Hello,
I have a Wemos D1 mini pro and i would like it to print some sensor values to a webserver. I also want it to send and store the data in a sheets file on my google drive.
I mixed together some example codes with a code from a guide (Log Temperature Sensor Data to Google Sheet using NodeMCU ESP8266) but now im stuck. I keep getting a "error with request" as soon as it starts writing to the file.
Here is the full output of the serial monitor?
Connecting to WiFi
Connecting to script.google.com
192.168.1.24
Write into cell 'A1'
Error with request. Response status code: 404
GET: Fetch Google Calendar Data:
Start Sending Sensor Data to Google Spreadsheet
Sent : Temp and Humid
POST or SEND Sensor data to Google Spreadsheet:
Error-count while connecting: 1
Temperature: 23.60°C
Humidity: 57.50%
Error-count while connecting: 2
Error-count while connecting: 3
Error-count while connecting: 4
Halting processor...
Final free heap: 45920
Final stack: 2064
And here is my code. It may look unorganized, and that is because it is.
Rui Santos
Complete project details at https://randomnerdtutorials.com/esp8266-dht11dht22-temperature-and-humidity-web-server-with-arduino-ide/
// Import required libraries
#include <Arduino.h>
#include <ESP8266WiFi.h>
#include <Hash.h>
#include <ESPAsyncTCP.h>
#include <ESPAsyncWebServer.h>
#include <Adafruit_Sensor.h>
#include <DHT.h>
#include <HTTPSRedirect.h>
// Replace with your network credentials
const char* ssid = "....";
const char* password = "...";
#define DHTPIN 5 // Digital pin connected to the DHT sensor
// Uncomment the type of sensor in use:
//#define DHTTYPE DHT11 // DHT 11
#define DHTTYPE DHT22 // DHT 22 (AM2302)
//#define DHTTYPE DHT21 // DHT 21 (AM2301)
//Sheets
float h;
float t;
String sheetHumid = "";
String sheetTemp = "";
const char* host = "script.google.com";
const char *GScriptId = "...."; // Replace with your own google script id
const int httpsPort = 443; //the https port is same
// echo | openssl s_client -connect script.google.com:443 |& openssl x509 -fingerprint -noout
const char* fingerprint = "";
String url = String("/macros/s/") + GScriptId + "/exec?value=Temperature"; // Write Teperature to Google Spreadsheet at cell A1
// Fetch Google Calendar events for 1 week ahead
String url2 = String("/macros/s/") + GScriptId + "/exec?cal"; // Write to Cell A continuosly
//replace with sheet name not with spreadsheet file name taken from google
String payload_base = "{\"command\": \"appendRow\", \
\"TempSheet\": \"Sheet1\", \
\"values\": ";
String payload = "";
HTTPSRedirect* client = nullptr;
// used to store the values of free stack and heap before the HTTPSRedirect object is instantiated
// so that they can be written to Google sheets upon instantiation
//SHEETS
DHT dht(DHTPIN, DHTTYPE);
//WEBSERVER
// Create AsyncWebServer object on port 80
AsyncWebServer server(80);
// Generally, you should use "unsigned long" for variables that hold time
// The value will quickly become too large for an int to store
unsigned long previousMillis = 0; // will store last time DHT was updated
// Updates DHT readings every 10 seconds
const long interval = 10000;
const char index_html[] PROGMEM = R"rawliteral(
<!DOCTYPE HTML><html>
<head>
<meta name="viewport" content="width=device-width, initial-scale=1">
<link rel="stylesheet" href="https://use.fontawesome.com/releases/v5.7.2/css/all.css" integrity="sha384-fnmOCqbTlWIlj8LyTjo7mOUStjsKC4pOpQbqyi7RrhN7udi9RwhKkMHpvLbHG9Sr" crossorigin="anonymous">
<style>
html {
font-family: Arial;
display: inline-block;
margin: 0px auto;
text-align: center;
h2 { font-size: 3.0rem; }
p { font-size: 3.0rem; }
.units { font-size: 1.2rem; }
.dht-labels{
font-size: 1.5rem;
vertical-align:middle;
padding-bottom: 15px;
</style>
</head>
<body>
<h2>ESP8266 DHT Server</h2>
<p>
<i class="fas fa-thermometer-half" style="color:#059e8a;"></i>
<span class="dht-labels">Temperature</span>
<span id="temperature">%TEMPERATURE%</span>
<sup class="units">°C</sup>
</p>
<p>
<i class="fas fa-tint" style="color:#00add6;"></i>
<span class="dht-labels">Humidity</span>
<span id="humidity">%HUMIDITY%</span>
<sup class="units">%</sup>
</p>
</body>
<script>
setInterval(function ( ) {
var xhttp = new XMLHttpRequest();
xhttp.onreadystatechange = function() {
if (this.readyState == 4 && this.status == 200) {
document.getElementById("temperature").innerHTML = this.responseText;
xhttp.open("GET", "/temperature", true);
xhttp.send();
}, 10000 ) ;
document.getElementById("humidity").innerHTML = this.responseText;
xhttp.open("GET", "/humidity", true);
xhttp.send();
}, 10000 ) ;
</script>
</html>)rawliteral";
// Replaces placeholder with DHT values
String processor(const String& var) {
//Serial.println(var);
if (var == "TEMPERATURE") {
return String(t);
else if (var == "HUMIDITY") {
return String(h);
return String();
//WEBSERVER STOP
// Serial port for debugging purposes
dht.begin();
// Connect to Wi-Fi
WiFi.begin(ssid, password);
Serial.println("Connecting to WiFi");
Serial.println(".");
// Use HTTPSRedirect class to create a new TLS connection
client = new HTTPSRedirect(httpsPort);
client->setInsecure();
client->setPrintResponseBody(true);
client->setContentTypeHeader("application/json");
Serial.print("Connecting to ");
Serial.println(host); //try to connect with "script.google.com"
// Try to connect for a maximum of 5 times then exit
bool flag = false;
for (int i = 0; i < 5; i++) {
int retval = client->connect(host, httpsPort);
if (retval == 1) {
flag = true;
Serial.println("Connection failed. Retrying...");
if (!flag) {
Serial.print("Could not connect to server: ");
Serial.println("Exiting...");
return;
// Print ESP8266 Local IP Address
// Route for root / web page
server.on("/", HTTP_GET, [](AsyncWebServerRequest * request) {
request->send_P(200, "text/html", index_html, processor);
server.on("/temperature", HTTP_GET, [](AsyncWebServerRequest * request) {
request->send_P(200, "text/plain", String(t).c_str());
server.on("/humidity", HTTP_GET, [](AsyncWebServerRequest * request) {
request->send_P(200, "text/plain", String(h).c_str());
// Start server
server.begin();
Serial.println("\nWrite into cell 'A1'");
Serial.println("------>");
// fetch spreadsheet data
client->GET(url, host);
Serial.println("\nGET: Fetch Google Calendar Data:");
client->GET(url2, host);
Serial.println("\nStart Sending Sensor Data to Google Spreadsheet");
// delete HTTPSRedirect object
delete client;
client = nullptr;
if (currentMillis - previousMillis >= interval) {
// save the last time you updated the DHT values
// Read temperature as Celsius (the default)
float newT = dht.readTemperature();
// Read temperature as Fahrenheit (isFahrenheit = true)
//float newT = dht.readTemperature(true);
// if temperature read failed, don't change t value
if (isnan(newT)) {
Serial.println("Failed to read from DHT sensor!");
else {
t = newT;
Serial.print("Temperature: "); Serial.print(t); Serial.println("°C ");
// Read Humidity
float newH = dht.readHumidity();
// if humidity read failed, don't change h value
if (isnan(newH)) {
else {
h = newH;
Serial.print("Humidity: "); Serial.print(h); Serial.println("%");
sheetHumid = String(h) + String("%"); //convert integer humidity to string humidity
sheetTemp = String(t) + String("°C");
static int error_count = 0;
static int connect_count = 0;
const unsigned int MAX_CONNECT = 20;
static bool flag = false;
payload = payload_base + "\"" + sheetTemp + "," + sheetHumid + "\"}";
if (!flag) {
flag = true;
if (client != nullptr) {
if (!client->connected()) {
client->POST(url2, host, payload, false);
Serial.print("Sent : "); Serial.println("Temp and Humid");
else {
Serial.print("Error creating client object!");
error_count = 5;
if (connect_count > MAX_CONNECT) {
connect_count = 0;
flag = false;
delete client;
return;
Serial.println("POST or SEND Sensor data to Google Spreadsheet:");
if (client->POST(url2, host, payload)) {
else {
++error_count;
Serial.print("Error-count while connecting: "); Serial.println(error_count);
if (error_count > 3) {
Serial.println("Halting processor...");
delete client;
client = nullptr;
Serial.printf("Final free heap: %u\n", ESP.getFreeHeap());
Serial.printf("Final stack: %u\n", ESP.getFreeContStack());
Serial.flush();
ESP.deepSleep(0);
delay(3000); // keep delay of minimum 2 seconds as dht allow reading after 2 seconds interval and also for google sheet
ANY help would be highly appreciated ![]()
