Error of 0x106 and wifi not connected issue with ESP32CAM
I am using ESP12-E to upload code to ESP32CAM (0V2640), CODE is getting uploaded but i am getting the error
18:33:42.372 -> E (45) camera: Detected camera not supported.
18:33:42.372 -> E (45) camera: Camera probe failed with error 0x106(ESP_ERR_NOT_SUPPORTED)
18:33:42.372 -> Camera init failed with error 0x106
Even wifi connected line is also not comming.
Please help.
I am also removing the GPI00 and GND pin of ESP cam after successful upload of the code and then pressing the reset button. still the same issue. all the updates are already done. please help.
I am getting the repeated statments each time after resest pin press of esp cam
Welcome to the forum
You started a topic in the Uncategorised category of the forum when its description explicitly tells you not to
Your topic has been moved to a relevant category. Please be careful in future when deciding where to start new topics
Which camera did you enable in the code? You need to have ONLY one camera specified. The other thing that will cause that error is a bad or loose camera cable.
If you are using an AI_THINKER, you need to uncomment it and comment out the ESP_EYE
I did that AI thinker, the thing is , wifi connected is not shwoing and the scrrenshot i shared which is continuously coming,,,
i guess error is that my wifi is not getting connected. how to ensure the tight connections?
Nothing to do with WiFi. Selecting the right camera (show me a screen shot of the hdr defines like I posted, and also of what board is selected.
What voltage are you using on the ESP32?
This is what you get when you google the error message.
I am using 3.3V power supply
#include <Arduino.h>
#include "esp_camera.h"
#include <WiFi.h>
// Select camera model in board_config.h
#include "board_config.h"
// Enter your WiFi credentials
const char *ssid = "OMSHIVAY";
const char *password = "11042008Prashant";
void startCameraServer();
void setupLedFlash();
  Serial.setDebugOutput(true);
  camera_config_t config;
  config.ledc_channel = LEDC_CHANNEL_0;
  config.ledc_timer = LEDC_TIMER_0;
  config.pin_d0 = Y2_GPIO_NUM;
  config.pin_d1 = Y3_GPIO_NUM;
  config.pin_d2 = Y4_GPIO_NUM;
  config.pin_d3 = Y5_GPIO_NUM;
  config.pin_d4 = Y6_GPIO_NUM;
  config.pin_d5 = Y7_GPIO_NUM;
  config.pin_d6 = Y8_GPIO_NUM;
  config.pin_d7 = Y9_GPIO_NUM;
  config.pin_xclk = XCLK_GPIO_NUM;
  config.pin_pclk = PCLK_GPIO_NUM;
  config.pin_vsync = VSYNC_GPIO_NUM;
  config.pin_href = HREF_GPIO_NUM;
  config.pin_sccb_sda = SIOD_GPIO_NUM;
  config.pin_sccb_scl = SIOC_GPIO_NUM;
  config.pin_pwdn = PWDN_GPIO_NUM;
  config.pin_reset = RESET_GPIO_NUM;
  config.xclk_freq_hz = 20000000;
  config.frame_size = FRAMESIZE_UXGA;
  config.pixel_format = PIXFORMAT_JPEG;  // for streaming
  //config.pixel_format = PIXFORMAT_RGB565; // for face detection/recognition
  config.grab_mode = CAMERA_GRAB_WHEN_EMPTY;
  config.fb_location = CAMERA_FB_IN_PSRAM;
  config.jpeg_quality = 12;
  config.fb_count = 1;
  // if PSRAM IC present, init with UXGA resolution and higher JPEG quality
  //                      for larger pre-allocated frame buffer.
  if (config.pixel_format == PIXFORMAT_JPEG) {
    if (psramFound()) {
      config.jpeg_quality = 10;
      config.fb_count = 2;
      config.grab_mode = CAMERA_GRAB_LATEST;
      // Limit the frame size when PSRAM is not available
      config.frame_size = FRAMESIZE_SVGA;
      config.fb_location = CAMERA_FB_IN_DRAM;
    // Best option for face detection/recognition
    config.frame_size = FRAMESIZE_240X240;
#if CONFIG_IDF_TARGET_ESP32S3
#endif
#if defined(CAMERA_MODEL_ESP_EYE)
  pinMode(13, INPUT_PULLUP);
  pinMode(14, INPUT_PULLUP);
#endif
  // camera init
  esp_err_t err = esp_camera_init(&config);
  if (err != ESP_OK) {
    Serial.printf("Camera init failed with error 0x%x", err);
    return;
  sensor_t *s = esp_camera_sensor_get();
  // initial sensors are flipped vertically and colors are a bit saturated
  if (s->id.PID == OV3660_PID) {
    s->set_vflip(s, 1);        // flip it back
    s->set_brightness(s, 1);   // up the brightness just a bit
    s->set_saturation(s, -2);  // lower the saturation
  // drop down frame size for higher initial frame rate
    s->set_framesize(s, FRAMESIZE_QVGA);
#if defined(CAMERA_MODEL_M5STACK_WIDE) || defined(CAMERA_MODEL_M5STACK_ESP32CAM)
  s->set_vflip(s, 1);
  s->set_hmirror(s, 1);
#endif
#if defined(CAMERA_MODEL_ESP32S3_EYE)
  s->set_vflip(s, 1);
#endif
// Setup LED FLash if LED pin is defined in camera_pins.h
#if defined(LED_GPIO_NUM)
  setupLedFlash();
#endif
  WiFi.begin(ssid, password);
  WiFi.setSleep(false);
  Serial.print("WiFi connecting");
    Serial.print(".");
  Serial.println("");
  Serial.println("WiFi connected");
  Serial.print("Camera Ready! Use 'http://");
  Serial.print(WiFi.localIP());
  Serial.println("' to connect");
  // Do nothing. Everything is done in another task by the web server
  delay(10000);
#ifndef BOARD_CONFIG_H
#define BOARD_CONFIG_H
// WARNING!!! PSRAM IC required for UXGA resolution and high JPEG quality
//            Ensure ESP32 Wrover Module or other board with PSRAM is selected
//            Partial images will be transmitted if image exceeds buffer size
//            You must select partition scheme from the board menu that has at least 3MB APP space.
//#define CAMERA_MODEL_WROVER_KIT // Has PSRAM
//define CAMERA_MODEL_ESP_EYE  // Has PSRAM
//#define CAMERA_MODEL_ESP32S3_EYE // Has PSRAM
//#define CAMERA_MODEL_M5STACK_PSRAM // Has PSRAM
//#define CAMERA_MODEL_M5STACK_V2_PSRAM // M5Camera version B Has PSRAM
//#define CAMERA_MODEL_M5STACK_WIDE // Has PSRAM
//#define CAMERA_MODEL_M5STACK_ESP32CAM // No PSRAM
//#define CAMERA_MODEL_M5STACK_UNITCAM // No PSRAM
//#define CAMERA_MODEL_M5STACK_CAMS3_UNIT  // Has PSRAM
#define CAMERA_MODEL_AI_THINKER // Has PSRAM
//#define CAMERA_MODEL_TTGO_T_JOURNAL // No PSRAM
//#define CAMERA_MODEL_XIAO_ESP32S3 // Has PSRAM
// ** Espressif Internal Boards **
//#define CAMERA_MODEL_ESP32_CAM_BOARD
//#define CAMERA_MODEL_ESP32S2_CAM_BOARD
//#define CAMERA_MODEL_ESP32S3_CAM_LCD
//#define CAMERA_MODEL_DFRobot_FireBeetle2_ESP32S3 // Has PSRAM
//#define CAMERA_MODEL_DFRobot_Romeo_ESP32S3 // Has PSRAM
#include "camera_pins.h"
#endif  // BOARD_CONFIG_H
Yep, that's what the cause is, change it to 5V on the 5V pin and the PSU should be capable of delivering 1A for when the WiFi radio kicks in.
on my esp or on espcam , i have to change to 5 V, I don't have 5V option on my esp (module 12 E) , kindly say from which to which I have to connect 5v.
Ok, those look good so just change the power supply and it should work.
u mean I have to connect 3X3 V from esp 12 e to 5v pin of ESP32 CAM? am i right
NO, you need to connect the esp32-cam 5V pin to a 5V supply.
Have you learned Ohm's law, kirchhoff's laws? You sound like you are not ready for this level yet.
I don't have 5V options from my ESPmodule12E development board... suggest me how ot supply 5V to the ESP32 CAM.
Use a wall wart, or battery pack. Or instead of the 12E get an FTDI.
You normally can't use a board pin to power another board.
What will you use to power the esp32-cam when you are done uploading and ready to deploy the device?
Do you know there is am MB board that will allow USB power?
I have seen many one had listed the same query, but there was no any suitable answer.
and even when i had given 3x3 v to espcam by esp12E., it flashed also when i pressed the resset pin of esp cam, but now it is not flashing and writing camera probe failed with error, detected camera not supported and camera init failed with error 0x106.
I am not confirm that whether my cam module is AI thinker or not , only written ESP 32S CAM and strip no is 0v2640.
is this ai thinker module? or i have choosen wrong camera model? kindly reply
