#using-arduino i am working in 3 phase fault detection project.
code is compiling and upload successfully on Arduino but
during hardware implement it is not displaying anything except "detecting fault---"
either you create fault (like: phase to neutral) or No fault condition.
(It does not run the main loop of code)
please help me to resolve this issue
#include <SoftwareSerial.h>
#include <ArduinoJson.h>
#include <LiquidCrystal.h>
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
SoftwareSerial nodemcu(9, 10);
int mVperAmp = 100;
float I1 = 0.00;
float I2 = 0.00;
float I3 = 0.00;
int FT = 1;
int MAP = 0;
double pickup_current = 0.55;
double fault_current = 0;
double Voltage1 = 0;
double Voltage2 = 0;
double Voltage3 = 0;
double Voltage4 = 0;
double VRMS1 = 0;
double VRMS2 = 0;
double VRMS3 = 0;
double VRMS4 = 0;
double AmpsRMS1 = 0;
double AmpsRMS2 = 0;
double AmpsRMS3 = 0;
double AmpsRMS4 = 0;
pinMode(7, OUTPUT);
pinMode(6, INPUT);
lcd.begin(16, 2);
nodemcu.begin(115200);
Serial.println("Program started");
lcd.print(" TRANSMISSION ");
lcd.setCursor(0, 1);
lcd.print(" LINE ");
delay(800);
lcd.clear();
lcd.print("FAULT DECTECTION");
lcd.print(" SYSTEM");
delay(800);
Voltage1 = getVPP1();
VRMS1 = (Voltage1 / 2.0) * 0.707;
AmpsRMS1 = (VRMS1 * 1000) / mVperAmp;
Serial.print(AmpsRMS1);
Serial.println(" Neutral RMS");
Voltage2 = getVPP2();
VRMS2 = (Voltage2 / 2.0) * 0.707;
AmpsRMS2 = (VRMS2 * 1000) / mVperAmp;
Serial.print(AmpsRMS2);
Serial.println(" Red RMS");
Voltage3 = getVPP3();
VRMS3 = (Voltage3 / 2.0) * 0.707;
AmpsRMS3 = (VRMS3 * 1000) / mVperAmp;
AmpsRMS3 = (AmpsRMS3 + (AmpsRMS3 * (0.40)));
Serial.print(AmpsRMS3);
Serial.println(" Green RMS");
Voltage4 = getVPP4();
VRMS4 = (Voltage4 / 2.0) * 0.707;
AmpsRMS4 = (VRMS4 * 1000) / mVperAmp;
Serial.print(AmpsRMS4);
Serial.println(" Blue RMS");
if (((AmpsRMS2 > pickup_current) && (AmpsRMS1 >= 0.37)) || ((AmpsRMS3 > pickup_current) && (AmpsRMS1 >= 0.37)) || ((AmpsRMS4 > pickup_current) && (AmpsRMS1 >= 0.37)) || ((AmpsRMS2 > pickup_current) && (AmpsRMS3 > pickup_current)) || ((AmpsRMS3 > pickup_current) && (AmpsRMS4 > pickup_current)) || ((AmpsRMS4 > pickup_current) && (AmpsRMS2 > pickup_current))) {
lcd.clear();
digitalWrite(7, HIGH);
while (digitalRead(6) == LOW) {
Serial.println(" RED RMS");
Serial.println(" GREEN RMS");
Serial.println(" BLUE RMS");
lcd.clear();
if ((AmpsRMS2 > pickup_current) && (AmpsRMS3 > pickup_current) && (AmpsRMS4 > pickup_current) && (AmpsRMS1 < 0.40)) {
tone(13, 1000);
lcd.print("Three Phase");
lcd.print("fault");
FT = 2;
} else if ((AmpsRMS2 > pickup_current) || (AmpsRMS3 > pickup_current) || (AmpsRMS4 > pickup_current)) {
if ((AmpsRMS2 > pickup_current) && (AmpsRMS3 > pickup_current) || (AmpsRMS3 > pickup_current) && (AmpsRMS4 > pickup_current) || (AmpsRMS4 > pickup_current) && (AmpsRMS2 > pickup_current)) {
tone(13, 1000);
if (AmpsRMS1 >= 0.38) {
lcd.clear();
lcd.print("Double line to");
lcd.print("Ground fault");
FT = 3;
lcd.print("line to line");
lcd.print("fault");
FT = 4;
tone(13, 1000);
lcd.print("Single line to");
FT = 5;
lcd.clear();
if ((AmpsRMS2 > pickup_current) && (AmpsRMS1 >= 0.37)) {
fault_current = AmpsRMS2;
lcd.clear();
lcd.setCursor(0, 0);
lcd.print("RED");
lcd.print("GROUND");
if ((AmpsRMS3 > pickup_current) && (AmpsRMS1 >= 0.37)) {
fault_current = AmpsRMS3;
lcd.clear();
lcd.print("GREEN");
if ((AmpsRMS4 > pickup_current) && (AmpsRMS1 >= 0.37)) {
fault_current = AmpsRMS4;
lcd.clear();
lcd.print("BLUE");
if ((AmpsRMS2 > pickup_current) && (AmpsRMS3 > pickup_current)) {
lcd.clear();
lcd.print("RED");
lcd.print("GREEN");
} else if ((AmpsRMS3 > pickup_current) && (AmpsRMS4 > pickup_current)) {
lcd.clear();
lcd.print("GREEN");
lcd.print("BLUE");
} else if ((AmpsRMS4 > pickup_current) && (AmpsRMS2 > pickup_current)) {
lcd.clear();
lcd.print("BLUE");
lcd.print("RED");
if (fault_current >= 1.10) {
MAP = 2;
lcd.setCursor(8, 0);
lcd.print("2 KM");
lcd.setCursor(8, 1);
lcd.print("2 KM");
if ((AmpsRMS2 > pickup_current) && (AmpsRMS3 > pickup_current) && (AmpsRMS4 > pickup_current)) {
delay(1500);
lcd.clear();
lcd.print("BLUE");
lcd.print("2 KM");
if ((fault_current >= 0.83) && (fault_current < 1.10)) {
MAP = 4;
lcd.print("4 KM");
lcd.print("4 KM");
delay(1500);
lcd.clear();
lcd.print("BLUE");
lcd.print("4 KM");
if ((fault_current >= 0.72) && (fault_current < 0.83)) {
MAP = 6;
lcd.print("6 KM");
lcd.print("6 KM");
delay(1500);
lcd.clear();
lcd.print("BLUE");
lcd.print("6 KM");
if ((fault_current >= pickup_current) && (fault_current < 0.72)) {
MAP = 8;
lcd.print("8 KM");
lcd.print("8 KM");
delay(1500);
lcd.clear();
lcd.print("BLUE");
lcd.print("8 KM");
digitalWrite(7, LOW);
noTone(13);
lcd.clear();
lcd.print(" NO FAULT ");
FT = 1;
void sendStatus() {
StaticJsonBuffer<1000> jsonBuffer;
JsonObject& data = jsonBuffer.createObject();
I1 = AmpsRMS1;
I2 = AmpsRMS2;
I3 = AmpsRMS3;
data["FT"] = FT;
data["MAP"] = MAP;
data["I1"] = I1;
data["I2"] = I2;
data["I3"] = I3;
data.printTo(nodemcu);
jsonBuffer.clear();
float getVPP1() {
lcd.clear();
lcd.print("FAULT DETECTING");
lcd.print("----------");
float result1;
int readValue1; //value read from the sensor
int maxValue1 = 0; // store max value here
int minValue1 = 1024; // store min value here
uint32_t start_time = millis();
while ((millis() - start_time) < 1000) //sample for 1 Sec
readValue1 = analogRead(A0);
// see if you have a new maxValue
if (readValue1 > maxValue1) {
/*record the maximum sensor value*/
maxValue1 = readValue1;
if (readValue1 < minValue1) {
/*record the minimum sensor value*/
minValue1 = readValue1;
// Subtract min from max
result1 = ((maxValue1 - minValue1) * 5.0) / 1024.0;
return result1;
float getVPP2() {
lcd.print("------------");
float result2;
int readValue2; //value read from the sensor
int maxValue2 = 0; // store max value here
int minValue2 = 1024; // store min value here
readValue2 = analogRead(A1);
if (readValue2 > maxValue2) {
maxValue2 = readValue2;
if (readValue2 < minValue2) {
minValue2 = readValue2;
result2 = ((maxValue2 - minValue2) * 5.0) / 1024.0;
return result2;
float getVPP3() {
lcd.print("--------------");
float result3;
int readValue3; //value read from the sensor
int maxValue3 = 0; // store max value here
int minValue3 = 1024; // store min value here
readValue3 = analogRead(A2);
if (readValue3 > maxValue3) {
maxValue3 = readValue3;
if (readValue3 < minValue3) {
minValue3 = readValue3;
result3 = ((maxValue3 - minValue3) * 5.0) / 1024.0;
return result3;
float getVPP4() {
lcd.print("----------------");
float result4;
int readValue4; //value read from the sensor
int maxValue4 = 0; // store max value here
int minValue4 = 1024; // store min value here
readValue4 = analogRead(A3);
if (readValue4 > maxValue4) {
maxValue4 = readValue4;
if (readValue4 < minValue4) {
minValue4 = readValue4;
result4 = ((maxValue4 - minValue4) * 5.0) / 1024.0;
return result4;
