expected initializer before '}' token
I'm a beginner with the arduino and lua language. editing 2 working scripts to get what i need done.
i have an ldr connected to my esp8266 i need the code to publish to an mqtt topic when a set threshold is read. However, i keep seeing this error: expected initializer before '}' token
What am i doing wrong?
Any help is much appreciated.
pinMode(13, OUTPUT); //pin connected to the relay
Serial.begin(115200); //sets serial port for communication
Serial.print("Connecting to ");
Serial.println(ssid);
WiFi.begin(ssid, wifi_password);
Serial.print(".");
// Debugging - Output the IP Address of the ESP8266
Serial.println("WiFi connected");
Serial.print("IP address: ");
// Connect to MQTT Broker
// client.connect returns a boolean value to let us know if the connection was successful.
if (client.connect(clientID)) {
Serial.println("Connected to MQTT Broker!");
else {
Serial.println("Connection to MQTT Broker failed...");
// read the value from the sensor:
sensorValue = analogRead(sensorPin);
Serial.println(sensorValue); //prints the values coming from the sensor on the screen
if (sensorValue < 700) //setting a threshold value
//digitalWrite(2,HIGH); //turn relay ON
client.publish(mqtt_topic, "Button pressed!");
else digitalWrite(2, LOW); //turn relay OFF
delay(100);
Haha.. it took me a second to see the problem after you pointed it out. I was using the wrong curly brace. And i posted the wrong part of the code too. Pardon me.
Now this is the error i get: a function-definition is not allowed here before '{' token
The braces are all there now. But still getting the error.
You will need another } after the line "Serial.println("Connection to MQTT Broker failed...");"
When you write your code, do a Ctrl-t before verifying it. That will autoformat your code, and things like misplaced braces will stand out.
ChrisTenone:
But before you do that... I find it beneficial to put a carriage return in after "void setup()" and its opening { and ditto with loop(), so it looks like this:
In fact, I edited the template and saved it so I get that style as my default. It's the Bare Minimum sketch in the examples folder of the Arduino install folder. (Not your sketchbook.)
ChrisTenone:
Bear with me now, I fixed the curly brace error now it says 'Serial' does not name a type
netrosec:
So help us to help you by posting the latest code.
If you make changes to your code, you should post the new code so that we know what you did and can put into our IDE and check it.
Please post the entire text of the error message. There is important information missing from your truncated posting of the error.
Please read the "how to use this forum-please read" stickies to see how to format and post code and error messages.
groundFungus:
Sorry about that.. I have now updated the original question with my current working code.
this is the whole error:
Arduino: 1.8.5 (Windows 10), Board: "NodeMCU 1.0 (ESP-12E Module), 80 MHz, 115200, 4M (3M SPIFFS)"
ldr:40: error: 'Serial' does not name a type
ldr:41: error: 'Serial' does not name a type
ldr:42: error: 'Serial' does not name a type
ldr:46: error: expected unqualified-id before 'if'
ldr:50: error: expected unqualified-id before 'else'
else {
C:\Users\w4r10ck3r\Desktop\ldr\ldr.ino: In function 'void loop()':
ldr:57: error: 'sensorValue' was not declared in this scope
ldr:57: error: 'sensorPin' was not declared in this scope
exit status 1
option enabled in File -> Preferences.
Put the cursor on the first brace of void setup().
The end of void setup() will be boxed in.
Where does void setup() end....
The block below it will be excluded from setup().
Leo..
Apart from any brace-related issues, you're trying to use the WiFi library but there's no include for it.
wilfredmedlin:
I did include it. I just didn't paste that part of the code here.
Please read the "how to use this forum-please read" stickies to see how to format and post code and error messages. Following the guidelines in the stickies helps us help you.
Do not change a previous post with new code, post the new code in a new post. That keeps the continuity of the thread.
Post the whole code, including the library includes, defines, variable declarations, etc.
netrosec:
That makes it harder for us to test your code.
Also, don't change your original post. Then the answers given don't make sense.
Post the full code with code tags. Read the forum rules first.
Leo..
Wawa:
Leo..
Here's the whole thing
#include <ESP8266WiFi.h>
#include <PubSubClient.h>
// WiFi
// Make sure to update this for your own WiFi network!
const char* ssid = "<./>";
const char* wifi_password = "warfcity";
// MQTT
// Make sure to update this for your own MQTT Broker!
const char* mqtt_server = "192.168.0.55";
const char* mqtt_topic = "laser";
// The client id identifies the ESP8266 device. Think of it a bit like a hostname (Or just a name, like Greg).
const char* clientID = "esp8266";
// Initialise the WiFi and MQTT Client objects
WiFiClient wifiClient;
PubSubClient client(mqtt_server, 1883, wifiClient); // 1883 is the listener port for the Broker
while (WiFi.status() != WL_CONNECTED)
Serial.print(".");
else {
delay(100);
The } that closes setup() is actually after the one closing loop(), so loop is inside setup.
So move the very very last } to be just above "void loop()"
wilfredmedlin:
ok i see that. Fixing that generated this error:
ldr:54: error: 'sensorValue' was not declared in this scope
ldr:54: error: 'sensorPin' was not declared in this scope
ldr:61: error: 'else' without a previous 'if'
exit status 1
Well those messages are un-ambiguous. Nowhere did you do eg:
int sensorValue;
wilfredmedlin:
int sensorValue;
Sorry i don't understand what you mean.
netrosec:
Ok well you need to back up a bit and look at some basics.
Variables need to be declared; have a read here, then here and the variables part on this page.
