Errore durante lo scaricamento di https://downloads.arduino.cc/libraries/library
Salve a tutti,sto cercando di aprire Gestione librerie di arduino IDE, ma riporta sempre il solito errore.
Ho provato a reinstallare Java e IDE ma non ha funzionato.
Ho anche disattivato firewall e antivirus.
 Errore durante lo scaricamento di https://downloads.arduino.cc/libraries/library_index.json
java.lang.RuntimeException: java.lang.Exception: Errore durante lo scaricamento di https://downloads.arduino.cc/libraries/library_index.json
	at cc.arduino.contributions.libraries.ui.LibraryManagerUI.lambda$onUpdatePressed$2(LibraryManagerUI.java:210)
	at java.lang.Thread.run(Thread.java:748)
Caused by: java.lang.Exception: Errore durante lo scaricamento di https://downloads.arduino.cc/libraries/library_index.json
	at cc.arduino.contributions.DownloadableContributionsDownloader.download(DownloadableContributionsDownloader.java:149)
	at cc.arduino.contributions.DownloadableContributionsDownloader.download(DownloadableContributionsDownloader.java:130)
	at cc.arduino.contributions.JsonDownloader.download(JsonDownloader.java:49)
	at cc.arduino.contributions.GZippedJsonDownloader.download(GZippedJsonDownloader.java:66)
	at cc.arduino.contributions.libraries.LibraryInstaller.updateIndex(LibraryInstaller.java:84)
	at cc.arduino.contributions.libraries.ui.LibraryManagerUI.lambda$onUpdatePressed$2(LibraryManagerUI.java:203)
	... 1 more
Caused by: java.net.SocketException: Permission denied: connect
	at java.net.TwoStacksPlainSocketImpl.socketConnect(Native Method)
	at java.net.AbstractPlainSocketImpl.doConnect(AbstractPlainSocketImpl.java:350)
	at java.net.AbstractPlainSocketImpl.connectToAddress(AbstractPlainSocketImpl.java:206)
	at java.net.AbstractPlainSocketImpl.connect(AbstractPlainSocketImpl.java:188)
	at java.net.PlainSocketImpl.connect(PlainSocketImpl.java:172)
	at java.net.SocksSocketImpl.connect(SocksSocketImpl.java:392)
	at java.net.Socket.connect(Socket.java:589)
	at sun.security.ssl.SSLSocketImpl.connect(SSLSocketImpl.java:666)
	at sun.net.NetworkClient.doConnect(NetworkClient.java:175)
	at sun.net.www.http.HttpClient.openServer(HttpClient.java:463)
	at sun.net.www.http.HttpClient.openServer(HttpClient.java:558)
	at sun.net.www.protocol.https.HttpsClient.<init>(HttpsClient.java:264)
	at sun.net.www.protocol.https.HttpsClient.New(HttpsClient.java:367)
	at sun.net.www.protocol.https.AbstractDelegateHttpsURLConnection.getNewHttpClient(AbstractDelegateHttpsURLConnection.java:191)
	at sun.net.www.protocol.http.HttpURLConnection.plainConnect0(HttpURLConnection.java:1199)
	at sun.net.www.protocol.http.HttpURLConnection.plainConnect(HttpURLConnection.java:1050)
	at sun.net.www.protocol.https.AbstractDelegateHttpsURLConnection.connect(AbstractDelegateHttpsURLConnection.java:177)
	at sun.net.www.protocol.https.HttpsURLConnectionImpl.connect(HttpsURLConnectionImpl.java:162)
	at cc.arduino.utils.network.HttpConnectionManager.makeConnection(HttpConnectionManager.java:155)
	at cc.arduino.utils.network.HttpConnectionManager.makeConnection(HttpConnectionManager.java:106)
	at cc.arduino.utils.network.FileDownloaderCache.updateCacheInfo(FileDownloaderCache.java:184)
	at cc.arduino.utils.network.FileDownloaderCache.getFileCached(FileDownloaderCache.java:153)
	at cc.arduino.utils.network.FileDownloader.downloadFile(FileDownloader.java:167)
	at cc.arduino.utils.network.FileDownloader.download(FileDownloader.java:129)
	at cc.arduino.contributions.DownloadableContributionsDownloader.download(DownloadableContributionsDownloader.java:147)
	... 6 more
ho cercato su google, ma non ho trovato niente di utile.
ho notato anche che non mi crea la cartella arduino15.
Buongiorno e benvenuto, :slight_smile:
essendo il tuo primo post, nel rispetto del regolamento della sezione Italiana del forum (… punto 13, primo capoverso), ti chiedo cortesemente di presentarti IN QUESTO THREAD (spiegando bene quali conoscenze hai di elettronica e di programmazione ... possibilmente evitando di scrivere solo una riga di saluto) e di leggere con molta attenzione tutto il su citato REGOLAMENTO ... Grazie. :slight_smile:
Guglielmo
P.S.: Ti ricordo che, purtroppo, fino a quando non sarà fatta la presentazione nell’apposito thread, nessuno ti potrà rispondere, quindi ti consiglio di farla al più presto. :wink:
P.P.S.: ... e, cortesemente, edita il tuo post qui sopra, perché la tua frase iniziale è stata troncata alla prima lettera ...
Scusate non sono abituato a scrivere sui forum :smiley:
Comunque mi sono presentato, e il corriere mi ha appena consegnato l arduino.
Non vedo l ora di cominciare, aiutatemi a risolvere questo problema per favore. :sob:
Che versione dell'IDE? Preso da dove? Installato come? Che sistema operativo? ... insomma, mancano un bel po' di informazioni :wink:
Guglielmo
Sono una frana....Arduino 1.8.13(Windows Store 1.8.42.0) su pc Windows
Non usare la versione da windows store. Disinstallalo.
Scarica dal sito il file .zip dell'IDE e spacchettalo in una cartella con un nome semplice, esempio: c:\ArduinoIDE
poi prima di avviarlo, creati una sottocartella portable: c:\ArduinoIDE\portable
In questo modo tutto l'IDE, i progetti, librerie saranno dentro a quella unica cartella.
Posso darti un consiglio (che trovi in un'infinità di thread)? ... vai nel pannello di controllo e DISINSTALLALO.
Poi vai sulla pagina ufficiale del download di Arduino, scarichi la versione .zip (NON l'.exe dell'installer), scompatti il .zip in una cartella dove tu puoi sia scrivere che leggere e ... li hai il tuo Arduino ... prova e vedi se la cosa si risolve, altrimenti facciamo un'altro passo.
Guglielmo
P.S.: Nid mi ha preceduto :smiley: ... ma ... aspetta per quanto riguarda la portable, vediamo se già la versione normale da .zip risolve. :wink:
Guglielmo, io consiglio comunque sempre il portable, per non avere ide da una parte e librerie/progetti sotto quel cacchio di c:\users\xxx\documents\etc.. che a volte sotto Win10 da problemi di permessi
...accidenti a Microsoft !! :slight_smile:
Niente da fare ragazzi
	at cc.arduino.contributions.libraries.ui.LibraryManagerUI.lambda$onUpdatePressed$2(LibraryManagerUI.java:207)
	... 1 more
	... 6 more
la cartella dove ho estratto ha tutti i permessi di questo mondo.
Ho provato con e senza cartella portable ma non cambia nulla. :cry:
Ho inserito l indirizzo https://downloads.arduino.cc/libraries/library_index.json nel browser e mi carica questo
  "libraries": [
      "name": "AudioZero",
      "version": "1.0.1",
      "author": "Arduino",
      "maintainer": "Arduino \u003cinfo@arduino.cc\u003e",
      "sentence": "Allows playing audio files from an SD card. For Arduino Zero only.",
      "paragraph": "With this library you can use the Arduino Zero DAC outputs to play audio files.\u003cbr /\u003eThe audio files must be in the raw .wav format.",
      "website": "http://arduino.cc/en/Reference/Audio",
      "category": "Signal Input/Output",
      "architectures": [
        "samd"
      "types": [
        "Arduino"
      "repository": "https://github.com/arduino-libraries/AudioZero.git",
      "url": "http://downloads.arduino.cc/libraries/github.com/arduino-libraries/AudioZero-1.0.1.zip",
      "archiveFileName": "AudioZero-1.0.1.zip",
      "size": 5836,
      "checksum": "SHA-256:980a6168380e9e46a6d9780f7d904d5845902b6fb53cb4e30bdc044114546613"
Il file è quello (mooolto più lungo)
Visto l'errore "java.net.SocketException: Permission denied: connect"
sembrerebbe non hai accesso a internet da Arduino IDE o da java
Sicuro di non avere un antivirus o un firewall ? Magari microsoft defender ?
