Error compiling for board Arduino Micro w/ XInput
I am having trouble with this here is the codes it gave me.
C:\Program Files (x86)\Arduino\hardware\xinput\avr\cores\arduino\xinput\USB_XInput_Descriptors.cpp:39:2: error: 'USB_VID' was not declared in this scope
USB_VID, // idEVendor
C:\Program Files (x86)\Arduino\hardware\xinput\avr\cores\arduino\xinput\USB_XInput_Descriptors.cpp:39:2: note: suggested alternative: 'USB_Recv'
USB_Recv
C:\Program Files (x86)\Arduino\hardware\xinput\avr\cores\arduino\xinput\USB_XInput_Descriptors.cpp:40:2: error: 'USB_PID' was not declared in this scope
USB_PID, // idProduct
C:\Program Files (x86)\Arduino\hardware\xinput\avr\cores\arduino\xinput\USB_XInput_Descriptors.cpp:40:2: note: suggested alternative: 'USB_Recv'
USB_Recv
Using library ArduinoXInput-master at version 1.2.5 in folder: C:\Users\Jordan's\Documents\Arduino\libraries\ArduinoXInput-master
Using library NintendoExtensionCtrl-master at version 0.8.3 in folder: C:\Users\Jordan's\Documents\Arduino\libraries\NintendoExtensionCtrl-master
Using library Wire at version 1.0 in folder: C:\Program Files (x86)\Arduino\hardware\xinput\avr\libraries\Wire
exit status 1
Error compiling for board Arduino Micro w/ XInput.
I guess you followed some sort of instructions to install this xinput thing. They might contain information the helpers here on the forum will find useful. Please post a link to them.
Here are the links
OK, that is very useful. I followed the instructions and it works just fine for me. The names that are shown as undeclared in your error messages are provided by the platform here:
I'm going to ask you to provide some additional information that might allow us to determine the cause of the problem.
Please do this:
  1. Select File > Preferences from the Arduino IDE's menus.
  2. Check the box next to "Show verbose output during: [] compilation".
  3. Click the OK button.
  4. Select Sketch > Verify/Compile from the Arduino IDE's menus.
  5. After the compilation fails you'll see a button on the right side of the orange bar in the Arduino IDE: Copy error messages. Click that button.
    This copies the full output to the clipboard.
  6. Open a forum reply here by clicking the Reply button.
  7. Click the </> icon on the post composer toolbar.
    This will add the forum's code block markup (```) to your reply to make sure the error messages are correctly formatted.
    Code block
  8. Press Ctrl+V.
    This will paste the compilation output into the code block.
  9. Move the cursor outside of the code tags before you add any additional text to your reply.
  10. Click the Reply button to post the output.
Arduino: 1.8.19 (Windows 10), Board: "Arduino Yún w/ XInput"
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\Jordan's\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Users\Jordan's\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\Jordan's\Documents\Arduino\libraries -fqbn=xinput:avr:yun -vid-pid=2341_8041 -ide-version=10819 -build-path C:\Users\Jordan's\AppData\Local\Temp\arduino_build_188797 -warnings=none -build-cache C:\Users\Jordan's\AppData\Local\Temp\arduino_cache_317120 -prefs=build.warn_data_percentage=75 -verbose C:\Users\Jordan's\Documents\Arduino\libraries\NintendoExtensionCtrl-master\examples\Guitar\Guitar_DebugPrint\Guitar_DebugPrint.ino
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\Jordan's\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Users\Jordan's\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\Jordan's\Documents\Arduino\libraries -fqbn=xinput:avr:yun -vid-pid=2341_8041 -ide-version=10819 -build-path C:\Users\Jordan's\AppData\Local\Temp\arduino_build_188797 -warnings=none -build-cache C:\Users\Jordan's\AppData\Local\Temp\arduino_cache_317120 -prefs=build.warn_data_percentage=75 -verbose C:\Users\Jordan's\Documents\Arduino\libraries\NintendoExtensionCtrl-master\examples\Guitar\Guitar_DebugPrint\Guitar_DebugPrint.ino
Using board 'yun' from platform in folder: C:\Program Files (x86)\Arduino\hardware\xinput\avr
Using core 'arduino' from platform in folder: C:\Program Files (x86)\Arduino\hardware\xinput\avr
Detecting libraries used...
"C:\\Users\\Jordan's\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega32u4 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_YUN -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\xinput\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\xinput\\avr\\variants\\yun" "C:\\Users\\Jordan's\\AppData\\Local\\Temp\\arduino_build_188797\\sketch\\Guitar_DebugPrint.ino.cpp" -o nul
Alternatives for NintendoExtensionCtrl.h: [NintendoExtensionCtrl-master@0.8.3]
ResolveLibrary(NintendoExtensionCtrl.h)
  -> candidates: [NintendoExtensionCtrl-master@0.8.3]
"C:\\Users\\Jordan's\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega32u4 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_YUN -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\xinput\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\xinput\\avr\\variants\\yun" "-IC:\\Users\\Jordan's\\Documents\\Arduino\\libraries\\NintendoExtensionCtrl-master\\src" "C:\\Users\\Jordan's\\AppData\\Local\\Temp\\arduino_build_188797\\sketch\\Guitar_DebugPrint.ino.cpp" -o nul
Alternatives for Wire.h: [Wire@1.0]
ResolveLibrary(Wire.h)
  -> candidates: [Wire@1.0]
"C:\\Users\\Jordan's\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega32u4 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_YUN -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\xinput\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\xinput\\avr\\variants\\yun" "-IC:\\Users\\Jordan's\\Documents\\Arduino\\libraries\\NintendoExtensionCtrl-master\\src" "-IC:\\Program Files (x86)\\Arduino\\hardware\\xinput\\avr\\libraries\\Wire\\src" "C:\\Users\\Jordan's\\AppData\\Local\\Temp\\arduino_build_188797\\sketch\\Guitar_DebugPrint.ino.cpp" -o nul
"C:\\Users\\Jordan's\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega32u4 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_YUN -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\xinput\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\xinput\\avr\\variants\\yun" "-IC:\\Users\\Jordan's\\Documents\\Arduino\\libraries\\NintendoExtensionCtrl-master\\src" "-IC:\\Program Files (x86)\\Arduino\\hardware\\xinput\\avr\\libraries\\Wire\\src" "C:\\Users\\Jordan's\\Documents\\Arduino\\libraries\\NintendoExtensionCtrl-master\\src\\controllers\\ClassicController.cpp" -o nul
"C:\\Users\\Jordan's\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega32u4 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_YUN -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\xinput\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\xinput\\avr\\variants\\yun" "-IC:\\Users\\Jordan's\\Documents\\Arduino\\libraries\\NintendoExtensionCtrl-master\\src" "-IC:\\Program Files (x86)\\Arduino\\hardware\\xinput\\avr\\libraries\\Wire\\src" "C:\\Users\\Jordan's\\Documents\\Arduino\\libraries\\NintendoExtensionCtrl-master\\src\\controllers\\DJTurntable.cpp" -o nul
"C:\\Users\\Jordan's\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega32u4 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_YUN -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\xinput\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\xinput\\avr\\variants\\yun" "-IC:\\Users\\Jordan's\\Documents\\Arduino\\libraries\\NintendoExtensionCtrl-master\\src" "-IC:\\Program Files (x86)\\Arduino\\hardware\\xinput\\avr\\libraries\\Wire\\src" "C:\\Users\\Jordan's\\Documents\\Arduino\\libraries\\NintendoExtensionCtrl-master\\src\\controllers\\DrawsomeTablet.cpp" -o nul
"C:\\Users\\Jordan's\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega32u4 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_YUN -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\xinput\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\xinput\\avr\\variants\\yun" "-IC:\\Users\\Jordan's\\Documents\\Arduino\\libraries\\NintendoExtensionCtrl-master\\src" "-IC:\\Program Files (x86)\\Arduino\\hardware\\xinput\\avr\\libraries\\Wire\\src" "C:\\Users\\Jordan's\\Documents\\Arduino\\libraries\\NintendoExtensionCtrl-master\\src\\controllers\\DrumController.cpp" -o nul
"C:\\Users\\Jordan's\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega32u4 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_YUN -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\xinput\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\xinput\\avr\\variants\\yun" "-IC:\\Users\\Jordan's\\Documents\\Arduino\\libraries\\NintendoExtensionCtrl-master\\src" "-IC:\\Program Files (x86)\\Arduino\\hardware\\xinput\\avr\\libraries\\Wire\\src" "C:\\Users\\Jordan's\\Documents\\Arduino\\libraries\\NintendoExtensionCtrl-master\\src\\controllers\\GuitarController.cpp" -o nul
"C:\\Users\\Jordan's\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega32u4 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_YUN -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\xinput\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\xinput\\avr\\variants\\yun" "-IC:\\Users\\Jordan's\\Documents\\Arduino\\libraries\\NintendoExtensionCtrl-master\\src" "-IC:\\Program Files (x86)\\Arduino\\hardware\\xinput\\avr\\libraries\\Wire\\src" "C:\\Users\\Jordan's\\Documents\\Arduino\\libraries\\NintendoExtensionCtrl-master\\src\\controllers\\Nunchuk.cpp" -o nul
"C:\\Users\\Jordan's\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega32u4 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_YUN -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\xinput\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\xinput\\avr\\variants\\yun" "-IC:\\Users\\Jordan's\\Documents\\Arduino\\libraries\\NintendoExtensionCtrl-master\\src" "-IC:\\Program Files (x86)\\Arduino\\hardware\\xinput\\avr\\libraries\\Wire\\src" "C:\\Users\\Jordan's\\Documents\\Arduino\\libraries\\NintendoExtensionCtrl-master\\src\\controllers\\uDrawTablet.cpp" -o nul
"C:\\Users\\Jordan's\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega32u4 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_YUN -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\xinput\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\xinput\\avr\\variants\\yun" "-IC:\\Users\\Jordan's\\Documents\\Arduino\\libraries\\NintendoExtensionCtrl-master\\src" "-IC:\\Program Files (x86)\\Arduino\\hardware\\xinput\\avr\\libraries\\Wire\\src" "C:\\Users\\Jordan's\\Documents\\Arduino\\libraries\\NintendoExtensionCtrl-master\\src\\internal\\ExtensionController.cpp" -o nul
"C:\\Users\\Jordan's\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega32u4 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_YUN -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\xinput\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\xinput\\avr\\variants\\yun" "-IC:\\Users\\Jordan's\\Documents\\Arduino\\libraries\\NintendoExtensionCtrl-master\\src" "-IC:\\Program Files (x86)\\Arduino\\hardware\\xinput\\avr\\libraries\\Wire\\src" "C:\\Users\\Jordan's\\Documents\\Arduino\\libraries\\NintendoExtensionCtrl-master\\src\\internal\\NXC_LinkedList.cpp" -o nul
"C:\\Users\\Jordan's\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega32u4 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_YUN -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\xinput\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\xinput\\avr\\variants\\yun" "-IC:\\Users\\Jordan's\\Documents\\Arduino\\libraries\\NintendoExtensionCtrl-master\\src" "-IC:\\Program Files (x86)\\Arduino\\hardware\\xinput\\avr\\libraries\\Wire\\src" "C:\\Users\\Jordan's\\Documents\\Arduino\\libraries\\NintendoExtensionCtrl-master\\src\\internal\\NXC_Utils.cpp" -o nul
"C:\\Users\\Jordan's\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega32u4 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_YUN -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\xinput\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\xinput\\avr\\variants\\yun" "-IC:\\Users\\Jordan's\\Documents\\Arduino\\libraries\\NintendoExtensionCtrl-master\\src" "-IC:\\Program Files (x86)\\Arduino\\hardware\\xinput\\avr\\libraries\\Wire\\src" "C:\\Program Files (x86)\\Arduino\\hardware\\xinput\\avr\\libraries\\Wire\\src\\Wire.cpp" -o nul
"C:\\Users\\Jordan's\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega32u4 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_YUN -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\xinput\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\xinput\\avr\\variants\\yun" "-IC:\\Users\\Jordan's\\Documents\\Arduino\\libraries\\NintendoExtensionCtrl-master\\src" "-IC:\\Program Files (x86)\\Arduino\\hardware\\xinput\\avr\\libraries\\Wire\\src" "C:\\Program Files (x86)\\Arduino\\hardware\\xinput\\avr\\libraries\\Wire\\src\\utility\\twi.c" -o nul
Generating function prototypes...
"C:\\Users\\Jordan's\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega32u4 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_YUN -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\xinput\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\xinput\\avr\\variants\\yun" "-IC:\\Users\\Jordan's\\Documents\\Arduino\\libraries\\NintendoExtensionCtrl-master\\src" "-IC:\\Program Files (x86)\\Arduino\\hardware\\xinput\\avr\\libraries\\Wire\\src" "C:\\Users\\Jordan's\\AppData\\Local\\Temp\\arduino_build_188797\\sketch\\Guitar_DebugPrint.ino.cpp" -o "C:\\Users\\Jordan's\\AppData\\Local\\Temp\\arduino_build_188797\\preproc\\ctags_target_for_gcc_minus_e.cpp"
"C:\\Program Files (x86)\\Arduino\\tools-builder\\ctags\\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\\Users\\Jordan's\\AppData\\Local\\Temp\\arduino_build_188797\\preproc\\ctags_target_for_gcc_minus_e.cpp"
Compiling sketch...
"C:\\Users\\Jordan's\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega32u4 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_YUN -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\xinput\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\xinput\\avr\\variants\\yun" "-IC:\\Users\\Jordan's\\Documents\\Arduino\\libraries\\NintendoExtensionCtrl-master\\src" "-IC:\\Program Files (x86)\\Arduino\\hardware\\xinput\\avr\\libraries\\Wire\\src" "C:\\Users\\Jordan's\\AppData\\Local\\Temp\\arduino_build_188797\\sketch\\Guitar_DebugPrint.ino.cpp" -o "C:\\Users\\Jordan's\\AppData\\Local\\Temp\\arduino_build_188797\\sketch\\Guitar_DebugPrint.ino.cpp.o"
Compiling libraries...
Compiling library "NintendoExtensionCtrl-master"
"C:\\Users\\Jordan's\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega32u4 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_YUN -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\xinput\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\xinput\\avr\\variants\\yun" "-IC:\\Users\\Jordan's\\Documents\\Arduino\\libraries\\NintendoExtensionCtrl-master\\src" "-IC:\\Program Files (x86)\\Arduino\\hardware\\xinput\\avr\\libraries\\Wire\\src" "C:\\Users\\Jordan's\\Documents\\Arduino\\libraries\\NintendoExtensionCtrl-master\\src\\controllers\\DJTurntable.cpp" -o "C:\\Users\\Jordan's\\AppData\\Local\\Temp\\arduino_build_188797\\libraries\\NintendoExtensionCtrl-master\\controllers\\DJTurntable.cpp.o"
"C:\\Users\\Jordan's\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega32u4 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_YUN -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\xinput\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\xinput\\avr\\variants\\yun" "-IC:\\Users\\Jordan's\\Documents\\Arduino\\libraries\\NintendoExtensionCtrl-master\\src" "-IC:\\Program Files (x86)\\Arduino\\hardware\\xinput\\avr\\libraries\\Wire\\src" "C:\\Users\\Jordan's\\Documents\\Arduino\\libraries\\NintendoExtensionCtrl-master\\src\\controllers\\ClassicController.cpp" -o "C:\\Users\\Jordan's\\AppData\\Local\\Temp\\arduino_build_188797\\libraries\\NintendoExtensionCtrl-master\\controllers\\ClassicController.cpp.o"
"C:\\Users\\Jordan's\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega32u4 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_YUN -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\xinput\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\xinput\\avr\\variants\\yun" "-IC:\\Users\\Jordan's\\Documents\\Arduino\\libraries\\NintendoExtensionCtrl-master\\src" "-IC:\\Program Files (x86)\\Arduino\\hardware\\xinput\\avr\\libraries\\Wire\\src" "C:\\Users\\Jordan's\\Documents\\Arduino\\libraries\\NintendoExtensionCtrl-master\\src\\controllers\\DrawsomeTablet.cpp" -o "C:\\Users\\Jordan's\\AppData\\Local\\Temp\\arduino_build_188797\\libraries\\NintendoExtensionCtrl-master\\controllers\\DrawsomeTablet.cpp.o"
"C:\\Users\\Jordan's\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega32u4 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_YUN -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\xinput\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\xinput\\avr\\variants\\yun" "-IC:\\Users\\Jordan's\\Documents\\Arduino\\libraries\\NintendoExtensionCtrl-master\\src" "-IC:\\Program Files (x86)\\Arduino\\hardware\\xinput\\avr\\libraries\\Wire\\src" "C:\\Users\\Jordan's\\Documents\\Arduino\\libraries\\NintendoExtensionCtrl-master\\src\\controllers\\DrumController.cpp" -o "C:\\Users\\Jordan's\\AppData\\Local\\Temp\\arduino_build_188797\\libraries\\NintendoExtensionCtrl-master\\controllers\\DrumController.cpp.o"
"C:\\Users\\Jordan's\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega32u4 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_YUN -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\xinput\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\xinput\\avr\\variants\\yun" "-IC:\\Users\\Jordan's\\Documents\\Arduino\\libraries\\NintendoExtensionCtrl-master\\src" "-IC:\\Program Files (x86)\\Arduino\\hardware\\xinput\\avr\\libraries\\Wire\\src" "C:\\Users\\Jordan's\\Documents\\Arduino\\libraries\\NintendoExtensionCtrl-master\\src\\controllers\\GuitarController.cpp" -o "C:\\Users\\Jordan's\\AppData\\Local\\Temp\\arduino_build_188797\\libraries\\NintendoExtensionCtrl-master\\controllers\\GuitarController.cpp.o"
"C:\\Users\\Jordan's\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega32u4 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_YUN -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\xinput\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\xinput\\avr\\variants\\yun" "-IC:\\Users\\Jordan's\\Documents\\Arduino\\libraries\\NintendoExtensionCtrl-master\\src" "-IC:\\Program Files (x86)\\Arduino\\hardware\\xinput\\avr\\libraries\\Wire\\src" "C:\\Users\\Jordan's\\Documents\\Arduino\\libraries\\NintendoExtensionCtrl-master\\src\\controllers\\Nunchuk.cpp" -o "C:\\Users\\Jordan's\\AppData\\Local\\Temp\\arduino_build_188797\\libraries\\NintendoExtensionCtrl-master\\controllers\\Nunchuk.cpp.o"
"C:\\Users\\Jordan's\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega32u4 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_YUN -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\xinput\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\xinput\\avr\\variants\\yun" "-IC:\\Users\\Jordan's\\Documents\\Arduino\\libraries\\NintendoExtensionCtrl-master\\src" "-IC:\\Program Files (x86)\\Arduino\\hardware\\xinput\\avr\\libraries\\Wire\\src" "C:\\Users\\Jordan's\\Documents\\Arduino\\libraries\\NintendoExtensionCtrl-master\\src\\controllers\\uDrawTablet.cpp" -o "C:\\Users\\Jordan's\\AppData\\Local\\Temp\\arduino_build_188797\\libraries\\NintendoExtensionCtrl-master\\controllers\\uDrawTablet.cpp.o"
"C:\\Users\\Jordan's\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega32u4 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_YUN -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\xinput\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\xinput\\avr\\variants\\yun" "-IC:\\Users\\Jordan's\\Documents\\Arduino\\libraries\\NintendoExtensionCtrl-master\\src" "-IC:\\Program Files (x86)\\Arduino\\hardware\\xinput\\avr\\libraries\\Wire\\src" "C:\\Users\\Jordan's\\Documents\\Arduino\\libraries\\NintendoExtensionCtrl-master\\src\\internal\\NXC_LinkedList.cpp" -o "C:\\Users\\Jordan's\\AppData\\Local\\Temp\\arduino_build_188797\\libraries\\NintendoExtensionCtrl-master\\internal\\NXC_LinkedList.cpp.o"
"C:\\Users\\Jordan's\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega32u4 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_YUN -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\xinput\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\xinput\\avr\\variants\\yun" "-IC:\\Users\\Jordan's\\Documents\\Arduino\\libraries\\NintendoExtensionCtrl-master\\src" "-IC:\\Program Files (x86)\\Arduino\\hardware\\xinput\\avr\\libraries\\Wire\\src" "C:\\Users\\Jordan's\\Documents\\Arduino\\libraries\\NintendoExtensionCtrl-master\\src\\internal\\ExtensionController.cpp" -o "C:\\Users\\Jordan's\\AppData\\Local\\Temp\\arduino_build_188797\\libraries\\NintendoExtensionCtrl-master\\internal\\ExtensionController.cpp.o"
"C:\\Users\\Jordan's\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega32u4 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_YUN -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\xinput\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\xinput\\avr\\variants\\yun" "-IC:\\Users\\Jordan's\\Documents\\Arduino\\libraries\\NintendoExtensionCtrl-master\\src" "-IC:\\Program Files (x86)\\Arduino\\hardware\\xinput\\avr\\libraries\\Wire\\src" "C:\\Users\\Jordan's\\Documents\\Arduino\\libraries\\NintendoExtensionCtrl-master\\src\\internal\\NXC_Utils.cpp" -o "C:\\Users\\Jordan's\\AppData\\Local\\Temp\\arduino_build_188797\\libraries\\NintendoExtensionCtrl-master\\internal\\NXC_Utils.cpp.o"
Compiling library "Wire"
"C:\\Users\\Jordan's\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega32u4 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_YUN -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\xinput\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\xinput\\avr\\variants\\yun" "-IC:\\Users\\Jordan's\\Documents\\Arduino\\libraries\\NintendoExtensionCtrl-master\\src" "-IC:\\Program Files (x86)\\Arduino\\hardware\\xinput\\avr\\libraries\\Wire\\src" "C:\\Program Files (x86)\\Arduino\\hardware\\xinput\\avr\\libraries\\Wire\\src\\Wire.cpp" -o "C:\\Users\\Jordan's\\AppData\\Local\\Temp\\arduino_build_188797\\libraries\\Wire\\Wire.cpp.o"
"C:\\Users\\Jordan's\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc" -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mmcu=atmega32u4 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_YUN -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\xinput\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\xinput\\avr\\variants\\yun" "-IC:\\Users\\Jordan's\\Documents\\Arduino\\libraries\\NintendoExtensionCtrl-master\\src" "-IC:\\Program Files (x86)\\Arduino\\hardware\\xinput\\avr\\libraries\\Wire\\src" "C:\\Program Files (x86)\\Arduino\\hardware\\xinput\\avr\\libraries\\Wire\\src\\utility\\twi.c" -o "C:\\Users\\Jordan's\\AppData\\Local\\Temp\\arduino_build_188797\\libraries\\Wire\\utility\\twi.c.o"
Compiling core...
"C:\\Users\\Jordan's\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc" -c -g -x assembler-with-cpp -flto -MMD -mmcu=atmega32u4 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_YUN -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\xinput\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\xinput\\avr\\variants\\yun" "C:\\Program Files (x86)\\Arduino\\hardware\\xinput\\avr\\cores\\arduino\\wiring_pulse.S" -o "C:\\Users\\Jordan's\\AppData\\Local\\Temp\\arduino_build_188797\\core\\wiring_pulse.S.o"
"C:\\Users\\Jordan's\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc" -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mmcu=atmega32u4 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_YUN -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\xinput\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\xinput\\avr\\variants\\yun" "C:\\Program Files (x86)\\Arduino\\hardware\\xinput\\avr\\cores\\arduino\\WInterrupts.c" -o "C:\\Users\\Jordan's\\AppData\\Local\\Temp\\arduino_build_188797\\core\\WInterrupts.c.o"
"C:\\Users\\Jordan's\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc" -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mmcu=atmega32u4 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_YUN -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\xinput\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\xinput\\avr\\variants\\yun" "C:\\Program Files (x86)\\Arduino\\hardware\\xinput\\avr\\cores\\arduino\\hooks.c" -o "C:\\Users\\Jordan's\\AppData\\Local\\Temp\\arduino_build_188797\\core\\hooks.c.o"
"C:\\Users\\Jordan's\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc" -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mmcu=atmega32u4 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_YUN -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\xinput\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\xinput\\avr\\variants\\yun" "C:\\Program Files (x86)\\Arduino\\hardware\\xinput\\avr\\cores\\arduino\\wiring_analog.c" -o "C:\\Users\\Jordan's\\AppData\\Local\\Temp\\arduino_build_188797\\core\\wiring_analog.c.o"
"C:\\Users\\Jordan's\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc" -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mmcu=atmega32u4 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_YUN -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\xinput\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\xinput\\avr\\variants\\yun" "C:\\Program Files (x86)\\Arduino\\hardware\\xinput\\avr\\cores\\arduino\\wiring.c" -o "C:\\Users\\Jordan's\\AppData\\Local\\Temp\\arduino_build_188797\\core\\wiring.c.o"
"C:\\Users\\Jordan's\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc" -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mmcu=atmega32u4 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_YUN -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\xinput\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\xinput\\avr\\variants\\yun" "C:\\Program Files (x86)\\Arduino\\hardware\\xinput\\avr\\cores\\arduino\\wiring_digital.c" -o "C:\\Users\\Jordan's\\AppData\\Local\\Temp\\arduino_build_188797\\core\\wiring_digital.c.o"
"C:\\Users\\Jordan's\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc" -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mmcu=atmega32u4 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_YUN -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\xinput\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\xinput\\avr\\variants\\yun" "C:\\Program Files (x86)\\Arduino\\hardware\\xinput\\avr\\cores\\arduino\\wiring_pulse.c" -o "C:\\Users\\Jordan's\\AppData\\Local\\Temp\\arduino_build_188797\\core\\wiring_pulse.c.o"
"C:\\Users\\Jordan's\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc" -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mmcu=atmega32u4 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_YUN -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\xinput\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\xinput\\avr\\variants\\yun" "C:\\Program Files (x86)\\Arduino\\hardware\\xinput\\avr\\cores\\arduino\\wiring_shift.c" -o "C:\\Users\\Jordan's\\AppData\\Local\\Temp\\arduino_build_188797\\core\\wiring_shift.c.o"
"C:\\Users\\Jordan's\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega32u4 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_YUN -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\xinput\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\xinput\\avr\\variants\\yun" "C:\\Program Files (x86)\\Arduino\\hardware\\xinput\\avr\\cores\\arduino\\CDC.cpp" -o "C:\\Users\\Jordan's\\AppData\\Local\\Temp\\arduino_build_188797\\core\\CDC.cpp.o"
"C:\\Users\\Jordan's\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega32u4 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_YUN -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\xinput\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\xinput\\avr\\variants\\yun" "C:\\Program Files (x86)\\Arduino\\hardware\\xinput\\avr\\cores\\arduino\\HardwareSerial1.cpp" -o "C:\\Users\\Jordan's\\AppData\\Local\\Temp\\arduino_build_188797\\core\\HardwareSerial1.cpp.o"
"C:\\Users\\Jordan's\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega32u4 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_YUN -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\xinput\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\xinput\\avr\\variants\\yun" "C:\\Program Files (x86)\\Arduino\\hardware\\xinput\\avr\\cores\\arduino\\HardwareSerial.cpp" -o "C:\\Users\\Jordan's\\AppData\\Local\\Temp\\arduino_build_188797\\core\\HardwareSerial.cpp.o"
"C:\\Users\\Jordan's\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega32u4 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_YUN -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\xinput\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\xinput\\avr\\variants\\yun" "C:\\Program Files (x86)\\Arduino\\hardware\\xinput\\avr\\cores\\arduino\\HardwareSerial0.cpp" -o "C:\\Users\\Jordan's\\AppData\\Local\\Temp\\arduino_build_188797\\core\\HardwareSerial0.cpp.o"
"C:\\Users\\Jordan's\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega32u4 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_YUN -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\xinput\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\xinput\\avr\\variants\\yun" "C:\\Program Files (x86)\\Arduino\\hardware\\xinput\\avr\\cores\\arduino\\HardwareSerial2.cpp" -o "C:\\Users\\Jordan's\\AppData\\Local\\Temp\\arduino_build_188797\\core\\HardwareSerial2.cpp.o"
"C:\\Users\\Jordan's\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega32u4 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_YUN -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\xinput\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\xinput\\avr\\variants\\yun" "C:\\Program Files (x86)\\Arduino\\hardware\\xinput\\avr\\cores\\arduino\\HardwareSerial3.cpp" -o "C:\\Users\\Jordan's\\AppData\\Local\\Temp\\arduino_build_188797\\core\\HardwareSerial3.cpp.o"
"C:\\Users\\Jordan's\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega32u4 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_YUN -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\xinput\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\xinput\\avr\\variants\\yun" "C:\\Program Files (x86)\\Arduino\\hardware\\xinput\\avr\\cores\\arduino\\IPAddress.cpp" -o "C:\\Users\\Jordan's\\AppData\\Local\\Temp\\arduino_build_188797\\core\\IPAddress.cpp.o"
"C:\\Users\\Jordan's\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega32u4 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_YUN -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\xinput\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\xinput\\avr\\variants\\yun" "C:\\Program Files (x86)\\Arduino\\hardware\\xinput\\avr\\cores\\arduino\\PluggableUSB.cpp" -o "C:\\Users\\Jordan's\\AppData\\Local\\Temp\\arduino_build_188797\\core\\PluggableUSB.cpp.o"
"C:\\Users\\Jordan's\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega32u4 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_YUN -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\xinput\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\xinput\\avr\\variants\\yun" "C:\\Program Files (x86)\\Arduino\\hardware\\xinput\\avr\\cores\\arduino\\Print.cpp" -o "C:\\Users\\Jordan's\\AppData\\Local\\Temp\\arduino_build_188797\\core\\Print.cpp.o"
"C:\\Users\\Jordan's\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega32u4 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_YUN -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\xinput\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\xinput\\avr\\variants\\yun" "C:\\Program Files (x86)\\Arduino\\hardware\\xinput\\avr\\cores\\arduino\\Stream.cpp" -o "C:\\Users\\Jordan's\\AppData\\Local\\Temp\\arduino_build_188797\\core\\Stream.cpp.o"
"C:\\Users\\Jordan's\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega32u4 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_YUN -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\xinput\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\xinput\\avr\\variants\\yun" "C:\\Program Files (x86)\\Arduino\\hardware\\xinput\\avr\\cores\\arduino\\Tone.cpp" -o "C:\\Users\\Jordan's\\AppData\\Local\\Temp\\arduino_build_188797\\core\\Tone.cpp.o"
"C:\\Users\\Jordan's\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega32u4 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_YUN -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\xinput\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\xinput\\avr\\variants\\yun" "C:\\Program Files (x86)\\Arduino\\hardware\\xinput\\avr\\cores\\arduino\\USBCore.cpp" -o "C:\\Users\\Jordan's\\AppData\\Local\\Temp\\arduino_build_188797\\core\\USBCore.cpp.o"
"C:\\Users\\Jordan's\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega32u4 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_YUN -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\xinput\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\xinput\\avr\\variants\\yun" "C:\\Program Files (x86)\\Arduino\\hardware\\xinput\\avr\\cores\\arduino\\WMath.cpp" -o "C:\\Users\\Jordan's\\AppData\\Local\\Temp\\arduino_build_188797\\core\\WMath.cpp.o"
"C:\\Users\\Jordan's\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega32u4 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_YUN -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\xinput\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\xinput\\avr\\variants\\yun" "C:\\Program Files (x86)\\Arduino\\hardware\\xinput\\avr\\cores\\arduino\\WString.cpp" -o "C:\\Users\\Jordan's\\AppData\\Local\\Temp\\arduino_build_188797\\core\\WString.cpp.o"
"C:\\Users\\Jordan's\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega32u4 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_YUN -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\xinput\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\xinput\\avr\\variants\\yun" "C:\\Program Files (x86)\\Arduino\\hardware\\xinput\\avr\\cores\\arduino\\abi.cpp" -o "C:\\Users\\Jordan's\\AppData\\Local\\Temp\\arduino_build_188797\\core\\abi.cpp.o"
"C:\\Users\\Jordan's\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega32u4 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_YUN -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\xinput\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\xinput\\avr\\variants\\yun" "C:\\Program Files (x86)\\Arduino\\hardware\\xinput\\avr\\cores\\arduino\\main.cpp" -o "C:\\Users\\Jordan's\\AppData\\Local\\Temp\\arduino_build_188797\\core\\main.cpp.o"
"C:\\Users\\Jordan's\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega32u4 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_YUN -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\xinput\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\xinput\\avr\\variants\\yun" "C:\\Program Files (x86)\\Arduino\\hardware\\xinput\\avr\\cores\\arduino\\new.cpp" -o "C:\\Users\\Jordan's\\AppData\\Local\\Temp\\arduino_build_188797\\core\\new.cpp.o"
"C:\\Users\\Jordan's\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega32u4 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_YUN -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\xinput\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\xinput\\avr\\variants\\yun" "C:\\Program Files (x86)\\Arduino\\hardware\\xinput\\avr\\cores\\arduino\\xinput\\USB_XInput_API.cpp" -o "C:\\Users\\Jordan's\\AppData\\Local\\Temp\\arduino_build_188797\\core\\xinput\\USB_XInput_API.cpp.o"
"C:\\Users\\Jordan's\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega32u4 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_YUN -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\xinput\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\xinput\\avr\\variants\\yun" "C:\\Program Files (x86)\\Arduino\\hardware\\xinput\\avr\\cores\\arduino\\xinput\\USB_XInput_Descriptors.cpp" -o "C:\\Users\\Jordan's\\AppData\\Local\\Temp\\arduino_build_188797\\core\\xinput\\USB_XInput_Descriptors.cpp.o"
  USB_Recv
  USB_Recv
exit status 1
Error compiling for board Arduino Yún w/ XInput.
It also says it is a Yun board even though it is a micro
It is odd. The -D flags for the USB_VID and USB_PID macros are missing from the compiler commands.
Let's try a fresh installation of the "Arduino XInput Boards" platform.
While we are at it, I'm going to move the installation to the sketchbook folder. I know the tutorial told you to put it in the Arduino IDE installation, and that does work, but it is really a bad idea to put anything there because it will be lost every time you update to a new version of the Arduino IDE and then you have to go back through the whole installation process all over again. The sketchbook folder persists through IDE updates, so you only need to do the "Arduino XInput Boards" platform. installation once.
Please try this:
  1. Close any Arduino IDE windows you have open.
  2. Delete this folder to remove the previous installation of the "Arduino XInput Boards" platform:
    Please be very careful when deleting things from your computer. When in doubt, back up!
  3. Create a folder named hardware in your sketchbook folder here:
  4. Download the "Arduino XInput Boards" platform from this link: https://github.com/dmadison/ArduinoXInput_AVR/releases/download/v1.0.2/ArduinoXInput_AVR_v1.0.2.zip
  5. Unzip the downloaded file.
  6. Copy the xinput folder to this path:
    C:\Users\Jordan's\Documents\Arduino\hardware\
You should now have a folder structure that looks like this:
`-- hardware
    `-- xinput
        `-- avr
            |-- boards.txt
            `-- etc...
Now start the Arduino IDE again and try compiling the Arduino sketch from the tutorial for the appropriate XInput board. Hopefully it will compile successfully this time.
Unfortunately this did not work.
I got it to work but the board keeps disconnecting while i am trying to upload the sketch.
An Arduino Micro (and other boards with native USB) will disconnect when the upload starts and provide a different port for the upload. Once the upload is complete, it will fall back to the original port.
Question is if your upload succeeded?
