ESP32-S Cam connection to telegram failed i heard installing an ssl certificate helps how do i do that exactly?
someone said i need a capacitor since the batteries dont give the current fast enough so a 10 microfarad capacitor + side beside the + of battery and - of capacitor beside gnd fo battery on breadboard right?
5ad4eb065416d1358b4137b817d834f7c1293475
You're sure listening to a lot of "someones" and you seem intent on trying just about anything except what will most likely fix the problem. That's use a good power supply that can deliver the required current and maintain 3.3v at the ESP32's 3.3v power terminal. Or use a suitable 5v supply at the ESP32's 5v power terminal. You could probably also get away with a 3.7v Li Ion or LiPo battery connected to the 3.3v terminal through a Schottky diode.
That's my advise. You can take it or not, it doesn't matter to me.
i am trying to fix this so why wouldnt i listen to everyone i can i've been told that 10micorfarad capacitor might help delivering needed current and voltage i want to know if you also think this will work? i use 2 1.5v batteries which is 3v enough for 3.3v pin no? but the esp32 only draws 0.35mA so why is that even?
hey cmon i really want this done i can power the esp32 3v or 3.6v whould either help cuz maybe the issue is current cuz esp only draws 0.35mA when it should atleaste take 180mA?
was my code well put? was this part of code needed to be put in? client_tcp.setInsecure(); //TODO replace with cert if the rest of this works if (client_tcp.connect(myDomain, 443)) {
Let me please know what i need to change on my code for it to work
Use either
  • setInsecure to temporarily disable certificate verification. With this, you don't need the giant PEM string at all. OR
  • setCACert to set the root cert PEM
You don't need both. That is the right place, before you try to connect.
Your original code in post #1 is a superset of the WiFiClientSecure example. The only thing it was missing is either the setInsecure or the setCACert and PEM. You could add either one to your original.
That's not the case, because your original code already has it
It's the very first thing, and why it doesn't brown out. But it wants to.
You still have a power problem.
Hey so i use for example setCACert on the top of the code of WificlientSecure ? Because i am new to this so it confuses me where to put certian lines of code
Also this is the easiest way to connect my esp32 to telegram right?
Where exactly is "on the top"? Remember:
It was already in the right place. You removed it; put it back.
hey so again i used the original code
  Wifi secure connection example for ESP32
  Running on TLS 1.2 using mbedTLS
  Suporting the following chipersuites:
  "TLS_ECDHE_ECDSA_WITH_AES_256_GCM_SHA384","TLS_ECDHE_RSA_WITH_AES_256_GCM_SHA384","TLS_DHE_RSA_WITH_AES_256_GCM_SHA384","TLS_ECDHE_ECDSA_WITH_AES_256_CCM","TLS_DHE_RSA_WITH_AES_256_CCM","TLS_ECDHE_ECDSA_WITH_AES_256_CBC_SHA384","TLS_ECDHE_RSA_WITH_AES_256_CBC_SHA384","TLS_DHE_RSA_WITH_AES_256_CBC_SHA256","TLS_ECDHE_ECDSA_WITH_AES_256_CBC_SHA","TLS_ECDHE_RSA_WITH_AES_256_CBC_SHA","TLS_DHE_RSA_WITH_AES_256_CBC_SHA","TLS_ECDHE_ECDSA_WITH_AES_256_CCM_8","TLS_DHE_RSA_WITH_AES_256_CCM_8","TLS_ECDHE_ECDSA_WITH_CAMELLIA_256_GCM_SHA384","TLS_ECDHE_RSA_WITH_CAMELLIA_256_GCM_SHA384","TLS_DHE_RSA_WITH_CAMELLIA_256_GCM_SHA384","TLS_ECDHE_ECDSA_WITH_CAMELLIA_256_CBC_SHA384","TLS_ECDHE_RSA_WITH_CAMELLIA_256_CBC_SHA384","TLS_DHE_RSA_WITH_CAMELLIA_256_CBC_SHA256","TLS_DHE_RSA_WITH_CAMELLIA_256_CBC_SHA","TLS_ECDHE_ECDSA_WITH_AES_128_GCM_SHA256","TLS_ECDHE_RSA_WITH_AES_128_GCM_SHA256","TLS_DHE_RSA_WITH_AES_128_GCM_SHA256","TLS_ECDHE_ECDSA_WITH_AES_128_CCM","TLS_DHE_RSA_WITH_AES_128_CCM","TLS_ECDHE_ECDSA_WITH_AES_128_CBC_SHA256","TLS_ECDHE_RSA_WITH_AES_128_CBC_SHA256","TLS_DHE_RSA_WITH_AES_128_CBC_SHA256","TLS_ECDHE_ECDSA_WITH_AES_128_CBC_SHA","TLS_ECDHE_RSA_WITH_AES_128_CBC_SHA","TLS_DHE_RSA_WITH_AES_128_CBC_SHA","TLS_ECDHE_ECDSA_WITH_AES_128_CCM_8","TLS_DHE_RSA_WITH_AES_128_CCM_8","TLS_ECDHE_ECDSA_WITH_CAMELLIA_128_GCM_SHA256","TLS_ECDHE_RSA_WITH_CAMELLIA_128_GCM_SHA256","TLS_DHE_RSA_WITH_CAMELLIA_128_GCM_SHA256","TLS_ECDHE_ECDSA_WITH_CAMELLIA_128_CBC_SHA256","TLS_ECDHE_RSA_WITH_CAMELLIA_128_CBC_SHA256","TLS_DHE_RSA_WITH_CAMELLIA_128_CBC_SHA256","TLS_DHE_RSA_WITH_CAMELLIA_128_CBC_SHA","TLS_ECDHE_ECDSA_WITH_3DES_EDE_CBC_SHA","TLS_ECDHE_RSA_WITH_3DES_EDE_CBC_SHA","TLS_DHE_RSA_WITH_3DES_EDE_CBC_SHA","TLS_DHE_PSK_WITH_AES_256_GCM_SHA384","TLS_DHE_PSK_WITH_AES_256_CCM","TLS_ECDHE_PSK_WITH_AES_256_CBC_SHA384","TLS_DHE_PSK_WITH_AES_256_CBC_SHA384","TLS_ECDHE_PSK_WITH_AES_256_CBC_SHA","TLS_DHE_PSK_WITH_AES_256_CBC_SHA","TLS_DHE_PSK_WITH_CAMELLIA_256_GCM_SHA384","TLS_ECDHE_PSK_WITH_CAMELLIA_256_CBC_SHA384","TLS_DHE_PSK_WITH_CAMELLIA_256_CBC_SHA384","TLS_PSK_DHE_WITH_AES_256_CCM_8","TLS_DHE_PSK_WITH_AES_128_GCM_SHA256","TLS_DHE_PSK_WITH_AES_128_CCM","TLS_ECDHE_PSK_WITH_AES_128_CBC_SHA256","TLS_DHE_PSK_WITH_AES_128_CBC_SHA256","TLS_ECDHE_PSK_WITH_AES_128_CBC_SHA","TLS_DHE_PSK_WITH_AES_128_CBC_SHA","TLS_DHE_PSK_WITH_CAMELLIA_128_GCM_SHA256","TLS_DHE_PSK_WITH_CAMELLIA_128_CBC_SHA256","TLS_ECDHE_PSK_WITH_CAMELLIA_128_CBC_SHA256","TLS_PSK_DHE_WITH_AES_128_CCM_8","TLS_ECDHE_PSK_WITH_3DES_EDE_CBC_SHA","TLS_DHE_PSK_WITH_3DES_EDE_CBC_SHA","TLS_RSA_WITH_AES_256_GCM_SHA384","TLS_RSA_WITH_AES_256_CCM","TLS_RSA_WITH_AES_256_CBC_SHA256","TLS_RSA_WITH_AES_256_CBC_SHA","TLS_ECDH_RSA_WITH_AES_256_GCM_SHA384","TLS_ECDH_RSA_WITH_AES_256_CBC_SHA384","TLS_ECDH_RSA_WITH_AES_256_CBC_SHA","TLS_ECDH_ECDSA_WITH_AES_256_GCM_SHA384","TLS_ECDH_ECDSA_WITH_AES_256_CBC_SHA384","TLS_ECDH_ECDSA_WITH_AES_256_CBC_SHA","TLS_RSA_WITH_AES_256_CCM_8","TLS_RSA_WITH_CAMELLIA_256_GCM_SHA384","TLS_RSA_WITH_CAMELLIA_256_CBC_SHA256","TLS_RSA_WITH_CAMELLIA_256_CBC_SHA","TLS_ECDH_RSA_WITH_CAMELLIA_256_GCM_SHA384","TLS_ECDH_RSA_WITH_CAMELLIA_256_CBC_SHA384","TLS_ECDH_ECDSA_WITH_CAMELLIA_256_GCM_SHA384","TLS_ECDH_ECDSA_WITH_CAMELLIA_256_CBC_SHA384","TLS_RSA_WITH_AES_128_GCM_SHA256","TLS_RSA_WITH_AES_128_CCM","TLS_RSA_WITH_AES_128_CBC_SHA256","TLS_RSA_WITH_AES_128_CBC_SHA","TLS_ECDH_RSA_WITH_AES_128_GCM_SHA256","TLS_ECDH_RSA_WITH_AES_128_CBC_SHA256","TLS_ECDH_RSA_WITH_AES_128_CBC_SHA","TLS_ECDH_ECDSA_WITH_AES_128_GCM_SHA256","TLS_ECDH_ECDSA_WITH_AES_128_CBC_SHA256","TLS_ECDH_ECDSA_WITH_AES_128_CBC_SHA","TLS_RSA_WITH_AES_128_CCM_8","TLS_RSA_WITH_CAMELLIA_128_GCM_SHA256","TLS_RSA_WITH_CAMELLIA_128_CBC_SHA256","TLS_RSA_WITH_CAMELLIA_128_CBC_SHA","TLS_ECDH_RSA_WITH_CAMELLIA_128_GCM_SHA256","TLS_ECDH_RSA_WITH_CAMELLIA_128_CBC_SHA256","TLS_ECDH_ECDSA_WITH_CAMELLIA_128_GCM_SHA256","TLS_ECDH_ECDSA_WITH_CAMELLIA_128_CBC_SHA256","TLS_RSA_WITH_3DES_EDE_CBC_SHA","TLS_ECDH_RSA_WITH_3DES_EDE_CBC_SHA","TLS_ECDH_ECDSA_WITH_3DES_EDE_CBC_SHA","TLS_RSA_PSK_WITH_AES_256_GCM_SHA384","TLS_RSA_PSK_WITH_AES_256_CBC_SHA384","TLS_RSA_PSK_WITH_AES_256_CBC_SHA","TLS_RSA_PSK_WITH_CAMELLIA_256_GCM_SHA384","TLS_RSA_PSK_WITH_CAMELLIA_256_CBC_SHA384","TLS_RSA_PSK_WITH_AES_128_GCM_SHA256","TLS_RSA_PSK_WITH_AES_128_CBC_SHA256","TLS_RSA_PSK_WITH_AES_128_CBC_SHA","TLS_RSA_PSK_WITH_CAMELLIA_128_GCM_SHA256","TLS_RSA_PSK_WITH_CAMELLIA_128_CBC_SHA256","TLS_RSA_PSK_WITH_3DES_EDE_CBC_SHA","TLS_PSK_WITH_AES_256_GCM_SHA384","TLS_PSK_WITH_AES_256_CCM","TLS_PSK_WITH_AES_256_CBC_SHA384","TLS_PSK_WITH_AES_256_CBC_SHA","TLS_PSK_WITH_CAMELLIA_256_GCM_SHA384","TLS_PSK_WITH_CAMELLIA_256_CBC_SHA384","TLS_PSK_WITH_AES_256_CCM_8","TLS_PSK_WITH_AES_128_GCM_SHA256","TLS_PSK_WITH_AES_128_CCM","TLS_PSK_WITH_AES_128_CBC_SHA256","TLS_PSK_WITH_AES_128_CBC_SHA","TLS_PSK_WITH_CAMELLIA_128_GCM_SHA256","TLS_PSK_WITH_CAMELLIA_128_CBC_SHA256","TLS_PSK_WITH_AES_128_CCM_8","TLS_PSK_WITH_3DES_EDE_CBC_SHA","TLS_EMPTY_RENEGOTIATION_INFO_SCSV"]
  2017 - Evandro Copercini - Apache 2.0 License.
#include <WiFiClientSecure.h>
const char* ssid = "WiFi-2.4-3106";   // your network SSID (name of wifi network)
const char* password = "FA3769159B";  // your network password
const char* server = "api.telegram.org";  // Server URL
// www.howsmyssl.com root certificate authority, to verify the server
// change it to your server root CA
// SHA1 fingerprint is broken now!
const char* test_root_ca = R"EOF(
     -----BEGIN CERTIFICATE-----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     -----END CERTIFICATE-----)EOF";
// You can use x.509 client certificates if you want
//const char* test_client_key = "";   //to verify the client
//const char* test_client_cert = "";  //to verify the client
WiFiClientSecure client;
  //Initialize serial and wait for port to open:
  delay(100);
  Serial.print("Attempting to connect to SSID: ");
  Serial.println(ssid);
  WiFi.begin(ssid, password);
  // attempt to connect to Wifi network:
    Serial.print(".");
    // wait 1 second for re-trying
  Serial.print("Connected to ");
  client.setCACert(test_root_ca);
  //client.setCertificate(test_client_cert); // for client verification
  //client.setPrivateKey(test_client_key);	// for client verification
  Serial.println("\nStarting connection to server...");
  if (!client.connect(server, 443))
    Serial.println("Connection failed!");
  else {
    Serial.println("Connected to server!");
    // Make a HTTP request:
    client.println("GET /bot HTTP/1.0");
    client.println("Host: api.telegram.org");
    client.println("Connection: close");
    client.println();
    while (client.connected()) {
      String line = client.readStringUntil('\n');
      if (line == "\r") {
        Serial.println("headers received");
    // if there are incoming bytes available
    // from the server, read them and print them:
    while (client.available()) {
      char c = client.read();
      Serial.write(c);
    client.stop();
  // do nothing
But it still gives me mode:DIO, clock div:1
load:0x3fff0030,len:1344
load:0x40078000,len:13964
load:0x40080400,len:3600
entry 0x400805f0
[ 15][D][esp32-hal-cpu.c:244] setCpuFrequencyMhz(): PLL: 480 / 2 = 240 Mhz, APB: 80000000 Hz
[ 470][I][esp32-hal-psram.c:96] psramInit(): PSRAM enabled
Attempting to connect to SSID: WiFi-2.4-3106
[ 627][D][WiFiGeneric.cpp:1040] _eventCallback(): Arduino Event: 0 - WIFI_READY
Brownout detector was triggered
ets Jul 29 2019 12:21:46
what are the solutions? because i am now using the 5v pin of the ESP32-CAM with an external powersource of 5.2v and my original code gives my the error telegram failed start an ssl-certificate is this a bad code or what is it ?
I connected the ESP32-CAM with a Wi-Fi just fine with the codes like camerwebserver, but what do i do to make the connection to Telegram? i get this error now why? `ets Jul 29 2019 12:21:46
rst:0x1 (POWERON_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP:0xee
clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
entry 0x400805f0
Connecting to WiFi-2.4-3106
STAIP address:
192.168.1.48
0
0
0
0
0
0
0
0
0
0
1
Connection to telegram failed.
0
1
Connection to telegram failed.`
I use this code now
Send photo alerts to telegram
// Enter your WiFi ssid and password
const char* ssid = "WiFi-2.4-3106";   //WIFI SSID
const char* password = "FA3769159B";  //WIFI password
String token = "7111914232:AAGstJfQW6ktr02JUv15jfgyoKOz9gjwxQA";
String chat_id = "1881487752";
#include <WiFi.h>
#include "soc/soc.h"
#include "soc/rtc_cntl_reg.h"
#include "esp_camera.h"
//CAMERA_MODEL_AI_THINKER
#define PWDN_GPIO_NUM 32
#define RESET_GPIO_NUM -1
#define XCLK_GPIO_NUM 0
#define SIOD_GPIO_NUM 26
#define SIOC_GPIO_NUM 27
#define Y9_GPIO_NUM 35
#define Y8_GPIO_NUM 34
#define Y7_GPIO_NUM 39
#define Y6_GPIO_NUM 36
#define Y5_GPIO_NUM 21
#define Y4_GPIO_NUM 19
#define Y3_GPIO_NUM 18
#define Y2_GPIO_NUM 5
#define VSYNC_GPIO_NUM 25
#define HREF_GPIO_NUM 23
#define PCLK_GPIO_NUM 22
int gpioPIR = 13;  //PIR Motion Sensor
  WRITE_PERI_REG(RTC_CNTL_BROWN_OUT_REG, 0);
  delay(10);
  WiFi.mode(WIFI_STA);
  Serial.println("");
  Serial.print("Connecting to ");
  long int StartTime = millis();
    if ((StartTime + 10000) < millis()) break;
  Serial.println("");
  Serial.println("STAIP address: ");
  Serial.println("");
  if (WiFi.status() != WL_CONNECTED) {
    Serial.println("Reset");
    ledcSetup(3, 5000, 8);
    ledcAttachPin(4, 3);
    ledcWrite(3, 10);
    delay(200);
    ledcWrite(3, 0);
    delay(200);
    ledcDetachPin(4);
    ESP.restart();
    for (int i = 0; i < 5; i++) {
      ledcWrite(3, 10);
      delay(200);
      ledcWrite(3, 0);
      delay(200);
    ledcDetachPin(4);
  camera_config_t config;
  config.ledc_channel = LEDC_CHANNEL_0;
  config.ledc_timer = LEDC_TIMER_0;
  config.pin_d0 = Y2_GPIO_NUM;
  config.pin_d1 = Y3_GPIO_NUM;
  config.pin_d2 = Y4_GPIO_NUM;
  config.pin_d3 = Y5_GPIO_NUM;
  config.pin_d4 = Y6_GPIO_NUM;
  config.pin_d5 = Y7_GPIO_NUM;
  config.pin_d6 = Y8_GPIO_NUM;
  config.pin_d7 = Y9_GPIO_NUM;
  config.pin_xclk = XCLK_GPIO_NUM;
  config.pin_pclk = PCLK_GPIO_NUM;
  config.pin_vsync = VSYNC_GPIO_NUM;
  config.pin_href = HREF_GPIO_NUM;
  config.pin_sscb_sda = SIOD_GPIO_NUM;
  config.pin_sscb_scl = SIOC_GPIO_NUM;
  config.pin_pwdn = PWDN_GPIO_NUM;
  config.pin_reset = RESET_GPIO_NUM;
  config.xclk_freq_hz = 20000000;
  config.pixel_format = PIXFORMAT_JPEG;
  //init with high specs to pre-allocate larger buffers
  if (psramFound()) {
    config.frame_size = FRAMESIZE_VGA;
    config.jpeg_quality = 10;  //0-63 lower number means higher quality
    config.fb_count = 2;
    config.frame_size = FRAMESIZE_QQVGA;
    config.jpeg_quality = 12;  //0-63 lower number means higher quality
    config.fb_count = 1;
  // camera init
  esp_err_t err = esp_camera_init(&config);
  if (err != ESP_OK) {
    Serial.printf("Camera init failed with error 0x%x", err);
    ESP.restart();
  sensor_t* s = esp_camera_sensor_get();
  s->set_framesize(s, FRAMESIZE_XGA);
  pinMode(gpioPIR, INPUT_PULLUP);
  int v = digitalRead(gpioPIR);
  Serial.println(v);
  if (v == 1) {
    alerts2Telegram(token, chat_id);
    delay(10000);
String alerts2Telegram(String token, String chat_id) {
  const char* myDomain = "api.telegram.org";
  String getAll = "", getBody = "";
  camera_fb_t* fb = NULL;
  fb = esp_camera_fb_get();
  if (!fb) {
    Serial.println("Camera capture failed");
    ESP.restart();
    return "Camera capture failed";
  WiFiClientSecure client_tcp;
    Serial.println("Connected to " + String(myDomain));
    String head = "--India\r\nContent-Disposition: form-data; name=\"chat_id\"; \r\n\r\n" + chat_id + "\r\n--India\r\nContent-Disposition: form-data; name=\"photo\"; filename=\"esp32-cam.jpg\"\r\nContent-Type: image/jpeg\r\n\r\n";
    String tail = "\r\n--India--\r\n";
    uint16_t imageLen = fb->len;
    uint16_t extraLen = head.length() + tail.length();
    uint16_t totalLen = imageLen + extraLen;
    client_tcp.println("POST /bot" + token + "/sendPhoto HTTP/1.1");
    client_tcp.println("Host: " + String(myDomain));
    client_tcp.println("Content-Length: " + String(totalLen));
    client_tcp.println("Content-Type: multipart/form-data; boundary=India");
    client_tcp.println();
    client_tcp.print(head);
    uint8_t* fbBuf = fb->buf;
    size_t fbLen = fb->len;
    for (size_t n = 0; n < fbLen; n = n + 1024) {
      if (n + 1024 < fbLen) {
        client_tcp.write(fbBuf, 1024);
        fbBuf += 1024;
      } else if (fbLen % 1024 > 0) {
        size_t remainder = fbLen % 1024;
        client_tcp.write(fbBuf, remainder);
    client_tcp.print(tail);
    esp_camera_fb_return(fb);
    int waitTime = 10000;  // timeout 10 seconds
    long startTime = millis();
    boolean state = false;
    while ((startTime + waitTime) > millis()) {
      Serial.print(".");
      delay(100);
      while (client_tcp.available()) {
        char c = client_tcp.read();
        if (c == '\n') {
          if (getAll.length() == 0) state = true;
          getAll = "";
        } else if (c != '\r')
          getAll += String(c);
        if (state == true) getBody += String(c);
      if (getBody.length() > 0) break;
    client_tcp.stop();
    Serial.println(getBody);
    getBody = "Connection to telegram failed.";
    Serial.println("Connection to telegram failed.");
  return getBody;
22
23
24
25
26
1
2
3
4
5
115200 baud
load:0x3fff0018,len:4
load:0x3fff001c,len:1216 0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
1
Connected to api.telegram.org
{"ok":false,"error_code":401,"description":"Unauthorized"}
1
0
1
this error also popped up when i tried to use 1.0.4 esp32 version on arduino ide
@abdul12345678910 ,
Your other topic on the same subject deleted.
Please do not duplicate your questions as doing so wastes the time and effort of the volunteers trying to help you as they are then answering the same thing in different places.
Please create one topic only for your question and choose the forum category carefully. If you have multiple questions about the same project then please ask your questions in the one topic as the answers to one question provide useful context for the others, and also you won’t have to keep explaining your project repeatedly.
Repeated duplicate posting could result in a temporary or permanent ban from the forum.
Could you take a few moments to Learn How To Use The Forum
Thank you.
If the code you posted
yielded
that doesn't seem right, but regardless: congratulations. You have successfully connected over HTTPS and gotten a response.
All I know about the specifics of Telegram is from scanning this tutorial, where it says that this
https://api.telegram.org/bot<YOUR_BOT_TOKEN>/getMe
should work. You included the token in that code -- which you should not do -- but it did allow me to try that call with curl and get the same 401 Unauthorized response. This is a basic security issue. Is that the right kind of token? Try getting another one.
I made the code a few months ago idk if that matter but regardless i copied the code so it’s gotta be correct, however idk what u meant i should do i i gotta remove a certain line in my code to get it working? This code https://api.telegram.org/bot<YOUR_BOT_TOKEN>/getMe ? just want the connection from esp32 to telegram
Your original question was about connecting to Telegram, which requires HTTPS. Now you are getting a 401 in the response, which proves you have a connection. That 401 is unrelated to Arduino programming with your ESP32.
One basic concept for using web APIs is that you can make those calls with a variety of agents. The advantage of using the /getMe is that it is a GET, which is simpler than a POST. Because of the lack of other requirements, you should be able to type that URL and press Enter directly in your browser, as long as you have a valid token to substitute, as indicated.
When security credentials are invalid for whatever reason, it is standard security practice for the service to simply say "no that doesn't work" -- the 401 Unauthorized in that response you got -- without providing details. This makes it harder for those trying to gain illegitimate access.
Having solved your connection problem, you now need to solve that 401. And again, as I said -- again -- the first thing to try is to get a new token. Determine whether tokens expire, and if so, when that will be next. Then
  1. Once you get a token that actually works with /getMe in the browser
  2. Make a copy of your now-connecting Arduino code and reproduce the /getMe results
  3. Then try that token with /sendPhoto, with the code you already have
Which url are you talking about? Is it my ip address which i get when connecting to wifi that i gotta type in my browser? you should be able to type that URL and press Enter directly in your browser
The API call. The /getMe URL. The one you pasted in post #36, with the appropriate token substituted as indicated.
Your token is invalid. It will be easier to get that working outside Arduino first.
so how do i test if my telegram bot work? botfather gave me this message
access http API: 16165165165161
161616... Is what i copied is that wrong? is it because this token is 3 months old?
Also my telegram bot doesn't respond when i send /start or /photo like how do i fix this ?
That /getMe call is what can you use to test if you can access your bot. The tutorial page I linked earlier says
The expired token you posted earlier did look like that; but 1616... does not. I noticed that when you insert something that doesn't look like a token, you get a 404 in the response instead.
That's the extent of my Telegram knowledge. It might be easier to create a new bot and get a new token. Good luck.
hey i got it wokring with a different code but i think the code itself was bad
