It seems that your setup is not designed for a 200 Ohm sensor, which is common for many exhaust gas sensors. Based on your description, you are using a PT1000, which is a 1K Ohm sensor. To test this, try running your setup with a PT1000 sensor—I believe it will work just fine.
Thank you for your reply!
I've read through the article. I've double chekt my soldering and electronic circut. Everything seems fine and matches. But on my MAX31865 I've got an [401] Rref (401 Ohm). Regarding to the article (and if my sensor is actual a PT1000) I would need a 4300 Ohm Resistor [4300] Rref. How can I find out how many Ohms my sensor would need? Icould not find an datasheet
Thats the sensor: ETM-01-1 https://de.aliexpress.com/i/1005001793272558.html
I've contacted the supplier to get a datasheet. Unfortunatly he will send it tomorrow haha..
Thats where the temp probe normally get used. looks decent to me tho. What are you guys thinking about that probe?
An amazing find, azon gives you a link to the Adafruit MAX31865 data which you will find the MAX part number which is readily available. Chasing the links I came up with this:
To calculate the reference resistor for a MAX31865 using a 200-ohm sensor, you need to understand the relationship between the sensor and the reference resistor. The MAX31865 is designed for use with RTD (Resistance Temperature Detectors) like PT100 (100 ohms at 0°C) or PT1000 (1000 ohms at 0°C), but the same principles apply when using a 200-ohm sensor.
Here’s how you can calculate the reference resistor:
1. Determine the sensor type:
You’re using a PT200 sensor (200 ohms at 0°C).
2. Choosing the reference resistor value:
The MAX31865 compares the resistance of the RTD sensor with the reference resistor to measure the temperature.
The reference resistor should closely match the nominal resistance of the RTD at 0°C. For a PT200 sensor, the reference resistor should ideally be a precision resistor with a value close to 200 ohms.
Using a 200-ohm precision resistor (with a tolerance of 0.1% or better) ensures accurate readings.
3. Why the reference resistor value matters:
The MAX31865 measures the ratio of the RTD resistance to the reference resistance. A reference resistor that closely matches the sensor’s nominal resistance helps maintain accuracy. Be sure to make good connections as this is a low resistance load.
For a PT200 sensor, using a 200-ohm reference resistor simplifies the calculations and improves the linearity of the measurements.
4. Calculation example:
If you have a 200-ohm RTD sensor, and you use a 200-ohm reference resistor, the MAX31865 will read the resistance ratio directly.
At 0°C, the RTD will have a resistance of 200 ohms, and the reference resistor will also be 200 ohms, resulting in a 1:1 ratio, which the MAX31865 can use to compute the temperature accurately.
What you need to do:
Choose a reference resistor that is as close as possible to 200 ohms, with a tolerance of ±0.1% or better to ensure accuracy. This can be a measured value.
Connect the RTD sensor and the reference resistor to the MAX31865 according to the datasheet, making sure that the reference resistor is in place where the chip expects it.
The MAX31865 will now use this reference resistor to calculate the resistance of the RTD sensor and determine the temperature.
That's the first thing I would test. There are resistance tables on the net.
A PT100 is 100 ohm @ zero degrees C, and about 110 ohm @ 25C.
A thermistor could be 10k @ 25 C, with a much larger resistance deviation.
Leo..
I guess you were kind of right…
I texted the last few days back and forth with the chinese supplier where i bought it. Fortunately he sent me the specs of the sensor today.
He told me that the sensor is the type PT1000.
Also it is a Type K thermocouple with inductive electromotive force and NOT resistance.
ATM i don’t know what to do with this information. But I’lldo some research now.
Just want to post it, if some of you guys may have an easy fix for it.
That makes absolutely no sense whatsoever It's either a PT1000 RTD or a K type thermocouple, can't be both. So you still don't know what it is.
Do you have a DMM or ohmmeter, so you can measure the resistance
That would indicate that it is a thermocouple.
Provided it has not been damage with all the testing you have been doing, it should work with a thermocouple amplifier board.
