Esp32 code related
There is something wrong in my code can anyone help me
In the code I have used a ttgo tcall module with sim 800l on it so the project is about measuring voltages of 4 gpioo pins and sending the data through sms due to unavailability of internet.
Everything is working just problem is happening in the i2c Part
The i2c pins for power management ic ip5306 is set to SDA- 21
and SCL-22 . And a 20*4 lcd is set to SDA-33 and SCL-32 when I am removing the i2c of ip5306 the lcd works fine and if ip5406 is included lcd stops working . Even the lcd address is 0x26 and the ic is 0x72 still encountering problems . I would be thankful if someone helps me (I am not going to deeper explanations for it would become too long)
The code. --------
const char simPIN[]   = "";
String SMS_Message;
#include <Wire.h>
// Define the serial console for debug prints, if needed
#define DUMP_AT_COMMANDS
#include<string.h>
#include "utilities.h"
// Configure TinyGSM library
#define TINY_GSM_MODEM_SIM800      // Modem is SIM800
#define TINY_GSM_RX_BUFFER   1024  // Set RX buffer to 1Kb
#include <Wire.h>
#include <TinyGsmClient.h>
// TTGO T-Call pins
#define MODEM_RST            5
#define MODEM_PWKEY          4
#define MODEM_POWER_ON       23
#define MODEM_TX             27
#define MODEM_RX             26
#define RST_PIN 14  // GPIO pin connected to the RST switch
#define SDA_PIN 33  // GPIO pin connected to the SDA pin of the LCD
#define SCL_PIN 32  // GPIO pin connected to the SCL pin of the LCD
#define I2C_SDA              21
#define I2C_SCL              22
#define LCD_ADDRESS 0x27  // I2C address for the LCD
#define LCD_COLS 20
#define LCD_ROWS 4
// Set serial for debug console (to Serial Monitor, default speed 115200)
#define SerialMon Serial
// Set serial for AT commands (to SIM800 module)
#define SerialAT  Serial1
//#define DUMP_AT_COMMANDS
#ifdef DUMP_AT_COMMANDS
#include <StreamDebugger.h>
StreamDebugger debugger(SerialAT, SerialMon);
TinyGsm modem(debugger);
#else
TinyGsm modem(SerialAT);
#endif
LiquidCrystal_I2C lcd(LCD_ADDRESS, LCD_COLS, LCD_ROWS);  // Address of the I2C module may vary, use i2c scanner to find it
const int voltagePinA = 2;   // Analog input pin for voltage A measurement
const int voltagePinB = 0;   // Analog input pin for voltage B measurement (GPI00)
const int voltagePinC = 4;   // Analog input pin for voltage C measurement (GPI02)
const int voltagePinD = 15;  // Analog input pin for voltage D measurement (GPI015)
unsigned long previousMillis = 0;
const long interval = 60000*60;  // Interval to measure voltages (60 seconds)
int mode = 1; // Default mode is 1
bool displayMeasurements = true;  // Flag to indicate whether to display measurements or "Mode 2"
void updateSerial();
// I2C for SIM800 (to keep it running when powered from battery)
TwoWire I2CPower = TwoWire(0);
#define uS_TO_S_FACTOR 1000000UL   /* Conversion factor for micro seconds to seconds */
#define IP5306_ADDR          0x75
#define IP5306_REG_SYS_CTL0  0x00
bool setPowerBoostKeepOn(int en){
  I2CPower.beginTransmission(IP5306_ADDR);
  I2CPower.write(IP5306_REG_SYS_CTL0);
  if (en) {
    I2CPower.write(0x37); // Set bit1: 1 enable 0 disable boost keep on
    I2CPower.write(0x35); // 0x37 is default reg value
  return I2CPower.endTransmission() == 0;
    // Your setup code here
    I2CPower.begin(I2C_SDA, I2C_SCL, 400000);
  // Keep power when running from battery
  bool isOk = setPowerBoostKeepOn(0);
  SerialMon.println(String("IP5306 KeepOn ") + (isOk ? "OK" : "FAIL"));
  // Set modem reset, enable, power pins
  pinMode(MODEM_PWKEY, OUTPUT);
  pinMode(MODEM_RST, OUTPUT);
  pinMode(MODEM_POWER_ON, OUTPUT);
  digitalWrite(MODEM_PWKEY, LOW);
  digitalWrite(MODEM_RST, HIGH);
  digitalWrite(MODEM_POWER_ON, HIGH);
  // LCD setup
  lcd.begin(LCD_COLS, LCD_ROWS);  // Initialize the LCD
  lcd.backlight();
  lcd.setCursor(0, 0);
  lcd.print("Voltage A : -");
  lcd.setCursor(0, 1);
  lcd.print("Voltage B : -");
  lcd.setCursor(0, 2);
  lcd.print("Voltage C : -");
  lcd.setCursor(0, 3);
  lcd.print("Voltage D : -");
Please present the hardware using schematics. Pen and paper usually works fine. Type out the logic names for the pins. Pin names tells nothing for helpers not having a translating Esp32 at hand.
So get rid of all the code from what you posted, apart from that specifically related to the ic ip5306 and LCD, much much easier to debug and spot potential problems.
Where did the code you posted come from ?
Now I have made it shorter..
