Ho acquistato una smart car munita di sensore SR04. Nel kit mi sono stati forniti i codici per le funzioni da lei svolte tra cui il codice C++ per l'attivazione del sensore SR04 per riconoscere gli ostacoli. Mediante IDE vado a fare la verifica e compaiono una serie di errori:
C:\Users\Asus\AppData\Local\Temp\ccoasYka.ltrans0.ltrans.o: In function avoid': C:\Users\Asus\Desktop\JAVA\KS0559(KS0559F)Keyestudio 4WD BT Multi-purpose Car V2.0\3. Arduino Tutorial\3. Projects\Project 13 Ultrasonic Obstacle Avoidance Smart Car\lesson_13_Avoiding_Car/lesson_13_Avoiding_Car.ino:50: undefined reference to SR04::Distance()'
C:\Users\Asus\Desktop\JAVA\KS0559(KS0559F)Keyestudio 4WD BT Multi-purpose Car V2.0\3. Arduino Tutorial\3. Projects\Project 13 Ultrasonic Obstacle Avoidance Smart Car\lesson_13_Avoiding_Car/lesson_13_Avoiding_Car.ino:61: undefined reference to SR04::Distance()' C:\Users\Asus\Desktop\JAVA\KS0559(KS0559F)Keyestudio 4WD BT Multi-purpose Car V2.0\3. Arduino Tutorial\3. Projects\Project 13 Ultrasonic Obstacle Avoidance Smart Car\lesson_13_Avoiding_Car/lesson_13_Avoiding_Car.ino:65: undefined reference to SR04::Distance()'
C:\Users\Asus\AppData\Local\Temp\ccoasYka.ltrans0.ltrans.o: In function _GLOBAL__sub_I_front': C:\Users\Asus\Desktop\JAVA\KS0559(KS0559F)Keyestudio 4WD BT Multi-purpose Car V2.0\3. Arduino Tutorial\3. Projects\Project 13 Ultrasonic Obstacle Avoidance Smart Car\lesson_13_Avoiding_Car/lesson_13_Avoiding_Car.ino:25: undefined reference to SR04::SR04(int, int)'
collect2.exe: error: ld returned 1 exit status
exit status 1
Compilation error: exit status 1
Il codice è il seguente:
keyestudio 4wd BT Car
lesson 13
Avoiding Car
http://www.keyestudio.com
#define SCL_Pin A5 //Set the clock pin to A5
#define SDA_Pin A4 //Set data pin to A4
//Array, used to store the data of pattern, can be calculated by yourself or obtained from the modulus tool
unsigned char front[] = {0x00,0x00,0x00,0x00,0x00,0x24,0x12,0x09,0x12,0x24,0x00,0x00,0x00,0x00,0x00,0x00};
unsigned char left[] = {0x00,0x00,0x00,0x00,0x00,0x00,0x44,0x28,0x10,0x44,0x28,0x10,0x44,0x28,0x10,0x00};
unsigned char right[] = {0x00,0x10,0x28,0x44,0x10,0x28,0x44,0x10,0x28,0x44,0x00,0x00,0x00,0x00,0x00,0x00};
unsigned char STOP01[] = {0x2E,0x2A,0x3A,0x00,0x02,0x3E,0x02,0x00,0x3E,0x22,0x3E,0x00,0x3E,0x0A,0x0E,0x00};
unsigned char clear[] = {0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00};
int left_ctrl = 2;//define the direction control pins of group B motor
int left_pwm = 5;//define the PWM control pins of group B motor
int right_ctrl = 4;//define the direction control pins of group A motor
int right_pwm = 6;//define the PWM control pins of group A motor
#include "SR04.h"//define the library of ultrasonic sensor
#define TRIG_PIN 12// set the signal output of ultrasonic sensor to D12
#define ECHO_PIN 13//set the signal input of ultrasonic sensor to D13
SR04 sr04 = SR04(ECHO_PIN,TRIG_PIN);
long distance,a1,a2;//define three distance
const int servopin = A3;//set the pin of servo to A3
pinMode(left_ctrl,OUTPUT);//set direction control pins of group B motor to OUTPUT
pinMode(left_pwm,OUTPUT);//set PWM control pins of group B motor to OUTPUT
pinMode(right_ctrl,OUTPUT);//set direction control pins of group A motor to OUTPUT
pinMode(right_pwm,OUTPUT);//set PWM control pins of group A motor to OUTPUT
pinMode(TRIG_PIN, OUTPUT); //Set the trig pin to output
pinMode(ECHO_PIN, INPUT); //Set the echo pin to input
servopulse(servopin,90);//the angle of servo is 90 degree
delay(300);
pinMode(SCL_Pin,OUTPUT);// Set the clock pin to output
pinMode(SDA_Pin,OUTPUT);//Set the data pin to output
matrix_display(clear);
avoid();//run the main program
void avoid()
distance=sr04.Distance(); //obtain the value detected by ultrasonic sensor
if((distance < 20)&&(distance != 0))//if the distance is greater than 0 and less than 10
car_Stop();//stop
matrix_display(STOP01);//show stop pattern
servopulse(servopin,160);//servo rotates to 160°
a1=sr04.Distance();//measure the distance
delay(100);
servopulse(servopin,20);//rotate to 20 degree
a2=sr04.Distance();//measure the distance
delay(100);
servopulse(servopin,90); //Return to the 90 degree position
if(a1 > a2)//compare the distance, if left distance is more than right distance
car_left();//turn left
matrix_display(left); //display left-turning pattern
servopulse(servopin,90);//servo rotates to 90 degree
delay(700); //turn left 700ms
matrix_display(front); //show forward pattern
else//if the right distance is greater than the left
car_right();//turn right
matrix_display(right); //display right-turning pattern
delay(700);
else//otherwise
car_front();//go forward
matrix_display(front); // show forward pattern
void car_front()//car goes forward
digitalWrite(left_ctrl,HIGH);
analogWrite(left_pwm,155);
digitalWrite(right_ctrl,HIGH);
analogWrite(right_pwm,155);
void car_back()//go back
digitalWrite(left_ctrl,LOW);
analogWrite(left_pwm,100);
digitalWrite(right_ctrl,LOW);
analogWrite(right_pwm,100);
void car_left()//car turns left
digitalWrite(left_ctrl, LOW);
analogWrite(left_pwm, 100);
digitalWrite(right_ctrl, HIGH);
analogWrite(right_pwm, 155);
void car_right()//car turns right
digitalWrite(left_ctrl, HIGH);
analogWrite(left_pwm, 155);
digitalWrite(right_ctrl, LOW);
analogWrite(right_pwm, 100);
void car_Stop()//stop
analogWrite(left_pwm,0);
analogWrite(right_pwm,0);
void servopulse(int servopin,int myangle)//the running angle of servo
for(int i=0; i<20; i++)
int pulsewidth = (myangle*11)+500;
digitalWrite(servopin,HIGH);
delayMicroseconds(pulsewidth);
digitalWrite(servopin,LOW);
delay(20-pulsewidth/1000);
//this function is used for dot matrix display
void matrix_display(unsigned char matrix_value[])
IIC_start(); //the function that calls the data transfer start condition
IIC_send(0xc0); //select address
for (int i = 0; i < 16; i++) //the pattern data is 16 bytes
IIC_send(matrix_value[i]); //Transmit the data of the pattern
IIC_end(); //End pattern data transmission
IIC_start();
IIC_send(0x8A); //Display control, select 4/16 pulse width
IIC_end();
//Conditions under which data transmission begins
void IIC_start()
digitalWrite(SDA_Pin, HIGH);
digitalWrite(SCL_Pin, HIGH);
delayMicroseconds(3);
digitalWrite(SDA_Pin, LOW);
digitalWrite(SCL_Pin, LOW);
//Indicates the end of data transmission
void IIC_end()
//transmit data
void IIC_send(unsigned char send_data)
for (byte mask = 0x01; mask != 0; mask <<= 1) //Each byte has 8 bits and is checked bit by bit starting at the lowest level
if (send_data & mask) { //Sets the high and low levels of SDA_Pin depending on whether each bit of the byte is a 1 or a 0
digitalWrite(SCL_Pin, HIGH); //Pull the clock pin SCL_Pin high to stop data transmission
digitalWrite(SCL_Pin, LOW); //pull the clock pin SCL_Pin low to change the SIGNAL of SDA
Chiedo aiuto, grazie.
