Hey guys i have been working on a project in which the analog values sampled at a particular frequency and stored in array. Then the value will be sent to user application ESP32 BLE. But I got stuck in this error.
/home/runner/work/esp32-arduino-lib-builder/esp32-arduino-lib-builder/esp-idf/components/freertos/queue.c:1443 (xQueueGenericReceive)- assert failed! abort() was called at PC 0x4008e1d5 on core 1
Backtrace: 0x40091b38:0x3ffe0b20 0x40091d69:0x3ffe0b40 0x4008e1d5:0x3ffe0b60 0x400d1a2d:0x3ffe0ba0 0x4008e525:0x3ffe0be0
Rebooting... ets Jun 8 2016 00:22:57
rst:0xc (SW_CPU_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT) configsip: 0, SPIWP:0xee clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00 mode:DIO, clock div:1 load:0x3fff0018,len:4 load:0x3fff001c,len:1044 load:0x40078000,len:8896 load:0x40080400,len:5816 entry 0x400806ac
I am Using Esp32arduino and Free Rtos for programming i error is in the semaphore from the interrupt but i couldn't able to find out exact solution. Please help me out guys
#include <ArduinoJson.h> #include <BLEDevice.h> #include <BLEServer.h> #include <BLEUtils.h> #include <BLE2902.h>
#if CONFIG_FREERTOS_UNICORE
static const BaseType_t app_cpu = 0;
#else
static const BaseType_t app_cpu = 1;
#endif//ADC Related Global Variables
static const uint16_t timer_divider =80;
static const uint64_t timer_max_count=1000;static const int adc_pin=A0;
static const int BUF_SIZE=1000;
static int buf[BUF_SIZE];
int Buff_Len=0;
static int Read=0;
static int Write=0;
static int count=0;
static float avg=0;
int i=0;
int BLE_flag=0;
String cmd;static hw_timer_t *timer=NULL;
static uint16_t val;
static int count1=0;static SemaphoreHandle_t bin_sem=NULL;
static SemaphoreHandle_t bin_sem2=NULL;
static portMUX_TYPE spinlock = portMUX_INITIALIZER_UNLOCKED;
//ADC Related Global Variables//BLE Global Variable
char Reading[4];
BLEServer *pServer = NULL;
BLECharacteristic * pTxCharacteristic;
bool deviceConnected = false;
bool oldDeviceConnected = false;//Declaration BLE necessary Classes
#define SERVICE_UUID "6E400001-B5A3-F393-E0A9-E50E24DCCA9E" // UART service UUID
#define CHARACTERISTIC_UUID_TX "6E400003-B5A3-F393-E0A9-E50E24DCCA9E"class MyServerCallbacks: public BLEServerCallbacks {
void onConnect(BLEServer* pServer) {
deviceConnected = true;
};void onDisconnect(BLEServer* pServer) {
}; //BLE Global Variables//Task Section
void IRAM_ATTR onTimer()
//samplingxSemaphoreGiveFromISR(bin_sem2,&task_woken);
if (task_woken) {
portYIELD_FROM_ISR();
}void move_to_Queue (void *parameters)
while(1)
xSemaphoreTake(bin_sem2,portMAX_DELAY);if(Buff_Len==BUF_SIZE||count1>2000)
Serial.println("Buffer is full");
xSemaphoreGive(bin_sem);}
// storing the instantaneous sample value to buffer
}void BLE_Task(void *parameters)
{ while(1) {xSemaphoreTake(bin_sem,portMAX_DELAY);
Serial.println("BLE");
// sending the data\lu
delay(10); // bluetooth stack will go into congestion, if too many packets are sent
Serial.println();}
}void setup()
vTaskDelay(1000/portTICK_PERIOD_MS);//BLE Declarations BLEDevice::init("UART Service" ); pServer = BLEDevice::createServer(); pServer->setCallbacks(new MyServerCallbacks()); BLEService *pService = pServer->createService(SERVICE_UUID); pTxCharacteristic = pService->createCharacteristic( CHARACTERISTIC_UUID_TX, BLECharacteristic::PROPERTY_NOTIFY ); pTxCharacteristic->addDescriptor(new BLE2902()); pService->start(); pServer->getAdvertising()->start(); Serial.println("Waiting a client connection to notify..."); //BLE Declaration //ADC Semaphore and Timer Declarations bin_sem = xSemaphoreCreateBinary(); bin_sem2 = xSemaphoreCreateBinary(); if(bin_sem==NULL||bin_sem2==NULL) { Serial.println("Could not create semaphore"); ESP.restart(); } xTaskCreatePinnedToCore(move_to_Queue, "move_to_Queue", 1024, NULL, 2, NULL, app_cpu); xTaskCreatePinnedToCore(BLE_Task, "BLE_Task", 2048, NULL, 2, NULL, app_cpu); timer = timerBegin(0, timer_divider, true); // Provide ISR to timer (timer, function, edge) timerAttachInterrupt(timer, &onTimer, true); // At what count should ISR trigger (timer, count, autoreload) timerAlarmWrite(timer, timer_max_count, true); // Allow ISR to trigger timerAlarmEnable(timer); vTaskDelete(NULL);
Thanks in advance guys
