ESP8266 won't be recognized by laptop
Hi all
I've got some hardware issue I don't know how to resolve here.
so I got this new esp8266 D1 mini board and soldered it myself. it worked for 2 nights, but the third night, it stopped working.
When I tried to plug esp8266 into a laptop, the blue light won't even flash, the Arduino IDE can't see the part. not even when I connect a battery to it.
initially, I thought it was because I burned it during soldering, but I felt like it should never worked if it was burned. but it did work for 2 days, right?
I tried some dumb methods like blow air into the port :confused: it actually works sometimes. but only for a few seconds.
also, I tried different laptops and different cables, nothing worked.
one thing I noticed is that when I wiggle the cable near the esp8266 port, sometimes the blue light flashes. made me think if I got some dirt into the port?
then this morning, I bought isopropyl alcohol to clean it, still didn't work. I seriously don't know what to do. please help :frowning: :frowning: :frowning:
Ling
"so I got this new esp8266 D1 mini board and soldered it myself"
You probably have a bad solder joint or loose/broken connection somewhere in the power supply circuit.
I thought about it, but they looked fine, except one spot looked burnt. is there any chance you know the way to determine the problem?
btw, pls see the attachment.
" is there any chance you know the way to determine the problem?"
Typically one would use a multimeter to check the power electrical flow path for voltage until the problem spot is found.
zoomkat:
i tried to do a continuity test, but the probe was too big even, its a really small board :confused: :confused:
"i tried to do a continuity test, but the probe was too big even, its a really small board :confused: :/"
You might wrap a thin piece of wire, like a strand of telephone wire, around the probe tip, then use that piece of wire to probe in the small places.
OPs pic.
Tom.. :slight_smile:
If all the soldering is related to mounting the header pins, then this has nothing to do with power or the USB connection. The solder joint on that left-most pin is dodgy but that is only the reset pin anyway.
There is a suspicious solder blob between D0 and D5 on that photo, though whether that could present a problem is unclear at best. :roll_eyes:
