I2C_ADDRESS:2:30: error: Adafruit_ADS1015.h: No such file or directory
compilation terminated.
exit status 1
exit status 1
option enabled in File -> Preferences.
When I replace line #include <Adafruit_ADS1015.h> by #include <Adafruit_ADS1X15.h>
error message
Arduino: 1.8.11 (Windows 10), Board: "ESP32 Dev Module, Disabled, Default 4MB with spiffs (1.2MB APP/1.5MB SPIFFS), 240MHz (WiFi/BT), QIO, 80MHz, 4MB (32Mb), 921600, None"
I2C_ADDRESS:4:26: error: no matching function for call to 'Adafruit_ADS1115::Adafruit_ADS1115(int)'
Adafruit_ADS1115 ads(0x48);
In file included from C:\Users\System\Documents\Arduino\I2C_ADDRESS\I2C_ADDRESS.ino:2:0:
C:\Users\System\Documents\Arduino\libraries\Adafruit_ADS1X15/Adafruit_ADS1X15.h:186:3: note: candidate: Adafruit_ADS1115::Adafruit_ADS1115()
Adafruit_ADS1115();
C:\Users\System\Documents\Arduino\libraries\Adafruit_ADS1X15/Adafruit_ADS1X15.h:186:3: note: candidate expects 0 arguments, 1 provided
C:\Users\System\Documents\Arduino\libraries\Adafruit_ADS1X15/Adafruit_ADS1X15.h:184:7: note: candidate: constexpr Adafruit_ADS1115::Adafruit_ADS1115(const Adafruit_ADS1115&)
class Adafruit_ADS1115 : public Adafruit_ADS1X15 {
C:\Users\System\Documents\Arduino\libraries\Adafruit_ADS1X15/Adafruit_ADS1X15.h:184:7: note: no known conversion for argument 1 from 'int' to 'const Adafruit_ADS1115&'
C:\Users\System\Documents\Arduino\libraries\Adafruit_ADS1X15/Adafruit_ADS1X15.h:184:7: note: candidate: constexpr Adafruit_ADS1115::Adafruit_ADS1115(Adafruit_ADS1115&&)
C:\Users\System\Documents\Arduino\libraries\Adafruit_ADS1X15/Adafruit_ADS1X15.h:184:7: note: no known conversion for argument 1 from 'int' to 'Adafruit_ADS1115&&'
exit status 1
OK, great. I can see from the tutorial that they were using version 1.0.0 of the "Adafruit ADS1X15" library. There was a breaking change to the library since then, which is the cause of the error.
The easiest fix is to use the old version of the library. Even though the tutorial author wrote the sketch for 1.0.0 of the library, you should be able to use up to version 1.1.2, which was the last release before the bump to 2.0.0 (the major version bump is used to indicate a breaking change).
Please try this:
Select Sketch > Include Library > Manage Libraries... from the Arduino IDE's menus.
Wait for the update to finish.
In the "Filter your search" field, type "Adafruit ADS1X15".
Press Enter.
Scroll down through the list of libraries until you see the "Adafruit ADS1X15" library. Click on it.
Yeah, updating the sketch to work with the modern library is the ideal solution because there might have been valuable improvements or bug fixes made to the library since the 1.1.2 release.
But if you just want the quick fix then using the library version the sketch was written for should do the trick.
I get following message after compiling the sketch
Sketch uses 214110 bytes (16%) of program storage space. Maximum is 1310720 bytes.
Global variables use 14144 bytes (4%) of dynamic memory, leaving 313536 bytes for local variables. Maximum is 327680 bytes.
````Preformatted text`
This line of the sketch configures the Arduino board to communicate over serial at 9600 baud:
But you have the Arduino IDE Serial Monitor configured for communication at 115200 baud. This will cause the communication from the Arduino to not be recognized by Serial Monitor. Select "9600" from the baud rate menu near the bottom right corner of the Serial Monitor window.
