Error camara index h, i tried anything and i have no solution,please help
i have this error and i nees e solution, my code only has this one error and i dont know how to solve it, can anyone help pls
fatal error: camara_index.h: No such file or directory
23 | #include "camara_index.h"
compilation terminated.
exit status 1
Welcome to the forum
Where did you get the sketch from and which Arduino board are you using ?
@gaby8277
Welcome to the Forum! Read the forum guidelines to see how to properly ask a question and some good information on making a good post. You will get faster and better help if you post all your code as requested by the forum guidelines.
Please go back and fix your original post.
Also please describe what the hardware do you use.
im using xiao esp32s3, the sketch i used is from a video of a project im doing ,https://www.youtube.com/watch?v=gmqgAcnKeFU&t=6s
Please insert the code to the forum as text using a code tags.
The video link for code analysis is of little use
The file is in the link to the code in the video. Download it and put it in the same folder as your sketch
#include <HTTP_Method.h>
#include <Middlewares.h>
#include <Uri.h>
#include <WebServer.h>
// Copyright 2015-2016 Espressif Systems (Shanghai) PTE LTD
// Licensed under the Apache License, Version 2.0 (the "License");
// you may not use this file except in compliance with the License.
// You may obtain a copy of the License at
Mod edit: link removed
// Unless required by applicable law or agreed to in writing, software
// distributed under the License is distributed on an "AS IS" BASIS,
// WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
// See the License for the specific language governing permissions and
// ESP-IDFlimitations under the License.
#include "esp_http_server.h"
#include "esp_timer.h"
#include "esp_camera.h"
#include "img_converters.h"
#include "Arduino.h"
extern int gpLb;
extern int gpLf;
extern int gpRb;
extern int gpRf;
extern int gpLed;
extern String WiFiAddr;
void WheelAct(int nLf, int nLb, int nRf, int nRb);
typedef struct {
size_t size; //number of values used for filtering
size_t index; //current value index
size_t count; //value count
int sum;
int * values; //array to be filled with values
} ra_filter_t;
typedef struct {
httpd_req_t *req;
size_t len;
} jpg_chunking_t;
#define PART_BOUNDARY "123456789000000000000987654321"
static const char* _STREAM_CONTENT_TYPE = "multipart/x-mixed-replace;boundary=" PART_BOUNDARY;
static const char* _STREAM_BOUNDARY = "\r\n--" PART_BOUNDARY "\r\n";
static const char* _STREAM_PART = "Content-Type: image/jpeg\r\nContent-Length: %u\r\n\r\n";
static ra_filter_t ra_filter;
httpd_handle_t stream_httpd = NULL;
httpd_handle_t camera_httpd = NULL;
static ra_filter_t * ra_filter_init(ra_filter_t * filter, size_t sample_size){
memset(filter, 0, sizeof(ra_filter_t));
filter->values = (int *)malloc(sample_size * sizeof(int));
if(!filter->values){
    return NULL;
memset(filter->values, 0, sample_size * sizeof(int));
filter->size = sample_size;
return filter;
static int ra_filter_run(ra_filter_t * filter, int value){
return value;
filter->sum -= filter->values[filter->index];
filter->values[filter->index] = value;
filter->sum += filter->values[filter->index];
filter->index++;
filter->index = filter->index % filter->size;
if (filter->count < filter->size) {
filter->count++;
return filter->sum / filter->count;
static size_t jpg_encode_stream(void * arg, size_t index, const void* data, size_t len){
jpg_chunking_t *j = (jpg_chunking_t *)arg;
if(!index){
j->len = 0;
if(httpd_resp_send_chunk(j->req, (const char *)data, len) != ESP_OK){
return 0;
j->len += len;
return len;
static esp_err_t capture_handler(httpd_req_t *req){
camera_fb_t * fb = NULL;
esp_err_t res = ESP_OK;
int64_t fr_start = esp_timer_get_time();
fb = esp_camera_fb_get();
if (!fb) {
    Serial.printf("Camera capture failed");
    httpd_resp_send_500(req);
    return ESP_FAIL;
httpd_resp_set_type(req, "image/jpeg");
httpd_resp_set_hdr(req, "Content-Disposition", "inline; filename=capture.jpg");
size_t fb_len = 0;
if(fb->format == PIXFORMAT_JPEG){
    fb_len = fb->len;
    res = httpd_resp_send(req, (const char *)fb->buf, fb->len);
    jpg_chunking_t jchunk = {req, 0};
    res = frame2jpg_cb(fb, 80, jpg_encode_stream, &jchunk)?ESP_OK:ESP_FAIL;
    httpd_resp_send_chunk(req, NULL, 0);
    fb_len = jchunk.len;
esp_camera_fb_return(fb);
int64_t fr_end = esp_timer_get_time();
Serial.printf("JPG: %uB %ums", (uint32_t)(fb_len), (uint32_t)((fr_end - fr_start)/1000));
return res;
static esp_err_t stream_handler(httpd_req_t *req){
size_t _jpg_buf_len = 0;
uint8_t * _jpg_buf = NULL;
char * part_buf[64];
static int64_t last_frame = 0;
if(!last_frame) {
    last_frame = esp_timer_get_time();
res = httpd_resp_set_type(req, _STREAM_CONTENT_TYPE);
if(res != ESP_OK){
    return res;
while(true){
    if (!fb) {
        res = ESP_FAIL;
        if(fb->format != PIXFORMAT_JPEG){
            bool jpeg_converted = frame2jpg(fb, 80, &_jpg_buf, &_jpg_buf_len);
            fb = NULL;
            if(!jpeg_converted){
                Serial.printf("JPEG compression failed");
                res = ESP_FAIL;
            _jpg_buf_len = fb->len;
            _jpg_buf = fb->buf;
    if(res == ESP_OK){
        size_t hlen = snprintf((char *)part_buf, 64, _STREAM_PART, _jpg_buf_len);
        res = httpd_resp_send_chunk(req, (const char *)part_buf, hlen);
    if(res == ESP_OK){
        res = httpd_resp_send_chunk(req, (const char *)_jpg_buf, _jpg_buf_len);
    if(res == ESP_OK){
        res = httpd_resp_send_chunk(req, _STREAM_BOUNDARY, strlen(_STREAM_BOUNDARY));
    if(fb){
        fb = NULL;
        _jpg_buf = NULL;
    } else if(_jpg_buf){
        free(_jpg_buf);
        _jpg_buf = NULL;
    if(res != ESP_OK){
    int64_t frame_time = fr_end - last_frame;
    last_frame = fr_end;
    frame_time /= 1000;
    uint32_t avg_frame_time = ra_filter_run(&ra_filter, frame_time);
    Serial.printf("MJPG: %uB %ums (%.1ffps), AVG: %ums (%.1ffps)"
        ,(uint32_t)(_jpg_buf_len),
        (uint32_t)frame_time, 1000.0 / (uint32_t)frame_time,
        avg_frame_time, 1000.0 / avg_frame_time
last_frame = 0;
return res;
static esp_err_t cmd_handler(httpd_req_t req){
char
buf;
size_t buf_len;
char variable[32] = {0,};
char value[32] = {0,};
buf_len = httpd_req_get_url_query_len(req) + 1;
if (buf_len > 1) {
    buf = (char*)malloc(buf_len);
    if(!buf){
        return ESP_FAIL;
    if (httpd_req_get_url_query_str(req, buf, buf_len) == ESP_OK) {
        if (httpd_query_key_value(buf, "var", variable, sizeof(variable)) == ESP_OK &&
            httpd_query_key_value(buf, "val", value, sizeof(value)) == ESP_OK) {
            free(buf);
            httpd_resp_send_404(req);
            return ESP_FAIL;
        free(buf);
        return ESP_FAIL;
    free(buf);
    return ESP_FAIL;
int val = atoi(value);
sensor_t * s = esp_camera_sensor_get();
int res = 0;
if(!strcmp(variable, "framesize")) {
    if(s->pixformat == PIXFORMAT_JPEG) res = s->set_framesize(s, (framesize_t)val);
else if(!strcmp(variable, "quality")) res = s->set_quality(s, val);
else if(!strcmp(variable, "contrast")) res = s->set_contrast(s, val);
else if(!strcmp(variable, "brightness")) res = s->set_brightness(s, val);
else if(!strcmp(variable, "saturation")) res = s->set_saturation(s, val);
else if(!strcmp(variable, "gainceiling")) res = s->set_gainceiling(s, (gainceiling_t)val);
else if(!strcmp(variable, "colorbar")) res = s->set_colorbar(s, val);
else if(!strcmp(variable, "awb")) res = s->set_whitebal(s, val);
else if(!strcmp(variable, "agc")) res = s->set_gain_ctrl(s, val);
else if(!strcmp(variable, "aec")) res = s->set_exposure_ctrl(s, val);
else if(!strcmp(variable, "hmirror")) res = s->set_hmirror(s, val);
else if(!strcmp(variable, "vflip")) res = s->set_vflip(s, val);
else if(!strcmp(variable, "awb_gain")) res = s->set_awb_gain(s, val);
else if(!strcmp(variable, "agc_gain")) res = s->set_agc_gain(s, val);
else if(!strcmp(variable, "aec_value")) res = s->set_aec_value(s, val);
else if(!strcmp(variable, "aec2")) res = s->set_aec2(s, val);
else if(!strcmp(variable, "dcw")) res = s->set_dcw(s, val);
else if(!strcmp(variable, "bpc")) res = s->set_bpc(s, val);
else if(!strcmp(variable, "wpc")) res = s->set_wpc(s, val);
else if(!strcmp(variable, "raw_gma")) res = s->set_raw_gma(s, val);
else if(!strcmp(variable, "lenc")) res = s->set_lenc(s, val);
else if(!strcmp(variable, "special_effect")) res = s->set_special_effect(s, val);
else if(!strcmp(variable, "wb_mode")) res = s->set_wb_mode(s, val);
else if(!strcmp(variable, "ae_level")) res = s->set_ae_level(s, val);
else {
    res = -1;
if(res){
    return httpd_resp_send_500(req);
httpd_resp_set_hdr(req, "Access-Control-Allow-Origin", "*");
return httpd_resp_send(req, NULL, 0);
static esp_err_t status_handler(httpd_req_t *req){
static char json_response[1024];
char * p = json_response;
*p++ = '{';
p+=sprintf(p, "\"framesize\":%u,", s->status.framesize);
p+=sprintf(p, "\"quality\":%u,", s->status.quality);
p+=sprintf(p, "\"brightness\":%d,", s->status.brightness);
p+=sprintf(p, "\"contrast\":%d,", s->status.contrast);
p+=sprintf(p, "\"saturation\":%d,", s->status.saturation);
p+=sprintf(p, "\"special_effect\":%u,", s->status.special_effect);
p+=sprintf(p, "\"wb_mode\":%u,", s->status.wb_mode);
p+=sprintf(p, "\"awb\":%u,", s->status.awb);
p+=sprintf(p, "\"awb_gain\":%u,", s->status.awb_gain);
p+=sprintf(p, "\"aec\":%u,", s->status.aec);
p+=sprintf(p, "\"aec2\":%u,", s->status.aec2);
p+=sprintf(p, "\"ae_level\":%d,", s->status.ae_level);
p+=sprintf(p, "\"aec_value\":%u,", s->status.aec_value);
p+=sprintf(p, "\"agc\":%u,", s->status.agc);
p+=sprintf(p, "\"agc_gain\":%u,", s->status.agc_gain);
p+=sprintf(p, "\"gainceiling\":%u,", s->status.gainceiling);
p+=sprintf(p, "\"bpc\":%u,", s->status.bpc);
p+=sprintf(p, "\"wpc\":%u,", s->status.wpc);
p+=sprintf(p, "\"raw_gma\":%u,", s->status.raw_gma);
p+=sprintf(p, "\"lenc\":%u,", s->status.lenc);
p+=sprintf(p, "\"hmirror\":%u,", s->status.hmirror);
p+=sprintf(p, "\"dcw\":%u,", s->status.dcw);
p+=sprintf(p, "\"colorbar\":%u", s->status.colorbar);
*p++ = '}';
*p++ = 0;
httpd_resp_set_type(req, "application/json");
return httpd_resp_send(req, json_response, strlen(json_response));
static esp_err_t index_handler(httpd_req_t *req){
httpd_resp_set_type(req, "text/html");
String page = "";
page += "<meta name="viewport" content="width=device-width, initial-scale=1.0, maximum-scale=1.0, user-scalable=0">\n";
page += "";
page += "";
//page += "
page += "
page += "
<button style=background-color:lightgrey;width:90px;height:80px onmousedown=getsend('go') onmouseup=getsend('stop') ontouchstart=getsend('go') ontouchend=getsend('stop') >Forward
page += "
page += "<button style=background-color:lightgrey;width:90px;height:80px; onmousedown=getsend('left') onmouseup=getsend('stop') ontouchstart=getsend('left') ontouchend=getsend('stop')>Left ";
page += "<button style=background-color:indianred;width:90px;height:80px onmousedown=getsend('stop') onmouseup=getsend('stop')>Stop ";
page += "<button style=background-color:lightgrey;width:90px;height:80px onmousedown=getsend('right') onmouseup=getsend('stop') ontouchstart=getsend('right') ontouchend=getsend('stop')>Right";
page += "
page += "
<button style=background-color:lightgrey;width:90px;height:80px onmousedown=getsend('back') onmouseup=getsend('stop') ontouchstart=getsend('back') ontouchend=getsend('stop') >Backward
page += "
page += "<button style=background-color:yellow;width:140px;height:40px onmousedown=getsend('ledon')>Light ON";
page += "<button style=background-color:yellow;width:140px;height:40px onmousedown=getsend('ledoff')>Light OFF";
page += "
return httpd_resp_send(req, &page[0], strlen(&page[0]));
static esp_err_t go_handler(httpd_req_t *req){
WheelAct(0, 90, 0, 90);
Serial.println("Go");
return httpd_resp_send(req, "OK", 2);
static esp_err_t back_handler(httpd_req_t *req){
WheelAct(90, 0, 90, 0);
Serial.println("Back");
static esp_err_t left_handler(httpd_req_t *req){
WheelAct(0, 110, 110, 0);
Serial.println("Left");
static esp_err_t right_handler(httpd_req_t *req){
WheelAct(110, 0, 0, 110);
Serial.println("Right");
static esp_err_t stop_handler(httpd_req_t *req){
WheelAct(0, 0, 0, 0);
Serial.println("Stop");
static esp_err_t ledon_handler(httpd_req_t *req){
digitalWrite(gpLed, HIGH);
Serial.println("LED ON");
static esp_err_t ledoff_handler(httpd_req_t *req){
digitalWrite(gpLed, LOW);
Serial.println("LED OFF");
void startCameraServer(){
httpd_config_t config = HTTPD_DEFAULT_CONFIG();
httpd_uri_t go_uri = {
    .uri       = "/go",
    .method    = HTTP_GET,
    .handler   = go_handler,
    .user_ctx  = NULL
httpd_uri_t back_uri = {
    .uri       = "/back",
    .method    = HTTP_GET,
    .handler   = back_handler,
    .user_ctx  = NULL
httpd_uri_t stop_uri = {
    .uri       = "/stop",
    .method    = HTTP_GET,
    .handler   = stop_handler,
    .user_ctx  = NULL
httpd_uri_t left_uri = {
    .uri       = "/left",
    .method    = HTTP_GET,
    .handler   = left_handler,
    .user_ctx  = NULL
httpd_uri_t right_uri = {
    .uri       = "/right",
    .method    = HTTP_GET,
    .handler   = right_handler,
    .user_ctx  = NULL
httpd_uri_t ledon_uri = {
    .uri       = "/ledon",
    .method    = HTTP_GET,
    .handler   = ledon_handler,
    .user_ctx  = NULL
httpd_uri_t ledoff_uri = {
    .uri       = "/ledoff",
    .method    = HTTP_GET,
    .handler   = ledoff_handler,
    .user_ctx  = NULL
httpd_uri_t index_uri = {
    .uri       = "/",
    .method    = HTTP_GET,
    .handler   = index_handler,
    .user_ctx  = NULL
httpd_uri_t status_uri = {
    .uri       = "/status",
    .method    = HTTP_GET,
    .handler   = status_handler,
    .user_ctx  = NULL
httpd_uri_t cmd_uri = {
    .uri       = "/control",
    .method    = HTTP_GET,
    .handler   = cmd_handler,
    .user_ctx  = NULL
httpd_uri_t capture_uri = {
    .uri       = "/capture",
    .method    = HTTP_GET,
    .handler   = capture_handler,
    .user_ctx  = NULL
httpd_uri_t stream_uri = {
.uri = "/stream",
.method = HTTP_GET,
.handler = stream_handler,
.user_ctx = NULL
ra_filter_init(&ra_filter, 20);
Serial.printf("Starting web server on port: '%d'", config.server_port);
if (httpd_start(&camera_httpd, &config) == ESP_OK) {
    httpd_register_uri_handler(camera_httpd, &index_uri);
    httpd_register_uri_handler(camera_httpd, &go_uri);
    httpd_register_uri_handler(camera_httpd, &back_uri);
    httpd_register_uri_handler(camera_httpd, &stop_uri);
    httpd_register_uri_handler(camera_httpd, &left_uri);
    httpd_register_uri_handler(camera_httpd, &right_uri);
    httpd_register_uri_handler(camera_httpd, &ledon_uri);
    httpd_register_uri_handler(camera_httpd, &ledoff_uri);
config.server_port += 1;
config.ctrl_port += 1;
Serial.printf("Starting stream server on port: '%d'", config.server_port);
if (httpd_start(&stream_httpd, &config) == ESP_OK) {
    httpd_register_uri_handler(stream_httpd, &stream_uri);
analogWrite(gpLf, nLf);
analogWrite(gpLb, nLb);
analogWrite(gpRf, nRf);
analogWrite(gpRb, nRb);
how i do that ?
Use code tags (the < CODE/ > icon above the compose window) to make it easier to read and copy for examination
Please post your full sketch, using code tags when you do
Posting your code using code tags prevents parts of it being interpreted as HTML coding and makes it easier to copy for examination
In my experience the easiest way to tidy up the code and add the code tags is as follows
Start by tidying up your code by using Tools/Auto Format in the IDE to make it easier to read. Then use Edit/Copy for Forum and paste what was copied in a new reply. Code tags will have been added to the code to make it easy to read in the forum thus making it easier to provide help.
It is also helpful to post error messages in code tags as it makes it easier to scroll through them and copy them for examination
Which part don't you understand ?
Do what?
Are you asking how to copy a file to a sketch folder?
#include <Uri.h>
// Mod edit: link removed
extern int gpLb;
extern int gpLf;
extern int gpRb;
extern int gpRf;
extern int gpLed;
typedef struct {
int sum;
} ra_filter_t;
typedef struct {
httpd_req_t *req;
size_t len;
} jpg_chunking_t;
    return NULL;
return filter;
return value;
filter->index++;
filter->count++;
if(!index){
j->len = 0;
return 0;
j->len += len;
return len;
if (!fb) {
    return ESP_FAIL;
size_t fb_len = 0;
    fb_len = fb->len;
return res;
if(!last_frame) {
if(res != ESP_OK){
    return res;
while(true){
    if (!fb) {
        res = ESP_FAIL;
            fb = NULL;
                res = ESP_FAIL;
            _jpg_buf = fb->buf;
    if(res == ESP_OK){
    if(res == ESP_OK){
    if(res == ESP_OK){
    if(fb){
        fb = NULL;
        _jpg_buf = NULL;
        free(_jpg_buf);
        _jpg_buf = NULL;
    if(res != ESP_OK){
    frame_time /= 1000;
last_frame = 0;
return res;
char
buf;
size_t buf_len;
if (buf_len > 1) {
    if(!buf){
        return ESP_FAIL;
            free(buf);
            return ESP_FAIL;
        free(buf);
        return ESP_FAIL;
    free(buf);
    return ESP_FAIL;
int res = 0;
else {
    res = -1;
if(res){
*p++ = '{';
*p++ = '}';
*p++ = 0;
String page = "";
page += "";
page += "";
//page += "
page += "
page += "
page += "
page += "
page += "
page += "
page += "
    .uri       = "/go",
    .method    = HTTP_GET,
    .user_ctx  = NULL
    .uri       = "/back",
    .method    = HTTP_GET,
    .user_ctx  = NULL
    .uri       = "/stop",
    .method    = HTTP_GET,
    .user_ctx  = NULL
    .uri       = "/left",
    .method    = HTTP_GET,
    .user_ctx  = NULL
    .uri       = "/right",
    .method    = HTTP_GET,
    .user_ctx  = NULL
    .uri       = "/ledon",
    .method    = HTTP_GET,
    .user_ctx  = NULL
    .uri       = "/ledoff",
    .method    = HTTP_GET,
    .user_ctx  = NULL
    .uri       = "/",
    .method    = HTTP_GET,
    .user_ctx  = NULL
    .uri       = "/status",
    .method    = HTTP_GET,
    .user_ctx  = NULL
    .uri       = "/control",
    .method    = HTTP_GET,
    .user_ctx  = NULL
    .uri       = "/capture",
    .method    = HTTP_GET,
    .user_ctx  = NULL
.uri = "/stream",
.method = HTTP_GET,
.user_ctx = NULL
exit status 1
Compilation error: camara_index.h: No such file or directory``
i chose the option «code» and it stayed like this
you inserted the code incorrectly again
i dont know how to put it corrctly
I suggest that you use the method that I suggested
#include <Uri.h>
//     http://www.apache.org/licenses/LICENSE-2.0
extern int gpLb;
extern int gpLf;
extern int gpRb;
extern int gpRf;
extern int gpLed;
typedef struct {
  int sum;
  int *values;  //array to be filled with values
} ra_filter_t;
typedef struct {
  httpd_req_t *req;
  size_t len;
} jpg_chunking_t;
static const char *_STREAM_CONTENT_TYPE = "multipart/x-mixed-replace;boundary=" PART_BOUNDARY;
static const char *_STREAM_BOUNDARY = "\r\n--" PART_BOUNDARY "\r\n";
static const char *_STREAM_PART = "Content-Type: image/jpeg\r\nContent-Length: %u\r\n\r\n";
static ra_filter_t *ra_filter_init(ra_filter_t *filter, size_t sample_size) {
  if (!filter->values) {
    return NULL;
  return filter;
static int ra_filter_run(ra_filter_t *filter, int value) {
    return value;
  filter->index++;
    filter->count++;
static size_t jpg_encode_stream(void *arg, size_t index, const void *data, size_t len) {
  if (!index) {
    j->len = 0;
  if (httpd_resp_send_chunk(j->req, (const char *)data, len) != ESP_OK) {
    return 0;
  j->len += len;
  return len;
static esp_err_t capture_handler(httpd_req_t *req) {
  camera_fb_t *fb = NULL;
  if (!fb) {
    return ESP_FAIL;
  size_t fb_len = 0;
  if (fb->format == PIXFORMAT_JPEG) {
    fb_len = fb->len;
    jpg_chunking_t jchunk = { req, 0 };
    res = frame2jpg_cb(fb, 80, jpg_encode_stream, &jchunk) ? ESP_OK : ESP_FAIL;
  Serial.printf("JPG: %uB %ums", (uint32_t)(fb_len), (uint32_t)((fr_end - fr_start) / 1000));
  return res;
static esp_err_t stream_handler(httpd_req_t *req) {
  uint8_t *_jpg_buf = NULL;
  char *part_buf[64];
  if (!last_frame) {
  if (res != ESP_OK) {
    return res;
  while (true) {
    if (!fb) {
      res = ESP_FAIL;
      if (fb->format != PIXFORMAT_JPEG) {
        fb = NULL;
        if (!jpeg_converted) {
          res = ESP_FAIL;
        _jpg_buf = fb->buf;
    if (res == ESP_OK) {
    if (fb) {
      fb = NULL;
      _jpg_buf = NULL;
    } else if (_jpg_buf) {
      free(_jpg_buf);
      _jpg_buf = NULL;
    frame_time /= 1000;
    Serial.printf("MJPG: %uB %ums (%.1ffps), AVG: %ums (%.1ffps)", (uint32_t)(_jpg_buf_len),
                  avg_frame_time, 1000.0 / avg_frame_time);
  last_frame = 0;
  return res;
static esp_err_t cmd_handler(httpd_req_t *req) {
  char *buf;
  size_t buf_len;
    0,
  char value[32] = {
    0,
  if (buf_len > 1) {
    buf = (char *)malloc(buf_len);
    if (!buf) {
      return ESP_FAIL;
      if (httpd_query_key_value(buf, "var", variable, sizeof(variable)) == ESP_OK && httpd_query_key_value(buf, "val", value, sizeof(value)) == ESP_OK) {
        free(buf);
        return ESP_FAIL;
      free(buf);
      return ESP_FAIL;
    free(buf);
    return ESP_FAIL;
  sensor_t *s = esp_camera_sensor_get();
  int res = 0;
  if (!strcmp(variable, "framesize")) {
    if (s->pixformat == PIXFORMAT_JPEG) res = s->set_framesize(s, (framesize_t)val);
  } else if (!strcmp(variable, "quality")) res = s->set_quality(s, val);
  else if (!strcmp(variable, "contrast")) res = s->set_contrast(s, val);
  else if (!strcmp(variable, "brightness")) res = s->set_brightness(s, val);
  else if (!strcmp(variable, "saturation")) res = s->set_saturation(s, val);
  else if (!strcmp(variable, "gainceiling")) res = s->set_gainceiling(s, (gainceiling_t)val);
  else if (!strcmp(variable, "colorbar")) res = s->set_colorbar(s, val);
  else if (!strcmp(variable, "awb")) res = s->set_whitebal(s, val);
  else if (!strcmp(variable, "agc")) res = s->set_gain_ctrl(s, val);
  else if (!strcmp(variable, "aec")) res = s->set_exposure_ctrl(s, val);
  else if (!strcmp(variable, "hmirror")) res = s->set_hmirror(s, val);
  else if (!strcmp(variable, "vflip")) res = s->set_vflip(s, val);
  else if (!strcmp(variable, "awb_gain")) res = s->set_awb_gain(s, val);
  else if (!strcmp(variable, "agc_gain")) res = s->set_agc_gain(s, val);
  else if (!strcmp(variable, "aec_value")) res = s->set_aec_value(s, val);
  else if (!strcmp(variable, "aec2")) res = s->set_aec2(s, val);
  else if (!strcmp(variable, "dcw")) res = s->set_dcw(s, val);
  else if (!strcmp(variable, "bpc")) res = s->set_bpc(s, val);
  else if (!strcmp(variable, "wpc")) res = s->set_wpc(s, val);
  else if (!strcmp(variable, "raw_gma")) res = s->set_raw_gma(s, val);
  else if (!strcmp(variable, "lenc")) res = s->set_lenc(s, val);
  else if (!strcmp(variable, "special_effect")) res = s->set_special_effect(s, val);
  else if (!strcmp(variable, "wb_mode")) res = s->set_wb_mode(s, val);
  else if (!strcmp(variable, "ae_level")) res = s->set_ae_level(s, val);
  else {
    res = -1;
  if (res) {
static esp_err_t status_handler(httpd_req_t *req) {
  char *p = json_response;
  *p++ = '{';
  p += sprintf(p, "\"framesize\":%u,", s->status.framesize);
  p += sprintf(p, "\"quality\":%u,", s->status.quality);
  p += sprintf(p, "\"brightness\":%d,", s->status.brightness);
  p += sprintf(p, "\"contrast\":%d,", s->status.contrast);
  p += sprintf(p, "\"saturation\":%d,", s->status.saturation);
  p += sprintf(p, "\"special_effect\":%u,", s->status.special_effect);
  p += sprintf(p, "\"wb_mode\":%u,", s->status.wb_mode);
  p += sprintf(p, "\"awb\":%u,", s->status.awb);
  p += sprintf(p, "\"awb_gain\":%u,", s->status.awb_gain);
  p += sprintf(p, "\"aec\":%u,", s->status.aec);
  p += sprintf(p, "\"aec2\":%u,", s->status.aec2);
  p += sprintf(p, "\"ae_level\":%d,", s->status.ae_level);
  p += sprintf(p, "\"aec_value\":%u,", s->status.aec_value);
  p += sprintf(p, "\"agc\":%u,", s->status.agc);
  p += sprintf(p, "\"agc_gain\":%u,", s->status.agc_gain);
  p += sprintf(p, "\"gainceiling\":%u,", s->status.gainceiling);
  p += sprintf(p, "\"bpc\":%u,", s->status.bpc);
  p += sprintf(p, "\"wpc\":%u,", s->status.wpc);
  p += sprintf(p, "\"raw_gma\":%u,", s->status.raw_gma);
  p += sprintf(p, "\"lenc\":%u,", s->status.lenc);
  p += sprintf(p, "\"hmirror\":%u,", s->status.hmirror);
  p += sprintf(p, "\"dcw\":%u,", s->status.dcw);
  p += sprintf(p, "\"colorbar\":%u", s->status.colorbar);
  *p++ = '}';
  *p++ = 0;
static esp_err_t index_handler(httpd_req_t *req) {
  String page = "";
  page += "<meta name=\"viewport\" content=\"width=device-width, initial-scale=1.0, maximum-scale=1.0, user-scalable=0\">\n";
  page += "<script>var xhttp = new XMLHttpRequest();</script>";
  page += "<script>function getsend(arg) { xhttp.open('GET', arg +'?' + new Date().getTime(), true); xhttp.send() } </script>";
  //page += "<p align=center><IMG SRC='http://" + WiFiAddr + ":81/stream' style='width:280px;'></p><br/><br/>";
  page += "<p align=center><IMG SRC='http://" + WiFiAddr + ":81/stream' style='width:300px;'></p><br/><br/>";
  page += "<p align=center> <button style=background-color:lightgrey;width:90px;height:80px onmousedown=getsend('go') onmouseup=getsend('stop') ontouchstart=getsend('go') ontouchend=getsend('stop') ><b>Forward</b></button> </p>";
  page += "<p align=center>";
  page += "<button style=background-color:lightgrey;width:90px;height:80px; onmousedown=getsend('left') onmouseup=getsend('stop') ontouchstart=getsend('left') ontouchend=getsend('stop')><b>Left</b></button>&nbsp;";
  page += "<button style=background-color:indianred;width:90px;height:80px onmousedown=getsend('stop') onmouseup=getsend('stop')><b>Stop</b></button>&nbsp;";
  page += "<button style=background-color:lightgrey;width:90px;height:80px onmousedown=getsend('right') onmouseup=getsend('stop') ontouchstart=getsend('right') ontouchend=getsend('stop')><b>Right</b></button>";
  page += "</p>";
  page += "<p align=center><button style=background-color:lightgrey;width:90px;height:80px onmousedown=getsend('back') onmouseup=getsend('stop') ontouchstart=getsend('back') ontouchend=getsend('stop') ><b>Backward</b></button></p>";
  page += "<button style=background-color:yellow;width:140px;height:40px onmousedown=getsend('ledon')><b>Light ON</b></button>";
  page += "<button style=background-color:yellow;width:140px;height:40px onmousedown=getsend('ledoff')><b>Light OFF</b></button>";
  page += "</p>";
static esp_err_t go_handler(httpd_req_t *req) {
static esp_err_t back_handler(httpd_req_t *req) {
static esp_err_t left_handler(httpd_req_t *req) {
static esp_err_t right_handler(httpd_req_t *req) {
static esp_err_t stop_handler(httpd_req_t *req) {
static esp_err_t ledon_handler(httpd_req_t *req) {
static esp_err_t ledoff_handler(httpd_req_t *req) {
void startCameraServer() {
    .uri = "/go",
    .method = HTTP_GET,
    .user_ctx = NULL
    .uri = "/back",
    .method = HTTP_GET,
    .user_ctx = NULL
    .uri = "/stop",
    .method = HTTP_GET,
    .user_ctx = NULL
    .uri = "/left",
    .method = HTTP_GET,
    .user_ctx = NULL
    .uri = "/right",
    .method = HTTP_GET,
    .user_ctx = NULL
    .uri = "/ledon",
    .method = HTTP_GET,
    .user_ctx = NULL
    .uri = "/ledoff",
    .method = HTTP_GET,
    .user_ctx = NULL
    .uri = "/",
    .method = HTTP_GET,
    .user_ctx = NULL
    .uri = "/status",
    .method = HTTP_GET,
    .user_ctx = NULL
    .uri = "/control",
    .method = HTTP_GET,
    .user_ctx = NULL
    .uri = "/capture",
    .method = HTTP_GET,
    .user_ctx = NULL
    .uri = "/stream",
    .method = HTTP_GET,
    .user_ctx = NULL
void WheelAct(int nLf, int nLb, int nRf, int nRb) {
C:\Users\a25988\Documents\Arduino\pap_correta_apenas_um_erro\pap_correta_apenas_um_erro.ino:23:10: fatal error: camara_index.h: No such file or directory
exit status 1
it gives this error everytime that i verify
Did you put camara_index.h in the same folder as your sketch ?
It should show up as a tab in the IDE editor window
yes it shows up in the tab but the promblem continues
