Hi
on my PCB i have these connectors:
2,54 mm pitch
1 pcs 5 pin
3 pcs 3 pin
2 pcs 2 pin
Is there a quality female connector, like in one piece that can be DIY connected to my cables
I only find female for PCB.
Something like this, where solder pins are hidden under a cover?
M
Juraj
June 20, 2024, 9:44am
3
I remove the black plastic from 'dupont' wires female ends and fit the metallic part into the housing like the ones linked by UKHeliBob
https://www.amazon.co.uk/HALJIA-120pcs-Multicolored-Dupont-Breadboard/dp/B06WV7XHJ9/
Look at what Molex has. try this term in your search engine: "molex 2.54 connectors"
jim-p
June 20, 2024, 5:04pm
5
No crimping, no soldering
This one is for 26 AWG there are others for 22-28
How IDC works
Thanks @UKHeliBob
This is probably correct form factor and system.
I get a feeling that this is "china" quality. I'm hoping to find something "better", but
Hi, @jim-p
I struggle to understand the datasheet. Can I ask to be 100% shure that this connector can connects to this:
I found this picture, Is there a "plug" that goes into connection space, to force cable into "split knife coupling"?
jim-p
June 21, 2024, 12:59pm
8
No, it will connect to the header you described in post #1
No plug. There is actually a special tool to push the wires down into the split knife but with a little patience you can do it with a small screw driver
jim-p
June 21, 2024, 1:05pm
9
Go here to see the different types for 2.54pitch and 6 position
system
Closed
December 18, 2024, 1:05pm
10
