Error uploading sketch from Arduino 1.8.4 to Intel Galileo 2 board
Hi there,
When trying to upload the basic 'Blink' sketch to my Galileo 2 board, I get the error report below.
Can I trouble someone to explain what this means please, and how to resolve it? BTW I'm quite the beginner here, so if it can be explained in laymans terms it would be much appreciated.
starting download script
Args to shell: /home/jeff/.arduino15/packages/Intel/tools/sketchUploader/1.6.2+1.0/x86/bin /tmp/arduino_build_665282/Blink.ino.elf /dev/ttyUSB0
Serial Port PORT
Using tty Port /dev/ttyUSB0
Sending Command String to move to download if not already in download mode
#!/bin/sh
clupload script to invoke lsz
Copyright (C) 2014 Intel Corporation
This library is free software; you can redistribute it and/or
modify it under the terms of the GNU Lesser General Public
License as published by the Free Software Foundation; either
version 2.1 of the License, or (at your option) any later version.
This library is distributed in the hope that it will be useful,
but WITHOUT ANY WARRANTY; without even the implied warranty of
MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
Lesser General Public License for more details.
You should have received a copy of the GNU Lesser General Public
License along with this library; if not, write to the Free Software
Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, MA 02110-1301 USA
echo "starting download script"
echo "Args to shell:" $*
ARG 1: Path to lsz executable.
ARG 2: Elf File to download
ARG 3: TTY port to use.
#path may contain \ need to change all to /
path_to_exe=$1
fixed_path=${path_to_exe//\//}
tty_port_id=$3
echo "Serial Port PORT" $com_port_id
echo "Using tty Port" $tty_port_id
echo "Sending Command String to move to download if not already in download mode"
echo "~sketch downloadGalileo" > $tty_port_id
#Give the host time to stop the process and wait for download
sleep 1
Deleting existing sketch on target
#Move the existing sketch on target.
echo "Deleting existing sketch on target"
"$fixed_path/lsz" --escape -c "mv -f /sketch/sketch.elf /sketch/sketch.elf.old" < $tty_port_id > $tty_port_id
Retry 0: Got TIMEOUT
Transfer incomplete
Execute the target download command
#Download the file.
host_file_name=$2
"$fixed_path/lsz" --escape --binary --overwrite $host_file_name < $tty_port_id > $tty_port_id
Retry 0: Timeout on pathname
Transfer incomplete
#mv the downloaded file to /sketch/sketch.elf
Moving downloaded file to /sketch/sketch.elf on target
target_download_name="${host_file_name##*/}"
echo "Moving downloaded file to /sketch/sketch.elf on target"
"$fixed_path/lsz" --escape -c "mv $target_download_name /sketch/sketch.elf; chmod +x /sketch/sketch.elf" < $tty_port_id > $tty_port_id
Transfer incomplete
An error occurred while uploading the sketch
