Esp8266 nodemcu onboard led help me
Hello; I'm working on the nodemcu module. When I load the existing codes, the built-in LED on the module does not light. It only lights up during installation. For this, I want to combine both my codes and the built-in led lighting codes in the examples section, but I keep getting an error. Could you please combine these two codes and help me? Thanks.
#define BLYNK_TEMPLATE_ID "TMPL6V-RAaoI3"
#define BLYNK_TEMPLATE_NAME "HOME ASİSTANS"
#define BLYNK_AUTH_TOKEN "d_97T8ioN3TwrW8gkX16S6v5ennboTKq"
#define BLYNK_PRINT Serial
#include <ESP8266WiFi.h>
#include <BlynkSimpleEsp8266.h>
char auth[] = BLYNK_AUTH_TOKEN;
char ssid[] = "HOME";//wifi adı
char pass[] = "Hena5825";//wifi şifresi
BLYNK_WRITE(V0)
  int value = param.asInt();
  Serial.println(value);
  if(value == 1)
    digitalWrite(D5, LOW);
    Serial.println("LED ON");
  if(value == 0)
     digitalWrite(D5, HIGH);
     Serial.println("LED OFF");
BLYNK_WRITE(V1)
  if(value == 1)
    digitalWrite(D6, LOW);
  if(value == 0)
     digitalWrite(D6, HIGH);
BLYNK_WRITE(V2)
  if(value == 1)
    digitalWrite(D7, LOW);
  if(value == 0)
     digitalWrite(D7, HIGH);
BLYNK_WRITE(V3)
  if(value == 1)
    digitalWrite(D8, LOW);
  if(value == 0)
     digitalWrite(D8, HIGH);
  Blynk.begin(auth, ssid, pass);
  pinMode(D5,OUTPUT);
  pinMode(D6,OUTPUT);
  pinMode(D7,OUTPUT);
  pinMode(D8,OUTPUT);
  Blynk.run();
#include <PolledTimeout.h>
void ledOn() {
  digitalWrite(LED_BUILTIN, LOW);  // Turn the LED on (Note that LOW is the voltage level
void ledOff() {
  digitalWrite(LED_BUILTIN, HIGH);  // Turn the LED off by making the voltage HIGH
void ledToggle() {
  digitalWrite(LED_BUILTIN, !digitalRead(LED_BUILTIN));  // Change the state of the LED
esp8266::polledTimeout::periodicFastUs halfPeriod(500000);  // use fully qualified type and avoid importing all ::esp8266 namespace to the global namespace
// the setup function runs only once at start
  Serial.printf("periodic/oneShotMs::timeMax()     = %u ms\n", (uint32_t)esp8266::polledTimeout::periodicMs::timeMax());
  Serial.printf("periodic/oneShotFastMs::timeMax() = %u ms\n", (uint32_t)esp8266::polledTimeout::periodicFastMs::timeMax());
  Serial.printf("periodic/oneShotFastUs::timeMax() = %u us\n", (uint32_t)esp8266::polledTimeout::periodicFastUs::timeMax());
  Serial.printf("periodic/oneShotFastNs::timeMax() = %u ns\n", (uint32_t)esp8266::polledTimeout::periodicFastNs::timeMax());
#if 0  // 1 for debugging polledTimeout
  Serial.printf("periodic/oneShotMs::rangeCompensate     = %u\n", (uint32_t)esp8266::polledTimeout::periodicMs::rangeCompensate);
  Serial.printf("periodic/oneShotFastMs::rangeCompensate = %u\n", (uint32_t)esp8266::polledTimeout::periodicFastMs::rangeCompensate);
  Serial.printf("periodic/oneShotFastUs::rangeCompensate = %u\n", (uint32_t)esp8266::polledTimeout::periodicFastUs::rangeCompensate);
  Serial.printf("periodic/oneShotFastNs::rangeCompensate = %u\n", (uint32_t)esp8266::polledTimeout::periodicFastNs::rangeCompensate);
#endif
  pinMode(LED_BUILTIN, OUTPUT);  // Initialize the LED_BUILTIN pin as an output
  using esp8266::polledTimeout::oneShotMs;  // import the type to the local namespace
  // STEP1; turn the led ON
  ledOn();
  // STEP2: wait for ON timeout
  oneShotMs timeoutOn(2000);
  while (!timeoutOn) { yield(); }
  // STEP3: turn the led OFF
  ledOff();
  // STEP4: wait for OFF timeout to assure the led is kept off for this time before exiting setup
  oneShotMs timeoutOff(2000);
  while (!timeoutOff) { yield(); }
  // Done with STEPs, do other stuff
  halfPeriod.reset();  // halfPeriod is global, so it gets inited on sketch start. Clear it here to make it ready for loop, where it's actually used.
// the loop function runs over and over again forever
  if (halfPeriod) { ledToggle(); }
Your topic has been moved from the Nano ESP32 category of the forum as it relates to a completely different board and processor
You forgot to include what this error is so only you know... It is always important to post the complete error message (if that is the error you are getting) How to get the best out of this forum - Using Arduino / Installation & Troubleshooting - Arduino Forum
What a big messy effort to make the onboard-led blink.
This does not need a library. Just a few lines of code
you should delete ALL your personal login-data in your posting
#define BLYNK_TEMPLATE_ID "your template ID"
#define BLYNK_TEMPLATE_NAME "your template name"
#define BLYNK_AUTH_TOKEN "your auth token"
char ssid[] = "my SSID";//wifi adı
char pass[] = "my password";//wifi şifresi
BLYNK_WRITE(V0)
  if(value == 1)
  if(value == 0)
BLYNK_WRITE(V1)
  if(value == 1)
  if(value == 0)
BLYNK_WRITE(V2)
  if(value == 1)
  if(value == 0)
BLYNK_WRITE(V3)
  if(value == 1)
  if(value == 0)
// easy to use helper-function for non-blocking timing
boolean TimePeriodIsOver (unsigned long &startOfPeriod, unsigned long TimePeriod) {
  unsigned long currentMillis  = millis();
  if ( currentMillis - startOfPeriod >= TimePeriod ) {
    // more time than TimePeriod has elapsed since last time if-condition was true
    startOfPeriod = currentMillis; // a new period starts right here so set new starttime
    return true;
  else return false;            // actual TimePeriod is NOT yet over
void BlinkHeartBeatLED(int IO_Pin, int BlinkPeriod) {
  static unsigned long MyBlinkTimer;
  pinMode(IO_Pin, OUTPUT);
  if ( TimePeriodIsOver(MyBlinkTimer,BlinkPeriod) ) {
    digitalWrite(IO_Pin,!digitalRead(IO_Pin) );
  pinMode(D5,OUTPUT);
  pinMode(D6,OUTPUT);
  pinMode(D7,OUTPUT);
  pinMode(D8,OUTPUT);
  BlinkHeartBeatLED(LED_BUILTIN,500);
  Blynk.run();
best regards Stefan
personal information is not correct so it's okay. Thank you for the code. I'll let you know after testing. @StefanL38
