[SOLVED] ESP8266 ESP-01 - Hard resetting via RTS pin
I've read that what I'm experiencing isn't an error, but I wasn't seeing that before and my sketches aren't working when I see this. I'm an extreme novice with this stuff, but trying to learn the ESP8266. I was able to use the AT commands no problem in the beginning, but then I tried a tutorial showing uploading blink onto the ESP8266. I was able to do that, but now I don't know how to get back to AT commands. This tutorial on installing firmware seemed very promising, but I was getting "esp8266 chip efuse check error esp_check_mac_and_efuse" errors. Before trying to upload the firmware, I had uploaded a blank sketch onto the ESP8266. After the firmware stopped working, I was curious if I could upload the blink sketch again, but now I'm seeing the "hard resetting via RTS pin" after uploading, and the blink sketch doesn't work. I'm 99% sure that I was previously seeing a soft reset message after uploading the blink sketch.
Now I've ordered serial adapters, but I still really want to be able to do it via my mega.
My issue was apparently with my switch setup. I'm still having issues with putting firmware back on, but the blink issue was resolved.
