\Documents\Arduino\FPVCar__1_\pap\car.ino:373:45: error: 'req' was not declared in this scope
C:\Users\a25988\Documents\Arduino\FPVCar__1_\pap\car.ino:379:33: error: 'httpd_req_t' was not declared in this scope
379 | static esp_err_t ledoff_handler(httpd_req_t req) {
C:\Users\a25988\Documents\Arduino\FPVCar__1_\pap\car.ino:379:46: error: 'req' was not declared in this scope
C:\Users\a25988\Documents\Arduino\FPVCar__1_\pap\car.ino:71:56: error: 'int ra_filter_run(ra_filter_t
, int)' redeclared as different kind of entity
C:\Users\a25988\Documents\Arduino\FPVCar__1_\pap\car.ino:71:12: note: previous declaration 'int ra_filter_run'
C:\Users\a25988\Documents\Arduino\FPVCar__1_\pap\car.ino:98:50: error: 'esp_err_t capture_handler(httpd_req_t
C:\Users\a25988\Documents\Arduino\FPVCar__1_\pap\car.ino:98:18: note: previous declaration 'esp_err_t capture_handler'
C:\Users\a25988\Documents\Arduino\FPVCar__1_\pap\car.ino:129:49: error: 'esp_err_t stream_handler(httpd_req_t
C:\Users\a25988\Documents\Arduino\FPVCar__1_\pap\car.ino:129:18: note: previous declaration 'esp_err_t stream_handler'
C:\Users\a25988\Documents\Arduino\FPVCar__1_\pap\car.ino: In function 'esp_err_t stream_handler(httpd_req_t
C:\Users\a25988\Documents\Arduino\FPVCar__1_\pap\car.ino:191:44: error: 'ra_filter_run' cannot be used as a function
191 | uint32_t avg_frame_time = ra_filter_run(&ra_filter, frame_time);
C:\Users\a25988\Documents\Arduino\FPVCar__1_\pap\car.ino: At global scope:
C:\Users\a25988\Documents\Arduino\FPVCar__1_\pap\car.ino:201:46: error: 'esp_err_t cmd_handler(httpd_req_t
C:\Users\a25988\Documents\Arduino\FPVCar__1_\pap\car.ino:201:18: note: previous declaration 'esp_err_t cmd_handler'
C:\Users\a25988\Documents\Arduino\FPVCar__1_\pap\car.ino:277:49: error: 'esp_err_t status_handler(httpd_req_t
C:\Users\a25988\Documents\Arduino\FPVCar__1_\pap\car.ino:277:18: note: previous declaration 'esp_err_t status_handler'
C:\Users\a25988\Documents\Arduino\FPVCar__1_\pap\car.ino:314:48: error: 'esp_err_t index_handler(httpd_req_t
C:\Users\a25988\Documents\Arduino\FPVCar__1_\pap\car.ino:314:18: note: previous declaration 'esp_err_t index_handler'
C:\Users\a25988\Documents\Arduino\FPVCar__1_\pap\car.ino:340:45: error: 'esp_err_t go_handler(httpd_req_t
C:\Users\a25988\Documents\Arduino\FPVCar__1_\pap\car.ino:340:18: note: previous declaration 'esp_err_t go_handler'
C:\Users\a25988\Documents\Arduino\FPVCar__1_\pap\car.ino:346:47: error: 'esp_err_t back_handler(httpd_req_t
C:\Users\a25988\Documents\Arduino\FPVCar__1_\pap\car.ino:346:18: note: previous declaration 'esp_err_t back_handler'
C:\Users\a25988\Documents\Arduino\FPVCar__1_\pap\car.ino:353:47: error: 'esp_err_t left_handler(httpd_req_t
C:\Users\a25988\Documents\Arduino\FPVCar__1_\pap\car.ino:353:18: note: previous declaration 'esp_err_t left_handler'
C:\Users\a25988\Documents\Arduino\FPVCar__1_\pap\car.ino:359:48: error: 'esp_err_t right_handler(httpd_req_t
C:\Users\a25988\Documents\Arduino\FPVCar__1_\pap\car.ino:359:18: note: previous declaration 'esp_err_t right_handler'
C:\Users\a25988\Documents\Arduino\FPVCar__1_\pap\car.ino:366:47: error: 'esp_err_t stop_handler(httpd_req_t
C:\Users\a25988\Documents\Arduino\FPVCar__1_\pap\car.ino:366:18: note: previous declaration 'esp_err_t stop_handler'
C:\Users\a25988\Documents\Arduino\FPVCar__1_\pap\car.ino:373:48: error: 'esp_err_t ledon_handler(httpd_req_t
C:\Users\a25988\Documents\Arduino\FPVCar__1_\pap\car.ino:373:18: note: previous declaration 'esp_err_t ledon_handler'
C:\Users\a25988\Documents\Arduino\FPVCar__1_\pap\car.ino:379:49: error: 'esp_err_t ledoff_handler(httpd_req_t
C:\Users\a25988\Documents\Arduino\FPVCar__1_\pap\car.ino:379:18: note: previous declaration 'esp_err_t ledoff_handler'
C:\Users\a25988\Documents\Arduino\FPVCar__1_\pap\car.ino: In function 'void startCameraServer()':
C:\Users\a25988\Documents\Arduino\FPVCar__1_\pap\car.ino:392:16: error: invalid conversion from 'esp_err_t' {aka 'int'} to 'esp_err_t (
)(httpd_req_t
)' {aka 'int (
)(httpd_req
)'} [-fpermissive]
392 | .handler = go_handler,
| esp_err_t {aka int}
C:\Users\a25988\Documents\Arduino\FPVCar__1_\pap\car.ino:399:16: error: invalid conversion from 'esp_err_t' {aka 'int'} to 'esp_err_t (
)(httpd_req_t
)' {aka 'int (
)(httpd_req
)'} [-fpermissive]
399 | .handler = back_handler,
| esp_err_t {aka int}
C:\Users\a25988\Documents\Arduino\FPVCar__1_\pap\car.ino:406:16: error: invalid conversion from 'esp_err_t' {aka 'int'} to 'esp_err_t (
)(httpd_req_t
)' {aka 'int (
)(httpd_req
)'} [-fpermissive]
406 | .handler = stop_handler,
| esp_err_t {aka int}
C:\Users\a25988\Documents\Arduino\FPVCar__1_\pap\car.ino:413:16: error: invalid conversion from 'esp_err_t' {aka 'int'} to 'esp_err_t (
)(httpd_req_t
)' {aka 'int (
)(httpd_req
)'} [-fpermissive]
413 | .handler = left_handler,
| esp_err_t {aka int}
C:\Users\a25988\Documents\Arduino\FPVCar__1_\pap\car.ino:420:16: error: invalid conversion from 'esp_err_t' {aka 'int'} to 'esp_err_t (
)(httpd_req_t
)' {aka 'int (
)(httpd_req
)'} [-fpermissive]
420 | .handler = right_handler,
| esp_err_t {aka int}
C:\Users\a25988\Documents\Arduino\FPVCar__1_\pap\car.ino:427:16: error: invalid conversion from 'esp_err_t' {aka 'int'} to 'esp_err_t (
)(httpd_req_t
)' {aka 'int (
)(httpd_req
)'} [-fpermissive]
427 | .handler = ledon_handler,
| esp_err_t {aka int}
C:\Users\a25988\Documents\Arduino\FPVCar__1_\pap\car.ino:434:16: error: invalid conversion from 'esp_err_t' {aka 'int'} to 'esp_err_t (
)(httpd_req_t
)' {aka 'int (
)(httpd_req
)'} [-fpermissive]
434 | .handler = ledoff_handler,
| esp_err_t {aka int}
C:\Users\a25988\Documents\Arduino\FPVCar__1_\pap\car.ino:441:16: error: invalid conversion from 'esp_err_t' {aka 'int'} to 'esp_err_t (
)(httpd_req_t
)' {aka 'int (
)(httpd_req
)'} [-fpermissive]
441 | .handler = index_handler,
| esp_err_t {aka int}
C:\Users\a25988\Documents\Arduino\FPVCar__1_\pap\car.ino:448:16: error: invalid conversion from 'esp_err_t' {aka 'int'} to 'esp_err_t (
)(httpd_req_t
)' {aka 'int (
)(httpd_req
)'} [-fpermissive]
448 | .handler = status_handler,
| esp_err_t {aka int}
C:\Users\a25988\Documents\Arduino\FPVCar__1_\pap\car.ino:455:16: error: invalid conversion from 'esp_err_t' {aka 'int'} to 'esp_err_t (
)(httpd_req_t
)' {aka 'int (
)(httpd_req
)'} [-fpermissive]
455 | .handler = cmd_handler,
| esp_err_t {aka int}
C:\Users\a25988\Documents\Arduino\FPVCar__1_\pap\car.ino:462:16: error: invalid conversion from 'esp_err_t' {aka 'int'} to 'esp_err_t (
)(httpd_req_t
)' {aka 'int ()(httpd_req)'} [-fpermissive]
462 | .handler = capture_handler,
| esp_err_t {aka int}
C:\Users\a25988\Documents\Arduino\FPVCar__1_\pap\car.ino:469:16: error: invalid conversion from 'esp_err_t' {aka 'int'} to 'esp_err_t ()(httpd_req_t)' {aka 'int ()(httpd_req)'} [-fpermissive]
469 | .handler = stream_handler,
| esp_err_t {aka int}
exit status 1
Compilation error: 'ra_filter_t' does not name a type
People have been trying to help you. Now it's time for you to do your part.
Imagine you are watching the Olympics.
You see the 10 metre diving competition and are very impressed by the performances. The way the divers twist and turn on the way down before plunging into the water without anything more than a few ripples in the water is mesmerizing.
You decide to take up competitive diving.
That same day, you buy a swimsuit and hurry down to your local pool. You get changed and run up the ladder to the 10 metre platform. You stand at the edge and jump off.
And then as you flail helpless on the way down, you yell "NOW WHAT?" to the horrified poolside spectators, just before hitting the water in a tangled heap, breaking numerous bones in the process.
All because you lacked the basic knowledge of how to swim, let alone of how to dive.
Expecting to take up a full sized project when you don't have any basic programming knowledge is simply absurd. There is no other word for it.
Fortunately, a long time forum member, @LarryD, has put together a comprehensive list of "Things You Need To Know". You won't need to master all of them right off the bat, but Getting Started, Arduino Programming Course and C++ for Beginners might all be useful starting points for you.
Bookmarking that message for future reference would be a good thing for you to do. Should you continue in this endeavour, you may find yourself returning to read other topics as you progress.
maybe wrote wrong include.... #include "camara_index.h" change #include "camera_index.h"
yeah i know that, this is a project for PAP, for my school course, i need the code for any project i thiked so no need for that text , if i couldnt i wouldnt programe but is nedeed
yeah i already did that , thank you , i give me the error aleready sendeded
Well, you can't help someone who doesn't want to learn.
i want a solution, i will learn in the process
