Hi everybody,
I started to code a demo-code which uses an MCP4922 12bit dual channel DAC together with an ESP32.
So I installed the MCP_DAC-library through the library-manager.
I adjust the board-selection to ESP32_DEV-module
rob Tillaard added ESP32-support like this
in the MCP_DAC-header-file
MCP_DAC/MCP_DAC.h at master · RobTillaart/MCP_DAC · GitHub there is
// ESP32 specific
#if defined(ESP32)
void selectHSPI() { _useHSPI = true; };
void selectVSPI() { _useHSPI = false; };
bool usesHSPI() { return _useHSPI; };
bool usesVSPI() { return !_useHSPI; };
// to overrule ESP32 default hw pins...
void setGPIOpins(uint8_t clk, uint8_t miso, uint8_t mosi, uint8_t select);
#endif
but If I try to compile a slightly modifyed
MCP4921 example code from here
The compiler complains
exit status 1
'selectVSPI' was not declared in this scope
Full compiler-output
Arduino: 1.8.13 (Windows 10), TD: 1.53, Board: "ESP32 Dev Module, Disabled, Default 4MB with spiffs (1.2MB APP/1.5MB SPIFFS), 240MHz (WiFi/BT), QIO, 80MHz, 4MB (32Mb), 921600, None"
F:\MyPortable-PRgs\arduino1.8.13\arduino-builder -dump-prefs -logger=machine -hardware F:\MyPortable-PRgs\arduino1.8.13\hardware -hardware F:\MyPortable-PRgs\arduino1.8.13\portable\packages -hardware F:\MyPortable-PRgs\arduino1.8.13\portable\sketchbook\hardware -tools F:\MyPortable-PRgs\arduino1.8.13\tools-builder -tools F:\MyPortable-PRgs\arduino1.8.13\hardware\tools\avr -tools F:\MyPortable-PRgs\arduino1.8.13\portable\packages -libraries F:\MyPortable-PRgs\arduino1.8.13\portable\sketchbook\libraries -fqbn=esp32:esp32:esp32:PSRAM=disabled,PartitionScheme=default,CPUFreq=240,FlashMode=qio,FlashFreq=80,FlashSize=4M,UploadSpeed=921600,DebugLevel=none -vid-pid=10C4_EA60 -ide-version=10813 -build-path C:\Users\dipl-\AppData\Local\Temp\arduino_build_546627 -warnings=all -build-cache C:\Users\dipl-\AppData\Local\Temp\arduino_cache_477629 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.esptool_py.path=F:\MyPortable-PRgs\arduino1.8.13\portable\packages\esp32\tools\esptool_py\3.0.0 -prefs=runtime.tools.esptool_py-3.0.0.path=F:\MyPortable-PRgs\arduino1.8.13\portable\packages\esp32\tools\esptool_py\3.0.0 -prefs=runtime.tools.xtensa-esp32-elf-gcc.path=F:\MyPortable-PRgs\arduino1.8.13\portable\packages\esp32\tools\xtensa-esp32-elf-gcc\1.22.0-97-gc752ad5-5.2.0 -prefs=runtime.tools.xtensa-esp32-elf-gcc-1.22.0-97-gc752ad5-5.2.0.path=F:\MyPortable-PRgs\arduino1.8.13\portable\packages\esp32\tools\xtensa-esp32-elf-gcc\1.22.0-97-gc752ad5-5.2.0 -prefs=runtime.tools.mkspiffs.path=F:\MyPortable-PRgs\arduino1.8.13\portable\packages\esp32\tools\mkspiffs\0.2.3 -prefs=runtime.tools.mkspiffs-0.2.3.path=F:\MyPortable-PRgs\arduino1.8.13\portable\packages\esp32\tools\mkspiffs\0.2.3 -verbose F:\MyPortable-PRgs\arduino1.8.13\portable\sketchbook\MCP4911_test-Lu-001\MCP4911_test-Lu-001.ino
F:\MyPortable-PRgs\arduino1.8.13\arduino-builder -compile -logger=machine -hardware F:\MyPortable-PRgs\arduino1.8.13\hardware -hardware F:\MyPortable-PRgs\arduino1.8.13\portable\packages -hardware F:\MyPortable-PRgs\arduino1.8.13\portable\sketchbook\hardware -tools F:\MyPortable-PRgs\arduino1.8.13\tools-builder -tools F:\MyPortable-PRgs\arduino1.8.13\hardware\tools\avr -tools F:\MyPortable-PRgs\arduino1.8.13\portable\packages -libraries F:\MyPortable-PRgs\arduino1.8.13\portable\sketchbook\libraries -fqbn=esp32:esp32:esp32:PSRAM=disabled,PartitionScheme=default,CPUFreq=240,FlashMode=qio,FlashFreq=80,FlashSize=4M,UploadSpeed=921600,DebugLevel=none -vid-pid=10C4_EA60 -ide-version=10813 -build-path C:\Users\dipl-\AppData\Local\Temp\arduino_build_546627 -warnings=all -build-cache C:\Users\dipl-\AppData\Local\Temp\arduino_cache_477629 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.esptool_py.path=F:\MyPortable-PRgs\arduino1.8.13\portable\packages\esp32\tools\esptool_py\3.0.0 -prefs=runtime.tools.esptool_py-3.0.0.path=F:\MyPortable-PRgs\arduino1.8.13\portable\packages\esp32\tools\esptool_py\3.0.0 -prefs=runtime.tools.xtensa-esp32-elf-gcc.path=F:\MyPortable-PRgs\arduino1.8.13\portable\packages\esp32\tools\xtensa-esp32-elf-gcc\1.22.0-97-gc752ad5-5.2.0 -prefs=runtime.tools.xtensa-esp32-elf-gcc-1.22.0-97-gc752ad5-5.2.0.path=F:\MyPortable-PRgs\arduino1.8.13\portable\packages\esp32\tools\xtensa-esp32-elf-gcc\1.22.0-97-gc752ad5-5.2.0 -prefs=runtime.tools.mkspiffs.path=F:\MyPortable-PRgs\arduino1.8.13\portable\packages\esp32\tools\mkspiffs\0.2.3 -prefs=runtime.tools.mkspiffs-0.2.3.path=F:\MyPortable-PRgs\arduino1.8.13\portable\packages\esp32\tools\mkspiffs\0.2.3 -verbose F:\MyPortable-PRgs\arduino1.8.13\portable\sketchbook\MCP4911_test-Lu-001\MCP4911_test-Lu-001.ino
Using board 'esp32' from platform in folder: F:\MyPortable-PRgs\arduino1.8.13\portable\packages\esp32\hardware\esp32\1.0.6
Using core 'esp32' from platform in folder: F:\MyPortable-PRgs\arduino1.8.13\portable\packages\esp32\hardware\esp32\1.0.6
cmd /c if exist "F:\\MyPortable-PRgs\\arduino1.8.13\\portable\\sketchbook\\MCP4911_test-Lu-001\\partitions.csv" copy /y "F:\\MyPortable-PRgs\\arduino1.8.13\\portable\\sketchbook\\MCP4911_test-Lu-001\\partitions.csv" "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino_build_546627\\partitions.csv"
cmd /c if not exist "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino_build_546627\\partitions.csv" copy "F:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6\\tools\\partitions\\default.csv" "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino_build_546627\\partitions.csv"
Detecting libraries used...
"F:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\1.22.0-97-gc752ad5-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DHAVE_CONFIG_H -DGCC_NOT_5_2_0=0 -DWITH_POSIX "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/config" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/app_trace" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/app_update" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/asio" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/bootloader_support" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/bt" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/coap" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/console" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/driver" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/efuse" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp-tls" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp32" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_adc_cal" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_event" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_http_client" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_http_server" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_https_ota" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_https_server" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_ringbuf" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_websocket_client" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/espcoredump" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/ethernet" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/expat" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/fatfs" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/freemodbus" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/freertos" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/heap" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/idf_test" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/jsmn" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/json" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/libsodium" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/log" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/lwip" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/mbedtls" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/mdns" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/micro-ecc" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/mqtt" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/newlib" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/nghttp" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/nvs_flash" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/openssl" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/protobuf-c" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/protocomm" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/pthread" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/sdmmc" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/smartconfig_ack" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/soc" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/spi_flash" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/spiffs" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/tcp_transport" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/tcpip_adapter" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/ulp" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/unity" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/vfs" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/wear_levelling" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/wifi_provisioning" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/wpa_supplicant" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/xtensa-debug-module" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp-face" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp32-camera" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp-face" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/fb_gfx" -std=gnu++11 -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=maybe-uninitialized -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-unused-but-set-parameter -Wno-missing-field-initializers -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10813 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_DEV\"" "-DARDUINO_VARIANT=\"esp32\"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6\\cores\\esp32" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6\\variants\\esp32" "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino_build_546627\\sketch\\MCP4911_test-Lu-001.ino.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
Alternatives for MCP_DAC.h: [MCP_DAC@0.1.2]
ResolveLibrary(MCP_DAC.h)
-> candidates: [MCP_DAC@0.1.2]
"F:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\1.22.0-97-gc752ad5-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DHAVE_CONFIG_H -DGCC_NOT_5_2_0=0 -DWITH_POSIX "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/config" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/app_trace" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/app_update" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/asio" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/bootloader_support" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/bt" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/coap" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/console" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/driver" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/efuse" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp-tls" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp32" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_adc_cal" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_event" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_http_client" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_http_server" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_https_ota" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_https_server" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_ringbuf" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_websocket_client" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/espcoredump" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/ethernet" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/expat" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/fatfs" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/freemodbus" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/freertos" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/heap" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/idf_test" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/jsmn" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/json" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/libsodium" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/log" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/lwip" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/mbedtls" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/mdns" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/micro-ecc" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/mqtt" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/newlib" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/nghttp" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/nvs_flash" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/openssl" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/protobuf-c" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/protocomm" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/pthread" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/sdmmc" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/smartconfig_ack" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/soc" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/spi_flash" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/spiffs" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/tcp_transport" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/tcpip_adapter" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/ulp" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/unity" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/vfs" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/wear_levelling" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/wifi_provisioning" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/wpa_supplicant" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/xtensa-debug-module" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp-face" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp32-camera" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp-face" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/fb_gfx" -std=gnu++11 -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=maybe-uninitialized -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-unused-but-set-parameter -Wno-missing-field-initializers -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10813 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_DEV\"" "-DARDUINO_VARIANT=\"esp32\"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6\\cores\\esp32" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6\\variants\\esp32" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\sketchbook\\libraries\\MCP_DAC" "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino_build_546627\\sketch\\MCP4911_test-Lu-001.ino.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
Alternatives for SPI.h: [SPI@1.0]
ResolveLibrary(SPI.h)
-> candidates: [SPI@1.0]
"F:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\1.22.0-97-gc752ad5-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DHAVE_CONFIG_H -DGCC_NOT_5_2_0=0 -DWITH_POSIX "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/config" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/app_trace" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/app_update" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/asio" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/bootloader_support" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/bt" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/coap" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/console" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/driver" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/efuse" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp-tls" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp32" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_adc_cal" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_event" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_http_client" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_http_server" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_https_ota" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_https_server" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_ringbuf" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_websocket_client" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/espcoredump" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/ethernet" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/expat" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/fatfs" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/freemodbus" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/freertos" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/heap" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/idf_test" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/jsmn" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/json" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/libsodium" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/log" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/lwip" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/mbedtls" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/mdns" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/micro-ecc" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/mqtt" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/newlib" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/nghttp" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/nvs_flash" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/openssl" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/protobuf-c" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/protocomm" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/pthread" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/sdmmc" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/smartconfig_ack" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/soc" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/spi_flash" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/spiffs" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/tcp_transport" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/tcpip_adapter" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/ulp" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/unity" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/vfs" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/wear_levelling" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/wifi_provisioning" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/wpa_supplicant" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/xtensa-debug-module" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp-face" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp32-camera" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp-face" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/fb_gfx" -std=gnu++11 -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=maybe-uninitialized -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-unused-but-set-parameter -Wno-missing-field-initializers -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10813 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_DEV\"" "-DARDUINO_VARIANT=\"esp32\"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6\\cores\\esp32" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6\\variants\\esp32" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\sketchbook\\libraries\\MCP_DAC" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6\\libraries\\SPI\\src" "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino_build_546627\\sketch\\MCP4911_test-Lu-001.ino.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
"F:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\1.22.0-97-gc752ad5-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DHAVE_CONFIG_H -DGCC_NOT_5_2_0=0 -DWITH_POSIX "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/config" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/app_trace" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/app_update" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/asio" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/bootloader_support" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/bt" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/coap" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/console" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/driver" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/efuse" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp-tls" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp32" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_adc_cal" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_event" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_http_client" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_http_server" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_https_ota" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_https_server" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_ringbuf" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_websocket_client" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/espcoredump" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/ethernet" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/expat" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/fatfs" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/freemodbus" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/freertos" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/heap" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/idf_test" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/jsmn" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/json" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/libsodium" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/log" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/lwip" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/mbedtls" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/mdns" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/micro-ecc" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/mqtt" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/newlib" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/nghttp" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/nvs_flash" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/openssl" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/protobuf-c" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/protocomm" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/pthread" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/sdmmc" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/smartconfig_ack" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/soc" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/spi_flash" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/spiffs" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/tcp_transport" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/tcpip_adapter" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/ulp" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/unity" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/vfs" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/wear_levelling" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/wifi_provisioning" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/wpa_supplicant" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/xtensa-debug-module" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp-face" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp32-camera" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp-face" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/fb_gfx" -std=gnu++11 -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=maybe-uninitialized -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-unused-but-set-parameter -Wno-missing-field-initializers -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10813 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_DEV\"" "-DARDUINO_VARIANT=\"esp32\"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6\\cores\\esp32" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6\\variants\\esp32" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\sketchbook\\libraries\\MCP_DAC" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6\\libraries\\SPI\\src" "F:\\MyPortable-PRgs\\arduino1.8.13\\portable\\sketchbook\\libraries\\MCP_DAC\\MCP_DAC.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
"F:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\1.22.0-97-gc752ad5-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DHAVE_CONFIG_H -DGCC_NOT_5_2_0=0 -DWITH_POSIX "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/config" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/app_trace" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/app_update" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/asio" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/bootloader_support" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/bt" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/coap" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/console" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/driver" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/efuse" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp-tls" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp32" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_adc_cal" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_event" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_http_client" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_http_server" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_https_ota" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_https_server" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_ringbuf" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_websocket_client" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/espcoredump" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/ethernet" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/expat" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/fatfs" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/freemodbus" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/freertos" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/heap" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/idf_test" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/jsmn" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/json" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/libsodium" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/log" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/lwip" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/mbedtls" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/mdns" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/micro-ecc" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/mqtt" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/newlib" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/nghttp" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/nvs_flash" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/openssl" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/protobuf-c" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/protocomm" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/pthread" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/sdmmc" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/smartconfig_ack" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/soc" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/spi_flash" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/spiffs" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/tcp_transport" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/tcpip_adapter" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/ulp" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/unity" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/vfs" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/wear_levelling" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/wifi_provisioning" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/wpa_supplicant" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/xtensa-debug-module" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp-face" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp32-camera" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp-face" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/fb_gfx" -std=gnu++11 -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=maybe-uninitialized -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-unused-but-set-parameter -Wno-missing-field-initializers -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10813 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_DEV\"" "-DARDUINO_VARIANT=\"esp32\"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6\\cores\\esp32" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6\\variants\\esp32" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\sketchbook\\libraries\\MCP_DAC" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6\\libraries\\SPI\\src" "F:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6\\libraries\\SPI\\src\\SPI.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
Generating function prototypes...
"F:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\1.22.0-97-gc752ad5-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DHAVE_CONFIG_H -DGCC_NOT_5_2_0=0 -DWITH_POSIX "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/config" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/app_trace" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/app_update" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/asio" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/bootloader_support" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/bt" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/coap" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/console" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/driver" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/efuse" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp-tls" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp32" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_adc_cal" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_event" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_http_client" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_http_server" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_https_ota" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_https_server" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_ringbuf" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_websocket_client" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/espcoredump" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/ethernet" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/expat" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/fatfs" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/freemodbus" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/freertos" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/heap" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/idf_test" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/jsmn" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/json" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/libsodium" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/log" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/lwip" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/mbedtls" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/mdns" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/micro-ecc" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/mqtt" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/newlib" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/nghttp" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/nvs_flash" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/openssl" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/protobuf-c" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/protocomm" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/pthread" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/sdmmc" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/smartconfig_ack" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/soc" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/spi_flash" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/spiffs" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/tcp_transport" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/tcpip_adapter" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/ulp" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/unity" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/vfs" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/wear_levelling" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/wifi_provisioning" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/wpa_supplicant" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/xtensa-debug-module" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp-face" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp32-camera" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp-face" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/fb_gfx" -std=gnu++11 -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=maybe-uninitialized -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-unused-but-set-parameter -Wno-missing-field-initializers -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10813 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_DEV\"" "-DARDUINO_VARIANT=\"esp32\"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6\\cores\\esp32" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6\\variants\\esp32" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\sketchbook\\libraries\\MCP_DAC" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6\\libraries\\SPI\\src" "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino_build_546627\\sketch\\MCP4911_test-Lu-001.ino.cpp" -o "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino_build_546627\\preproc\\ctags_target_for_gcc_minus_e.cpp" -DARDUINO_LIB_DISCOVERY_PHASE
"F:\\MyPortable-PRgs\\arduino1.8.13\\tools-builder\\ctags\\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino_build_546627\\preproc\\ctags_target_for_gcc_minus_e.cpp"
Sketch wird kompiliert...
"F:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\1.22.0-97-gc752ad5-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DHAVE_CONFIG_H -DGCC_NOT_5_2_0=0 -DWITH_POSIX "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/config" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/app_trace" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/app_update" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/asio" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/bootloader_support" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/bt" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/coap" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/console" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/driver" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/efuse" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp-tls" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp32" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_adc_cal" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_event" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_http_client" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_http_server" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_https_ota" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_https_server" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_ringbuf" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_websocket_client" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/espcoredump" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/ethernet" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/expat" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/fatfs" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/freemodbus" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/freertos" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/heap" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/idf_test" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/jsmn" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/json" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/libsodium" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/log" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/lwip" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/mbedtls" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/mdns" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/micro-ecc" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/mqtt" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/newlib" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/nghttp" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/nvs_flash" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/openssl" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/protobuf-c" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/protocomm" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/pthread" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/sdmmc" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/smartconfig_ack" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/soc" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/spi_flash" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/spiffs" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/tcp_transport" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/tcpip_adapter" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/ulp" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/unity" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/vfs" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/wear_levelling" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/wifi_provisioning" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/wpa_supplicant" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/xtensa-debug-module" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp-face" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp32-camera" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp-face" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/fb_gfx" -std=gnu++11 -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -Wall -Werror=all -Wextra -Wno-error=maybe-uninitialized -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-unused-but-set-parameter -Wno-missing-field-initializers -Wno-sign-compare -fno-rtti -MMD -c -DF_CPU=240000000L -DARDUINO=10813 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_DEV\"" "-DARDUINO_VARIANT=\"esp32\"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6\\cores\\esp32" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6\\variants\\esp32" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\sketchbook\\libraries\\MCP_DAC" "-IF:\\MyPortable-PRgs\\arduino1.8.13\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6\\libraries\\SPI\\src" "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino_build_546627\\sketch\\MCP4911_test-Lu-001.ino.cpp" -o "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino_build_546627\\sketch\\MCP4911_test-Lu-001.ino.cpp.o"
F:\MyPortable-PRgs\arduino1.8.13\portable\sketchbook\MCP4911_test-Lu-001\MCP4911_test-Lu-001.ino:21:0: warning: "ESP32" redefined
#define ESP32 true
<command-line>:0:0: note: this is the location of the previous definition
F:\MyPortable-PRgs\arduino1.8.13\portable\sketchbook\MCP4911_test-Lu-001\MCP4911_test-Lu-001.ino: In function 'void setup()':
MCP4911_test-Lu-001:37:14: error: 'selectVSPI' was not declared in this scope
selectVSPI();
MCP4911_test-Lu-001:39:27: error: 'usesVSPI' was not declared in this scope
Serial.println(usesVSPI());
Bibliothek MCP_DAC in Version 0.1.2 im Ordner: F:\MyPortable-PRgs\arduino1.8.13\portable\sketchbook\libraries\MCP_DAC wird verwendet
Bibliothek SPI in Version 1.0 im Ordner: F:\MyPortable-PRgs\arduino1.8.13\portable\packages\esp32\hardware\esp32\1.0.6\libraries\SPI wird verwendet
exit status 1
So to me it seems that the condition
#if defined(ESP32)
void selectHSPI() { _useHSPI = true; };...
evaluates to false.
So how can I check if ESP32 is defined?
or if I can't check it how can I add a line to achieve that this if-condition evaluates to true?
of course a quick & dirty work-around is to remove the if defined. But I want to keep the library itself "clean"
my code
#define dbg(myFixedText, variableName) \
Serial.print( F(#myFixedText " " #variableName"=") ); \
Serial.println(variableName);
// usage: dbg("1:my fixed text",myVariable);
// myVariable can be any variable or expression that is defined in scope
#define dbgi(myFixedText, variableName,timeInterval) \
do { \
static unsigned long intervalStartTime; \
if ( millis() - intervalStartTime >= timeInterval ){ \
intervalStartTime = millis(); \
Serial.println(variableName); \
} while (false);
// usage: dbgi("2:my fixed text",myVar,myInterval);
// myVar can be any variable or expression that is defined in scope
// myInterval is the time-interval which must pass by before the next
// print is executed
#define ESP32 true
#include "MCP_DAC.h"
// MCP4911 MCP(11, 13); // SW SPI
MCP4922 MCP; // HW SPI
volatile int x;
uint32_t start, stop;
Serial.println(__FILE__);
Serial.print("SPI:\t");
Serial.println(MCP.usesHWSPI());
selectVSPI();
Serial.print("selectVSPI()\t");
MCP.begin(10);
Serial.print("MCP_DAC_LIB_VERSION: ");
Serial.println(MCP_DAC_LIB_VERSION);
Serial.print("CHANNELS:\t");
Serial.println(MCP.channels());
Serial.print("MAXVALUE:\t");
Serial.println(MCP.maxValue());
delay(100);
performance_test();
analogWrite_test();
Serial.println("\nDone...");
void analogWrite_test()
Serial.println(__FUNCTION__);
for (int channel = 0; channel < MCP.channels(); channel++)
Serial.println(channel);
for (uint16_t value = 0; value < MCP.maxValue(); value += 0xFF)
MCP.analogWrite(value, channel);
Serial.print(value);
Serial.print("\t");
Serial.println(analogRead(A0));
delay(10);
void performance_test()
start = micros();
for (uint16_t value = 0; value < MCP.maxValue(); value++)
x = MCP.analogWrite(value, 0);
stop = micros();
Serial.print(MCP.maxValue());
Serial.print(" x MCP.analogWrite():\t");
Serial.print(stop - start);
Serial.print("\t");
Serial.println((stop - start) / (MCP.maxValue() + 1.0) );
delay(10);
start = micros();
MCP.fastWriteA(value);
stop = micros();
Serial.print(" x MCP.fastWriteA():\t");
Serial.print("\t");
delay(10);
// -- END OF FILE --
best regards Stefan
