I have a Wemos D1 mini, (ESP8266), a geared dc brushed motor 1 - 40 rpm, induction sensor attached to the output shaft with 36 pulses per revolution, and BTS7960B 43A H-Bridge Motor Driver
The induction sensor runs at 5v input with a voltage divider on the output to 3.3v.
My problem is I get erratic output from the tacho code and seems no matter what I do I cannot fix it.
I have tried with and without the pwm freq change.
int RPWM = 12;
int LPWM = 16;
int L_EN = 13;
int R_EN = 15;
//void setPWMfrequency(int freq){
// TCCR2B = TCCR2B & 0b11111000 | freq ;
volatile float time = 0;
volatile float time_last = 0;
volatile float rpm_array[5] = {0, 0, 0, 0, 0};
int pot;
// setPWMfrequency(0x02);// timer 0 , 3.92KHz
pinMode(2, INPUT);
pinMode(L_EN, OUTPUT);
pinMode(R_EN, OUTPUT);
analogWriteFreq(3920);//set pwm freq for ESP8266
//Digital Pin 2 Set As An Interrupt
attachInterrupt(14, fan_interrupt, FALLING);
// pot = analogRead(0);
digitalWrite(R_EN, HIGH);
digitalWrite(L_EN, HIGH);
analogWrite(RPWM, 100);// default is 0 - 1023
analogWrite(LPWM, 0);
//Main Loop To Calculate RPM and Update LCD Display
while (1) {
//analogWrite(RPWM, 100);
// analogWrite(RPWM, 0);
//analogWrite(6, map(pot, 0,1023, 0, 255));
float rpm = 0;
//Slow Down The LCD Display Updates
delay(400);
//Update The RPM
noInterrupts();
unsigned long copyTime = time;
interrupts();
if (time > 0)
//5 Sample Moving Average To Smooth Out The Data
rpm_array[0] = rpm_array[1];
rpm_array[1] = rpm_array[2];
rpm_array[2] = rpm_array[3];
rpm_array[3] = rpm_array[4];
rpm_array[4] = 60 * (1000000 / (time * 36));
//Last 5 Average RPM Counts Eqauls....
rpm = (rpm_array[0] + rpm_array[1] + rpm_array[2] + rpm_array[3] + rpm_array[4]) / 5;
// rpm = 60*(1000000/(time * 36));
Serial.print(rpm);
Serial.println(" rpm");
//Serial.println(pot);
//Capture The IR Break-Beam Interrupt
void fan_interrupt()
time = (micros() - time_last);
time_last = micros();
and the output:
pm
3.04 rpm
3.35 rpm
3.66 rpm
3.68 rpm
3.69 rpm
2.95 rpm
103.91 rpm
204.86 rpm
204.85 rpm
204.83 rpm
55759.90 rpm
55659.08 rpm
55558.25 rpm
55558.68 rpm
55559.19 rpm
4.47 rpm
4.40 rpm
3.96 rpm
3.52 rpm
3.01 rpm
2.63 rpm
2.27 rpm
2.28 rpm
2.29 rpm
2.30 rpm
Any ideas?
