ESP8266 MQTT Callback function not called
Hello
I am using esp8266 and MQTT.
I'm going to use publish and subscribe to output sensor values and switch toggle.
Outputting with 'publish' works well. However, 'subscribe' is ignored. Maybe the callback function is not called.
This is part of my code.
#include <ESP8266WiFi.h>
#include <PubSubClient.h> //MQTT
const char* mqtt_server = ""
const char* ssid = "";
const char* password =  "";
WiFiClient espClient;
PubSubClient client(espClient);
  //WiFi Server
  delay(10);
  // We start by connecting to a WiFi network
  Serial.print("Connecting to ");
  Serial.println(ssid);
  WiFi.begin(ssid, password);
  while (WiFi.status() != WL_CONNECTED)
    Serial.print(".");
  Serial.println("");
  Serial.println("WiFi connected");
  Serial.println("IP address: ");
  client.setServer(mqtt_server, 1883);
  client.setCallback(callback); //MOTT receive callback
  if (!client.connected()) //서버 연결 끊기면 다시 연결 대기
    reconnect();
        //Send to MQTT sensor value (success)
        sprintf(bpm_msg, "BMP : %d", beatAvg);
        client.publish("/bpm", bpm_msg);
        sprintf(spo2_msg, "SPO2 : %d", SPO2f);
        client.publish("/spo2", spo2_msg);
void reconnect()
  // Loop until we're reconnected
  while (!client.connected())
    Serial.print("Try MQTT connection...");
    // Attempt to connect
    if (client.connect("ESP8266Client"))
      Serial.println("connected");
      client.subscribe("/mode"); //received from mode topic
      Serial.print("failed, rc=");
      Serial.print(client.state());
      Serial.println(" try again in 5 seconds");
      // Wait 5 seconds before retrying
      delay(5000);
void callback(char* topic, byte* payload, unsigned int length) //call when received?
  Serial.print("Message arrived ["); //Not outputed!!
  Serial.print(topic);
  Serial.print("] ");
  String message;
  for (int i = 0; i < length; i++)
    Serial.print((char)payload[i]);
  //MQTT received
  if (topic == '/mode') //mode토픽에서 수신
    Serial.print("Status : ");
    if ((char)payload[0] == 'on')
      mode_state = 1;
      Serial.println("ON");
    if ((char)payload[0] == 'off')
      mode_state = 0;
      Serial.println("OFF");
And I used MQTT in Node RED.
On the dashboard, switch on/off control works well and outputs well to debug mqtt.
Can I get some help with this problem?
Thank you.
Often, Serial.print() will not work reliably in a call back routine, depending on how it is initiated.
You have to find some other way of debugging that routine.
Thank you for your answer!
I replaced ESP8266 with a different board and it worked strangely well. I'll have to test it a little bit more.
