Expected initializer before '.' token error is coming for this code plz tell me what to do? (for my ESP8266)
#include <BearSSLHelpers.h>
#include <CertStoreBearSSL.h>
#include <ESP8266WiFi.h>
#include <ESP8266WiFiAP.h>
#include <ESP8266WiFiGeneric.h>
#include <ESP8266WiFiGratuitous.h>
#include <ESP8266WiFiMulti.h>
#include <ESP8266WiFiScan.h>
#include <ESP8266WiFiSTA.h>
#include <ESP8266WiFiType.h>
#include <WiFiClient.h>
#include <WiFiClientSecure.h>
#include <WiFiClientSecureAxTLS.h>
#include <WiFiClientSecureBearSSL.h>
#include <WiFiServer.h>
#include <WiFiServerSecure.h>
#include <WiFiServerSecureAxTLS.h>
#include <WiFiServerSecureBearSSL.h>
#include <WiFiUdp.h>
#include <Adafruit_GFX.h>
#include <Adafruit_GrayOLED.h>
#include <Adafruit_SPITFT.h>
#include <Adafruit_SPITFT_Macros.h>
#include <gfxfont.h>
#include <WiFi.h>
#include <ESP8266HTTPClient.h>
#include <ArduinoJson.h>
#include <SerialESP8266wifi.h>
#include <Arduino_JSON.h>
#include <JSON.h>
#include <JSONVar.h>
#include <Wire.h>
#include <Adafruit_SSD1306.h>
#include <splash.h>
#include <ESP8266HTTPClient.h> // http web access library
#include <ArduinoJson.h> // JSON decoding library
// Libraries for SSD1306 OLED display
#include <Wire.h> // include wire library (for I2C devices such as the SSD1306 display)
#include <Adafruit_GFX.h> // include Adafruit graphics library
#include <Adafruit_SSD1306.h> // include Adafruit SSD1306 OLED display driver
#define OLED_RESET 5 // define SSD1306 OLED reset at ESP8266 GPIO5 (NodeMCU D1)
Adafruit_SSD1306 display(OLED_RESET);
// set Wi-Fi SSID and password
const char *ssid = "TP-Link_6742";
const char *password = "26051973";
// set location and API key
String Location = "Amravati, IN";
String API_Key = "eb9274010b722f75502bbf8fa15f4872";
Wire.begin(4, 0); // set I2C pins [SDA = GPIO4 (D2), SCL = GPIO0 (D3)], default clock is 100kHz
// by default, we'll generate the high voltage from the 3.3v line internally! (neat!)
display.begin(SSD1306_SWITCHCAPVCC, 0x3C); // initialize with the I2C addr 0x3D (for the 128x64)
// init done
Wire.setClock(400000L); // set I2C clock to 400kHz
display.clearDisplay(); // clear the display buffer
display.setTextColor(WHITE, BLACK);
display.setTextSize(1);
display.setCursor(0, 0);
display.println("Weather News By Anupam");
display.print(" Station - Amravati");
display.display();
const char WiFi.begin ("ssid, password");
Serial.print("Connecting.");
display.setCursor(0, 24);
display.println("Connecting...");
display.println("Made By Anupam");
display.display();
while ( WiFi.status() != WL_CONNECTED )
Serial.print(".");
Serial.println("connected");
display.print("connected");
display.display();
if (WiFi.status() == WL_CONNECTED) //Check WiFi connection status
HTTPClient http; //Declare an object of class HTTPClient
// specify request destination
http.begin("http://api.openweathermap.org/data/2.5/weather?q=" + Location + "&APPID=" + API_Key); // !!
int httpCode = http.GET(); // send the request
if (httpCode > 0) // check the returning code
String payload = http.getString(); //Get the request response payload
 DynamicJsonBuffer jsonBuffer(512);
// Parse JSON object
JsonObject& root = jsonBuffer.parseObject(payload);
if (!root.success()) {
Serial.println(F("Parsing failed!"));
return;
float temp = (float)(root["main"]["temp"]) - 273.15; // get temperature in °C
int humidity = root["main"]["humidity"]; // get humidity in %
float pressure = (float)(root["main"]["pressure"]) / 1000; // get pressure in bar
float wind_speed = root["wind"]["speed"]; // get wind speed in m/s
int wind_degree = root["wind"]["deg"]; // get wind degree in °
// print data
Serial.printf("Temperature = %.2f°C\r\n", temp);
Serial.printf("Humidity = %d %%\r\n", humidity);
Serial.printf("Pressure = %.3f bar\r\n", pressure);
Serial.printf("Wind speed = %.1f m/s\r\n", wind_speed);
Serial.printf("Wind degree = %d°\r\n\r\n", wind_degree);
display.printf("Temperature: %5.2f C\r\n", temp);
display.printf("Humidity : %d %%\r\n", humidity);
display.printf("Pressure : %.3fbar\r\n", pressure);
display.printf("Wind speed : %.1f m/s\r\n", wind_speed);
display.printf("Wind degree: %d", wind_degree);
display.drawRect(109, 24, 3, 3, WHITE); // put degree symbol ( ° )
display.drawRect(97, 56, 3, 3, WHITE);
display.display();
http.end(); //Close connection
delay(60000); // wait 1 minute
// End of code.
@yjhdhmkij, your topic has been moved to a more suitable location on the forum. Installation and Troubleshooting is not for problems with your project :wink: See About the Installation & Troubleshooting category.
Can you please provide the full error message; there should be a button "Copy error messages" in the orange bar when compilation fails. Click it and next paste here in a reply.
i cant change location
What does that mean? If you want to move the topic, that's already done. If something else, please elaborate.
This Is The Error
C:\Users\Admin\Downloads\led\led.ino: In function 'void setup()':
led:100: error: expected initializer before '.' token
exit status 1
i changed the topic
Lose the "const char"
It's still / again in the wrong section :wink: Installation and Troubleshooting is not for problems with your project :wink: See About the IDE 1.x category.
done
It's again in the wrong category. I will move it, please leave it where I put it.
