Ethernet shield
Hello,
I just parched new Ethernet shield from China.
This one:
http://www.ekitszone.com/Products/4-enc28j60-ethernet-shield-for-arduion.aspx
I am having some problems making it run.
I used the client example code but I could attempted connect to google.
Any how, this shield using ports 10-13. My be this is the problem.
Thank you.
Hi, I wrote a library for this chip.
You might like to try:
It simplifies the code that Nuelectronics supply with their similar product.
The boards work well, though they make the voltage regulator mightly hot!
Oh, I forgot to say.
These boards will not work with the standard Arduino ethernet library, which uses a different chip.
Thank you for the lib.
But I have problem working with it.
I compile and every thing but I cant connect to a server.
I added Serial.print("connect");
Do you know of any common problems?
what's your sketch look like?
Have you definitely used an available internal IP address?
I used an ip address that i checked in my browser.
post your sketch.
No reply tonight - its my bed time! But I'll look tomorrow.
Thank you.
