Esp32 + OV7670 giving weird outputs
So I'm trying to use a barebones ESP32 WROVER IE with an OV7670 (not esp32 cam)
I'm using JPEGENC and a base64 encoder to encode it into a base64 string which I then display on my webserver. This all works fine and dandy but the problem is that I am getting very weird results when using RGB565 (JPEGEnc only supports rgb565 or grayscale, but I want colour images)
I'm not sure why any of these problems are happening. My code: (sorry for making it very long, currently the only part that is actually used, where the camera capture and encoding happens, is in the function cs_ei_get_buffer_encode_to_png on line 414):
/* Edge Impulse Arduino examples
 * Copyright (c) 2022 EdgeImpulse Inc.
 * Permission is hereby granted, free of charge, to any person obtaining a copy
 * of this software and associated documentation files (the "Software"), to deal
 * in the Software without restriction, including without limitation the rights
 * to use, copy, modify, merge, publish, distribute, sublicense, and/or sell
 * copies of the Software, and to permit persons to whom the Software is
 * furnished to do so, subject to the following conditions:
 * The above copyright notice and this permission notice shall be included in
 * all copies or substantial portions of the Software.
 * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
 * IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
 * FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE
 * AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
 * LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM,
 * OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE
 * SOFTWARE.
// These sketches are tested with 2.0.4 ESP32 Arduino Core
// https://github.com/espressif/arduino-esp32/releases/tag/2.0.4
/* Includes ---------------------------------------------------------------- */
#include <faec_detection_inferencing.h>
#include "edge-impulse-sdk/dsp/image/image.hpp"
#include "esp_camera.h"
#include <WiFi.h>
#include <JPEGENC.h>
#include <base64.hpp>
#include <ArduinoJson.h>
// Select camera model - find more camera models in camera_pins.h file here
// https://github.com/espressif/arduino-esp32/blob/master/libraries/ESP32/examples/Camera/CameraWebServer/camera_pins.h
#define CAMERA_MODEL_ESP_EYE // Has PSRAM
//#define CAMERA_MODEL_AI_THINKER  // Has PSRAM
#define PWDN_GPIO_NUM 32
#define RESET_GPIO_NUM -1
#define XCLK_GPIO_NUM 0
#define SIOD_GPIO_NUM 26
#define SIOC_GPIO_NUM 27
#define Y9_GPIO_NUM 35
#define Y8_GPIO_NUM 34
#define Y7_GPIO_NUM 39
#define Y6_GPIO_NUM 36
#define Y5_GPIO_NUM 21
#define Y4_GPIO_NUM 19
#define Y3_GPIO_NUM 18
#define Y2_GPIO_NUM 5
#define VSYNC_GPIO_NUM 25
#define HREF_GPIO_NUM 23
#define PCLK_GPIO_NUM 22
//#error "Camera model not selected"
/* Constant defines -------------------------------------------------------- */
#define EI_CAMERA_RAW_FRAME_BUFFER_COLS 640
#define EI_CAMERA_RAW_FRAME_BUFFER_ROWS 480
#define EI_CAMERA_FRAME_BYTE_SIZE 3
/* Private variables ------------------------------------------------------- */
static bool debug_nn = false;  // Set this to true to see e.g. features generated from the raw signal
static bool is_initialised = false;
uint8_t *snapshot_buf;  //points to the output of the capture
static camera_config_t camera_config = {
  .pin_pwdn = PWDN_GPIO_NUM,
  .pin_reset = RESET_GPIO_NUM,
  .pin_xclk = XCLK_GPIO_NUM,
  .pin_sscb_sda = SIOD_GPIO_NUM,
  .pin_sscb_scl = SIOC_GPIO_NUM,
  .pin_d7 = Y9_GPIO_NUM,
  .pin_d6 = Y8_GPIO_NUM,
  .pin_d5 = Y7_GPIO_NUM,
  .pin_d4 = Y6_GPIO_NUM,
  .pin_d3 = Y5_GPIO_NUM,
  .pin_d2 = Y4_GPIO_NUM,
  .pin_d1 = Y3_GPIO_NUM,
  .pin_d0 = Y2_GPIO_NUM,
  .pin_vsync = VSYNC_GPIO_NUM,
  .pin_href = HREF_GPIO_NUM,
  .pin_pclk = PCLK_GPIO_NUM,
  //XCLK 20MHz or 10MHz for OV2640 double FPS (Experimental)
  .xclk_freq_hz = 10000000,
  .ledc_timer = LEDC_TIMER_0,
  .ledc_channel = LEDC_CHANNEL_0,
  .pixel_format = PIXFORMAT_GRAYSCALE,  //YUV422,GRAYSCALE,RGB565,JPEG
  .frame_size = FRAMESIZE_QVGA,      //QQVGA-UXGA Do not use sizes above QVGA when not JPEG
  .jpeg_quality = 12,  //0-63 lower number means higher quality
  .fb_count = 1,       //if more than one, i2s runs in continuous mode. Use only with JPEG
  .fb_location = CAMERA_FB_IN_PSRAM,
  .grab_mode = CAMERA_GRAB_WHEN_EMPTY,
// Dual core tools
TaskHandle_t WebServerTask;
TaskHandle_t CamTask;
ei::signal_t current_signal;
/* Function definitions ------------------------------------------------------- */
bool ei_camera_init(void);
void ei_camera_deinit(void);
bool ei_camera_capture(uint32_t img_width, uint32_t img_height, uint8_t *out_buf);
* @brief      Arduino setup function
  //comment out the below line to start inference immediately after upload
  while (!Serial)
  Serial.println("Webserver is initializing on the second core.");
  xTaskCreatePinnedToCore(
    WebServer,      /* Function to implement the task */
    "Webserver",    /* Name of the task */
    10000,          /* Stack size in words */
    NULL,           /* Task input parameter */
    0,              /* Priority of the task */
    &WebServerTask, /* Task handle. */
    1);             /* Core where the task should run */
  Serial.println("Edge Impulse Inferencing Demo");
  if (ei_camera_init() == false) {
    ei_printf("Failed to initialize Camera!\r\n");
    ei_printf("Camera initialized\r\n");
  ei_printf("\nStarting continious inference in 2 seconds...\n");
  ei_sleep(2000);
* @brief      Get data and run inferencing
* @param[in]  debug  Get debug info if true
  // instead of wait_ms, we'll wait on the signal, this allows threads to cancel us...
  if (ei_sleep(5) != EI_IMPULSE_OK) {
    return;
  snapshot_buf = (uint8_t *)malloc(EI_CAMERA_RAW_FRAME_BUFFER_COLS * EI_CAMERA_RAW_FRAME_BUFFER_ROWS * EI_CAMERA_FRAME_BYTE_SIZE);
  // check if allocation was successful
  if (snapshot_buf == nullptr) {
    ei_printf("ERR: Failed to allocate snapshot buffer!\n");
    return;
  ei::signal_t signal;
  signal.total_length = EI_CLASSIFIER_INPUT_WIDTH * EI_CLASSIFIER_INPUT_HEIGHT;
  signal.get_data = &ei_camera_get_data;
  current_signal = signal;
  if (ei_camera_capture((size_t)EI_CLASSIFIER_INPUT_WIDTH, (size_t)EI_CLASSIFIER_INPUT_HEIGHT, snapshot_buf) == false) {
    //ei_printf("Failed to capture image\r\n");
    free(snapshot_buf);
    return;
  //Serial.println(String((char *)snapshot_buf));
  // Run the classifier
  ei_impulse_result_t result = { 0 };
  EI_IMPULSE_ERROR err = run_classifier(&signal, &result, debug_nn);
  if (err != EI_IMPULSE_OK) {
    ei_printf("ERR: Failed to run classifier (%d)\n", err);
    return;
  // print the predictions
  ei_printf("Predictions (DSP: %d ms., Classification: %d ms., Anomaly: %d ms.): \n",
            result.timing.dsp, result.timing.classification, result.timing.anomaly);
#if EI_CLASSIFIER_OBJECT_DETECTION == 1
  ei_printf("Object detection bounding boxes:\r\n");
  for (uint32_t i = 0; i < result.bounding_boxes_count; i++) {
    ei_impulse_result_bounding_box_t bb = result.bounding_boxes[i];
    if (bb.value == 0) {
      continue;
    ei_printf("  %s (%f) [ x: %u, y: %u, width: %u, height: %u ]\r\n",
              bb.label,
              bb.value,
              bb.x,
              bb.y,
              bb.width,
              bb.height);
  // Print the prediction results (classification)
#else
  ei_printf("Predictions:\r\n");
  for (uint16_t i = 0; i < EI_CLASSIFIER_LABEL_COUNT; i++) {
    ei_printf("  %s: ", ei_classifier_inferencing_categories[i]);
    ei_printf("%.5f\r\n", result.classification[i].value);
#endif
  // Print anomaly result (if it exists)
#if EI_CLASSIFIER_HAS_ANOMALY
  ei_printf("Anomaly prediction: %.3f\r\n", result.anomaly);
#endif
#if EI_CLASSIFIER_HAS_VISUAL_ANOMALY
  ei_printf("Visual anomalies:\r\n");
  for (uint32_t i = 0; i < result.visual_ad_count; i++) {
    ei_impulse_result_bounding_box_t bb = result.visual_ad_grid_cells[i];
      continue;
              bb.label,
              bb.value,
              bb.x,
              bb.y,
              bb.width,
              bb.height);
#endif
  free(snapshot_buf);
 * @brief   Setup image sensor & start streaming
 * @retval  false if initialisation failed
bool ei_camera_init(void) {
  if (is_initialised) return true;
#if defined(CAMERA_MODEL_ESP_EYE)
  pinMode(13, INPUT_PULLUP);
  pinMode(14, INPUT_PULLUP);
#endif
  //initialize the camera
  esp_err_t err = esp_camera_init(&camera_config);
  if (err != ESP_OK) {
    Serial.printf("Camera init failed with error 0x%x\n", err);
    return false;
  sensor_t *s = esp_camera_sensor_get();
  // initial sensors are flipped vertically and colors are a bit saturated
  if (s->id.PID == OV3660_PID) {
    s->set_vflip(s, 1);       // flip it back
    s->set_brightness(s, 1);  // up the brightness just a bit
    s->set_saturation(s, 0);  // lower the saturation
#if defined(CAMERA_MODEL_M5STACK_WIDE)
  s->set_vflip(s, 1);
  s->set_hmirror(s, 1);
#elif defined(CAMERA_MODEL_ESP_EYE)
  s->set_vflip(s, 1);
  s->set_awb_gain(s, 1);
#endif
  is_initialised = true;
  return true;
 * @brief      Stop streaming of sensor data
void ei_camera_deinit(void) {
  //deinitialize the camera
  esp_err_t err = esp_camera_deinit();
    ei_printf("Camera deinit failed\n");
    return;
  return;
bool buffering_c = false;
 * @brief      Capture, rescale and crop image
 * @param[in]  img_width     width of output image
 * @param[in]  img_height    height of output image
 * @param[in]  out_buf       pointer to store output image, NULL may be used
 *                           if ei_camera_frame_buffer is to be used for capture and resize/cropping.
 * @retval     false if not initialised, image captured, rescaled or cropped failed
bool ei_camera_capture(uint32_t img_width, uint32_t img_height, uint8_t *out_buf) {
  if (buffering_c == true) {
    ei_printf("You cannot use ei_camera_capture on a thread while another thread is running it!\n");
    return false;
  buffering_c = true;
  bool do_resize = false;
  if (!is_initialised) {
    //ei_camera_init();
    //ei_printf("ERR: Camera is not initialized\r\n");
    return false;
  camera_fb_t *fb = esp_camera_fb_get();
  if (!fb) {
    ei_printf("Camera capture failed\n");
    return false;
  bool converted = fmt2rgb888(fb->buf, fb->len, PIXFORMAT_RGB565, snapshot_buf);
  esp_camera_fb_return(fb);
  if (!converted) {
    ei_printf("Conversion failed\n");
    return false;
  if ((img_width != EI_CAMERA_RAW_FRAME_BUFFER_COLS)
      || (img_height != EI_CAMERA_RAW_FRAME_BUFFER_ROWS)) {
    do_resize = true;
  if (do_resize) {
    ei::image::processing::crop_and_interpolate_rgb888(
      out_buf,
      EI_CAMERA_RAW_FRAME_BUFFER_COLS,
      EI_CAMERA_RAW_FRAME_BUFFER_ROWS,
      out_buf,
      img_width,
      img_height);
  return true;
bool buffering = false;
static int ei_camera_get_data(size_t offset, size_t length, float *out_ptr) {
  // if another call to get camera data is active, returns false
  if (buffering == true) {
    ei_printf("You cannot use ei_camera_get_data on a thread while another thread is running it!\n");
    return 0;
  buffering = true;
  // we already have a RGB888 buffer, so recalculate offset into pixel index
  size_t pixel_ix = offset * 3;
  size_t pixels_left = length;
  size_t out_ptr_ix = 0;
  while (pixels_left != 0) {
    // Swap BGR to RGB here
    // due to https://github.com/espressif/esp32-camera/issues/379
    out_ptr[out_ptr_ix] = (snapshot_buf[pixel_ix + 2] << 16) + (snapshot_buf[pixel_ix + 1] << 8) + snapshot_buf[pixel_ix];
    // go to the next pixel
    out_ptr_ix++;
    pixel_ix += 3;
    pixels_left--;
  // disable buffering
  buffering = false;
  // and done!
  return 0;
#if !defined(EI_CLASSIFIER_SENSOR) || EI_CLASSIFIER_SENSOR != EI_CLASSIFIER_SENSOR_CAMERA
#error "Invalid model for current sensor"
#endif
JPEGENC jpg;
JPEGENCODE jpe;
uint8_t *out_jpg = NULL;
String b64 = "";
// cs = custom functiom
void cs_ei_get_buffer_encode_to_png(void *pvParams) {
  Serial.println("start1");
  Serial.println("lololololol");
    Serial.println("lololololololol");
    return;
  buffering_c = true;
  Serial.println("got fb");
  if (!fb) {
    return;
  jpeg docs
    int open(const char *szFilename, JPEGE_OPEN_CALLBACK *pfnOpen, JPEGE_CLOSE_CALLBACK *pfnClose, JPEGE_READ_CALLBACK *pfnRead, JPEGE_WRITE_CALLBACK *pfnWrite, JPEGE_SEEK_CALLBACK *pfnSeek);
    int open(uint8_t *pOutput, int iBufferSize);
    int close();
    int encodeBegin(JPEGENCODE *pEncode, int iWidth, int iHeight, uint8_t ucPixelType, uint8_t ucSubSample, uint8_t ucQFactor);
    int addMCU(JPEGENCODE *pEncode, uint8_t *pPixels, int iPitch);
    int addFrame(JPEGENCODE *pEncode, uint8_t *pPixels, int iPitch);
    int getLastError();
  size_t out_jpg_len1 = 0, out_jpg_len2;
  out_jpg = (uint8_t *)ps_malloc(65536);
  Serial.println("outjpg inited");
  jpg.open(out_jpg, 65536);
  Serial.println("jpg opened");
  int rc = jpg.encodeBegin(&jpe, fb->width, fb->height, JPEGE_PIXEL_GRAYSCALE, JPEGE_SUBSAMPLE_420, JPEGE_Q_BEST);
  Serial.println("jpg encoded");
  if (rc != JPEGE_SUCCESS) {
    ei_printf("Failed to encode JPEG");
    return;
  // bytes per line = width * 2 (16 bits/pixel)
  jpg.addFrame(&jpe, fb->buf, fb->width * 2);
  Serial.println("jpg fb added");
  int32_t iDataSize = jpg.close();
  Serial.println("jpg closed");
  Serial.println("Output file size =");
  Serial.println(iDataSize, DEC);
  Serial.println("returned");
  uint8_t temp;
  unsigned char output[65536];
  Serial.println("Base64 buffer created");
  unsigned int base64_length = encode_base64((unsigned char *)out_jpg, iDataSize, output);
  Serial.println("Encoded");
  b64 = String((char *)output);
  Serial.println("lulzies");
  vTaskDelete(NULL);
// helpers
//core 2
const char *ssid = "Ramialk_2020_2.4GEXT";  // CHANGE IT
const char *password = "0504915088";        // CHANGE IT
WiFiServer server(80);
String html = R"(
  <!DOCTYPE html>
  <html>
    <head>
      <title>ESP32 Camera Webserver</title>
      <style>
      </style>
      <script>
        const url = '/update'
        let dataBegin = 'data:image/jpeg;base64,'
        let data = ''
        async function updateData() {
          let image = document.getElementById('img')
          const response = await fetch(url, {
            method: "GET",
        let json = await response.json()
        console.log(json.image)
        image.src = dataBegin + json.image
      </script>
    </head>
    <body>
      <h1>Hello World!</h1>
      <img src='' alt='Image from OV7670 cam' id='img'><br>
      <button onclick='updateData()'>Update Camera</button>
    </body>
  </html>
// Current time
unsigned long currentTime = millis();
// Previous time
unsigned long previousTime = 0;
// Define timeout time in milliseconds (example: 2000ms = 2s)
const long timeoutTime = 2000;
String header;
void WebServer(void *pvParams) {
  //Serial.begin(9600);
  Serial.print("Connecting to ");
  Serial.println(ssid);
  WiFi.begin(ssid, password);
    Serial.print(".");
  // Print local IP address and start web server
  Serial.println("");
  Serial.println("WiFi connected.");
  Serial.println("IP address: ");
  server.begin();
  // Start continous loop (required for XTaskCreatePinnedToCore)
  for (;;) {
    WiFiClient client = server.available();
    if (client) {
      previousTime = currentTime;
      Serial.println("New Client.");                                             // print a message out in the serial port
      String currentLine = "";                                                   // make a String to hold incoming data from the client
      while (client.connected() && currentTime - previousTime <= timeoutTime) {  // loop while the client's connected
        if (client.available()) {  // if there's bytes to read from the client,
          char c = client.read();  // read a byte, then
          Serial.write(c);         // print it out the serial monitor
          header += c;
          if (c == '\n') {  // if the byte is a newline character
            // if the current line is blank, you got two newline characters in a row.
            // that's the end of the client HTTP request, so send a response:
            if (currentLine.length() == 0) {
              // HTTP headers always start with a response code (e.g. HTTP/1.1 200 OK)
              // and a content-type so the client knows what's coming, then a blank line:
              if (header.indexOf("GET /update") >= 0) {
                Serial.println("update");
                // do not send HTML
                // instead sends back the resolution with JSON
                JsonDocument doc;
                  cs_ei_get_buffer_encode_to_png, /* Function to implement the task */
                  "CamTask",                      /* Name of the task */
                  100000,                         /* Stack size in words */
                  1,                              /* Priority of the task */
                  &CamTask,                       /* Task handle. */
                Serial.println("e");
                configASSERT(CamTask);
                Serial.println("help me");
                /*if (CamTask != NULL) {
                  Serial.println("deletion");
                  vTaskDelete(CamTask);
                Serial.println("Expecto patronum");
                doc["image"] = b64;
                // Use the handle to delete the task.
                String out;
                serializeJson(doc, out);
                client.println(out);
                //breaks from loop to prevent HTML from being sent
              client.println("Content-type:text/html");
              client.println("Connection: close");
              client.println();
              // turns the GPIOs on and off
              client.print(html);
              // The HTTP response ends with another blank line
              client.println();
              // Break out of the while loop
            } else {  // if you got a newline, then clear currentLine
              currentLine = "";
          } else if (c != '\r') {  // if you got anything else but a carriage return character,
            currentLine += c;      // add it to the end of the currentLine
      // Clear the header variable
      header = "";
      // Close the connection
      client.stop();
      Serial.println("Client disconnected.");
      Serial.println("");
I have triple checked my pin connection so I believe it isn't a problem
UPDATE: So the problem was with JPEGENC, the jpeg encoder I used. I tried frame2jpg (the jpeg encoder that came with esp_camera.h) and things became less pixelated and clearer
