Hi All,
I am new to Arduino and I am getting the above error for the sketch below:
#include <SPI.h>
#include <Wire.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
#include <Fonts/FreeSans9pt7b.h>
#define SCREEN_WIDTH 128 // OLED display width, in pixels
#define SCREEN_HEIGHT 64 // OLED display height, in pixels
// Declaration for an SSD1306 display connected to I2C (SDA, SCL pins)
#define OLED_RESET -1 // Reset pin # (or -1 if sharing Arduino reset pin)
Adafruit_SSD1306 display(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, OLED_RESET);
display.begin(SSD1306_SWITCHCAPVCC, 0x3C);
display.clearDisplay();
display.setTextSize(1); // Normal 1:1 pixel scale
display.setTextColor(WHITE); // Draw white text
display.cp437(true); // Use full 256 char 'Code Page 437' font
display.println("Something cool”);
display.display();
All help is welcome
The error message told you the exact line number where there error occurred. What line is that? Do you see the indicated error?
The compiler told you where, but you chose not to share the error message.
You're missing a loop function AND code tags.
Use code tags (the </> icon above the compose window) to make it easier to read and copy for examination
Hi UKHeliBob,
Thanks for the welcome and advice.
Do you wish me to resubmit my question?
Zarcoff
Arduino: 1.8.19 (Windows 10), Board: "Atmel atmega328pb Xplained mini"
C:\Users\M17 R3\Documents\Arduino\sketch_apr03a\sketch_apr03a.ino:39:17: warning: missing terminating " character
sketch_apr03a:39:17: error: missing terminating " character
C:\Users\M17 R3\Documents\Arduino\sketch_apr03a\sketch_apr03a.ino: In function 'void setup()':
sketch_apr03a:41:18: error: expected ')' before ';' token
display.display();
exit status 1
option enabled in File -> Preferences.
That second pair of quotes looks odd
No, but please edit your first post, select all of the code and then click the code tags icon ( </> ) to add the code tags
Also copy the full error message from the IDE using the Copy Error message button and post it here, also in code tags before saving the edited post
Using code tags in both cases makes it easier to read and copy for examination
Well spotted.
They are "smart" quotes put in by your operating system. Did you type this into the Arduino IDE?
