Good morning everybody,
In a few words, my problem is as follows:
I cannot compile a sketch...
It always gives me a "fatal error: I2C.h: No such file or directory" message.
I understand that the IDE is searching to include a file or a directory named "I2C.h" which it cannot find.
And...
I could not find it in my "library directory" either...
The sketch will be run on an Arduino Nano.
Hence, I'll pay for the beers if somebody would be so nice and help me through this problem.
Please see below the sketch in question (thanks to the original author...)
and further down, my error message...
Thanks a million for your time...
#define eeprom_dist 4 //Define eeprom memory location to store mile or km calculation
#define eeprom_level 5 //Define eeprom memory location to store mile or km calculation
* AS3935 communicates with i2c in this sketch
* and the Nokia 5110 uses SPI
Adafruit_PCD8544 display = Adafruit_PCD8544(8, 5, 4);
#include "I2C.h"
// include Playing With Fusion AXS3935 libraries
#include "PWFusion_AS3935_I2C.h"
// interrupt trigger global var
volatile int8_t AS3935_ISR_Trig = 0;
// define some values used by the panel and buttons
int adc_key_in = 0;
int z=0;
int mi=0;
#define btnLEFT 3
#define btnDOWN 2
#define btnUP 1
#define btnRIGHT 0
#define btnSELECT 4
#define btnNONE 5
// defines for hardware config
#define SI_PIN 9
#define IRQ_PIN 2 // digital pins 2 and 3 are available for interrupt capability
#define AS3935_ADD 0x03 // x03 - standard PWF SEN-39001-R01 config
#define AS3935_CAPACITANCE 104 // <-- SET THIS VALUE TO THE NUMBER LISTED ON YOUR BOARD
// defines for general chip settings
#define AS3935_INDOORS 0
#define AS3935_OUTDOORS 1
#define AS3935_DIST_DIS 1
#define AS3935_DIST_EN 0
int l=0;
int n=0;
int lsDist=0;
int mapDist=0;
int m=0;
int dist=0;
int tt=0;
// prototypes
void AS3935_ISR();
//--- data that builds the onscreen icons
PWF_AS3935_I2C lightning0((uint8_t)IRQ_PIN, (uint8_t)SI_PIN, (uint8_t)AS3935_ADD);
const unsigned char PROGMEM lightning_bmp[32] = {
0x01, 0xE0, 0x02, 0x20, 0x0C, 0x18, 0x12, 0x24, 0x21, 0x06, 0x10, 0x02, 0x1F, 0xFC, 0x01, 0xF0,
0x01, 0xC0, 0x03, 0x80, 0x07, 0xF8, 0x00, 0xF0, 0x00, 0xC0, 0x01, 0x80, 0x01, 0x00, 0x01, 0x00
const unsigned char PROGMEM cloud[32] = {
0x01, 0xE0, 0x02, 0x20, 0x0C, 0x18, 0x12, 0x24, 0x21, 0x06, 0x10, 0x02, 0x1F, 0xFC, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00
const unsigned char PROGMEM lightning[32] = {
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0xF8, 0x01, 0xF0,
int read_buttons()
adc_key_in = analogRead(0); // read the value from Button Panel. Values returned if a button gets pressed and which one it was....
if (adc_key_in > 1000) return btnNONE;
if (adc_key_in ==0 ) return btnLEFT;
if (adc_key_in > 310 and adc_key_in< 330 ) return btnDOWN;
if (adc_key_in > 120 and adc_key_in<145 ) return btnUP;
if (adc_key_in > 480 and adc_key_in<550) return btnRIGHT;
if (adc_key_in > 700 and adc_key_in< 800) return btnSELECT;
return btnNONE; // when all others fail, return this...
//-----------the config menu
void menu ()
delay(400);
while (read_buttons() != 4){
display.clearDisplay();
display.setCursor(0,0);
display.setTextSize(1);
display.println("Enter=Return");
display.setCursor(0,8);
display.println("Up = Mi");
display.setCursor(0,18);
display.println("down = KM");
display.setCursor(0,28);
display.println("Left=Indoors");
display.setCursor(0,38);
display.println("Right=Outdoors ");
display.display();
if (read_buttons() == 1){
mi=0;
EEPROM.write(eeprom_dist,0); //Write setting for (1)Mile/(0)Kilometer calculation to EEPROM for recall after power off
display.println("Set to KM");
display.display();
menu();
if (read_buttons() == 2){
mi=1;
EEPROM.write(eeprom_dist,1); //Write setting for Mile/Kilometer calculation to EEPROM for recall after power off
display.println("Set to Miles");
display.display();
menu();
if (read_buttons() == 0){
lightning0.AS3935_SetIndoors();
dist=0;
EEPROM.write(eeprom_level,0); //Write setting for (0)Indoor/(1)Outdoor setting on AS3935 to EEPROM for recall after power off
display.println("Indoor");
display.setCursor(0,20);
display.println("Operation");
display.display();
menu();
if (read_buttons() == 3){
lightning0.AS3935_SetOutdoors();
dist=1;
EEPROM.write(eeprom_level,1); //Write setting for (0)Indoor/(1)Outdoor setting on AS3935 to EEPROM for recall after power off
display.println("Outdoor");
display.display();
menu();
return;
mi = EEPROM.read(eeprom_dist); //Read Stored Settings from EEPROM
dist = EEPROM.read(eeprom_level); //Read Stored Settings from EEPROM
pinMode(6,OUTPUT);
display.begin();
// init done
// you can change the contrast around to adapt the display
// for the best viewing!
display.setContrast(25);
display.display(); // show splashscreen
display.println("Raht Lightning Detector");
display.drawBitmap(35, 22, lightning_bmp, 16, 16, 1);
display.setTextColor(BLACK);
display.display();
flash();
display.display();
delay(3000);
// setup for the the I2C library: (enable pullups, set speed to 400kHz)
I2c.begin();
I2c.pullup(true);
I2c.setSpeed(1);
delay(2);
lightning0.AS3935_DefInit(); // set registers to default
// now update sensor cal for your application and power up chip
lightning0.AS3935_ManualCal(AS3935_CAPACITANCE, AS3935_OUTDOORS, AS3935_DIST_EN);
// AS3935_ManualCal Parameters:
// --> capacitance, in pF (marked on package)
// --> indoors/outdoors (AS3935_INDOORS:0 / AS3935_OUTDOORS:1)
// --> disturbers (AS3935_DIST_EN:1 / AS3935_DIST_DIS:2)
// function also powers up the chip
// enable interrupt (hook IRQ pin to Arduino Uno/Mega interrupt input: 0 -> pin 2, 1 -> pin 3 )
attachInterrupt(0, AS3935_ISR, RISING);
lightning0.AS3935_PrintAllRegs();
AS3935_ISR_Trig = 0; // clear trigger
//------- this just gets played over and over..... and over...... and o......
analogWrite(6,60); //---turn on the backlight
//----- build the screen
display.println("LastStrike");
display.println("Dist: "+ String(lsDist));
display.setCursor(50,8);
//--- if we pick miles, do this
if (mi==1){ display.println(" Mi");}
//otherwise assume we want to do this....
else { display.println(" Km");}
display.setCursor(0,17);
display.println("0");
display.setCursor(72,17);
//if miles--- 40 km = aaprox 25 miles
if(mi==1){
display.println("25");
else{
//--- otherwise just scale it for 40 km
display.println("40");
display.setCursor(0,39);
display.println("Strikes: ");
display.setCursor(48,39);
display.println(String(l));
display.setCursor(64,39);
//-- place an indication that we're set to inside in the lower right corner of the display
if (dist==1){display.println("Out");}
else{
//-- or Show were set for outdoors
display.println("In");}
//--draw the distance scale
display.drawLine( 0, 37, 84, 37, BLACK);
display.drawLine( 0, 25, 0, 37, BLACK);
display.drawLine( 21, 35, 21, 37, BLACK);
display.drawLine( 42, 35, 42, 37, BLACK);
display.drawLine( 63, 35, 63, 37, BLACK);
display.drawLine( 83, 25, 83, 37, BLACK);
//display.fillCircle(mapDist,35,2,BLACK);
if (l==0)
//-- we begin with no strikes detected
display.setCursor(9,24);
display.println("No Strikes");
if (l>0)
//-if theres a strike. place a little zap at the distance it is...
display.drawBitmap(mapDist, 22, lightning, 16, 16, 1);
if (mapDist>20){
display.println("Far Ligntning");
display.display();
if(0 == AS3935_ISR_Trig){
// Serial.println(read_buttons());
animateCloud();
//Serial.println(read_buttons());
if (read_buttons() !=5){
menu();
// reset interrupt flag
// now get interrupt source
uint8_t int_src = lightning0.AS3935_GetInterruptSrc();
if(0 == int_src)
display.setCursor(72,0);
display.println("?");
display.display();
//delay(1000);
display.println(" ");
else if(1 == int_src)
flash();
uint8_t lightning_dist_km = lightning0.AS3935_GetLightningDistKm();
l++;
display.println(" Lightning!!");
if (mi==1){
lsDist=(lightning_dist_km * 0.62137);
else{
lsDist=(lightning_dist_km);
display.println((lsDist));
mapDist = map(lsDist, 0, 25, 0, 83);
display.println(" Miles");
display.display();
flash();
else if(2 == int_src)
//display.clearDisplay();
display.println("N");
// n++;
display.display();
else if(3 == int_src)
display.println("Noise level too high");
display.display();
// lightning0.AS3935_PrintAllRegs(); // for debug...
// this is irq handler for AS3935 interrupts, has to return void and take no arguments
// always make code in interrupt handlers fast and short
void AS3935_ISR()
AS3935_ISR_Trig = 1;
//---flash the display routine
void flash(){
for (int y=1;y<5;y++){
digitalWrite(6,LOW);
display.invertDisplay(true);
delay(100);
digitalWrite(6,HIGH);
display.invertDisplay(false);
delay(100);
//--make that cloud go baby!!
void animateCloud(){
display.drawBitmap(m,15, cloud, 16, 16, 1);
display.display();
if(m>=80){m=0;}
m++;
delay(200);
C:\Users\09112022\Documents\Arduino\Lightning1\Lightning1.ino:16:10: fatal error: I2C.h: No such file or directory
#include "I2C.h"
compilation terminated.
exit status 1
Compilation error: I2C.h: No such file or directory
