I am experiencing an issue while communicating between an ESP32 and the BNO085 using the SparkFun library and the example:
I have connected power and the SDA and SCL pins. The data appears on the serial monitor, but after a few seconds, it stops updating. After resetting the device, the same issue occurs.
Could this be caused by the reset pins?
Has anyone encountered this problem or knows how to fix it?
Post your annotated schematic showing exactly how you have wired it. Be sure to include all connections, power, ground, power sources and any other items connected.
