Problem with ESP32-cam pir motion connected to Telegram
Hi guys, I m trying to do a DIY where you connect ESP32-cam to a pir motion and send notification & pictures to Telegram. I've been following the steps shown in youtube tutorials, I had a first fail when I used a sketch found in a tutorial, it said "failed to connect to telegram" on the serial monitor.
I uploaded succefully another code in my ESP32-cam, pressed the reset button and had this response on my serial monitor :
18:7:00.625 -> Connecting to router
18:7:00.626 -> .......
18:7:04.135 -> ESP32-CAM IP Address: 192.168.1.10
18:7:04.136 ->
• I set up correctly my telegram bot
• The settings for esp32-cam on arduinoIDE are ok, such as wroover module etc..
• I connected correctly my pir sensor ( GND->GND, OUT pin->GPIO2 as shown in the tutorial and VCC->5v ) but I still don't get anything in my telegram bot ...
A m I missing something ? Is there any specific library to download ? I already downloaded UniversalTelegramBot by brian lough, ArduinoJson by Benoit Blenchon and bunch of others for Esp32-cam.
Also note that I tested my pir motion with another simple sketch which makes esp's led blink when motion is detected and it worked. In addtion I tested my ESP32-cam with the CameraWebServer sketch given by ArduinoIDE and it also worked. And I m using Arduino IDE 2.0 beta.
Here is the code that I m using ( I obviously added the ssid, password, bottoken and chatID before uploading in my esp ^^ )
#include <WiFiClientSecure.h>
#include "soc/soc.h"
#include "soc/rtc_cntl_reg.h"
#include "esp_camera.h"
#include <UniversalTelegramBot.h>
#include <ArduinoJson.h>
#include <Wire.h>
const char* ssid = "********";
const char* password = "*******";
String chatId = "1662******";
String BOTtoken = "170895024********";
bool sendPhoto = false;
WiFiClientSecure clientTCP;
UniversalTelegramBot bot(BOTtoken, clientTCP);
//CAMERA_MODEL_AI_THINKER
#define PWDN_GPIO_NUM     32
#define RESET_GPIO_NUM    -1
#define XCLK_GPIO_NUM      0
#define SIOD_GPIO_NUM     26
#define SIOC_GPIO_NUM     27
#define Y9_GPIO_NUM       35
#define Y8_GPIO_NUM       34
#define Y7_GPIO_NUM       39
#define Y6_GPIO_NUM       36
#define Y5_GPIO_NUM       21
#define Y4_GPIO_NUM       19
#define Y3_GPIO_NUM       18
#define Y2_GPIO_NUM        5
#define VSYNC_GPIO_NUM    25
#define HREF_GPIO_NUM     23
#define PCLK_GPIO_NUM     22
#define FLASH_LED_PIN 4
#define pir 2
bool flashState = LOW;
bool flag = 0;
int botRequestDelay = 1000;   // mean time between scan messages
long lastTimeBotRan;     // last time messages' scan has been done
void handleNewMessages(int numNewMessages);
String sendPhotoTelegram();
void setup(){
  WRITE_PERI_REG(RTC_CNTL_BROWN_OUT_REG, 0);
  pinMode(FLASH_LED_PIN, OUTPUT);
  pinMode(pir,INPUT);
  digitalWrite(FLASH_LED_PIN, flashState);
  WiFi.mode(WIFI_STA);
  Serial.print("Connecting to ");
  Serial.println(ssid);
  WiFi.begin(ssid, password);
    Serial.print(".");
  Serial.print("ESP32-CAM IP Address: ");
  camera_config_t config;
  config.ledc_channel = LEDC_CHANNEL_0;
  config.ledc_timer = LEDC_TIMER_0;
  config.pin_d0 = Y2_GPIO_NUM;
  config.pin_d1 = Y3_GPIO_NUM;
  config.pin_d2 = Y4_GPIO_NUM;
  config.pin_d3 = Y5_GPIO_NUM;
  config.pin_d4 = Y6_GPIO_NUM;
  config.pin_d5 = Y7_GPIO_NUM;
  config.pin_d6 = Y8_GPIO_NUM;
  config.pin_d7 = Y9_GPIO_NUM;
  config.pin_xclk = XCLK_GPIO_NUM;
  config.pin_pclk = PCLK_GPIO_NUM;
  config.pin_vsync = VSYNC_GPIO_NUM;
  config.pin_href = HREF_GPIO_NUM;
  config.pin_sscb_sda = SIOD_GPIO_NUM;
  config.pin_sscb_scl = SIOC_GPIO_NUM;
  config.pin_pwdn = PWDN_GPIO_NUM;
  config.pin_reset = RESET_GPIO_NUM;
  config.xclk_freq_hz = 20000000;
  config.pixel_format = PIXFORMAT_JPEG;
  //init with high specs to pre-allocate larger buffers
  if(psramFound()){
    config.frame_size = FRAMESIZE_UXGA;
    config.jpeg_quality = 10;  //0-63 lower number means higher quality
    config.fb_count = 2;
    config.frame_size = FRAMESIZE_SVGA;
    config.jpeg_quality = 12;  //0-63 lower number means higher quality
    config.fb_count = 1;
  // camera init
  esp_err_t err = esp_camera_init(&config);
  if (err != ESP_OK) {
    Serial.printf("Camera init failed with error 0x%x", err);
    ESP.restart();
  // Drop down frame size for higher initial frame rate
  sensor_t * s = esp_camera_sensor_get();
  s->set_framesize(s, FRAMESIZE_SVGA);  // UXGA|SXGA|XGA|SVGA|VGA|CIF|QVGA|HQVGA|QQVGA
void loop(){
    Serial.print(".");
    delay(2000);
  if (sendPhoto){
    Serial.println("Preparing photo");
    sendPhoto = false;
  if (flag){
    if(digitalRead(pir) == 1){
      Serial.print("Motion Detected, Value = ");
      Serial.println(digitalRead(pir));
      String motion = "Motion detected !!\n";
      motion += "You will get a photo right now.\n";
      bot.sendMessage(chatId, motion, "");
  if (millis() > lastTimeBotRan + botRequestDelay){
    int numNewMessages = bot.getUpdates(bot.last_message_received + 1);
    while (numNewMessages){
      Serial.println("got response");
      handleNewMessages(numNewMessages);
    lastTimeBotRan = millis();
  delay(850);
String sendPhotoTelegram(){
  const char* myDomain = "api.telegram.org";
  String getAll = "";
  String getBody = "";
  camera_fb_t * fb = NULL;
  fb = esp_camera_fb_get();
  if(!fb) {
    Serial.println("Camera capture failed");
    ESP.restart();
    return "Camera capture failed";
  Serial.println("Connect to " + String(myDomain));
  if (clientTCP.connect(myDomain, 443)) {
    Serial.println("Connection successful");
    String head = "--RandomNerdTutorials\r\nContent-Disposition: form-data; name=\"chat_id\"; \r\n\r\n" + chatId + "\r\n--RandomNerdTutorials\r\nContent-Disposition: form-data; name=\"photo\"; filename=\"esp32-cam.jpg\"\r\nContent-Type: image/jpeg\r\n\r\n";
    String tail = "\r\n--RandomNerdTutorials--\r\n";
    uint16_t imageLen = fb->len;
    uint16_t extraLen = head.length() + tail.length();
    uint16_t totalLen = imageLen + extraLen;
    clientTCP.println("POST /bot"+BOTtoken+"/sendPhoto HTTP/1.1");
    clientTCP.println("Host: " + String(myDomain));
    clientTCP.println("Content-Length: " + String(totalLen));
    clientTCP.println("Content-Type: multipart/form-data; boundary=RandomNerdTutorials");
    clientTCP.println();
    clientTCP.print(head);
    uint8_t *fbBuf = fb->buf;
    size_t fbLen = fb->len;
    for (size_t n=0;n<fbLen;n=n+1024) {
      if (n+1024<fbLen) {
        clientTCP.write(fbBuf, 1024);
        fbBuf += 1024;
      else if (fbLen%1024>0) {
        size_t remainder = fbLen%1024;
        clientTCP.write(fbBuf, remainder);
    clientTCP.print(tail);
    esp_camera_fb_return(fb);
    int waitTime = 10000;   // timeout 10 seconds
    long startTimer = millis();
    boolean state = false;
    while ((startTimer + waitTime) > millis()){
      Serial.print(".");
      delay(100);
      while (clientTCP.available()){
          char c = clientTCP.read();
          if (c == '\n'){
            if (getAll.length()==0) state=true;
            getAll = "";
          else if (c != '\r'){
            getAll += String(c);
          if (state==true){
            getBody += String(c);
       if (getBody.length()>0) break;
    clientTCP.stop();
    Serial.println(getBody);
  else {
    getBody="Connected to api.telegram.org failed.";
    Serial.println("Connected to api.telegram.org failed.");
  return getBody;
void handleNewMessages(int numNewMessages){
  Serial.print("Handle New Messages: ");
  Serial.println(numNewMessages);
  for (int i = 0; i < numNewMessages; i++){
    // Chat id of the requester
    String chat_id = String(bot.messages[i].chat_id);
    if (chat_id != chatId){
      bot.sendMessage(chat_id, "Unauthorized user", "");
      continue;
    // Print the received message
    String text = bot.messages[i].text;
    Serial.println(text);
    String fromName = bot.messages[i].from_name;
    if (text == "/flash"){
      flashState = !flashState;
    if (text == "/photo"){
      sendPhoto = true;
      Serial.println("New photo  request");
    if (text == "/piron"){
      flag = 1;
      bot.sendMessage(chatId, "PIR Sensor is on. You will get a notification if a motion is detected.", "");
    if (text == "/piroff"){
      flag = 0;
      bot.sendMessage(chatId, "PIR sensor is off. No motion can be detected anymore", "");
//    if (text == "/readings"){
//      String readings = getReadings();
//      bot.sendMessage(chatId, readings, "");
    if (text == "/start"){
      String welcome = "Hi sir, welcome to your SensorDetectionAlert space, \n";
      welcome += "here are the commands I can execute for you :\n";
      welcome += "/photo : Take a photo\n";
      welcome += "/flash : Turn flash LED on\n";
      welcome += "/piron : Turn sensor PIR on\n";
      welcome += "/piroff : Turn sensor PIR off\n";
//      welcome += "/readings : request sensor readings\n\n";
      welcome += "I will also send you a notification whenever the PIR sensor detect any motion. Have a good day.\n";
      bot.sendMessage(chatId, welcome, "Markdown");
Credit for the code : Irdus Project on youtube.
Please, Help ^^ ! Would be much appreciated if someone could help me !
Nb : Sorry if It's not the right category to put this is.
Hi @noobide,
Welcome to the forum! I have never used a telegram bot, but here is a great tutorial using a esp32-cam with PIR and telegram ESP32-CAM Shield PCB with Telegram: Photos, Outputs, Sensor, Motion | Random Nerd Tutorials
Hope this helps.
@noobide if you are not bounded to UniversalTelegramBot library, you could try my library wich have 2 specific example for ESP32-CAM
AsyncTelegram2 - ESP32-CAM examples
Version 2 is not yet in the ide library manager so you have to download the zip file from github and install it manually.
Hi, This is a great project idea. I'm going to have to set this up
Thanks @kgray9 :slight_smile:
I've seen this tutorial, they're basically all showing the same steps but different codes, exept this one is adding a BME sensor and a pcb board at the end. I might give it a try though.
Thanks for your time !
There's no way the guy who built asynctelegram library is answering my topic rn !!! So cool !!!
Jokes aside, I think I'll start everything from the bottom again using Arduino 1.8 and your library this time !
Thanks for your answer :slight_smile:
Very easy project .. when you don't have to face random problems like this one ..
Quick update,
I decided to test the project without using the PIR sensor, using Arduino IDE 1.8 this time, so I uploaded this code instead
  Rui Santos
  Complete project details at https://RandomNerdTutorials.com/telegram-control-esp32-esp8266-nodemcu-outputs/
  Project created using Brian Lough's Universal Telegram Bot Library: https://github.com/witnessmenow/Universal-Arduino-Telegram-Bot
  Example based on the Universal Arduino Telegram Bot Library: https://github.com/witnessmenow/Universal-Arduino-Telegram-Bot/blob/master/examples/ESP8266/FlashLED/FlashLED.ino
#ifdef ESP32
  #include <WiFi.h>
#else
  #include <ESP8266WiFi.h>
#endif
#include <UniversalTelegramBot.h>   // Universal Telegram Bot Library written by Brian Lough: https://github.com/witnessmenow/Universal-Arduino-Telegram-Bot
// Replace with your network credentials
const char* ssid = "REPLACE_WITH_YOUR_SSID";
const char* password = "REPLACE_WITH_YOUR_PASSWORD";
// Initialize Telegram BOT
#define BOTtoken "XXXXXXXXXX:XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX"  // your Bot Token (Get from Botfather)
// Use @myidbot to find out the chat ID of an individual or a group
// Also note that you need to click "start" on a bot before it can
// message you
#define CHAT_ID "XXXXXXXXXX"
#ifdef ESP8266
  X509List cert(TELEGRAM_CERTIFICATE_ROOT);
#endif
WiFiClientSecure client;
UniversalTelegramBot bot(BOTtoken, client);
// Checks for new messages every 1 second.
unsigned long lastTimeBotRan;
const int ledPin = 4;
bool ledState = LOW;
// Handle what happens when you receive new messages
void handleNewMessages(int numNewMessages) {
  Serial.println("handleNewMessages");
  Serial.println(String(numNewMessages));
  for (int i=0; i<numNewMessages; i++) {
    if (chat_id != CHAT_ID){
      continue;
    String from_name = bot.messages[i].from_name;
    if (text == "/start") {
      String welcome = "Welcome, " + from_name + ".\n";
      welcome += "Use the following commands to control your outputs.\n\n";
      welcome += "/led_on to turn GPIO ON \n";
      welcome += "/led_off to turn GPIO OFF \n";
      welcome += "/state to request current GPIO state \n";
      bot.sendMessage(chat_id, welcome, "");
    if (text == "/led_on") {
      bot.sendMessage(chat_id, "LED state set to ON", "");
      ledState = HIGH;
      digitalWrite(ledPin, ledState);
    if (text == "/led_off") {
      bot.sendMessage(chat_id, "LED state set to OFF", "");
      ledState = LOW;
    if (text == "/state") {
      if (digitalRead(ledPin)){
        bot.sendMessage(chat_id, "LED is ON", "");
      else{
        bot.sendMessage(chat_id, "LED is OFF", "");
  #ifdef ESP8266
    configTime(0, 0, "pool.ntp.org");      // get UTC time via NTP
    client.setTrustAnchors(&cert); // Add root certificate for api.telegram.org
  #endif
  pinMode(ledPin, OUTPUT);
  // Connect to Wi-Fi
  #ifdef ESP32
    client.setCACert(TELEGRAM_CERTIFICATE_ROOT); // Add root certificate for api.telegram.org
  #endif
    Serial.println("Connecting to WiFi..");
  // Print ESP32 Local IP Address
  if (millis() > lastTimeBotRan + botRequestDelay)  {
    while(numNewMessages) {
AND IT WORKED !!! I had the expected response on my Telegram Bot.
However, once adding the PIR and uploading the first sketch, it didn't work anymore and this is very confusing.
I see 3 reasons here :
• Problem comes from my circuit ( But as long as my pir worked with a simpler code then it has nothing to do with the circuit ?! )
• Problem comes from the code (in that case it'd be very nice of you if someone could spot the issue )
• I'm very bad at these stuff
Hi @cotestatnt,
It seems like on Arduino IDE 2.0 beta, it is not possible to install manually any of your two libraries, I get the error : AsyncTelegram_main.h (or smth like that) is missing.
Where on arduino 1.8 I did it without any issue.
I took a closer look at this tutorial and it seems that the code is exactly the same as the one I m using, except BME sensor lines have been removed.
So either irdus project used the code for his tutorial or the opposite
Arduino 2.0 looks for library in the same folder as 1.8 do.
You can simply put the files manually in that folder (for example on Windows system is C:\users\yourusern\documents\Arduino\libraries ) or use legacy IDE to install.it.
As your project looked interesting I ordered the ESP32-CAM and finished the project today.
Like you I removed the BME code.
It is now connected to Telegram bot and I used my existing PIR.
Took me awhile to work out how to stop the bot. :slight_smile:
I added an LED to light up when there is motion as it is not connected to serial, and this is the only way for me to know it's triggered.
It would not work properly until I changed PIR VCC from 3.3 to 5V. It kept false triggering with 3V3.
Here is the code I used based on the video.
  Rui Santos
  Complete project details at https://RandomNerdTutorials.com/esp32-cam-shield-pcb-telegram/
  The above copyright notice and this permission notice shall be included in all
  copies or substantial portions of the Software.
#include <WiFi.h>
#include <Wire.h>
//#include "SparkFunBME280.h"
const char* ssid = "";
const char* password = "";
// message you
String chatId = "";
String BOTtoken = "";
#define MOVE_LED_PIN 2
// Motion Sensor
bool motionDetected = false;
/*// Define I2C Pins for BME280
#define I2C_SDA 14
#define I2C_SCL 15
BME280 bme;
/*// Get BME280 sensor readings and return them as a String variable
String getReadings(){
  float temperature, humidity;
  temperature = bme.readTempC();
  //temperature = bme.readTempF();
  humidity = bme.readFloatHumidity();
  String message = "Temperature: " + String(temperature) + " ºC \n";
  message += "Humidity: " + String (humidity) + " % \n";
  return message;
// Indicates when motion is detected
static void IRAM_ATTR detectsMovement(void * arg){
  //Serial.println("MOTION DETECTED!!!");
  motionDetected = true;
void setup(){
  pinMode(MOVE_LED_PIN,OUTPUT);
  digitalWrite(MOVE_LED_PIN,LOW);
 /* // Init BME280 sensor
  Wire.begin(I2C_SDA, I2C_SCL);
  bme.settings.commInterface = I2C_MODE;
  bme.settings.I2CAddress = 0x76;
  bme.settings.runMode = 3;
  bme.settings.tStandby = 0;
  bme.settings.filter = 0;
  bme.settings.tempOverSample = 1;
  bme.settings.pressOverSample = 1;
  bme.settings.humidOverSample = 1;
  bme.begin();
  clientTCP.setCACert(TELEGRAM_CERTIFICATE_ROOT); // Add root certificate for api.telegram.org
    Serial.print(".");
  if(psramFound()){
  // camera init
    ESP.restart();
  s->set_framesize(s, FRAMESIZE_CIF);  // UXGA|SXGA|XGA|SVGA|VGA|CIF|QVGA|HQVGA|QQVGA
  // PIR Motion Sensor mode INPUT_PULLUP
  //err = gpio_install_isr_service(0);
  err = gpio_isr_handler_add(GPIO_NUM_13, &detectsMovement, (void *) 13);
  if (err != ESP_OK){
    Serial.printf("handler add failed with error 0x%x \r\n", err);
  err = gpio_set_intr_type(GPIO_NUM_13, GPIO_INTR_POSEDGE);
  if (err != ESP_OK){
    Serial.printf("set intr type failed with error 0x%x \r\n", err);
void loop(){
  if (sendPhoto){
    sendPhoto = false;
  if(motionDetected){
    digitalWrite(MOVE_LED_PIN,HIGH);
    bot.sendMessage(chatId, "Motion detected!!", "");
    Serial.println("Motion Detected");
  String getAll = "";
  if(!fb) {
    ESP.restart();
      if (n+1024<fbLen) {
        fbBuf += 1024;
      Serial.print(".");
      delay(100);
      while (clientTCP.available()) {
        if (state==true) getBody += String(c);
        if (c == '\n') {
          getAll = "";
        else if (c != '\r')
    clientTCP.stop();
  else {
  return getBody;
      continue;
    if (text == "/flash") {
    if (text == "/photo") {
      sendPhoto = true;
/*    if (text == "/readings"){
      String welcome = "Welcome to the ESP32-CAM Telegram bot.\n";
      welcome += "/photo : takes a new photo\n";
      welcome += "/flash : toggle flash LED\n";
      welcome += "You'll receive a photo whenever motion is detected.\n";
Hi @anon21599558,
The HC-SR501 PIR motion sensor requires 5V on its VCC pin. On the bottom of the sensor though, is a 3.3V regulator. Here is a site that explains how to run it off of 3.3V if you're interested. Modifying Cheap PIR Motion Sensor to Work at 3.3V | Random Nerd Tutorials
Well ... it worked ! I was about to give up honestly so thanks a lot to you @anon21599558 ! And cotestatnt, kgray9, of course, thanks for your answers guys !
It seems that Irdus project's sketch was the problem. I thought it was the same sketch as the Random nerd tutorials one (Like 90% of it is the same though) but after taking an other closer look to it, I see one difference that could explain my issue, this line has been removed from irdus's sketch
Anyways.
However, even though I got a response from my Telegram bot, the pir didn't work at first, so I added these lines in the void loop :
bool PirControler = 0;
  if (PirControler){
    if(digitalRead(PIR) == 1){
      digitalWrite(LED, HIGH); // Turns the esp's LED on
      Serial.println(digitalRead(PIR));
      String motion = "Motion detected !\n";
      motion += "You will receive a photo now.\n";
Also removed these lines :
And everything worked perfectly !
Thanks again guys, hope this will help a lot of people :slight_smile:
Now is there by any chance a way to add the video stream to this sktech ? Like, combine this code to the CameraWebServer one provided by esp library ?
There it is, @anon21599558. I've been able to combine the two sketchs, which was surprisingly easy to do. So now I also have access to the video streaming. Here is the code I use :
#include <WiFi.h>
#include <Wire.h>
#define CAMERA_MODEL_AI_THINKER // Has PSRAM
#include "camera_pins.h"
const char* ssid = "---------";
const char* password = "--------";
String chatId = "-------";
String BOTtoken = "-------------";
#define LED 4
#define PIR 2
// Motion Sensor
void startCameraServer();
  pinMode(LED, OUTPUT);
  digitalWrite(LED, flashState);
    Serial.print(".");
  Serial.setDebugOutput(true);
  // if PSRAM IC present, init with UXGA resolution and higher JPEG quality
  //                      for larger pre-allocated frame buffer.
  if(psramFound()){
  // camera init
    return;
    ESP.restart();
  // initial sensors are flipped vertically and colors are a bit saturated
  if (s->id.PID == OV3660_PID) {
    s->set_vflip(s, 1); // flip it back
    s->set_brightness(s, 1); // up the brightness just a bit
    s->set_saturation(s, -2); // lower the saturation
  // drop down frame size for higher initial frame rate
  s->set_framesize(s, FRAMESIZE_QVGA);
  if (err != ESP_OK){
  if (err != ESP_OK){
  Serial.print("Camera Ready! Use 'http://");
  Serial.print(WiFi.localIP());
  Serial.println("' to connect");
  if (sendPhoto){
    sendPhoto = false;
  if(motionDetected){
  if (PirControler){
      /*digitalWrite(LED, HIGH);
      delay (500);*/
  String getAll = "";
  if(!fb) {
    ESP.restart();
      if (n+1024<fbLen) {
        fbBuf += 1024;
      Serial.print(".");
      delay(100);
        if (c == '\n') {
          getAll = "";
        else if (c != '\r')
    clientTCP.stop();
  else {
  return getBody;
      continue;
      sendPhoto = true;
    if (text == "/PIRON"){
      PirControler = 1;
      bot.sendMessage(chatId, "PIR Sensor is ON, you will get a notification if a motion is detected.", "");
    if (text == "/PIROFF"){
      PirControler = 0;
      bot.sendMessage(chatId, "PIR sensor is OFF, you will no longer receive any notification.", "");
      String welcome = "Hi sir, here are the commands I can execute for you :\n";
      welcome += "/Photo : Take a new photo.\n";
      welcome += "/Flash : Toggle flash LED.\n";
      welcome += "/PIRON : Activate your PIR sensor.\n";
      welcome += "/PIROFF : Shut your PIR sensor down.\n";
    /*else {
      bot.sendMessage(chatId, "I don't understand, sorry. Refer to the commands I showed you above.", "");
I also tried to add these lines
      delay (500);  // It is supposed to turn esp's LED on when motion is detected, but the LED doesn't turn off after that..
  /*else {
But it didn't work as expected, gonna have to find a way to fix that ^^
Well done.
I copied your code and then put my network and Telegram data and it did not compile as you're using a library #include "camera_pins.h". I'll have to look deeper to see why and whether I should start with my code or modify your code for me to check your questions.
This turns the LED on for 500, what turns it off again?
You'll need to explain what you are trying to achieve, ie is the light a deterant or is it for the image capturing?
@noobide, a curiosity, wich is the maximum upload speed you can achieve?
I'm not sure if I got the right answer to your question, the upload speed that I'm using is 921600 (Tools --> upload speed --> 921600). And 115200 baud selected on serial monitor !
