Hi, I am fairly new to Arduino and ESP.
I want to make a monitoring system using esp32 cam and an SPI TFT LCD.
I have hardwired the TFT to the ESP32CAM and checked with some example code, the tft is working.
I also checked the camera stream, which is working and I can view the stream using its IP through wi-fi.
Now, I want to stream the output of the camera to the TFT directly, WITHOUT wi-fi involved. 10 to 20 FPS would be OK, better if higher can be done
The TFT LCD module I am using is 2.0 Inch SPI TFT LCD Color Screen Module ILI9225 Serial Interface 176 x 220
ESP32CAM module wiring is done as below
TFT ESP32CAM
VCC- 5V
G -- G
SDA- 13
CS - 15
CLK- 14
RS - 2
RST- 4
My code to check ESP32CAM for TFT is:
#include "SPI.h"
#include "TFT_22_ILI9225.h"
#include "math.h"
#define TFT_RST 4 //16 //4
#define TFT_RS 2 //12 //2
#define TFT_CLK 14
#define TFT_CS 15
#define TFT_SDI 13
#define TFT_LED 0 // 0 if wired to +5V directly
#define TFT_BRIGHTNESS 100 // Initial brightness of TFT backlight (optional)
//TFT_22_ILI9225 tft = TFT_22_ILI9225(TFT_RST, TFT_RS, TFT_CS, TFT_LED, TFT_BRIGHTNESS);
TFT_22_ILI9225 tft = TFT_22_ILI9225(TFT_RST, TFT_RS, TFT_CS, TFT_SDI, TFT_CLK, TFT_LED, TFT_BRIGHTNESS);
static const uint8_t PROGMEM tux[] =
0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xf0,
0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xfe,0x0,0xf,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xf0,
0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xc0,0x0,0x0,0x7f,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xf0,
0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xfe,0x0,0x0,0x0,0x1f,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xf0,
0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xf8,0x0,0x0,0x0,0x7,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xf0,
0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xe0,0x0,0x0,0x0,0x1,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xf0,
0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xc0,0x0,0x0,0x0,0x0,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xf0,
0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0x80,0x0,0x0,0x0,0x0,0x7f,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xf0,
0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0x0,0x0,0x0,0x0,0x0,0x3f,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xf0,
0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xfe,0x0,0x0,0x0,0x0,0x0,0x1f,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xf0,
0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xfc,0x0,0x0,0x0,0x0,0x0,0xf,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xf0,
0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xf8,0x0,0x0,0x0,0x0,0x0,0x7,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xf0,
0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xf0,0x0,0x0,0x0,0x0,0x0,0x7,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xf0,
0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xf0,0x0,0x0,0x0,0x0,0x0,0x3,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xf0,
0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xe0,0x0,0x0,0x0,0x0,0x0,0x1,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xf0,
0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xc0,0x0,0x0,0x0,0x0,0x0,0x1,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xf0,
0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xc0,0x0,0x0,0x0,0x0,0x0,0x0,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xf0,
0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0x80,0x0,0x0,0x0,0x0,0x0,0x0,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xf0,
0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0x80,0x0,0x0,0x0,0x0,0x0,0x0,0x7f,0xff,0xff,0xff,0xff,0xff,0xff,0xf0,
0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x7f,0xff,0xff,0xff,0xff,0xff,0xff,0xf0,
0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x3f,0xff,0xff,0xff,0xff,0xff,0xff,0xf0,
0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xfe,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x3f,0xff,0xff,0xff,0xff,0xff,0xff,0xf0,
0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xfe,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x1f,0xff,0xff,0xff,0xff,0xff,0xff,0xf0,
0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xfe,0x0,0x0,0x0,0x1,0xfc,0x0,0x0,0x1f,0xff,0xff,0xff,0xff,0xff,0xff,0xf0,
0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xfe,0x0,0x0,0x0,0x7,0xfe,0x0,0x0,0x1f,0xff,0xff,0xff,0xff,0xff,0xff,0xf0,
0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xfe,0x1,0xf8,0x0,0xf,0xff,0x0,0x0,0x1f,0xff,0xff,0xff,0xff,0xff,0xff,0xf0,
0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xfe,0x3,0xfc,0x0,0x1f,0xff,0x80,0x0,0x1f,0xff,0xff,0xff,0xff,0xff,0xff,0xf0,
0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xfe,0x7,0xfe,0x0,0x1f,0xff,0xc0,0x0,0x1f,0xff,0xff,0xff,0xff,0xff,0xff,0xf0,
0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xfe,0x7,0xfe,0x0,0x3f,0xff,0xc0,0x0,0x1f,0xff,0xff,0xff,0xff,0xff,0xff,0xf0,
0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xfe,0xf,0xff,0x0,0x3f,0xff,0xe0,0x0,0x1f,0xff,0xff,0xff,0xff,0xff,0xff,0xf0,
0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xfe,0xf,0xff,0x0,0x7f,0xf,0xe0,0x0,0xf,0xff,0xff,0xff,0xff,0xff,0xff,0xf0,
0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xfe,0xf,0xbf,0x80,0x7e,0x7,0xf0,0x0,0xf,0xff,0xff,0xff,0xff,0xff,0xff,0xf0,
0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xfe,0xf,0xf,0x80,0x7c,0x7,0xf0,0x0,0xf,0xff,0xff,0xff,0xff,0xff,0xff,0xf0,
0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xfe,0xe,0x7,0x80,0x78,0x3,0xf0,0x0,0xf,0xff,0xff,0xff,0xff,0xff,0xff,0xf0,
0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xfe,0xe,0x3,0x80,0x78,0x3,0xf0,0x0,0xf,0xff,0xff,0xff,0xff,0xff,0xff,0xf0,
0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xfe,0xe,0x3,0x0,0x38,0x3,0xf0,0x0,0xf,0xff,0xff,0xff,0xff,0xff,0xff,0xf0,
0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xfe,0xe,0x0,0x0,0x0,0x3,0xf0,0x0,0xf,0xff,0xff,0xff,0xff,0xff,0xff,0xf0,
0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xfe,0xe,0x0,0xff,0xc0,0x3,0xe0,0x0,0xf,0xff,0xff,0xff,0xff,0xff,0xff,0xf0,
0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xfe,0x6,0x1,0xff,0xf8,0x3,0xe0,0x0,0xf,0xff,0xff,0xff,0xff,0xff,0xff,0xf0,
0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0x7,0x7,0xff,0xfc,0x7,0xe0,0x0,0xf,0xff,0xff,0xff,0xff,0xff,0xff,0xf0,
0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0x3,0x8f,0xff,0xff,0x7,0xc0,0x0,0xf,0xff,0xff,0xff,0xff,0xff,0xff,0xf0,
0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0x3,0x1f,0xff,0xff,0xc0,0x80,0x0,0xf,0xff,0xff,0xff,0xff,0xff,0xff,0xf0,
0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0x0,0x3f,0xff,0xff,0xf8,0x0,0x0,0xf,0xff,0xff,0xff,0xff,0xff,0xff,0xf0,
0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0x0,0xff,0xff,0xff,0xff,0x0,0x0,0xf,0xff,0xff,0xff,0xff,0xff,0xff,0xf0,
0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0x1,0xff,0xff,0xff,0xff,0xc0,0x0,0xf,0xff,0xff,0xff,0xff,0xff,0xff,0xf0,
0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0x3,0xff,0xff,0xff,0xff,0xe0,0x0,0xf,0xff,0xff,0xff,0xff,0xff,0xff,0xf0,
0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xf,0xff,0xff,0xff,0xff,0xf0,0x0,0xf,0xff,0xff,0xff,0xff,0xff,0xff,0xf0,
0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xfe,0xf,0xff,0xff,0xff,0xfe,0xf0,0x0,0xf,0xff,0xff,0xff,0xff,0xff,0xff,0xf0,
0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xfe,0x19,0xff,0xff,0xff,0xf8,0x70,0x0,0xf,0xff,0xff,0xff,0xff,0xff,0xff,0xf0,
0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xfe,0x18,0xff,0xff,0xff,0xe0,0xf0,0x0,0xf,0xff,0xff,0xff,0xff,0xff,0xff,0xf0,
0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xfe,0x1c,0x7f,0xff,0xff,0x87,0xf0,0x0,0xf,0xff,0xff,0xff,0xff,0xff,0xff,0xf0,
0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xfe,0xe,0x3f,0xff,0xff,0xf,0xe0,0x0,0x7,0xff,0xff,0xff,0xff,0xff,0xff,0xf0,
0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xfe,0x7,0x1f,0xff,0xfc,0x3f,0xc0,0x0,0x7,0xff,0xff,0xff,0xff,0xff,0xff,0xf0,
0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xfe,0x7,0x87,0xff,0xf0,0xff,0x80,0x0,0x7,0xff,0xff,0xff,0xff,0xff,0xff,0xf0,
0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xfc,0x3,0xe1,0xff,0xc3,0xff,0x10,0x0,0x3,0xff,0xff,0xff,0xff,0xff,0xff,0xf0,
0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xfc,0x0,0xf0,0x38,0xf,0xfe,0x38,0x0,0x3,0xff,0xff,0xff,0xff,0xff,0xff,0xf0,
0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xfc,0x0,0x7e,0x0,0x3f,0xf8,0x78,0x0,0x3,0xff,0xff,0xff,0xff,0xff,0xff,0xf0,
0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xf8,0x2,0x1f,0xe7,0xff,0xc1,0xf8,0x0,0x1,0xff,0xff,0xff,0xff,0xff,0xff,0xf0,
0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xf8,0x3,0x8f,0xff,0xff,0x7,0xfc,0x0,0x1,0xff,0xff,0xff,0xff,0xff,0xff,0xf0,
0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xf8,0x3,0xc7,0xff,0xfe,0x3f,0xfc,0x0,0x0,0xff,0xff,0xff,0xff,0xff,0xff,0xf0,
0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xf0,0x3,0xe3,0xff,0xf8,0x7f,0xfc,0x0,0x0,0x7f,0xff,0xff,0xff,0xff,0xff,0xf0,
0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xf0,0x7,0xf0,0xff,0xe1,0xff,0xfe,0x0,0x0,0x7f,0xff,0xff,0xff,0xff,0xff,0xf0,
0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xf0,0x7,0xfc,0x3f,0x7,0xff,0xfe,0x0,0x0,0x3f,0xff,0xff,0xff,0xff,0xff,0xf0,
0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xe0,0x7,0xfe,0x0,0x1f,0xff,0xfe,0x0,0x0,0x3f,0xff,0xff,0xff,0xff,0xff,0xf0,
0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xe0,0x7,0xff,0xc0,0xff,0xff,0xff,0x0,0x0,0x1f,0xff,0xff,0xff,0xff,0xff,0xf0,
0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xc0,0x7,0xff,0xff,0xff,0xff,0xff,0x0,0x0,0xf,0xff,0xff,0xff,0xff,0xff,0xf0,
0xff,0xff,0xff,0xff,0xff,0xff,0xff,0x80,0xf,0xff,0xff,0xff,0xff,0xff,0x0,0x0,0x7,0xff,0xff,0xff,0xff,0xff,0xf0,
0xff,0xff,0xff,0xff,0xff,0xff,0xff,0x80,0xf,0xff,0xff,0xff,0xff,0xff,0x80,0x0,0x7,0xff,0xff,0xff,0xff,0xff,0xf0,
0xff,0xff,0xff,0xff,0xff,0xff,0xff,0x0,0xf,0xff,0xff,0xff,0xff,0xff,0x80,0x0,0x3,0xff,0xff,0xff,0xff,0xff,0xf0,
0xff,0xff,0xff,0xff,0xff,0xff,0xfe,0x0,0x1f,0xff,0xff,0xff,0xff,0xff,0x80,0x0,0x1,0xff,0xff,0xff,0xff,0xff,0xf0,
0xff,0xff,0xff,0xff,0xff,0xff,0xfe,0x0,0x1f,0xff,0xff,0xff,0xff,0xff,0xc0,0x0,0x0,0xff,0xff,0xff,0xff,0xff,0xf0,
0xff,0xff,0xff,0xff,0xff,0xff,0xfc,0x0,0x1f,0xff,0xff,0xff,0xff,0xff,0xc0,0x0,0x0,0x7f,0xff,0xff,0xff,0xff,0xf0,
0xff,0xff,0xff,0xff,0xff,0xff,0xf8,0x0,0x3f,0xff,0xff,0xff,0xff,0xff,0xc0,0x0,0x0,0x7f,0xff,0xff,0xff,0xff,0xf0,
0xff,0xff,0xff,0xff,0xff,0xff,0xf0,0x0,0x3f,0xff,0xff,0xff,0xff,0xff,0xe0,0x0,0x0,0x3f,0xff,0xff,0xff,0xff,0xf0,
0xff,0xff,0xff,0xff,0xff,0xff,0xe0,0x0,0x3f,0xff,0xff,0xff,0xff,0xff,0xe0,0x0,0x0,0x1f,0xff,0xff,0xff,0xff,0xf0,
0xff,0xff,0xff,0xff,0xff,0xff,0xe0,0x0,0x7f,0xff,0xff,0xff,0xff,0xff,0xf0,0x0,0x0,0xf,0xff,0xff,0xff,0xff,0xf0,
0xff,0xff,0xff,0xff,0xff,0xff,0xc0,0x0,0x7f,0xff,0xff,0xff,0xff,0xff,0xf0,0x0,0x0,0x7,0xff,0xff,0xff,0xff,0xf0,
0xff,0xff,0xff,0xff,0xff,0xff,0x80,0x0,0x7f,0xff,0xff,0xff,0xff,0xff,0xf8,0x0,0x0,0x7,0xff,0xff,0xff,0xff,0xf0,
0xff,0xff,0xff,0xff,0xff,0xff,0x0,0x0,0xff,0xff,0xff,0xff,0xff,0xff,0xf8,0x0,0x0,0x3,0xff,0xff,0xff,0xff,0xf0,
0xff,0xff,0xff,0xff,0xff,0xff,0x0,0x0,0xff,0xff,0xff,0xff,0xff,0xff,0xf8,0x0,0x0,0x1,0xff,0xff,0xff,0xff,0xf0,
0xff,0xff,0xff,0xff,0xff,0xfe,0x0,0x1,0xff,0xff,0xff,0xff,0xff,0xff,0xfc,0x0,0x0,0x0,0xff,0xff,0xff,0xff,0xf0,
0xff,0xff,0xff,0xff,0xff,0xfc,0x0,0x1,0xff,0xff,0xff,0xff,0xff,0xff,0xfc,0x2,0x0,0x0,0xff,0xff,0xff,0xff,0xf0,
0xff,0xff,0xff,0xff,0xff,0xfc,0x0,0x1,0xff,0xff,0xff,0xff,0xff,0xff,0xfe,0x1,0x0,0x0,0x7f,0xff,0xff,0xff,0xf0,
0xff,0xff,0xff,0xff,0xff,0xf8,0x0,0x3,0xff,0xff,0xff,0xff,0xff,0xff,0xfe,0x0,0x80,0x0,0x3f,0xff,0xff,0xff,0xf0,
0xff,0xff,0xff,0xff,0xff,0xf0,0x0,0x3,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0x0,0x40,0x0,0x3f,0xff,0xff,0xff,0xf0,
0xff,0xff,0xff,0xff,0xff,0xf0,0x0,0x7,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0x0,0x20,0x0,0x1f,0xff,0xff,0xff,0xf0,
0xff,0xff,0xff,0xff,0xff,0xe0,0x0,0x7,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0x80,0x0,0x0,0xf,0xff,0xff,0xff,0xf0,
0xff,0xff,0xff,0xff,0xff,0xc0,0x0,0xf,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0x80,0x10,0x0,0xf,0xff,0xff,0xff,0xf0,
0xff,0xff,0xff,0xff,0xff,0xc0,0x10,0xf,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xc0,0x8,0x0,0x7,0xff,0xff,0xff,0xf0,
0xff,0xff,0xff,0xff,0xff,0x80,0x20,0x1f,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xc0,0x0,0x0,0x7,0xff,0xff,0xff,0xf0,
0xff,0xff,0xff,0xff,0xff,0x0,0x20,0x1f,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xe0,0x4,0x0,0x3,0xff,0xff,0xff,0xf0,
0xff,0xff,0xff,0xff,0xff,0x0,0x40,0x1f,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xe0,0x2,0x0,0x1,0xff,0xff,0xff,0xf0,
0xff,0xff,0xff,0xff,0xfe,0x0,0x40,0x3f,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xf0,0x2,0x0,0x1,0xff,0xff,0xff,0xf0,
0xff,0xff,0xff,0xff,0xfe,0x0,0x80,0x3f,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xf0,0x1,0x0,0x0,0xff,0xff,0xff,0xf0,
0xff,0xff,0xff,0xff,0xfc,0x0,0x80,0x7f,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xf8,0x1,0x0,0x0,0xff,0xff,0xff,0xf0,
0xff,0xff,0xff,0xff,0xfc,0x1,0x0,0x7f,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xf8,0x1,0x80,0x0,0x7f,0xff,0xff,0xf0,
0xff,0xff,0xff,0xff,0xf8,0x1,0x0,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xfc,0x0,0x80,0x0,0x7f,0xff,0xff,0xf0,
0xff,0xff,0xff,0xff,0xf8,0x2,0x0,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xfc,0x0,0xc0,0x0,0x7f,0xff,0xff,0xf0,
0xff,0xff,0xff,0xff,0xf0,0x2,0x1,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xfc,0x0,0xc0,0x0,0x3f,0xff,0xff,0xf0,
0xff,0xff,0xff,0xff,0xf0,0x6,0x1,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xfe,0x0,0x40,0x0,0x3f,0xff,0xff,0xf0,
0xff,0xff,0xff,0xff,0xe0,0x4,0x3,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xfe,0x0,0x60,0x0,0x1f,0xff,0xff,0xf0,
0xff,0xff,0xff,0xff,0xe0,0x4,0x3,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0x0,0x60,0x0,0x1f,0xff,0xff,0xf0,
0xff,0xff,0xff,0xff,0xc0,0xc,0x3,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0x0,0x60,0x0,0x1f,0xff,0xff,0xf0,
0xff,0xff,0xff,0xff,0xc0,0xc,0x7,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0x0,0x60,0x0,0xf,0xff,0xff,0xf0,
0xff,0xff,0xff,0xff,0xc0,0x8,0x7,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0x80,0x30,0x0,0xf,0xff,0xff,0xf0,
0xff,0xff,0xff,0xff,0x80,0x8,0x7,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0x80,0x30,0x0,0xf,0xff,0xff,0xf0,
0xff,0xff,0xff,0xff,0x80,0x18,0xf,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0x80,0x30,0x0,0x7,0xff,0xff,0xf0,
0xff,0xff,0xff,0xff,0x80,0x18,0xf,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xc0,0x30,0x0,0x7,0xff,0xff,0xf0,
0xff,0xff,0xff,0xff,0x0,0x18,0xf,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xc0,0x30,0x0,0x7,0xff,0xff,0xf0,
0xff,0xff,0xff,0xff,0x0,0x18,0x1f,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xe0,0x70,0x0,0x7,0xff,0xff,0xf0,
0xff,0xff,0xff,0xfe,0x0,0x18,0x1f,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xe0,0x70,0x0,0x3,0xff,0xff,0xf0,
0xff,0xff,0xff,0xfe,0x0,0x18,0x3f,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xe0,0xf0,0x0,0x3,0xff,0xff,0xf0,
0xff,0xff,0xff,0xfc,0x0,0x18,0x3f,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xf0,0x0,0x3,0xff,0xff,0xf0,
0xff,0xff,0xff,0xfc,0x0,0x1c,0x3f,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xf0,0x0,0x3,0xff,0xff,0xf0,
0xff,0xff,0xff,0xfc,0x0,0x1c,0x3f,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xf8,0x0,0x3,0xff,0xff,0xf0,
0xff,0xff,0xff,0xfc,0x0,0x1c,0x3f,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0x80,0x3e,0x0,0x3,0xff,0xff,0xf0,
0xff,0xff,0xff,0xfc,0x0,0x1e,0x3f,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0x0,0x7,0x80,0x3,0xff,0xff,0xf0,
0xff,0xff,0xff,0xfc,0x0,0xe,0x3f,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xfe,0x1e,0x1,0xe0,0x3,0xff,0xff,0xf0,
0xff,0xff,0xff,0xfc,0x0,0xf,0x3f,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xfe,0x3f,0xc0,0x70,0x3,0xff,0xff,0xf0,
0xff,0xff,0xff,0xfc,0x0,0x7,0x7f,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xfe,0x7f,0xf0,0x38,0x3,0xff,0xff,0xf0,
0xff,0xff,0xff,0xfc,0x0,0x7,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xfc,0x7f,0xf8,0xc,0x3,0xff,0xff,0xf0,
0xff,0xff,0xff,0xfc,0x0,0x3,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xfc,0xff,0xfe,0x6,0x3,0xff,0xff,0xf0,
0xff,0xff,0xff,0xfc,0x0,0x3,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xf0,0xff,0xff,0x2,0x7,0xff,0xff,0xf0,
0xff,0xff,0xff,0xfc,0x0,0x1,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xe0,0xff,0xff,0x3,0x7,0xff,0xff,0xf0,
0xff,0xff,0xff,0xfc,0x0,0x0,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xc0,0x7f,0xff,0x3,0x7,0xff,0xff,0xf0,
0xff,0xff,0xff,0xfc,0x1e,0x0,0x7f,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0x84,0x7f,0xff,0x3,0x7,0xff,0xff,0xf0,
0xff,0xff,0xff,0xf8,0x7f,0x80,0x3f,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xc,0x7f,0xfe,0x2,0xf,0xff,0xff,0xf0,
0xff,0xff,0xff,0xf0,0xff,0xe0,0xf,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0x1e,0x7f,0xfe,0x0,0xf,0xff,0xff,0xf0,
0xff,0xff,0xff,0xe1,0xff,0xf0,0x7,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xfe,0x1e,0x3f,0xfc,0x0,0x3,0xff,0xff,0xf0,
0xff,0xff,0xff,0xc3,0xff,0xf8,0x1,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xfe,0x3e,0x1f,0xf0,0x0,0x1,0xff,0xff,0xf0,
0xff,0xff,0xff,0xc7,0xff,0xfc,0x0,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xfc,0x3e,0xf,0xe0,0xf,0xe0,0xff,0xff,0xf0,
0xff,0xff,0xff,0x87,0xff,0xfe,0x0,0x3f,0xff,0xff,0xff,0xff,0xff,0xff,0xfc,0x7f,0x2,0x0,0x1f,0xf8,0x7f,0xff,0xf0,
0xff,0xff,0xff,0xf,0xff,0xfe,0x0,0x1f,0xff,0xff,0xff,0xff,0xff,0xff,0xfc,0x7f,0x80,0x0,0x3f,0xfc,0x7f,0xff,0xf0,
0xff,0xff,0xfe,0x1f,0xff,0xff,0x0,0xf,0xff,0xff,0xff,0xff,0xff,0xff,0xfc,0x7f,0x80,0x0,0xff,0xfc,0x3f,0xff,0xf0,
0xff,0xff,0xf8,0x3f,0xff,0xff,0x80,0x3,0xff,0xff,0xff,0xff,0xff,0xff,0xf8,0x7f,0xc0,0x3,0xff,0xfe,0x3f,0xff,0xf0,
0xff,0xff,0xc0,0x7f,0xff,0xff,0x80,0x1,0xff,0xff,0xff,0xff,0xff,0xff,0xf8,0xff,0xf0,0xf,0xff,0xfe,0x3f,0xff,0xf0,
0xff,0xff,0x0,0xff,0xff,0xff,0xc0,0x0,0xff,0xff,0xff,0xff,0xff,0xff,0xf8,0xff,0xff,0xff,0xff,0xff,0x1f,0xff,0xf0,
0xff,0xfc,0x3,0xff,0xff,0xff,0xc0,0x0,0x7f,0xff,0xff,0xff,0xff,0xff,0xf8,0xff,0xff,0xff,0xff,0xff,0x1f,0xff,0xf0,
0xff,0xf0,0x1f,0xff,0xff,0xff,0xe0,0x0,0x3f,0xff,0xff,0xff,0xff,0xff,0xf8,0xff,0xff,0xff,0xff,0xff,0x1f,0xff,0xf0,
0xff,0xe0,0xff,0xff,0xff,0xff,0xe0,0x0,0x1f,0xff,0xff,0xff,0xff,0xff,0xf8,0xff,0xff,0xff,0xff,0xff,0xf,0xff,0xf0,
0xff,0xe1,0xff,0xff,0xff,0xff,0xf0,0x0,0x1f,0xff,0xff,0xff,0xff,0xff,0xf8,0xff,0xff,0xff,0xff,0xff,0x8f,0xff,0xf0,
0xff,0xc3,0xff,0xff,0xff,0xff,0xf0,0x0,0xf,0xff,0xff,0xff,0xff,0xff,0xf8,0xff,0xff,0xff,0xff,0xff,0x8f,0xff,0xf0,
0xff,0xc7,0xff,0xff,0xff,0xff,0xf8,0x0,0x7,0xff,0xff,0xff,0xff,0xff,0xf0,0xff,0xff,0xff,0xff,0xff,0x8f,0xff,0xf0,
0xff,0x87,0xff,0xff,0xff,0xff,0xf8,0x0,0x7,0xff,0xff,0xff,0xff,0xff,0xf1,0xff,0xff,0xff,0xff,0xff,0x87,0xff,0xf0,
0xff,0x8f,0xff,0xff,0xff,0xff,0xfc,0x0,0x3,0xff,0xff,0xff,0xff,0xff,0xf1,0xff,0xff,0xff,0xff,0xff,0xc7,0xff,0xf0,
0xff,0x8f,0xff,0xff,0xff,0xff,0xfc,0x0,0x3,0xff,0xff,0xff,0xff,0xff,0xf1,0xff,0xff,0xff,0xff,0xff,0xc3,0xff,0xf0,
0xff,0x8f,0xff,0xff,0xff,0xff,0xfe,0x0,0x1,0xff,0xff,0xff,0xff,0xff,0xf1,0xff,0xff,0xff,0xff,0xff,0xe1,0xff,0xf0,
0xff,0x8f,0xff,0xff,0xff,0xff,0xff,0x0,0x1,0xff,0xff,0xff,0xff,0xff,0xf1,0xff,0xff,0xff,0xff,0xff,0xf0,0xff,0xf0,
0xff,0x8f,0xff,0xff,0xff,0xff,0xff,0x80,0x1,0xff,0xff,0xff,0xff,0xff,0xf1,0xff,0xff,0xff,0xff,0xff,0xf8,0x7f,0xf0,
0xff,0x8f,0xff,0xff,0xff,0xff,0xff,0xc0,0x1,0xff,0xff,0xff,0xff,0xff,0xf1,0xff,0xff,0xff,0xff,0xff,0xfc,0x3f,0xf0,
0xff,0x87,0xff,0xff,0xff,0xff,0xff,0xc0,0x3,0xff,0xff,0xff,0xff,0xff,0xe1,0xff,0xff,0xff,0xff,0xff,0xfe,0x3f,0xf0,
0xff,0xc7,0xff,0xff,0xff,0xff,0xff,0xe0,0x7,0xff,0xff,0xff,0xff,0xff,0xe1,0xff,0xff,0xff,0xff,0xff,0xfe,0x1f,0xf0,
0xff,0xc7,0xff,0xff,0xff,0xff,0xff,0xf0,0xf,0xff,0xff,0xff,0xff,0xff,0xe3,0xff,0xff,0xff,0xff,0xff,0xff,0x1f,0xf0,
0xff,0xc7,0xff,0xff,0xff,0xff,0xff,0xf8,0x7f,0xff,0xff,0xff,0xff,0xff,0xe3,0xff,0xff,0xff,0xff,0xff,0xff,0xf,0xf0,
0xff,0xc7,0xff,0xff,0xff,0xff,0xff,0xf8,0x7f,0xff,0xff,0xff,0xff,0xff,0xc3,0xff,0xff,0xff,0xff,0xff,0xff,0x8f,0xf0,
0xff,0xc7,0xff,0xff,0xff,0xff,0xff,0xfc,0x3f,0xff,0xff,0xff,0xff,0xff,0xc7,0xff,0xff,0xff,0xff,0xff,0xff,0x8f,0xf0,
0xff,0xc7,0xff,0xff,0xff,0xff,0xff,0xfe,0x1f,0xff,0xff,0xff,0xff,0xff,0xc7,0xff,0xff,0xff,0xff,0xff,0xff,0x8f,0xf0,
0xff,0xc7,0xff,0xff,0xff,0xff,0xff,0xff,0xf,0xff,0xff,0xff,0xff,0xff,0xc7,0xff,0xff,0xff,0xff,0xff,0xff,0xf,0xf0,
0xff,0xc7,0xff,0xff,0xff,0xff,0xff,0xff,0x8f,0xff,0xff,0xff,0xff,0xff,0x7,0xff,0xff,0xff,0xff,0xff,0xff,0x1f,0xf0,
0xff,0x8f,0xff,0xff,0xff,0xff,0xff,0xff,0x87,0xff,0xff,0xff,0xff,0xfe,0xf,0xff,0xff,0xff,0xff,0xff,0xfe,0x1f,0xf0,
0xff,0x8f,0xff,0xff,0xff,0xff,0xff,0xff,0xc3,0xff,0xff,0xff,0xff,0xf8,0xf,0xff,0xff,0xff,0xff,0xff,0xf8,0x3f,0xf0,
0xff,0x8f,0xff,0xff,0xff,0xff,0xff,0xff,0xe1,0xff,0xff,0xff,0xff,0xe0,0xf,0xff,0xff,0xff,0xff,0xff,0xf0,0x7f,0xf0,
0xff,0xf,0xff,0xff,0xff,0xff,0xff,0xff,0xe0,0x7f,0xff,0xff,0xff,0x80,0x1f,0xff,0xff,0xff,0xff,0xff,0xc0,0xff,0xf0,
0xff,0x1f,0xff,0xff,0xff,0xff,0xff,0xff,0xf0,0x1f,0xff,0xff,0xfe,0x0,0x1f,0xff,0xff,0xff,0xff,0xff,0x3,0xff,0xf0,
0xff,0x1f,0xff,0xff,0xff,0xff,0xff,0xff,0xf0,0x3,0xff,0xff,0xf0,0x0,0x1f,0xff,0xff,0xff,0xff,0xfc,0x7,0xff,0xf0,
0xff,0x1f,0xff,0xff,0xff,0xff,0xff,0xff,0xf8,0x0,0x3f,0xfe,0x0,0x0,0x1f,0xff,0xff,0xff,0xff,0xf0,0x1f,0xff,0xf0,
0xff,0x1f,0xff,0xff,0xff,0xff,0xff,0xff,0xf8,0x0,0x0,0x0,0x0,0x0,0x3f,0xff,0xff,0xff,0xff,0xc0,0x7f,0xff,0xf0,
0xff,0x1f,0xff,0xff,0xff,0xff,0xff,0xff,0xfc,0x0,0x0,0x0,0x0,0x0,0x3f,0xff,0xff,0xff,0xff,0x1,0xff,0xff,0xf0,
0xff,0x1f,0xff,0xff,0xff,0xff,0xff,0xff,0xfc,0x0,0x0,0x0,0x0,0x0,0x3f,0xff,0xff,0xff,0xfc,0x7,0xff,0xff,0xf0,
0xff,0x8f,0xff,0xff,0xff,0xff,0xff,0xff,0xfc,0x0,0x0,0x0,0x0,0x0,0x3f,0xff,0xff,0xff,0xf8,0x1f,0xff,0xff,0xf0,
0xff,0x87,0xff,0xff,0xff,0xff,0xff,0xff,0xfc,0x0,0x0,0x0,0x0,0x0,0x3f,0xff,0xff,0xff,0xf0,0x7f,0xff,0xff,0xf0,
0xff,0xc1,0xff,0xff,0xff,0xff,0xff,0xff,0xfc,0x0,0x0,0x0,0x0,0x0,0x3f,0xff,0xff,0xff,0xe0,0xff,0xff,0xff,0xf0,
0xff,0xe0,0xf,0xff,0xff,0xff,0xff,0xff,0xfc,0x0,0x0,0x0,0x0,0x0,0x3f,0xff,0xff,0xff,0xc3,0xff,0xff,0xff,0xf0,
0xff,0xf0,0x0,0xf,0xff,0xff,0xff,0xff,0xf8,0x0,0x0,0x0,0x0,0x0,0x3f,0xff,0xff,0xff,0x87,0xff,0xff,0xff,0xf0,
0xff,0xfc,0x0,0x0,0x7f,0xff,0xff,0xff,0xf8,0x0,0x1f,0xff,0xf0,0x0,0x3f,0xff,0xff,0xff,0xf,0xff,0xff,0xff,0xf0,
0xff,0xff,0xe0,0x0,0x7,0xff,0xff,0xff,0xf8,0x7,0xff,0xff,0xff,0xfe,0x1f,0xff,0xff,0xfe,0x1f,0xff,0xff,0xff,0xf0,
0xff,0xff,0xff,0xc0,0x0,0xff,0xff,0xff,0xf1,0xff,0xff,0xff,0xff,0xff,0x1f,0xff,0xff,0xfc,0x3f,0xff,0xff,0xff,0xf0,
0xff,0xff,0xff,0xff,0x0,0x3f,0xff,0xff,0xe1,0xff,0xff,0xff,0xff,0xff,0xf,0xff,0xff,0xf8,0x7f,0xff,0xff,0xff,0xf0,
0xff,0xff,0xff,0xff,0xf0,0xf,0xff,0xff,0xc3,0xff,0xff,0xff,0xff,0xff,0x8f,0xff,0xff,0xf0,0xff,0xff,0xff,0xff,0xf0,
0xff,0xff,0xff,0xff,0xfe,0x3,0xff,0xff,0x87,0xff,0xff,0xff,0xff,0xff,0x87,0xff,0xff,0xc1,0xff,0xff,0xff,0xff,0xf0,
0xff,0xff,0xff,0xff,0xff,0x80,0x3f,0xfe,0xf,0xff,0xff,0xff,0xff,0xff,0xc3,0xff,0xff,0x83,0xff,0xff,0xff,0xff,0xf0,
0xff,0xff,0xff,0xff,0xff,0xe0,0x0,0x0,0x1f,0xff,0xff,0xff,0xff,0xff,0xe1,0xff,0xfe,0x7,0xff,0xff,0xff,0xff,0xf0,
0xff,0xff,0xff,0xff,0xff,0xf8,0x0,0x0,0x3f,0xff,0xff,0xff,0xff,0xff,0xf0,0x7f,0xf8,0x1f,0xff,0xff,0xff,0xff,0xf0,
0xff,0xff,0xff,0xff,0xff,0xff,0x80,0x1,0xff,0xff,0xff,0xff,0xff,0xff,0xf8,0xf,0x80,0x3f,0xff,0xff,0xff,0xff,0xf0,
0xff,0xff,0xff,0xff,0xff,0xff,0xfe,0x3f,0xff,0xff,0xff,0xff,0xff,0xff,0xfc,0x0,0x0,0xff,0xff,0xff,0xff,0xff,0xf0,
0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0x0,0x3,0xff,0xff,0xff,0xff,0xff,0xf0,
0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xf0,0x3f,0xff,0xff,0xff,0xff,0xff,0xf0,
Serial.println("Initializing TFT...");
// hspi.begin();
// tft.begin(hspi);
tft.begin();
Serial.println("TFT initialized.");
tft.clear();
tft.drawRectangle(0, 0, tft.maxX() - 1, tft.maxY() - 1, COLOR_WHITE);
tft.setFont(Terminal6x8);
tft.drawText(10, 10, "hello!");
tft.clear();
tft.drawText(10, 20, "clear");
tft.drawText(10, 30, "text small");
tft.setBackgroundColor(COLOR_YELLOW);
tft.setFont(Terminal12x16);
tft.drawText(90, 30, "BIG", COLOR_RED);
tft.setBackgroundColor(COLOR_BLACK);
tft.drawText(10, 40, "setBacklight off");
tft.setBacklight(LOW);
tft.setBacklight(HIGH);
tft.drawText(10, 50, "setBacklight on");
tft.drawRectangle(10, 10, 110, 110, COLOR_BLUE);
tft.drawText(10, 60, "rectangle");
tft.fillRectangle(20, 20, 120, 120, COLOR_RED);
tft.drawText(10, 70, "solidRectangle");
tft.drawCircle(80, 80, 50, COLOR_YELLOW);
tft.drawText(10, 80, "circle");
tft.fillCircle(90, 90, 30, COLOR_GREEN);
tft.drawText(10, 90, "solidCircle");
tft.drawLine(0, 0, tft.maxX() - 1, tft.maxY() - 1, COLOR_CYAN);
tft.drawText(10, 100, "line");
for (uint8_t i = 0; i < 127; i++)
tft.drawPixel(random(tft.maxX()), random(tft.maxY()), random(0xffff));
tft.drawText(10, 110, "point");
for (uint8_t i = 0; i < 4; i++) {
tft.clear();
tft.setOrientation(i);
tft.drawText(10, 10, "setOrientation (" + String("0123").substring(i, i + 1) + ")");
tft.drawRectangle(10, 20, 50, 60, COLOR_GREEN);
tft.drawCircle(70, 80, 10, COLOR_BLUE);
tft.drawLine(30, 40, 70, 80, COLOR_YELLOW);
tft.setOrientation(0);
tft.clear();
tft.drawText(10, 100, "drawing bitmap");
tft.clear();
tft.drawBitmap(0, 0, tux, 180, 220, COLOR_WHITE);
delay(5000);
tft.clear();
tft.drawText(10, 40, "bye!", COLOR_RED);
tft.drawText(10, 60, "off");
tft.setBacklight(false);
tft.setDisplay(false);
while(true);
My code to check ESP32CAM for camera stream is like below, but it keeps saying
Camera capture failed, I only wanted to check if the fb is getting captured. IDK if I need to add something else to make it work...
#include "esp_camera.h"
#include <WiFi.h>
//---------------------------- TFT ---------------------------//
#include "SPI.h"
#include <JPEGDecoder.h>
#include "math.h"
// WARNING!!! PSRAM IC required for UXGA resolution and high JPEG quality
// Ensure ESP32 Wrover Module or other board with PSRAM is selected
// Partial images will be transmitted if image exceeds buffer size
// You must select partition scheme from the board menu that has at least 3MB APP space.
// Face Recognition is DISABLED for ESP32 and ESP32-S2, because it takes up from 15
// seconds to process single frame. Face Detection is ENABLED if PSRAM is enabled as well
// Select camera model
//#define CAMERA_MODEL_WROVER_KIT // Has PSRAM
//#define CAMERA_MODEL_ESP_EYE // Has PSRAM
//#define CAMERA_MODEL_ESP32S3_EYE // Has PSRAM
//#define CAMERA_MODEL_M5STACK_PSRAM // Has PSRAM
//#define CAMERA_MODEL_M5STACK_V2_PSRAM // M5Camera version B Has PSRAM
//#define CAMERA_MODEL_M5STACK_WIDE // Has PSRAM
//#define CAMERA_MODEL_M5STACK_ESP32CAM // No PSRAM
//#define CAMERA_MODEL_M5STACK_UNITCAM // No PSRAM
#define CAMERA_MODEL_AI_THINKER // Has PSRAM
//#define CAMERA_MODEL_TTGO_T_JOURNAL // No PSRAM
//#define CAMERA_MODEL_XIAO_ESP32S3 // Has PSRAM
// ** Espressif Internal Boards **
//#define CAMERA_MODEL_ESP32_CAM_BOARD
//#define CAMERA_MODEL_ESP32S2_CAM_BOARD
//#define CAMERA_MODEL_ESP32S3_CAM_LCD
//#define CAMERA_MODEL_DFRobot_FireBeetle2_ESP32S3 // Has PSRAM
//#define CAMERA_MODEL_DFRobot_Romeo_ESP32S3 // Has PSRAM
#include "camera_pins.h"
// Enter your WiFi credentials
const char* ssid = "e";
const char* password = "statistics";
void startCameraServer();
void setupLedFlash(int pin);
#include "SPI.h"
#include "math.h"
#define TFT_CLK 14
#define TFT_CS 15
#define TFT_SDI 13
//-----------------------------TFT----------------------------//
Serial.setDebugOutput(true);
camera_config_t config;
config.ledc_channel = LEDC_CHANNEL_0;
config.ledc_timer = LEDC_TIMER_0;
config.pin_d0 = Y2_GPIO_NUM;
config.pin_d1 = Y3_GPIO_NUM;
config.pin_d2 = Y4_GPIO_NUM;
config.pin_d3 = Y5_GPIO_NUM;
config.pin_d4 = Y6_GPIO_NUM;
config.pin_d5 = Y7_GPIO_NUM;
config.pin_d6 = Y8_GPIO_NUM;
config.pin_d7 = Y9_GPIO_NUM;
config.pin_xclk = XCLK_GPIO_NUM;
config.pin_pclk = PCLK_GPIO_NUM;
config.pin_vsync = VSYNC_GPIO_NUM;
config.pin_href = HREF_GPIO_NUM;
config.pin_sccb_sda = SIOD_GPIO_NUM;
config.pin_sccb_scl = SIOC_GPIO_NUM;
config.pin_pwdn = PWDN_GPIO_NUM;
config.pin_reset = RESET_GPIO_NUM;
config.xclk_freq_hz = 20000000;
config.frame_size = FRAMESIZE_UXGA;
config.pixel_format = PIXFORMAT_JPEG; // for streaming
//config.pixel_format = PIXFORMAT_RGB565; // for face detection/recognition
config.grab_mode = CAMERA_GRAB_WHEN_EMPTY;
config.fb_location = CAMERA_FB_IN_PSRAM;
config.jpeg_quality = 10; // 10
config.fb_count = 1;
// if PSRAM IC present, init with UXGA resolution and higher JPEG quality
// for larger pre-allocated frame buffer.
if(config.pixel_format == PIXFORMAT_JPEG){
if(psramFound()){
config.fb_count = 2;
config.grab_mode = CAMERA_GRAB_LATEST;
// Limit the frame size when PSRAM is not available
config.frame_size = FRAMESIZE_SVGA;
config.fb_location = CAMERA_FB_IN_DRAM;
// Best option for face detection/recognition
config.frame_size = FRAMESIZE_240X240;
#if CONFIG_IDF_TARGET_ESP32S3
#endif
#if defined(CAMERA_MODEL_ESP_EYE)
pinMode(13, INPUT_PULLUP);
pinMode(14, INPUT_PULLUP);
#endif
// camera init
esp_err_t err = esp_camera_init(&config);
if (err != ESP_OK) {
Serial.printf("Camera init failed with error 0x%x", err);
return;
sensor_t * s = esp_camera_sensor_get();
// initial sensors are flipped vertically and colors are a bit saturated
if (s->id.PID == OV3660_PID) {
s->set_vflip(s, 1); // flip it back
s->set_brightness(s, 1); // up the brightness just a bit
s->set_saturation(s, -2); // lower the saturation
// drop down frame size for higher initial frame rate
s->set_framesize(s, FRAMESIZE_QVGA);
#if defined(CAMERA_MODEL_M5STACK_WIDE) || defined(CAMERA_MODEL_M5STACK_ESP32CAM)
s->set_vflip(s, 1);
s->set_hmirror(s, 1);
#endif
#if defined(CAMERA_MODEL_ESP32S3_EYE)
s->set_vflip(s, 1);
#endif
// Setup LED FLash if LED pin is defined in camera_pins.h
#if defined(LED_GPIO_NUM)
setupLedFlash(LED_GPIO_NUM);
#endif
WiFi.begin(ssid, password);
WiFi.setSleep(false);
Serial.print(".");
Serial.println("");
Serial.println("WiFi connected");
Serial.print("Camera Ready! Use 'http://");
Serial.print(WiFi.localIP());
Serial.println("' to connect");
void setBackgroundColor(uint16_t color = COLOR_BLACK);
camera_fb_t *fb = esp_camera_fb_get();
if (!fb) {
Serial.println("Camera capture failed");
return;
PLEASE help me, I know little about this but I try my best to understand
