ESP32-WROOM_32 vs ESP32-WROOM-32E
Hello everyone!
In my project I use ESP32-WROOM-32.
For the first two boards, the programming went smoothly with the specified module (in the picture marked 1).
I use a mini-nova programmer based on CP210x with added transistors for BOOT and RESET. In addition, I added two buttons to it in case of need (marked 3 in the picture).
After successful testing I made 6 identical devices, the only difference is the module. Now it is ESP32-WROOM-32E (board number 2). My supplier says these modules are fully compatible and I found that in the documentation as well.
However, this is not the case.
I never get a response from the module. Nothing is displayed in the terminal when I press BOOT or create a BOOT-RESET-BOOT sequence.
That awful message "A fatal error occurred: Failed to connect to ESP32: Timed out waiting for packet header" comes out when I try to program.
I disconnected all peripherals from the module, only the necessary for programming remained and again negative.
Has anyone had similar experiences and how do I resolve this?
Photo: 002 — Postimages
ESPRESSIF makes the ESP32. Perhaps asking them about the chip they make? Clickly, clicky for the ESPRESSIF site
Solved, problem was LED connected at RX line in my programmer what make DC offset so 0 in received serial signal from ESP was 1.1V. Without this LED 0 is correct (0V).
