I have been trying nearly all the ways and i opened this topic into discussion but got not proper answer..
I have a sensor and i would like to find the max and min value after 10 readings. any idea? basically put one for loop then save them into readings[index]
int min=0,max=0;
int readings[10];
for(int index=0; index<10; index++)
readings[index] = analogRead(A0);
but how can i find and store max and min value among 10 values?
Set min to 1024, max to -1.
Within your loop, use an if to test whether the latest reading is less than min and if so, set min to the new value. Similar thing for max.
Thanks for your answer. Here i have done something .I can see sensor reading and running average but can not see max and min value shows me always zero! Any idea?
const int numReadings=5;
int readings[numReadings]; //Number of readings
int index; // the index of current reading
int sensorMin=1023; //min sensor value
int sensorMax=0; //max sensor value
int deltaMax; // Max_value- Average
int deltaMin; // Min_value- Average
int total; //the running total
int average; // The average
pinMode(10, OUTPUT);
pinMode(11, OUTPUT);
readings[index]=analogRead(A0);
for (int i=0 ;i<numReadings;i++)
readings[i]=0;
//record the min ,max sensor value
if (readings[index]<sensorMin){
sensorMin=readings[index];
if (readings[index]>sensorMax){
sensorMax=readings[index];
total=total-readings[index]; //substract the last reading
readings[index]=analogRead(A0); //read from the sensor
total=total+readings[index]; //add the reading in the total
index=index+1;
if (index >= numReadings)
index = 0;
average=total /numReadings; //running average
deltaMax=sensorMax-average;
deltaMin=average-sensorMin;
if(deltaMax >1||deltaMin >1){
digitalWrite(11,LOW);
digitalWrite(10,LOW);
index=0 ; //turn the beginning read the sensor again
if(deltaMax>average){
digitalWrite(10,readings[index]);
if(deltaMin<average){
digitalWrite(11,readings[index]);
Serial.println (average);
delay(100);
You manually set the whole array to 0 before checking it against the max/min. 0 will always be >= 0, and 0 will always be < 1023. Set the array to the input data instead of initializing it to 0 directly before checking for min/max.
I did not get exacyly what you mean.with this code readings*=0; i initialitze the array and fill the array with sensor readings.when i delete this sensor shows 0 for the average values then i say* * *if (readings[index]<sensorMin){ sensorMin=readings[index]; } if (readings[index]>sensorMax){ sensorMax=readings[index]; }* * and my codes shows me the sensor readings, average but my codes does not show the min and max values among sensor readings :S * *//record the min ,max sensor value if (readings[index]<sensorMin){ sensorMin=readings[index]; } if (readings[index]>sensorMax){ sensorMax=readings[index]; } }* *
You're calculating the average in your loop, but only calculating the min/max once in the setup function. Further, you calculate the min/max directly after initializing the entire array to 0. Of course they're going to read 0.
Yes now i am able to see the running average value of 5 readings and max value also.but i cant see min value..it always shows me ''0''
readings[i]=0;
index=index+1;
index = 0;
Here i have changed the codes a little bit ..i see the max value and mix value perfectly! but average value shows always 0!
sensorMax=sensorMax-readings[index]; //substract the last reading
sensorMax=analogRead(A0);
sensorMin=sensorMin+readings[index];
index=index+1;
index = 0;
I really need your idea and help..thanks a lot in advance
What you still need to learn is improve your writing style/layout.
Press CTRL-T in the IDE autoformats the code and that improves readability a lot.
Furthermore some spaces and empty lines
readings[index]=readings[index]; //read from the sensor
sensorMax = sensorMax - readings[index]; //substract the last reading
if (readings[index] > sensorMax){
sensorMax = analogRead(A0);
sensorMin = sensorMin + readings[index];
if (readings[index] < sensorMin){
sensorMin = readings[index];
total = total - readings[index]; //substract the last reading
total=total + readings[index]; //add the reading in the total
index=index + 1;
index = 0;
average = total /numReadings; //running average
deltaMax = sensorMax - average;
deltaMin = average - sensorMin;
finally
can be shortenend to
sensorMax -= readings[index];
Thanks for the informative answer and tipps but i still did not solve the problem of calculation average value..
as i told in previous post that now i am able to read the sensor and find the max and min value ..however average value still shows ''0'' .
sensorMax-=readings[index]; //substract the last reading
sensorMin+=readings[index]; //substract the last reading
total-=readings[index]; //substract the last reading
total+=readings[index]; //add the reading in the total
index=index+1;
index = 0;
is it maybe i did not initialize the array? but when i make this then i cant get min and max values..:S
thanks for your help in advance
code comment conflict
Simplified your code, may contain typo or so, not tested, but it should work with minor mods
int numReadings = 10;
int readings[10];
int index = 0;
int sensorMax = 0;
int sensorMin = 0;
sensorMin = sensorMax;
// MEASUREMENTS
// every iteration of loop makes one additional measurement,
// so the first 10 readings will display too low average
int value = analogRead(A0);
readings[index] = value;
index++;
if (index >= numReadings) index = 0;
// DO SOME MATH
if (value > sensorMax) sensorMax = value;
if (value < sensorMin) sensorMin = value;
//running average
float total = 0;
for (int i = 0; i< numReadings; i++) total += readings[index];
float average = total /numReadings;
// OUTPUT TO SERIAL
Serial.print("\tMIN:\t");
Serial.print(sensorMin);
Serial.print("\tMAX:\t");
Serial.print(sensorMax);
Serial.print("\tAVG:\t");
Serial.println(average, 1); // 1 decimal
there was one typo in my code as I didn't check, now it should work
int readings[10];
int index = 0;
int sensorMax = 0;
int sensorMin = 0;
// MEASUREMENTS
index++;
// DO SOME MATH
//running average
float total = 0;
for (int i = 0; i< numReadings; i++) total += readings[i];
// OUTPUT TO SERIAL
output, as predicted it takes 10 readings to stabilize ..
Thanks a lot for your answer,i really appreciate it.
I have also tested the codes ,at the beginning it works ..(i am using a strain sensor so depending on position UP/DOWN the sensor value changes) so when i dont apply strain it shows ;
as you see it works at the beginning but the values do not come back to their initial values when i stop applying strain.Therefore I am thinking in this way;
int sensorMax = 0;
int sensorMin = 1023;
//You have said 0 for both but we should set them min. high and read for anything lower than that
I initialize both min and max with the first reading which is technically speaking 100% correct.
When you have only one reading it is the min and the max.
THis is a variation of the code that determines the min/max from the last 10 reads only, again the first 10 reads are biased.
int readings[10];
int index = 0;
// MEASUREMENTS
index++;
//running average, min and max
float total = 0;
int sensorMax = 0;
if (readings[i] > sensorMax) sensorMax = readings[i];
if (readings[i] < sensorMin) sensorMin = readings[i];
// OUTPUT TO SERIAL
Thanks a ton for your help and idea..after some small changes I have done it and now the codes is able to see running average,max and min values..
I want to go further though
while there is no strain I would like to store my average value into average_offset variable..and then as I apply strain in up or down direction the average value will change but I want to keep the average_offset value same.(it must not change with average value somehow) and then depending on the comparison between average and average_offsett i will turn one of the led on.
within the loop it seems to be hard to keep the average_offsett value because this average_offset value will change when i do not apply any strain or when i come back to initial state....what about interrupts?
I don't understand the above. It is ambiguous at best, these two parts conflict
I would like to store my average value into average_offset variable*
but I want to keep the average_offset value same*
The first states that average_offset will follow the value of average, the second denies it. Can you rephrase your needs?
is the average_offset a constant or is it a calculated value?
Sorry for being so vague..let me put the question in that way..
I have strain sensor and within the code as we have done before ,we read the sensor (eq 10 times) then we find the max ,mix and average value of this readings...when there is no applied strain the sensor will give only same value which is also max,min and average of the readings.
therefore I defined variables ; deltaMax=sensorMax-average ; deltaMin=average-sensorMin ; so when there is no strain deltaMax and deltaMin will be zero.By applying the strain in up or down direction these values will be non-zero and depending on thise cases leds for up and down position will be on or off.
Up to know I am able to see these values correctly..Here the problem starts...when I apply the strain in up or down position and hold it for a while the ''deltaMax and deltaMin'' values becomes 0 after 5 seconds because the max min values become same [which means there is no strain ] so even in the uppest position of sensor,,
Therefore I want to define a new variable '' average_offset'' ...while deltaMax and deltaMin= 0 ,average_offset=average; but this value must be same and every e.g 10 minutes I want to define ''new'' average_offset and go through the loop again..
So let me put in example [for 5 readings] readings ; 100,100,100,100,100 max=100, min=100,average=100,deltaMax and deltaMin= 0 so that average_offset=100
I apply strain and new reading =120 average=110 average_offset=100 ----reading >average_offset so strain is in UP directioon.
