ESP32 xiao s3 v1.2 Seeed Studio TX and RX pins
Hi friends !
This board ESP32 xiao s3 v1.2 Seeedstudio is almost new in market and there are some troubles that i faced while i was first using it. I would like to leave this post to other people who have faced the same problems and thank to the Arduino Forum for allowing us to enjoy this awesome platform:
1) Regarding to TX and RX pins: if you want to use Serial communication with TX and RX pins you must use
//Ensure you put letter D before the pin number. Otherwise it won't work
#define RX_PIN D7
#define TX_PIN D6
void setup(){
 Serial1.begin(115200,SERIAL_8N1,RX_PIN,TX_PIN);
void loop(){
//Proceed to read or write the data coming from
//TX and RX pins
-Otherwise if you only will use Serial communication by USB wire you must use the standard Serial.begin(115200);
void setup(){
void loop(){
//Proceed to log data into Serial Monitor with Serial.println()
//or Serial.read();
2) Regarding to see data from TX and RX pins in serial monitor: you must initialize both as follows:
#define RX_PIN D7
#define TX_PIN D6
void setup(){
 Serial.begin(115200);               //Data sent to PC
 Serial1.begin(115200,SERIAL_8N1,RX_PIN,TX_PIN);   //Data read by ESP32S3 XIAO
void loop(){
//TX and RX pins and send to Serial Monitor via USB
if(Serial1.available()){
  Serial.println(Serial1.read());
Can you provide a link to the module you are discussing ?
@k2k1 , Thanks for your sharing information.
We can find here:
And similar discussion:
https://forum.arduino.cc/t/esp32-xiao-s3-seeedstudio-v1-2-and-pms5003-not-working/
Thank you so much! I've been stuck trying to figure this out for hours.
