ESP32Cam
ESP32Cam Won't OTA! - "No response from ESP"
Platform using Windows 8.1 pro
OTA won't connect - Chrome on port 3232 says refused, pings fine from my nobile on wifi....
Worked fine prior on USB power and working as the camera server... doesn't like OTA
That module is listed in ports
Tried reseting it, now using a dedicated PSU brick to 5V.
Do I need to ground D0?! Thats stupid if so... didn't work, before I moved to brick.
Checked that espota.exe is on private exception in firewall.
only shows HTTPD no 3232
Shit - now only UI shows on http, no streams show
Here is where the error comes from in espota.py:
def serve(remoteAddr, localAddr, remotePort, localPort, password, filename, command = FLASH):
# Create a TCP/IP socket
sock = socket.socket(socket.AF_INET, socket.SOCK_STREAM)
server_address = (localAddr, localPort)
logging.info('Starting on %s:%s', str(server_address[0]), str(server_address[1]))
try:
sock.bind(server_address)
sock.listen(1)
except:
logging.error("Listen Failed")
return 1
content_size = os.path.getsize(filename)
f = open(filename,'rb')
file_md5 = hashlib.md5(f.read()).hexdigest()
f.close()
logging.info('Upload size: %d', content_size)
message = '%d %d %d %s\n' % (command, localPort, content_size, file_md5)
# Wait for a connection
inv_trys = 0
data = ''
msg = 'Sending invitation to %s ' % (remoteAddr)
sys.stderr.write(msg)
sys.stderr.flush()
while (inv_trys < 10):
inv_trys += 1
sock2 = socket.socket(socket.AF_INET, socket.SOCK_DGRAM)
remote_address = (remoteAddr, int(remotePort))
try:
sent = sock2.sendto(message.encode(), remote_address)
except:
sys.stderr.write('failed\n')
sys.stderr.flush()
sock2.close()
logging.error('Host %s Not Found', remoteAddr)
return 1
sock2.settimeout(TIMEOUT)
try:
data = sock2.recv(37).decode()
except:
sys.stderr.write('.')
sys.stderr.flush()
sock2.close()
sys.stderr.write('\n')
sys.stderr.flush()
if (inv_trys == 10):
logging.error('No response from the ESP')
return 1
Just what I uploaded via the USB> 8266 shorted to reset > It;s cp2102 USB-UART > Tx , Rx > ESP32Cam Tx , Rx...
#include <WiFi.h>
#include <WiFiUdp.h>
#include <ArduinoOTA.h>
const char* ssid = "JMR";
const char* password = "crystal2965";
Serial.println("Booting");
WiFi.mode(WIFI_STA);
WiFi.begin(ssid, password);
while (WiFi.waitForConnectResult() != WL_CONNECTED) {
Serial.println("Connection Failed! Rebooting...");
delay(5000);
ESP.restart();
// Port defaults to 3232
// ArduinoOTA.setPort(3232);
// Hostname defaults to esp3232-[MAC]
// ArduinoOTA.setHostname("myesp32");
// No authentication by default
// ArduinoOTA.setPassword("admin");
// Password can be set with it's md5 value as well
// MD5(admin) = 21232f297a57a5a743894a0e4a801fc3
// ArduinoOTA.setPasswordHash("21232f297a57a5a743894a0e4a801fc3");
ArduinoOTA.onStart([]() {
String type;
if (ArduinoOTA.getCommand() == U_FLASH)
type = "sketch";
else // U_SPIFFS
type = "filesystem";
// NOTE: if updating SPIFFS this would be the place to unmount SPIFFS using SPIFFS.end()
Serial.println("Start updating " + type);
ArduinoOTA.onEnd([]() {
Serial.println("\nEnd");
ArduinoOTA.onProgress([](unsigned int progress, unsigned int total) {
Serial.printf("Progress: %u%%\r", (progress / (total / 100)));
ArduinoOTA.onError([](ota_error_t error) {
Serial.printf("Error[%u]: ", error);
if (error == OTA_AUTH_ERROR) Serial.println("Auth Failed");
else if (error == OTA_BEGIN_ERROR) Serial.println("Begin Failed");
else if (error == OTA_CONNECT_ERROR) Serial.println("Connect Failed");
else if (error == OTA_RECEIVE_ERROR) Serial.println("Receive Failed");
else if (error == OTA_END_ERROR) Serial.println("End Failed");
ArduinoOTA.begin();
Serial.println("Ready");
Serial.print("IP address: ");
ArduinoOTA.handle();
