ESP32-S Cam connection to telegram failed i heard installing an ssl certificate helps how do i do that exactly?
Hey so i have a school project and i am making a detection system where a pir sensor will detect a burglar which will then have a ESP32-CAM take a picture of a burglar saves this picture on an sd card and sends the picture to telegram via my phone i follow the steps of https://www.viralsciencecreativity.com/post/esp32-cam-motion-alert-send-image-to-telegram
but after i upload his code `
#include <dummy.h>
// Viral Science www.viralsciencecreativity.com www.youtube.com/c/viralscience
// ESP32 Cam Motion Alert | Send Image to Telegram
// Enter your WiFi ssid and password
const char* ssid = "WiFi-2.4-3106";   //WIFI SSID
const char* password = "FA3769159B";  //WIFI password
String token = "7111914232:AAGstJfQW6ktr02JUv15jfgyoKOz9gjwxQA";
String chat_id = "1881487752";
#include <WiFi.h>
#include <WiFiClientSecure.h>
#include "soc/soc.h"
#include "soc/rtc_cntl_reg.h"
#include "esp_camera.h"
//CAMERA_MODEL_AI_THINKER
#define PWDN_GPIO_NUM 32
#define RESET_GPIO_NUM -1
#define XCLK_GPIO_NUM 0
#define SIOD_GPIO_NUM 26
#define SIOC_GPIO_NUM 27
#define Y9_GPIO_NUM 35
#define Y8_GPIO_NUM 34
#define Y7_GPIO_NUM 39
#define Y6_GPIO_NUM 36
#define Y5_GPIO_NUM 21
#define Y4_GPIO_NUM 19
#define Y3_GPIO_NUM 18
#define Y2_GPIO_NUM 5
#define VSYNC_GPIO_NUM 25
#define HREF_GPIO_NUM 23
#define PCLK_GPIO_NUM 22
int gpioPIR = 13;  //PIR Motion Sensor
  WRITE_PERI_REG(RTC_CNTL_BROWN_OUT_REG, 0);
  delay(10);
  WiFi.mode(WIFI_STA);
  Serial.println("");
  Serial.print("Connecting to ");
  Serial.println(ssid);
  WiFi.begin(ssid, password);
  long int StartTime = millis();
    if ((StartTime + 10000) < millis()) break;
  Serial.println("");
  Serial.println("STAIP address: ");
  Serial.println("");
  if (WiFi.status() != WL_CONNECTED) {
    Serial.println("Reset");
    ledcSetup(3, 5000, 8);
    ledcAttachPin(4, 3);
    ledcWrite(3, 10);
    delay(200);
    ledcWrite(3, 0);
    delay(200);
    ledcDetachPin(4);
    ESP.restart();
    for (int i = 0; i < 5; i++) {
      ledcWrite(3, 10);
      delay(200);
      ledcWrite(3, 0);
      delay(200);
    ledcDetachPin(4);
  camera_config_t config;
  config.ledc_channel = LEDC_CHANNEL_0;
  config.ledc_timer = LEDC_TIMER_0;
  config.pin_d0 = Y2_GPIO_NUM;
  config.pin_d1 = Y3_GPIO_NUM;
  config.pin_d2 = Y4_GPIO_NUM;
  config.pin_d3 = Y5_GPIO_NUM;
  config.pin_d4 = Y6_GPIO_NUM;
  config.pin_d5 = Y7_GPIO_NUM;
  config.pin_d6 = Y8_GPIO_NUM;
  config.pin_d7 = Y9_GPIO_NUM;
  config.pin_xclk = XCLK_GPIO_NUM;
  config.pin_pclk = PCLK_GPIO_NUM;
  config.pin_vsync = VSYNC_GPIO_NUM;
  config.pin_href = HREF_GPIO_NUM;
  config.pin_sscb_sda = SIOD_GPIO_NUM;
  config.pin_sscb_scl = SIOC_GPIO_NUM;
  config.pin_pwdn = PWDN_GPIO_NUM;
  config.pin_reset = RESET_GPIO_NUM;
  config.xclk_freq_hz = 20000000;
  config.pixel_format = PIXFORMAT_JPEG;
  if (psramFound()) {
    config.frame_size = FRAMESIZE_VGA;
    config.jpeg_quality = 10;  //0-63 lower number means higher quality
    config.fb_count = 2;
    config.frame_size = FRAMESIZE_QQVGA;
    config.jpeg_quality = 12;  //0-63 lower number means higher quality
    config.fb_count = 1;
  // camera init
  esp_err_t err = esp_camera_init(&config);
  if (err != ESP_OK) {
    Serial.printf("Camera init failed with error 0x%x", err);
    ESP.restart();
  sensor_t* s = esp_camera_sensor_get();
  s->set_framesize(s, FRAMESIZE_XGA);
  pinMode(gpioPIR, INPUT_PULLUP);
  int v = digitalRead(gpioPIR);
  Serial.println(v);
  if (v == 1) {
    alerts2Telegram(token, chat_id);
    delay(10000);
String alerts2Telegram(String token, String chat_id) {
  const char* myDomain = "api.telegram.org";
  String getAll = "", getBody = "";
  camera_fb_t* fb = NULL;
  fb = esp_camera_fb_get();
  if (!fb) {
    Serial.println("Camera capture failed");
    ESP.restart();
    return "Camera capture failed";
  WiFiClientSecure client_tcp;
  if (client_tcp.connect(myDomain, 443)) {
    Serial.println("Connected to " + String(myDomain));
    String head = "--India\r\nContent-Disposition: form-data; name=\"chat_id\"; \r\n\r\n" + chat_id + "\r\n--India\r\nContent-Disposition: form-data; name=\"photo\"; filename=\"esp32-cam.jpg\"\r\nContent-Type: image/jpeg\r\n\r\n";
    String tail = "\r\n--India--\r\n";
    uint16_t imageLen = fb->len;
    uint16_t extraLen = head.length() + tail.length();
    uint16_t totalLen = imageLen + extraLen;
    client_tcp.println("POST /bot" + token + "/sendPhoto HTTP/1.1");
    client_tcp.println("Host: " + String(myDomain));
    client_tcp.println("Content-Length: " + String(totalLen));
    client_tcp.println("Content-Type: multipart/form-data; boundary=India");
    client_tcp.println();
    client_tcp.print(head);
    uint8_t* fbBuf = fb->buf;
    size_t fbLen = fb->len;
    for (size_t n = 0; n < fbLen; n = n + 1024) {
      if (n + 1024 < fbLen) {
        client_tcp.write(fbBuf, 1024);
        fbBuf += 1024;
      } else if (fbLen % 1024 > 0) {
        size_t remainder = fbLen % 1024;
        client_tcp.write(fbBuf, remainder);
    client_tcp.print(tail);
    esp_camera_fb_return(fb);
    int waitTime = 10000;  // timeout 10 seconds
    long startTime = millis();
    boolean state = false;
    while ((startTime + waitTime) > millis()) {
      Serial.print(".");
      delay(100);
      while (client_tcp.available()) {
        char c = client_tcp.read();
        if (c == '\n') {
          if (getAll.length() == 0) state = true;
          getAll = "";
        } else if (c != '\r')
          getAll += String(c);
        if (state == true) getBody += String(c);
      if (getBody.length() > 0) break;
    client_tcp.stop();
    Serial.println(getBody);
    getBody = "Connection to telegram failed.";
    Serial.println("Connection to telegram failed.");
  return getBody;
`and press rst i see on the serial monitor this error how do i fix this? (i have my pir sensor not connect to this detection system yet) ets Jul�ets Jul 29 2019 12:21:46
rst:0x1 (POWERON_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP:0xee
clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
mode:DIO, clock div:1
load:0x3fff0030,len:1344
load:0x40078000,len:13964
load:0x40080400,len:3600
entry 0x400805f0
Connecting to WiFi-2.4-3106
STAIP address:
192.168.1.2
1
1
1
rst:0xc (SW_CPU_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
entry 0x400805f0
The error Camera capture failed suggests an issue with the camera module. You can check the camera with a simple and short test code.
yes no everything should be fine with that i was able to take a picture and save it on an sd card i should also mention i dont have an ssl certificate in my code for telegram is that really needed? because it seems complicated
When connecting with TLS, usually over port 443, WiFiClientSecure will attempt to verify that the responding server really is who you asked for. That's a major point of https. However, the first thing you can try for testing purposes only is to turn that off.
With ESP32, under the tools menu, you should have Core Debug Level. Set that to Debug to see more info, and re-upload. When the connect call fails, you will probably see something like
[E][WiFiClientSecure.cpp:144] connect(): start_ssl_client: -1
Before that call, add (in your case)
  client_tcp.setInsecure(); //TODO replace with cert if the rest of this works
and hopefully, you should see instead
[D][ssl_client.cpp:176] start_ssl_client(): WARNING: Skipping SSL Verification. INSECURE!
and your "Connected to" message. If so, congratulations.
Now, using the cert is easy enough. It's in PEM format, which is a block text "fenced" with BEGIN something and END something, inside a raw string that looks like this:
const char GO_DADDY_ROOT_CERT_G2[] = R"(
-----BEGIN CERTIFICATE-----
MIIEfTCCA2WgAwIBAgIDG+cVMA0GCSqGSIb3DQEBCwUAMGMxCzAJBgNVBAYTAlVT
MSEwHwYDVQQKExhUaGUgR28gRGFkZHkgR3JvdXAsIEluYy4xMTAvBgNVBAsTKEdv
  // omitted a bunch of lines in the middle //
qm5vjLyb4lddJIGvl5echK1srDdMZvNhkREg5L4wn3qkKQmw4TRfZHcYQFHfjDCm
rw==
-----END CERTIFICATE-----
Then swap that setInsecure call with another one-liner using that string
  // client_tcp.setInsecure(); // don't need this anymore
  client_tcp.setCACert(GO_DADDY_ROOT_CERT_G2);
You should no longer see the INSECURE warning, but the connection should still work.
Now the harder part is getting that PEM data. Notice that I omitted a bunch in my example above. Also, how do you even determine that the root cert is from GoDaddy? At least two ways. First, through the browser UI, usually starting by clicking on the lock before the URL, after visiting api.telegram.org. This case is complicated by the fact that visiting the site root redirects you to core.telegram.org instead, which uses a different cert, one for *.telegram.org. But they both use the same root certificate, which is expected. Not only will Telegram have the same root cert for all its sites, but lots of other entities use GoDaddy as their Certificate Authority (CA) and use the same root cert as well.
There are too many UI variations to enumerate, and a given browser can even change its own UI occasionally. After clicking that lock, clicking around to get more information on the secure connection should lead to a way to view the certificate; where you should find that the certificate chain goes like this
  1. api.telegram.org
  2. Go Daddy Secure Certificate Authority - G2
  3. Go Daddy Root Certificate Authority - G2
And there should be a way to download the Root's cert in PEM format.
The second way is with openssl, which should be readily available on Linux and Mac (and on Windows through WSL and other ways). You can find various recipes, but this one works well (with bash)
openssl s_client -showcerts -verify 5 -connect api.telegram.org:443 < /dev/null |
   awk '/BEGIN CERTIFICATE/,/END CERTIFICATE/{ if(/BEGIN CERTIFICATE/){a++}; out="cert"a".pem"; print >out}'
for cert in *.pem; do
        newname=$(openssl x509 -noout -subject -in $cert | sed -nE 's/.*CN ?= ?(.*)/\1/; s/[ ,.*]/_/g; s/__/_/g; s/_-_/-/; s/^_//g;p' | tr '[:upper:]' '[:lower:]').pem
        echo "${newname}"; mv "${cert}" "${newname}"
done
which should print
verify depth is 5
depth=2 C = US, ST = Arizona, L = Scottsdale, O = "GoDaddy.com, Inc.", CN = Go Daddy Root Certificate Authority - G2
verify return:1
depth=1 C = US, ST = Arizona, L = Scottsdale, O = "GoDaddy.com, Inc.", OU = http://certs.godaddy.com/repository/, CN = Go Daddy Secure Certificate Authority - G2
verify return:1
depth=0 CN = api.telegram.org
verify return:1
DONE
api_telegram_org.pem
go_daddy_secure_certificate_authority-g2.pem
go_daddy_root_certificate_authority-g2.pem
subject=c_=_us_o_=_"the_go_daddy_group_inc_"_ou_=_go_daddy_class_2_certification_authority.pem
You may need to scroll right to see the Common Names (CN) listed in reverse. The greatest depth is "Go Daddy Root", for which there is a corresponding .pem file. (There's a fourth file, which is the self-issued issuer of that root cert, but the file name has a bunch of equal signs because it has no CN; ignore that one.) Paste the content of the root .pem -- the first few and last few lines should match the example above.
BTW, if you use the wrong cert, the error you should see (with the Core Debug Level at something other than None) is
[E][ssl_client.cpp:37] _handle_error(): [start_ssl_client():273]: (-9984) X509 - Certificate verification failed, e.g. CRL, CA or signature check failed
[E][WiFiClientSecure.cpp:144] connect(): start_ssl_client: -9984
Is that complicated? As the expression goes, "the S in IoT stands for Security". Using the certificate is not trivial, but hardly a burden. You should use it.
Hey man i tried uploading the code with the root n wificlientsecure but it gave me a brownout detected why is this? i got my esp32-cam working with an external powercource with 2 1.5v batteries?
this is my error btw ets Jul 29 2019 12:21:46
entry 0x400805f0
[ 24][D][esp32-hal-cpu.c:244] setCpuFrequencyMhz(): PLL: 480 / 2 = 240 Mhz, APB: 80000000 Hz
[ 479][I][esp32-hal-psram.c:96] psramInit(): PSRAM enabled
[ 757][D][WiFiGeneric.cpp:1040] _eventCallback(): Arduino Event: 0 - WIFI_READY
[ 833][D][WiFiGeneric.cpp:1040] _eventCallback(): Arduino Event: 2 - STA_START
.[ 939][D][WiFiGeneric.cpp:1040] _eventCallback(): Arduino Event: 4 - STA_CONNECTED
......[ 4070][D][WiFiGeneric.cpp:1040] _eventCallback(): Arduino Event: 7 - STA_GOT_IP
[ 4078][D][WiFiGeneric.cpp:1103] _eventCallback(): STA IP: 192.168.1.2, MASK: 255.255.255.0, GW: 192.168.1.1
ESP32-CAM IP Address: 192.168.1.2
[ 4371][E][WiFiClientSecure.cpp:144] connect(): start_ssl_client: -1
[ 5378][E][WiFiClientSecure.cpp:144] connect(): start_ssl_client: -1
[ 6385][E][WiFiClientSecure.cpp:144] connect(): start_ssl_client: -1
[ 7392][E][WiFiClientSecure.cpp:144] connect(): start_ssl_client: -1
A brownout while uploading, or while running it after? In any case, I don't see any mention of brownout in the output you just posted.
I do see the connect(): start_ssl_client: -1. Is that with the root cert? Show the relevant code: the PEM data and the code in the area that uses it (if the whole this is too big to post). The GoDaddy certificate is a public document, so it is OK to post. I didn't do it keep the post shorter and make it an exercise to find it.
No that error with ssl client is what i am getting with my original code to get te connect my esp32cam to telegram. The brouwnout detected error u can see here is what i am getting when i go to examples/wificlientsecure and try to upload that code. Please help me i use 2 1.5v 2300mAh batteries it should be more that enough esp32-cam take max 300mA so why is this? `ets Jul 29 2019 12:21:46
entry 0x400805f0
[ 480][I][esp32-hal-psram.c:96] psramInit(): PSRAM enabled
Attempting to connect to SSID: WiFi-2.4-3106
[ 619][D][WiFiGeneric.cpp:1040] _eventCallback(): Arduino Event: 0 - WIFI_READY
Brownout detector was triggered
entry 0x400805f0
Brownout detector was triggered`
Do you mean the example under File | Examples | WiFiClientSecure | WiFiClientSecure ? If you comment-out the key statement
  client.setCACert(test_root_ca);
do you still get a brownout? If that "fixes it", then consider that verifying a certificate is "more math" that makes the CPU work harder, and you may have identified that you have borderline power. I have no specific suggestions to add to this, which includes how to disable the brownout detector. I have never had this problem, and never tried any of those solutions.
BTW, the version of the example I have is old; the certificate in the code expired in 2021. And the GET line unnecessary includes the origin, the scheme and host. It should instead be GET /a/check HTTP/1.0 But if you're modifying the example to test against api.telegram.org, both will be changed anyway.
Hey so i only removeed the client.setCACert(test_root_ca); line and after the upload i couldn't get anything on the serial monitor i pressed rst and nothing happened on the serial monitor and what do u mean with that the code in wifisclientsecure is expired? i changed the root to one godaddy root certificate with the" and \n" \ every line so what made the code not work and ouput anything on serial data do u know? do i need to change more to the code ? Here is my code currently
  Wifi secure connection example for ESP32
  Running on TLS 1.2 using mbedTLS
  Suporting the following chipersuites:
  "TLS_ECDHE_ECDSA_WITH_AES_256_GCM_SHA384","TLS_ECDHE_RSA_WITH_AES_256_GCM_SHA384","TLS_DHE_RSA_WITH_AES_256_GCM_SHA384","TLS_ECDHE_ECDSA_WITH_AES_256_CCM","TLS_DHE_RSA_WITH_AES_256_CCM","TLS_ECDHE_ECDSA_WITH_AES_256_CBC_SHA384","TLS_ECDHE_RSA_WITH_AES_256_CBC_SHA384","TLS_DHE_RSA_WITH_AES_256_CBC_SHA256","TLS_ECDHE_ECDSA_WITH_AES_256_CBC_SHA","TLS_ECDHE_RSA_WITH_AES_256_CBC_SHA","TLS_DHE_RSA_WITH_AES_256_CBC_SHA","TLS_ECDHE_ECDSA_WITH_AES_256_CCM_8","TLS_DHE_RSA_WITH_AES_256_CCM_8","TLS_ECDHE_ECDSA_WITH_CAMELLIA_256_GCM_SHA384","TLS_ECDHE_RSA_WITH_CAMELLIA_256_GCM_SHA384","TLS_DHE_RSA_WITH_CAMELLIA_256_GCM_SHA384","TLS_ECDHE_ECDSA_WITH_CAMELLIA_256_CBC_SHA384","TLS_ECDHE_RSA_WITH_CAMELLIA_256_CBC_SHA384","TLS_DHE_RSA_WITH_CAMELLIA_256_CBC_SHA256","TLS_DHE_RSA_WITH_CAMELLIA_256_CBC_SHA","TLS_ECDHE_ECDSA_WITH_AES_128_GCM_SHA256","TLS_ECDHE_RSA_WITH_AES_128_GCM_SHA256","TLS_DHE_RSA_WITH_AES_128_GCM_SHA256","TLS_ECDHE_ECDSA_WITH_AES_128_CCM","TLS_DHE_RSA_WITH_AES_128_CCM","TLS_ECDHE_ECDSA_WITH_AES_128_CBC_SHA256","TLS_ECDHE_RSA_WITH_AES_128_CBC_SHA256","TLS_DHE_RSA_WITH_AES_128_CBC_SHA256","TLS_ECDHE_ECDSA_WITH_AES_128_CBC_SHA","TLS_ECDHE_RSA_WITH_AES_128_CBC_SHA","TLS_DHE_RSA_WITH_AES_128_CBC_SHA","TLS_ECDHE_ECDSA_WITH_AES_128_CCM_8","TLS_DHE_RSA_WITH_AES_128_CCM_8","TLS_ECDHE_ECDSA_WITH_CAMELLIA_128_GCM_SHA256","TLS_ECDHE_RSA_WITH_CAMELLIA_128_GCM_SHA256","TLS_DHE_RSA_WITH_CAMELLIA_128_GCM_SHA256","TLS_ECDHE_ECDSA_WITH_CAMELLIA_128_CBC_SHA256","TLS_ECDHE_RSA_WITH_CAMELLIA_128_CBC_SHA256","TLS_DHE_RSA_WITH_CAMELLIA_128_CBC_SHA256","TLS_DHE_RSA_WITH_CAMELLIA_128_CBC_SHA","TLS_ECDHE_ECDSA_WITH_3DES_EDE_CBC_SHA","TLS_ECDHE_RSA_WITH_3DES_EDE_CBC_SHA","TLS_DHE_RSA_WITH_3DES_EDE_CBC_SHA","TLS_DHE_PSK_WITH_AES_256_GCM_SHA384","TLS_DHE_PSK_WITH_AES_256_CCM","TLS_ECDHE_PSK_WITH_AES_256_CBC_SHA384","TLS_DHE_PSK_WITH_AES_256_CBC_SHA384","TLS_ECDHE_PSK_WITH_AES_256_CBC_SHA","TLS_DHE_PSK_WITH_AES_256_CBC_SHA","TLS_DHE_PSK_WITH_CAMELLIA_256_GCM_SHA384","TLS_ECDHE_PSK_WITH_CAMELLIA_256_CBC_SHA384","TLS_DHE_PSK_WITH_CAMELLIA_256_CBC_SHA384","TLS_PSK_DHE_WITH_AES_256_CCM_8","TLS_DHE_PSK_WITH_AES_128_GCM_SHA256","TLS_DHE_PSK_WITH_AES_128_CCM","TLS_ECDHE_PSK_WITH_AES_128_CBC_SHA256","TLS_DHE_PSK_WITH_AES_128_CBC_SHA256","TLS_ECDHE_PSK_WITH_AES_128_CBC_SHA","TLS_DHE_PSK_WITH_AES_128_CBC_SHA","TLS_DHE_PSK_WITH_CAMELLIA_128_GCM_SHA256","TLS_DHE_PSK_WITH_CAMELLIA_128_CBC_SHA256","TLS_ECDHE_PSK_WITH_CAMELLIA_128_CBC_SHA256","TLS_PSK_DHE_WITH_AES_128_CCM_8","TLS_ECDHE_PSK_WITH_3DES_EDE_CBC_SHA","TLS_DHE_PSK_WITH_3DES_EDE_CBC_SHA","TLS_RSA_WITH_AES_256_GCM_SHA384","TLS_RSA_WITH_AES_256_CCM","TLS_RSA_WITH_AES_256_CBC_SHA256","TLS_RSA_WITH_AES_256_CBC_SHA","TLS_ECDH_RSA_WITH_AES_256_GCM_SHA384","TLS_ECDH_RSA_WITH_AES_256_CBC_SHA384","TLS_ECDH_RSA_WITH_AES_256_CBC_SHA","TLS_ECDH_ECDSA_WITH_AES_256_GCM_SHA384","TLS_ECDH_ECDSA_WITH_AES_256_CBC_SHA384","TLS_ECDH_ECDSA_WITH_AES_256_CBC_SHA","TLS_RSA_WITH_AES_256_CCM_8","TLS_RSA_WITH_CAMELLIA_256_GCM_SHA384","TLS_RSA_WITH_CAMELLIA_256_CBC_SHA256","TLS_RSA_WITH_CAMELLIA_256_CBC_SHA","TLS_ECDH_RSA_WITH_CAMELLIA_256_GCM_SHA384","TLS_ECDH_RSA_WITH_CAMELLIA_256_CBC_SHA384","TLS_ECDH_ECDSA_WITH_CAMELLIA_256_GCM_SHA384","TLS_ECDH_ECDSA_WITH_CAMELLIA_256_CBC_SHA384","TLS_RSA_WITH_AES_128_GCM_SHA256","TLS_RSA_WITH_AES_128_CCM","TLS_RSA_WITH_AES_128_CBC_SHA256","TLS_RSA_WITH_AES_128_CBC_SHA","TLS_ECDH_RSA_WITH_AES_128_GCM_SHA256","TLS_ECDH_RSA_WITH_AES_128_CBC_SHA256","TLS_ECDH_RSA_WITH_AES_128_CBC_SHA","TLS_ECDH_ECDSA_WITH_AES_128_GCM_SHA256","TLS_ECDH_ECDSA_WITH_AES_128_CBC_SHA256","TLS_ECDH_ECDSA_WITH_AES_128_CBC_SHA","TLS_RSA_WITH_AES_128_CCM_8","TLS_RSA_WITH_CAMELLIA_128_GCM_SHA256","TLS_RSA_WITH_CAMELLIA_128_CBC_SHA256","TLS_RSA_WITH_CAMELLIA_128_CBC_SHA","TLS_ECDH_RSA_WITH_CAMELLIA_128_GCM_SHA256","TLS_ECDH_RSA_WITH_CAMELLIA_128_CBC_SHA256","TLS_ECDH_ECDSA_WITH_CAMELLIA_128_GCM_SHA256","TLS_ECDH_ECDSA_WITH_CAMELLIA_128_CBC_SHA256","TLS_RSA_WITH_3DES_EDE_CBC_SHA","TLS_ECDH_RSA_WITH_3DES_EDE_CBC_SHA","TLS_ECDH_ECDSA_WITH_3DES_EDE_CBC_SHA","TLS_RSA_PSK_WITH_AES_256_GCM_SHA384","TLS_RSA_PSK_WITH_AES_256_CBC_SHA384","TLS_RSA_PSK_WITH_AES_256_CBC_SHA","TLS_RSA_PSK_WITH_CAMELLIA_256_GCM_SHA384","TLS_RSA_PSK_WITH_CAMELLIA_256_CBC_SHA384","TLS_RSA_PSK_WITH_AES_128_GCM_SHA256","TLS_RSA_PSK_WITH_AES_128_CBC_SHA256","TLS_RSA_PSK_WITH_AES_128_CBC_SHA","TLS_RSA_PSK_WITH_CAMELLIA_128_GCM_SHA256","TLS_RSA_PSK_WITH_CAMELLIA_128_CBC_SHA256","TLS_RSA_PSK_WITH_3DES_EDE_CBC_SHA","TLS_PSK_WITH_AES_256_GCM_SHA384","TLS_PSK_WITH_AES_256_CCM","TLS_PSK_WITH_AES_256_CBC_SHA384","TLS_PSK_WITH_AES_256_CBC_SHA","TLS_PSK_WITH_CAMELLIA_256_GCM_SHA384","TLS_PSK_WITH_CAMELLIA_256_CBC_SHA384","TLS_PSK_WITH_AES_256_CCM_8","TLS_PSK_WITH_AES_128_GCM_SHA256","TLS_PSK_WITH_AES_128_CCM","TLS_PSK_WITH_AES_128_CBC_SHA256","TLS_PSK_WITH_AES_128_CBC_SHA","TLS_PSK_WITH_CAMELLIA_128_GCM_SHA256","TLS_PSK_WITH_CAMELLIA_128_CBC_SHA256","TLS_PSK_WITH_AES_128_CCM_8","TLS_PSK_WITH_3DES_EDE_CBC_SHA","TLS_EMPTY_RENEGOTIATION_INFO_SCSV"]
  2017 - Evandro Copercini - Apache 2.0 License.
const char* ssid = "WiFi-2.4-3106";   // your network SSID (name of wifi network)
const char* password = "FA3769159B";  // your network password
const char* server = "api.telegram.org";  // Server URL
// www.howsmyssl.com root certificate authority, to verify the server
// change it to your server root CA
// SHA1 fingerprint is broken now!
const char* test_root_ca =
  "-----BEGIN CERTIFICATE-----\n"
  "MIIDxTCCAq2gAwIBAgIBADANBgkqhkiG9w0BAQsFADCBgzELMAkGA1UEBhMCVVMx\n"
  "EDAOBgNVBAgTB0FyaXpvbmExEzARBgNVBAcTClNjb3R0c2RhbGUxGjAYBgNVBAoT\n"
  "EUdvRGFkZHkuY29tLCBJbmMuMTEwLwYDVQQDEyhHbyBEYWRkeSBSb290IENlcnRp\n"
  "ZmljYXRlIEF1dGhvcml0eSAtIEcyMB4XDTA5MDkwMTAwMDAwMFoXDTM3MTIzMTIz\n"
  "NTk1OVowgYMxCzAJBgNVBAYTAlVTMRAwDgYDVQQIEwdBcml6b25hMRMwEQYDVQQH\n"
  "EwpTY290dHNkYWxlMRowGAYDVQQKExFHb0RhZGR5LmNvbSwgSW5jLjExMC8GA1UE\n"
  "AxMoR28gRGFkZHkgUm9vdCBDZXJ0aWZpY2F0ZSBBdXRob3JpdHkgLSBHMjCCASIw\n"
  "DQYJKoZIhvcNAQEBBQADggEPADCCAQoCggEBAL9xYgjx+lk09xvJGKP3gElY6SKD\n"
  "E6bFIEMBO4Tx5oVJnyfq9oQbTqC023CYxzIBsQU+B07u9PpPL1kwIuerGVZr4oAH\n"
  "/PMWdYA5UXvl+TW2dE6pjYIT5LY/qQOD+qK+ihVqf94Lw7YZFAXK6sOoBJQ7Rnwy\n"
  "DfMAZiLIjWltNowRGLfTshxgtDj6AozO091GB94KPutdfMh8+7ArU6SSYmlRJQVh\n"
  "GkSBjCypQ5Yj36w6gZoOKcUcqeldHraenjAKOc7xiID7S13MMuyFYkMlNAJWJwGR\n"
  "tDtwKj9useiciAF9n9T521NtYJ2/LOdYq7hfRvzOxBsDPAnrSTFcaUaz4EcCAwEA\n"
  "AaNCMEAwDwYDVR0TAQH/BAUwAwEB/zAOBgNVHQ8BAf8EBAMCAQYwHQYDVR0OBBYE\n"
  "FDqahQcQZyi27/a9BUFuIMGU2g/eMA0GCSqGSIb3DQEBCwUAA4IBAQCZ21151fmX\n"
  "WWcDYfF+OwYxdS2hII5PZYe096acvNjpL9DbWu7PdIxztDhC2gV7+AJ1uP2lsdeu\n"
  "9tfeE8tTEH6KRtGX+rcuKxGrkLAngPnon1rpN5+r5N9ss4UXnT3ZJE95kTXWXwTr\n"
  "gIOrmgIttRD02JDHBHNA7XIloKmf7J6raBKZV8aPEjoJpL1E/QYVN8Gb5DKj7Tjo\n"
  "2GTzLH4U/ALqn83/B2gX2yKQOC16jdFU8WnjXzPKej17CuPKf1855eJ1usV2GDPO\n"
  "LPAvTK33sefOT6jEm0pUBsV/fdUID+Ic/n4XuKxe9tQWskMJDE32p2u0mYRlynqI\n"
  "4uJEvlz36hz1\n"
  "-----END CERTIFICATE-----\n";
// You can use x.509 client certificates if you want
//const char* test_client_key = "";   //to verify the client
//const char* test_client_cert = "";  //to verify the client
WiFiClientSecure client;
  //Initialize serial and wait for port to open:
  delay(100);
  Serial.print("Attempting to connect to SSID: ");
  // attempt to connect to Wifi network:
    Serial.print(".");
    // wait 1 second for re-trying
  Serial.print("Connected to ");
  Serial.println("\nStarting connection to server...");
  if (!client.connect(server, 443))
    Serial.println("Connection failed!");
  else {
    Serial.println("Connected to server!");
    // Make a HTTP request:
    client.println("GET https://www.howsmyssl.com/a/check HTTP/1.0");
    client.println("Host: www.howsmyssl.com");
    client.println("Connection: close");
    client.println();
    while (client.connected()) {
      String line = client.readStringUntil('\n');
      if (line == "\r") {
        Serial.println("headers received");
    // if there are incoming bytes available
    // from the server, read them and print them:
    while (client.available()) {
      char c = client.read();
      Serial.write(c);
    client.stop();
  // do nothing
That not right. As @kenb4 stated, the certificate must be a raw text string. This is what the one for HiveMQ looks like:
  const char *const test_root_ca  = R"EOF(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=
)EOF";
Better to turn it into comment, so you can see where it is supposed to go, and it is easy to put back. If you're using the IDE, Ctrl-/ (maybe Cmd-/ on Mac) will toggle the current line or selection.
That's more work than using a raw string delimited by R"( and )" like I had, but it should work.
After swapping the cert, you changed
but you also need to change
to match. As I said, you actually don't need/want the origin in the request-line after the GET, because you have/need the Host header. You do want a path that doesn't redirect -- /bot by itself works, even though it is actually 404, it returns a body. So changing to
    client.println("GET /bot HTTP/1.0");
    client.println("Host: api.telegram.org");
and restoring
where it was before, before the client.connect call, I get
headers received
{"ok":false,"error_code":404,"description":"Not Found"}
If you're not getting anything in the Serial Monitor, try closing it and reopening.
But i saw many that say i have to use " and /n / no? But is that all i got to change sorry it's a bit new to me
hey so u use R"EOF( Raw Text String )EOF" ?
A raw string is the easiest and least error-prone, because you can just paste the content directly, without having to add quotes, and it will preserve the line breaks in the string. The text is flush to the left margin, and can be indented appropriately.
You can use just R"()" because the ) does not appear inside a PEM. For other text, like HTML, you want to add something like EOF, which will work as long as the string content doesn't have )EOF as part of the text. You can/must make that marker as unique as necessary.
If you're not using a raw string, then having adjacent quoted strings, regardless of whitespace, is probably next best; the compiler will just concatenate them for you. In that case, you need to add the \n for the line feeds, as you had it.
The sample went one step further originally:
with a backslash at the end of each line. This causes the lines to be joined, but is unnecessary. It is required when doing #define for multi-line macros, but not for regular C++ code; sorta like in HTML, any amount of whitespace -- that is not part of a quoted string -- is treated the same.
As I said, I only had to change those two println and put the setCACert back, and it worked for me.
That sample was last modified 3 years ago, in April. If you check the certificate in the code
openssl x509 -in the.pem -text -noout -checkend 0
it expired at the end of September 2021.
        Validity
            Not Before: Sep 30 21:12:19 2000 GMT
            Not After : Sep 30 14:01:15 2021 GMT
and at the bottom
Certificate will expire
With -checkend 0, "will" mean now.
That is the current stable release, v2.0.16. In the latest pre-release of v3, they have renamed WiFiClientSecure to NetworkClientSecure and the certificate has not been updated.
Hey so again i get this error rst:0xc (SW_CPU_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
entry 0x400805f0
[ 23][D][esp32-hal-cpu.c:244] setCpuFrequencyMhz(): PLL: 480 / 2 = 240 Mhz, APB: 80000000 Hz
[ 618][D][WiFiGeneric.cpp:1040] _eventCallback(): Arduino Event: 0 - WIFI_READY
spammed let me know if there are better way i want my esp32-cam to be able to send pictures so i can make a detectian system with also a pir sensor here is my code now let me know what i messed up
  "4uJEvlz36hz1\n"
  delay(100);
    Serial.print(".");
  else {
    client.println();
      if (line == "\r") {
      Serial.write(c);
    client.stop();
  // do nothing
i also tried withR"EOF( and )EOF"; still got me brownout detected
The various ways of doing the PEM string result in the exact same binary, and you're not even using it. You can try removing it entirely to verify that is not the issue.
If you're getting a brownout just by connecting to WiFi, you've got a bigger problem. Did you try the suggestions in that link I posted earlier?
You have a powering problem.
That's only 3v (and change) to start with. ESP32 is a 3.3v device, with the added current drain of a WiFi connection, the supply voltage is dropping below the brownout detection threshold. Use a better power supply.
Yes so on your recommended website they power the esp32 from the fdti I use an external power source to the 3.3v pin
also the code they recommended turning off brownout fails to upload, it doesn't fit in the code i think. Also in other codes i am able to succefully connect to wifi and even take a picture and safe with the esp32-cam the only problem now is not being able to connect my esp32-cam to my telegram and trying the code wifclientsecure only results in brownout while i use 2 1.5 batteries 2300 mAh which would give me 3v and 2300mAh so what u think i should do?
when batteries connected there is 2.6v with all the loses a esp32 needs atleas 2.2v i thougt? should i try 3 batteries 1.2v? thats 3.6v and someone said it's an current problem not a voltage one and i measure 0.35mA to the esp32 is that bad? my batteries can give 2300mAh so why the esp32 only draws 0.35mA ??
