I'm new to using the ESP8266 and just bought some from two different sources. Both are E12 versions. One is a "Makerfocus 2pcs ESP8266 Module ESP-12E NodeMcu LUA WiFi Internet New Version Development Board", Amazon.com
I updated to the Arduino IDE v1.8.5 and installed the 2.4.1 ESP8266 drivers under the Board Manager.
I've tried several different examples to get the boards going and sometimes they work like they are supposed too. However, I cannot consistently connect to them. I get a "Can't Connect to Network" error from my laptop, tablet and cell phone. But then after trying a bunch of times it will connect. Once it connects it seems to reconnect fairly regularly, but if I upload a different sketch it will become difficult to reconnect again, even with the same IP Address and Password.
Here is an example of code I've tried:
/* Create a WiFi access point and provide a web server on it. *
** For more details see http://42bots.com.
#include <ESP8266WiFi.h>
#include <ESP8266WebServer.h>
IPAddress apIP(42, 42, 42, 42); // Defining a static IP address: local & gateway
// Default IP in AP mode is 192.168.4.1
/* This are the WiFi access point settings. Update them to your likin */
const char *ssid = "ESP8266";
const char *password = "ESP8266Test";
// Define a web server at port 80 for HTTP
ESP8266WebServer server(80);
const int ledPin = D1; // an LED is connected to NodeMCU pin D1 (ESP8266 GPIO5) via a 1K Ohm resistor
bool ledState = false;
void handleRoot() {
digitalWrite (LED_BUILTIN, 0); //turn the built in LED on pin DO of NodeMCU on
digitalWrite (ledPin, server.arg("led").toInt());
ledState = digitalRead(ledPin);
/* Dynamically generate the LED toggle link, based on its current state (on or off)*/
char ledText[80];
if (ledState) {
strcpy(ledText, "LED is on. <a href=\"/?led=0\">Turn it OFF!</a>");
else {
strcpy(ledText, "LED is OFF. <a href=\"/?led=1\">Turn it ON!</a>");
char html[1000];
int sec = millis() / 1000;
int min = sec / 60;
int hr = min / 60;
int brightness = analogRead(A0);
brightness = (int)(brightness + 5) / 10; //converting the 0-1024 value to a (approximately) percentage value
// Build an HTML page to display on the web-server root address
snprintf ( html, 1000,
"<html>\
<head>\
<meta http-equiv='refresh' content='10'/>\
<title>ESP8266 WiFi Network</title>\
<style>\
body { background-color: #cccccc; font-family: Arial, Helvetica, Sans-Serif; font-size: 1.5em; Color: #000000; }\
h1 { Color: #AA0000; }\
</style>\
</head>\
<body>\
<h1>ESP8266 Wi-Fi Access Point and Web Server Demo</h1>\
<p>Uptime: %02d:%02d:%02d</p>\
<p>Brightness: %d%</p>\
<p>%s<p>\
<p>This page refreshes every 10 seconds. Click <a href=\"javascript:window.location.reload();\">here</a> to refresh the page now.</p>\
</body>\
</html>",
hr, min % 60, sec % 60,
brightness,
ledText
server.send ( 200, "text/html", html );
digitalWrite ( LED_BUILTIN, 1 );
void handleNotFound() {
digitalWrite ( LED_BUILTIN, 0 );
String message = "File Not Found\n\n";
message += "URI: ";
message += server.uri();
message += "\nMethod: ";
message += ( server.method() == HTTP_GET ) ? "GET" : "POST";
message += "\nArguments: ";
message += server.args();
message += "\n";
for ( uint8_t i = 0; i < server.args(); i++ ) {
message += " " + server.argName ( i ) + ": " + server.arg ( i ) + "\n";
server.send ( 404, "text/plain", message );
digitalWrite ( LED_BUILTIN, 1 ); //turn the built in LED on pin DO of NodeMCU off
pinMode ( ledPin, OUTPUT );
digitalWrite ( ledPin, 0 );
Serial.println("Configuring access point...");
//set-up the custom IP address
WiFi.mode(WIFI_AP_STA);
WiFi.softAPConfig(apIP, apIP, IPAddress(255, 255, 255, 0)); // subnet FF FF FF 00
/* You can remove the password parameter if you want the AP to be open. */
WiFi.softAP(ssid, password);
IPAddress myIP = WiFi.softAPIP();
Serial.print("AP IP address: ");
Serial.println(myIP);
server.on ( "/", handleRoot );
server.on ( "/led=1", handleRoot);
server.on ( "/led=0", handleRoot);
server.on ( "/inline", []() {
server.send ( 200, "text/plain", "this works as well" );
server.onNotFound ( handleNotFound );
server.begin();
Serial.println("HTTP server started");
server.handleClient();
Anyone have any suggestions on what I might be doing wrong?
