ESP8266 - uploading program gives Hard resetting via RTS Pin error
Hi folks - bought some new ESP8266 boards and downloaded NodeMCU drivers. Every time I try to upload a sketch, I get the attached
I've tried with NodeMCU 0.9 (worked for me before with these boards), NodeMCU 1.0, as well as generic ESP8266. Same issue every time.
Ideas?
That doesn't look like an error to me? Just reporting that once it's done updating, it does a hard reset via the RTS pin (assuming the board you're using has that rigged up) so that the sketch you uploaded starts.
Also, don't post pictures of text, copy/paste the text into your post. Use code tags </> to make it more readable on the forums.
