Hi there,
I had made a song changer button for my music on my phone. It works by connecting the phone to a Bluetooth speaker, then also connecting the phone to the ESP32 and using the ESP32 to send AVRCP 'next song' messages to the phone using BluetoothA2DPSink library.
It has been working since I made it around 6 months ago but after re-uploading my code to change the pins it does not work at all. If I try to re-upload what was working my on the original IDE/computer it gives me depreciation messages and errors.
What I have tried: (I dont really know what I am doing)
- 2 different ESP32 boards
- Older versions of the library (gives depreciation errors)
- Different GPIO's / Power Supply / USB cable
- Changing the 'core runs' role in the IDE board settings
- Removing excess code - error relates to a connection
- Reflash Bootloader
- Extend the Watchdog (GPT code suggestion)
- Removing the watchdog (GPT code suggestion)
- Adding delays in the code (GPT code suggestion)
I assume something is corrupt or something is broken but I am very unsure which way to go from here. Any help is greatly appreciated!
Arduino IDE: 1.8.19 Ubuntu - Snap App.
Message on Startup:
I%]/⸮p<⸮-a.ii⸮\mt<5⸮Y⸮%%E (401) esp_core⸮fX][}⸮⸮⸮͡⸮ Core dump data check failed:
Calculated checksum='29912723'
Image checksum='ffffffff'
ets Jun 8 2016 00:22:57
rst:0x1 (POWERON_RESET),boot:0x3 (DOWNLOAD_BOOT(UART0/UART1/SDIO_REI_REO_V2))
waiting for download
Crash Error:
E (180732) task_wdt: Task watchdog got triggered. The following tasks/users did not reset the watchdog in time:
E (180732) task_wdt: - IDLE0 (CPU 0)
E (180732) task_wdt: Tasks currently running:
E (180732) task_wdt: CPU 0: BTC_TASK
E (180732) task_wdt: CPU 1: IDLE1
E (180732) task_wdt: Aborting.
E (180732) task_wdt: Print CPU 0 (current core) backtrace
Backtrace: 0x400d3939:0x3ffd0ad0 0x400d38d5:0x3ffd0af0 0x40199035:0x3ffd0b10 0x400d264f:0x3ffd0b30 0x4011a121:0x3ffd0b50 0x401127ad:0x3ffd0b90 0x40112749:0x3ffd0bb0 0x400963b2:0x3ffd0be0
ELF file SHA256: e5bddc78635f2c46
Guru Meditation Error: Core 0 panic'ed (Unhandled debug exception).
Backtrace: 0x3ffc41ad:0x000007d0 |<-CORRUPTED
Re-entered core dump! Exception happened during core dump!
Rebooting...
)R9 ⸮⸮C
⸮B⸮!B⸮⸮⸮⸮⸮⸮⸮C⸮!⸮[)⸮!⸮L⸮⸮Initializing Bluetooth...
Bluetooth A2DP sink started.
My Code:
#include "BluetoothA2DPSink.h"
BluetoothA2DPSink device;
int openPin = 4;
Serial.println("Initializing Bluetooth...");
device.start("RamPup9");
Serial.println("Bluetooth A2DP sink started.");
delay(10);
Upload Settings:
The same Error Codes in VERBOSE:
Start:
ɭU7⸮p<⸮-y.ii⸮\md,5⸮I⸮J⸮
⸮⸮⸮⸮⸮ψ⸮BH" ~Ł!⸮⸮
)⸮⸮⸮)⸮⸮L!⸮⸮⸮⸮o⸮⸮k.⸮⸮zίH⸮⸮BH⸮a⸮ X
⸮H1~⸮B,⸮⸮⸮⸮rۊ⸮⸮⸮L! ⸮⸮)B⸮⸮k⸮R⸮ç⸮B⸮⸮⸮⸮r⸮y1⸮⸮⸮L!⸮B⸮ R⸮⸮⸮[)⸮n!⸮⸮N⸮8S⸮@⸮N⸮
)⸮⸮⸮C⸮⸮)"⸮⸮⸮S)⸮⸮⸮⸮⸮⸮⸮⸮⸮Ϥ⸮⸮⸮⸮)⸮⸮C⸮~⸮⸮⸮⸮⸮⸮⸮⸮B⸮j⸮⸮⸮⸮⸮⸮⸮⸮g⸮c⸮⸮B⸮⸮⸮e⸮jG⸮⸮⸮⸮⸮⸮)⸮qc⸮c⸮a⸮⸮⸮⸮⸮⸮b⸮FB⸮⸮⸮BR⸮⸮B2Fb⸮⸮⸮⸮⸮>⸮⸮⸮Ό⸮⸮⸮⸮R⸮Ǐ⸮⸮⸮⸮R⸮⸮⸮⸮⸮b⸮L⸮Ǐ⸮⸮⸮⸮⸮c⸮Zz⸮⸮BR⸮b⸮Z⸮⸮⸮B⸮S⸮⸮Z⸮⸮⸮⸮⸮⸮⸮t⸮⸮⸮c⸮⸮%⸮⸮⸮⸮⸮⸮1⸮r⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮!⸮⸮!⸮⸮!⸮1⸮B⸮!⸮⸮c
⸮⸮⸮⸮⸮⸮cG⸮⸮B⸮up$1⸮[ 751][V][esp32-hal-uart.c:560] uartBegin(): UART0 initialization done.
[ 931][D][BluetoothA2DPSink.cpp:90] start(): [BT_AV] start
[ 1023][I][BluetoothA2DPCommon.cpp:257] log_free_heap(): [BT_AV] Available Heap: 221672
[ 1117][I][BluetoothA2DPSink.cpp:102] start(): [BT_AV] Device name will be set to 'RamPup9'
[ 1215][D][BluetoothA2DPSink.cpp:1063] init_nvs(): [BT_AV] init_nvs
[ 1288][D][BluetoothA2DPCommon.cpp:163] get_last_connection(): [BT_AV] get_last_connection
[ 1385][I][BluetoothA2DPCommon.cpp:177] get_last_connection(): [BT_AV] nvs_blob does not exist
[ 1486][D][BluetoothA2DPCommon.cpp:186] get_last_connection(): [BT_AV] => 00:00:00:00:00:00
[ 1584][I][BluetoothA2DPSink.cpp:165] init_i2s(): [BT_AV] init_i2s
[ 1656][D][BluetoothA2DPSink.cpp:186] init_bluetooth(): [BT_AV] init_bluetooth
[ 1809][I][BluetoothA2DPSink.cpp:191] init_bluetooth(): [BT_AV] controller initialized
[ 2121][I][BluetoothA2DPSink.cpp:200] init_bluetooth(): [BT_AV] bluedroid initialized
[ 2277][I][BluetoothA2DPSink.cpp:209] init_bluetooth(): [BT_AV] bluedroid enabled
[ 2364][D][BluetoothA2DPSink.cpp:322] app_task_start_up(): [BT_AV] app_task_start_up
[ 2455][D][BluetoothA2DPSink.cpp:1178] ccall_app_task_handler(): [BT_AV] ccall_app_task_handler
[ 2557][D][BluetoothA2DPSink.cpp:278] app_task_handler(): [BT_AV] app_task_handler
[ 2646][D][BluetoothA2DPSink.cpp:234] app_work_dispatch(): [BT_API] app_work_dispatch event 0x0, param len 0
[ 2761][D][BluetoothA2DPSink.cpp:264] app_send_msg(): [BT_AV] app_send_msg
[ 2842][D][BluetoothA2DPSink.cpp:286] app_task_handler(): [BT_API] app_task_handler, sig 0x1, 0x0
[ 2946][D][BluetoothA2DPSink.cpp:289] app_task_handler(): [BT_API] app_task_handler, APP_SIG_WORK_DISPATCH sig: 1
[ 3067][D][BluetoothA2DPSink.cpp:257] app_work_dispatched(): [BT_AV] app_work_dispatched
[ 3162][D][BluetoothA2DPSink.cpp:1211] ccall_av_hdl_stack_evt(): [BT_AV] ccall_av_hdl_stack_evt
[ 3264][D][BluetoothA2DPSink.cpp:911] av_hdl_stack_evt(): [BT_AV] av_hdl_stack_evt evt 0
[ 3359][D][BluetoothA2DPSink.cpp:916] av_hdl_stack_evt(): [BT_AV] av_hdl_stack_evt av_hdl_stack_evt BT_APP_EVT_STACK_UP
[ 3486][D][BluetoothA2DPSink.cpp:926] av_hdl_stack_evt(): [BT_AV] AVRCP controller initialized!
[ 3486][D][BluetoothA2DPSink.cpp:1205] ccall_app_gap_callback(): [BT_AV] ccall_app_gap_callback
[ 3690][I][BluetoothA2DPSink.cpp:433] app_gap_callback(): [BT_A[V ] 3e6v9e0n]t[:D ]1[0Bl
uetoothA2DPSink.cpp:972] av_hdl_stack_evt(): [BT_AV] set_scan_mode_connectable(true)
[ 3875][I][BluetoothA2DPCommon.cpp:358] set_scan_mode_connectable(): [BT_AV] set_scan_mode_connectable true
[ 3878][D][BluetoothA2DPSink.cpp:1191] ccall_app_a2d_callback(): [BT_AV] ccall_app_a2d_callback
[ 4092][D][BluetoothA2DPSink.cpp:986] app_a2d_callback(): [BT_AV] app_a2d_callback
[ 4092][I][BluetoothA2DPSink.cpp:159] start(): [BT_AV] IDF Version 5.1
[ 4257][D][BluetoothA2DPSink.cpp:1009] app_a2d_callback(): [[B T _4A2V5]7 ]a[pIp]_[aB2ldu_ectaololtbhaAc2kD PECSoPm_mAo2nD._cApUD:25CFG_log_free_heap(): [BT_AV] Available Heap: 118360
=========== A[f t e4r4 5S1e]t[uDp] [SBtlaurett o=o=t=h=A=2=D=P=S=i=n=k=.
cpp:234] app_work_dispatch(): [BT_API] app_work_dispatch event 0x4, param len 16
IN[T E R4N6A4L4 ]M[eDm]o[rByl uIentfooo:t
h
[ 4749][D][BluetoothA2DPSink.cpp:286] app_task_handler(): [BT_API] app_tas[k _ h4a7n4d9l]e[rD,] [sBilgu e0txo1o,t h0Ax24D
P
[ 4955][[D ] [4B9l5u5e]t[oIo]t[hBAl2uDePtSoiontkh.Ac2pDpP:S2i8n9k]. capppp:_4t3a3s]k _ahpapn_dglaepr_(c)a:l l[bBaTc_kA(P)I:] [aBp_tV] event: 10
[ 5138][D][BluetoothA2DPSink.cpp[: 2 5571]3 8a]p[pD_]w[oBrlku_edtiosoptahtAc2hDePdS(i)n:k .[cBpTp_:A1V2]0 5a]p pc_cwaolrlk__adpi_gap_cal
[ 5324][I][Bluetooth[A 2 D5P3S2i4n]k[.Dc]p[pB:l4u3e3t]o oatphpA_2gDaPpS_icnakl.lcbpapc:k1(2)2:5 ][ BcTc_aAlVl]_ aevv_ehndtl:_ a10
evt(): [BT_AV] ccall_av_hdl_a2d_evt
[ 5500][D][Bl[u e t5o5o0t0h]A[2DD]P[SBilnuke.tcopopt:h1A220D5P]S icncka.lclp_pa:p4p9_2g]a pa_vc_ahldllb_aac2kd(_)e:v t[(B)T:_ A[V] cc]la_app_gap_callback
[ 5664][I][Bluet[o o t5h6A624D]P[SIi]n[kB.lcupept:o4o3t3h]A 2aDpPpS_ignakp._ccpapl:l5b1a6c]k (a)v:_ h[dBlT__aA2Vd]_ eevvte(n)t:: 10
AV] A2DP PROF STATE: Init Compl
Total Size : 275112 B ( 268.7 KB)
Free Bytes : 138404 B ( 135.2 KB)
Allocated Bytes : 125628 B ( 122.7 KB)
Minimum Free Bytes: 136780 B ( 133.6 KB)
Largest Free Block: 110580 B ( 108.0 KB)
GPIO Info:
GPIO : BUS_TYPE[bus/unit][chan]
1 : UART_TX[0]
3 : UART_RX[0]
============ After Setup End =============
Crash:
[ 45332][D][BluetoothA2DPSink.cpp:1205] ccall_app_gap_callback(): [BT_AV] ccall_app_gap_callback
[ 45434][I][BluetoothA2DPSink.cpp:433] app_gap_callback(): [BT_AV] event: 16
[ 45518][D][BluetoothA2DPSink.cpp:1191] ccall_app_a2d_callback(): [BT_AV] ccall_app_a2d_callback
[ 45620][D][BluetoothA2DPSink.cpp:986] app_a2d_callback(): [BT_AV] app_a2d_callback
[ 45709][D][BluetoothA2DPSink.cpp:990] app_a2d_callback(): [BT_AV] app_a2d_callback ESP_A2D_CONNECTION_STATE_EVT
[ 45828][D][BluetoothA2DPSink.cpp:234] app_work_dispatch(): [BT_API] app_work_dispatch event 0x0, param len 16
[ 45945][D][BluetoothA2DPSink.cpp:264] app_send_msg(): [BT_AV] app_send_msg
[ 46025][D][BluetoothA2DPSink.cpp:286] app_task_handler(): [BT_API] app_task_handler, sig 0x1, 0x0
[ 46025][D][BluetoothA2DPSink.cpp:1191] ccall_app_a2d_callback(): [BT_AV] ccall_app_a2d_callback
[ 46231][D][BluetoothA2DPSink.cpp:289] app_task_handl[e r4(6)2:3 1[]B[TD_]A[PBIl]u eatpopo_tthaAs2kD_PhSainndkl.ecrp,p :A9P8P6_]S appOa2_DISllbCH sig:[1T
[ 46415[ 46415][D][BluetoothA2DPSink.cpp:257] app_]wo[rDk]_[dBilsupeattocohtehdA(2)D:P S[iBnTk_.AcVp]p :a1p0p0_1w]o rakp_pd_ias2p_cahlback(): [BT_AV] app_a2d_callback ESP_A2D_AUDIO_CFG_EVT
[ 46612][D][BluetoothA2DPSink.cpp:1225] ccall_av_hdl_a2d_evt(): [BT_AV] ccall_av_hdl_a2d_evt
[ 46612][D][BluetoothA2DPSink.cpp:234] app_work_dispatch(): [BT_API] app_work_dispatch event 0x2, param len 16
[ 46827][D][BluetoothA2DPSink.cpp:492] av_h[d l4_a2d_evt(): [BT_AV] av_hdl_a2d_evt evt 0
6827][D][BluetoothA2DPSink.cpp:264] app_send_msg(): [BT_AV] app_send_msg
[ 46998][D][BluetoothA2DPSink.cpp:496] av_hdl_a2d_evt(): [BT_AV] av_hdl_a2d_evt ESP_A2D_CONNECTION_STATE_EVT
[ 46998][D][BluetoothA2DPSink.cpp:1191] ccall_app_a2d_callback(): [BT_AV] ccall_app_a2d_callback
[ 47215][ 47[2D1]5[]B[lDu]e[tBoloutehtAo2oDtPhSAi2nDkP.Scipnpk:.6c1p2p]: 9h8a6n]d laep_pc_oan2nde_cctailolnb_asctka(t)e:( )[:B T[BV_] ] p_ndd_callbacti
n_state evt 0
[ 47389][I][BluetoothA2DPSink.cpp:617] handle_connection_state(): [BT_AV] partner addr[e s4s7:3 8a98]:[2Wb]:[bB9l:u7e8t:oeo1t:h2A2DPSink.cpp:1017] app_a2d_callback(): [BT_AV] Unhandled A2DP event: 5
[ 47597][D][BluetoothA2DPSink.cpp:1191] ccall_app_a2d_callback(): [BT_AV] ccall_app_a2d_callback
[ 47597][I][BluetoothA2DPSink.cpp:619] handle_connection_state(): [BT_AV] A2DP connection state: Connecting, [a8:2b:b9:78:e1:21]
[ 47834][D][BluetoothA2DPSink.cpp:986] app_a2d_callback([) :4 7[8B3T4_]A[VI]] [aBplpu_eat2odo_tchaAl2lDbPaSciknk
.cpp:677] handle_connection_state(): [BT_AV] ESP_A2D_CONNECTION_STATE_CONNECTING
[ 48039][D][BluetoothA2DPSink.cpp:990] app_a2d_callback(): [BT_AV] app_a2d_callback ESP_A2D_CONNECTION_STATE_EVT
[ 48039][D][BluetoothA2DPSink.cpp:286] app_task_handler(): [BT_API] app_task_handler, sig 0x1, 0x2
[ 48262][D][BluetoothA2DPSink.cpp:289] app_task_handler(): [BT_API] app_task_handler, APP_SIG_WORK_DISPATCH sig: 1
[ 48262][D][BluetoothA2DPSink.cpp:234] app_work_dispatch(): [BT_API] app_work_dispatch event 0x0, param len 16
[ 48499][D][BluetoothA2DPSink.cpp:257] app_work_dispatched(): [BT_AV] ap[p _4w8o4r9k9_]d[iDs]p[aBtlcuheetdo
o
[ 48674][D][BluetoothA2DPSink.cpp:1225] ccall_av_hdl_a2d_evt(): [BT_AV] ccall_av_hdl_a2d_evt
[ 48772][D][BluetoothA2DPSink.cpp:492] av_hdl_a2d_evt(): [BT_AV] av_hdl_a2d_evt evt 2
[ 48863][D][BluetoothA2DPSink.cpp:506] av_hdl_a2d_evt(): [BT_AV] av_hdl_a2d_evt ESP_A2D_AUDIO_CFG_EVT
[ 48883][D][BluetoothA2DPSink.cpp:1205] ccall_app_gap_callback(): [BT_AV] ccall_app_gap_callback
[ 49072][D][Bluet[o o4t9h0A722D]P[SIi]n[kB.lcupept:o5o3t1h]A 2hDaPnSdilnek_.acupdpi:o4_2c7f]g (a)p:p _[gBaTp__AcVa]l lhbaancdkl(e_: dio_cfg ESt BT
GAP_MODE_CHG_EVT
[ 49244][I][BluetoothA2DPSink.cpp:534] handle_audio_cfg(): [BT_AV] a2dp audio_cfg_cb , codec type 0
[ 49244][I][BluetoothA2DPCommon.cpp:257] log_free_heap(): [BT_AV] Available Heap: 101936
[ 49443][I][BluetoothA2DPSink.cpp:547] handle_audio_cfg(): [BT_AV] a2dp audio_cfg_cb , sample_rate 44100
[ 49445][D][BluetoothA2DPSink.cpp:1205] ccall_app_gap_callback(): [BT_AV] ccall_app_gap_callback
[ 49655][I][BluetoothA2DPSink.cpp:554] handle_audio_cfg(): [BT_AV] configure audio player 21-15-2-35
[ 49655][I][BluetoothA2DPSink.cpp:427] app_gap_callback(): [BT_AV] ESP_BT_GAP_MODE_CHG_EVT
[ 49860][D][BluetoothA2DPSink.cpp:286] app_task_handler(): [BT_API] app_task_handler, sig 0x1, 0x0
[ 49860][I][BluetoothA2DPCommon.cpp:257] log_free_heap(): [BT_AV] Available Heap: 108624
[ 50058][D][BluetoothA2DPSink.cpp:289] app_task_handler(): [BT_API] app_task_handler, APP_SIG_WORK_DISPATCH sig: 1
[ 50058][D][BluetoothA2DPSink.cpp:1198] ccall_app_rc_ct_callback(): [BT_AV] ccall_app_rc_ct_callback
[ 50285][D][BluetoothA2DPSink.cpp:257] app_work_dispatched(): [BT_AV] app_work_dispatched
[ 50285][D][BluetoothA2DPSink.cpp:442] app_rc_ct_callback(): [BT_AV] app_rc_ct_callback
[ 50472][D][BluetoothA2DPSink.cpp:1225] ccall_av_hdl_a2d_evt(): [BT_AV] ccall_av_hdl_a2d_evt
[ 50472][D][BluetoothA2DPSink.cpp:452] app_rc_ct_callback(): [BT_AV] app_rc_ct_callback ESP_AVRC_CT_CONNECTION_STATE_EVT
[ 50697][D][BluetoothA2DPSink.cpp:492] av_hdl_a2d_evt(): [BT_AV] av_hdl_a2d_evt evt 0
[ 50697][D][BluetoothA2DPSink.cpp:234] app_work_dispatch(): [BT_API] app_work_dispatch event 0x0, param len 12
[ 50905][D][BluetoothA2DPSink.cpp:496][ a5v0_9h0d5l]_[aD2]d[_Belvute(t)o:o t[hBAT2_DAPVS]i nakv._chpdpl:_2a624d]_ eavptp _EsSePnA2DmsOgNECTI [_BTA_E_E]
p_send_msg
[ 51079][D][BluetoothA2DPSink.cpp:612] handle_connection_state(): [BT_AV] handle_connection_state evt 0
[ 51079][D][BluetoothA2DPSink.cpp:1311] ccall_app_rc_tg_callback(): [BT_AV] ccall_app_rc_tg_callback
[ 51294][D][BluetoothA2DPSink.cpp:1259] app_rc_tg_callback()[: 5[1B2T9_4A]V[]I ]a[pBpl_urect_otogt_hcAa2lDlPbSaicnkk
cpp:617] handle_connection_state(): [BT_AV] partner address: a8:2b:b9:78:e1:21
[ 51503][D][BluetoothA2DPSink.cpp:234] app_work_dispatch(): [BT_API] app_[w o5r1k5_0d3i]s[pIa]t[cBhl ueevteonott h0Ax20D,P Spianrk.cppen 9]
andle_connection_state(): [BT_AV] A2DP connection state: Connected, [a8:2b:b9:78:e1:21]
[ 51743][I][BluetoothA2DPSink.cpp:682] handle_connection_state(): [BT_AV] ESP_A2D[_ C5O1N7N4E3C]T[IDO]N[_BSlTuAeTtEo_oCtOhNAN2EDCPEDink.cpp:264] app_send_msg(): [BT_AV] app_send_msg
[ 51934][I][Bluet[o o5t1h9A324D]P[CDo]m[mBolnu.ectpopo:t3h5A82]D PsSeitn_ks.ccapnp_:m1o1d9e8_]c ocncnaelclt_aabplpe_(r)c:_ c[tB_TaAV] ack(sc: [BTd_AVonncctabl_app_src_ct_callback
[ 52121][D][BluetoothA2DPSink.cpp:442] app_rc_ct_callback(): [BT_AV] app_rc_ct_callback
[ 52122][D][BluetoothA2DPSink.cpp:286] app_task_handler(): [BT_API] app_task_handler, sig 0x1, 0x0
[ 52318][D][[B l5u2e3t1o8o]t[hDA]2[DBPlSuientko.octphpA:22D8P9S]i nakp.pc_ptpa:s4k6_7h]a nadplpe_rr(c)_:c t[_BcTa_lAlPbIa]c ka(p)p tBsk_h] dlpr, APc_ScalWbRc_ ISPP_CV Rig:C T_REMOTE_FEATURES_EVT
[ 52522][D][BluetoothA2DPSink.cpp:257] app_work_dispatched(): [BT_AV] app_work_dispatched
[ 52522][D][BluetoothA2DPSink.cpp:234] app_work_dispatch(): [BT_API] app_work_dispatch event 0x5, param len 12
[ 52734][D][BluetoothA2DPSink.cpp:1218] ccall_av_hdl_avrc_evt(): [BT_AV] ccall_av_hdl_avrc[_ e5v2t73
4][D][BluetoothA2DPSink.cpp:264] app_send_msg(): [BT_AV] app_send_msg
[ 52914][D][Blu[e t5o2o9t1h4A]2[DDP]S[iBnlku.ectpopo:t1h3A121D]P Scicnakl.lc_papp:p8_2r8c]_ tagv__chadlll_baavcrkc(_)e:v t[(B)T:_[AV]AV]cav_hdlpavrc__tg eca 0
ack
[ 53086][I][BluetoothA2DPSink.cpp:832] av_hdl_avrc_evt(): [BT_AV] AVRC conn_state evt: [s t5a3t0e8 61],[ D[]a[8B:l2ube:tbo9o:t7h8:21:Sink
cpp:1259] app_rc_tg_callback(): [BT_AV] app_rc_tg_callback
[ 53292][D][BluetoothA2DPSink.cpp:286] app_task_handler(): [BT_API] app_task_handler, sig 0x1, 0x0
[ 53292][D][BluetoothA2DPSink.cpp:234] app_work_dispatch(): [BT_API] app_work_dispatch event 0x1, param len 12
[ 53513][D][BluetoothA2DPSink.[c p5p3:521839]][ Da]p[pB_ltuaestko_ohtahnAd2lDePrS(i)n:k .[cBpTp_:A2P6I4]] aapppp__tsaesnkd__hmasndl: , AP__SIG_WORK_seSd_mCg sig: 1
[ 53686][D][BluetoothA2DPSink.cpp:257] app_work_dispatched(): [BT_AV] app_work_dispatched
[ 53686][D][BluetoothA2DPSink.cpp:1311] ccall_app_rc_tg_callback(): [BT_AV] ccall_app_rc_tg_callback
E (54084) task_wdt: Task watchdog got triggered. The following tasks/users did not reset the watchdog in time:
E (54084) task_wdt: - IDLE0 (CPU 0)
E (54084) task_wdt: Tasks currently running:
E (54084) task_wdt: CPU 0: BTC_TASK
E (54084) task_wdt: CPU 1: BtAppT
E (54084) task_wdt: Aborting.
E (54084) task_wdt: Print CPU 0 (current core) backtrace
Backtrace: 0x400d7692:0x3ffd0ae0 0x40162b41:0x3ffd0b20 0x400d3b85:0x3ffd0ba0 0x400e843a:0x3ffd0be0 0x400e8b61:0x3ffd0c00 0x400e7e14:0x3ffd0c90 0x4019da76:0x3ffd0cc0 0x400e83ad:0x3ffd0ce0 0x40112f6d:0x3ffd0d00 0x401151ad:0x3ffd0d20 0x400963b2:0x3ffd0d50
ELF file SHA256: d6a475b4ff8ab237
...THEN IT RESTARTS THE DEVICE
