#include <SoftwareSerial.h>
#include <ArduinoJson.h>
#include <LiquidCrystal.h>
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
SoftwareSerial nodemcu(9, 10);
int mVperAmp = 100;
float I1 = 0.00;
float I2 = 0.00;
float I3 = 0.00;
int FT = 1;
int MAP = 0;
double pickup_current = 0.55;
double fault_current = 0;
double Voltage1 = 0;
double Voltage2 = 0;
double Voltage3 = 0;
double Voltage4 = 0;
double VRMS1 = 0;
double VRMS2 = 0;
double VRMS3 = 0;
double VRMS4 = 0;
double AmpsRMS1 = 0;
double AmpsRMS2 = 0;
double AmpsRMS3 = 0;
double AmpsRMS4 = 0;
void setup(){
pinMode (7, OUTPUT);
pinMode (6, INPUT);
lcd.begin(16, 2);
nodemcu.begin(115200);
Serial.println("Program started");
lcd.print(" TRANSMISSION ");
lcd.setCursor (0, 1);
lcd.print(" LINE ");
delay(800);
lcd.clear();
lcd.print("FAULT DECTECTION");
lcd.print(" SYSTEM");
delay(800);
void loop(){
sendStatus();
Voltage1 = getVPP1();
VRMS1 = (Voltage1/2.0) *0.707;
AmpsRMS1 = (VRMS1 * 1000)/mVperAmp;
Serial.print(AmpsRMS1);
Serial.println(" Neutral RMS");
Voltage2 = getVPP2();
VRMS2 = (Voltage2/2.0) *0.707;
AmpsRMS2 = (VRMS2 * 1000)/mVperAmp;
Serial.print(AmpsRMS2);
Serial.println(" Red RMS");
Voltage3 = getVPP3();
VRMS3 = (Voltage3/2.0) 0.707;
AmpsRMS3 = (VRMS3 * 1000)/mVperAmp;
AmpsRMS3 = (AmpsRMS3+(AmpsRMS3(0.40)));
Serial.print(AmpsRMS3);
Serial.println(" Green RMS");
Voltage4 = getVPP4();
VRMS4 = (Voltage4/2.0) *0.707;
AmpsRMS4 = (VRMS4 * 1000)/mVperAmp;
Serial.print(AmpsRMS4);
Serial.println(" Blue RMS");
if (((AmpsRMS2 > pickup_current) && (AmpsRMS1 >= 0.37)) || ((AmpsRMS3 > pickup_current) && (AmpsRMS1 >= 0.37)) || ((AmpsRMS4 > pickup_current) && (AmpsRMS1 >= 0.37)) || ((AmpsRMS2 > pickup_current) && (AmpsRMS3 > pickup_current)) || ((AmpsRMS3 > pickup_current) && (AmpsRMS4 > pickup_current)) || ((AmpsRMS4 > pickup_current) && (AmpsRMS2 > pickup_current))){
lcd.clear();
digitalWrite (7, HIGH);
while (digitalRead(6) == LOW){
Serial.println(" RED RMS");
Serial.println(" GREEN RMS");
Serial.println(" BLUE RMS");
lcd.clear();
if ((AmpsRMS2 > pickup_current) && (AmpsRMS3 > pickup_current) && (AmpsRMS4 > pickup_current) && (AmpsRMS1 < 0.40)){
tone (13, 1000);
lcd.print ("Three Phase");
lcd.print("fault");
FT = 2;
else if ((AmpsRMS2 > pickup_current) || (AmpsRMS3 > pickup_current) || (AmpsRMS4 > pickup_current)){
if ((AmpsRMS2 > pickup_current) && (AmpsRMS3 > pickup_current)|| (AmpsRMS3 > pickup_current) && (AmpsRMS4 > pickup_current)|| (AmpsRMS4 > pickup_current) && (AmpsRMS2 > pickup_current)){
tone (13, 1000);
if (AmpsRMS1 >= 0.38){
lcd.clear();
lcd.print ("Double line to");
lcd.print("Ground fault");
FT = 3;
else{
lcd.print ("line to line");
lcd.print("fault");
FT = 4;
else {
tone (13, 1000);
lcd.print ("Single line to");
FT = 5;
lcd.clear();
if ((AmpsRMS2 > pickup_current) && (AmpsRMS1 >= 0.37))
fault_current = AmpsRMS2;
lcd.clear();
lcd.setCursor (0, 0);
lcd.print("RED");
lcd.print("GROUND");
if ((AmpsRMS3 > pickup_current) && (AmpsRMS1 >= 0.37))
fault_current = AmpsRMS3;
lcd.clear();
lcd.print("GREEN");
if ((AmpsRMS4 > pickup_current) && (AmpsRMS1 >= 0.37))
fault_current = AmpsRMS4;
lcd.clear();
lcd.print("BLUE");
if ((AmpsRMS2 > pickup_current) && (AmpsRMS3 > pickup_current))
lcd.clear();
lcd.print("RED");
lcd.print("GREEN");
else if ((AmpsRMS3 > pickup_current) && (AmpsRMS4 > pickup_current))
lcd.clear();
lcd.print("GREEN");
lcd.print("BLUE");
else if ((AmpsRMS4 > pickup_current) && (AmpsRMS2 > pickup_current))
lcd.clear();
lcd.print("BLUE");
lcd.print("RED");
if (fault_current >= 1.10){
MAP = 2;
lcd.setCursor(8, 0);
lcd.print("2 KM");
lcd.setCursor(8, 1);
lcd.print("2 KM");
if ((AmpsRMS2 > pickup_current) && (AmpsRMS3 > pickup_current) && (AmpsRMS4 > pickup_current)){
delay(1500);
lcd.clear();
lcd.setCursor(0, 0);
lcd.print("BLUE");
lcd.print("2 KM");
if ((fault_current >= 0.83) && (fault_current < 1.10)){
MAP = 4;
lcd.print("4 KM");
lcd.print("4 KM");
delay(1500);
lcd.clear();
lcd.print("BLUE");
lcd.print("4 KM");
if ((fault_current >= 0.72) && (fault_current < 0.83)){
MAP = 6;
lcd.print("6 KM");
lcd.print("6 KM");
delay(1500);
lcd.clear();
lcd.print("BLUE");
lcd.print("6 KM");
if ((fault_current >= pickup_current) && (fault_current < 0.72)){
MAP = 8;
lcd.print("8 KM");
lcd.print("8 KM");
delay(1500);
lcd.clear();
lcd.print("BLUE");
lcd.print("8 KM");
else {
digitalWrite (7, LOW);
noTone(13);
lcd.clear();
lcd.print(" NO FAULT ");
FT = 1;
void sendStatus(){
StaticJsonBuffer<1000> jsonBuffer;
JsonObject& data = jsonBuffer.createObject();
I1 = AmpsRMS1;
I2 = AmpsRMS2;
I3 = AmpsRMS3;
data["FT"] = FT;
data["MAP"] = MAP;
data["I1"] = I1;
data["I2"] = I2;
data["I3"] = I3;
data.printTo(nodemcu);
jsonBuffer.clear();
float getVPP1()
lcd.clear();
lcd.print("FAULT DETECTING");
lcd.print("----------");
float result1;
int readValue1; //value read from the sensor
int maxValue1 = 0; // store max value here
int minValue1 = 1024; // store min value here
uint32_t start_time = millis();
while((millis()-start_time) < 1000) //sample for 1 Sec
readValue1 = analogRead(A0);
// see if you have a new maxValue
if (readValue1 > maxValue1)
/record the maximum sensor value/
maxValue1 = readValue1;
if (readValue1 < minValue1)
/record the minimum sensor value/
minValue1 = readValue1;
// Subtract min from max
result1 = ((maxValue1 - minValue1) * 5.0)/1024.0;
return result1;
float getVPP2()
lcd.print("------------");
float result2;
int readValue2; //value read from the sensor
int maxValue2 = 0; // store max value here
int minValue2 = 1024; // store min value here
readValue2 = analogRead(A1);
if (readValue2 > maxValue2)
maxValue2 = readValue2;
if (readValue2 < minValue2)
minValue2 = readValue2;
result2 = ((maxValue2 - minValue2) * 5.0)/1024.0;
return result2;
float getVPP3()
lcd.print("--------------");
float result3;
int readValue3; //value read from the sensor
int maxValue3 = 0; // store max value here
int minValue3 = 1024; // store min value here
readValue3 = analogRead(A2);
if (readValue3 > maxValue3)
maxValue3 = readValue3;
if (readValue3 < minValue3)
minValue3 = readValue3;
result3 = ((maxValue3 - minValue3) * 5.0)/1024.0;
return result3;
float getVPP4()
lcd.print("----------------");
float result4;
int readValue4; //value read from the sensor
int maxValue4 = 0; // store max value here
int minValue4 = 1024; // store min value here
readValue4 = analogRead(A3);
if (readValue4 > maxValue4)
maxValue4 = readValue4;
if (readValue4 < minValue4)
minValue4 = readValue4;
result4 = ((maxValue4 - minValue4) * 5.0)/1024.0;
return result4;
