First try with .h and .cpp, Multiple Definition issue
Hi guys,
I'm not very expert with arduino and with programming in general;
I make a CPS (Concented Solar Power) for my thesis ( i'm becoming a mechanical engineer) and i'm trying to develope an automated system for the Solar Traking and for putting temperature data online on a chart.
Every thing works pretty well, but I'd love to split the code in come .h and .cpp files to make it more "professional".
So I splitted the loop in a few functions(FS,SC,PrintTime), but i'm getting this issue:
sketch\FS.cpp.o:(.bss.display+0x0): multiple definition of `display'
sketch\Controller.ino.cpp.o:(.bss.display+0x0): first defined here
sketch\PrintTime.cpp.o:(.bss.display+0x0): multiple definition of `display'
sketch\SC.cpp.o:(.bss.display+0x0): multiple definition of `display'
collect2.exe: error: ld returned 1 exit status
I Think the problem in related to: all the function print something on the display (SSD1306). I created a .h file with all the delarations for that display, then i included it in every .cpp files.
I have tried lot of thing, i cannot understand why it says there are multiple definition.
Could someone help me please?
Thanks in advance guys,
RIccardo.
"Concented"
Concentric?
Concentrated?
Error code, but no code == no help
Without seeing your complete code it is difficult to provide any help so please post your sketch and library files
Please post your code following the advice given in the link below
please post your code using </>
Read the error messages, then be sure you are repeating the declarations, not the definitions of all those things it’s complaining about.
a7
Are you maybe missing the "extern" keyword?
Thank guys,
I miss a few things like the code to put data on web( already tested alone)
And 2 temperature sensor.
l'll try to share the code..
Main one
#include "PINOUT.h"
#include "FS.h"
#include "SC.h"
#include "PrintTime.h"
boolean FS = true ;
const char* ntpServer = "pool.ntp.org";
const long  gmtOffset_sec = 3600;
const int   daylightOffset_sec = 3600;
//////time/////////
const char* ssid       = "TP-LINK_A7650E";
const char* password   = "*************";
  pinMode ( LS1, INPUT );
  pinMode ( LS2, INPUT );
  pinMode ( LS3, INPUT );
  pinMode ( LS4, INPUT );
  pinMode ( MTC, OUTPUT );
  pinMode ( MTA, OUTPUT );
  pinMode ( MPA, OUTPUT );
  pinMode ( MPO, OUTPUT );
  pinMode ( SMAXTILT, INPUT );
  pinMode ( SMINTILT, INPUT );
  pinMode ( SMAXPAN , INPUT );
  pinMode ( SMINPAN, INPUT );
  digitalWrite ( MTC, HIGH);
  digitalWrite ( MTA, HIGH);
  digitalWrite ( MPA, HIGH);
  digitalWrite ( MPO, HIGH);
/////OLED_I2C///////
display.begin(SSD1306_SWITCHCAPVCC, 0x3C);
  //connect to WiFi
  Serial.printf("Connecting to %s ", ssid);
  WiFi.begin(ssid, password);
      Serial.print(".");
  Serial.println(" CONNECTED");
  //init and get the time
  configTime(gmtOffset_sec, daylightOffset_sec, ntpServer);
printLocalTime();
 if ( FS == true){FirstStart(); FS = false; } ////FIRST START
  SolarCheck();
FS.ccp (first start = open to max)
#include "FS.h"
void FirstStart(){
  Serial.println ("1st start");
  Serial.println ("tilt");
  display.clearDisplay();
  display.setCursor(0, 0);
  display.println("First Start Adj..");
  display.display();
  display.print("Tilt Axis..");
  display.display();
    while (digitalRead(SMAXTILT) == 1){ digitalWrite(MTA, LOW);}
    digitalWrite(MTA, HIGH);
         Serial.println ("tilt max");
         display.println("Tilt Max!");
         display.println("Pan Axis...");
         display.display();
         Serial.println ("pan");
    while (digitalRead(SMAXPAN) == 1){digitalWrite(MPA, LOW);}
    digitalWrite(MPA, HIGH);
        Serial.println ("pan max");
        display.print("Pan Max!");
        display.display();
        delay(2000);
FS.h
#ifndef FS_H
#define FS_H
#include "PINOUT.h"
#include "displaydef.h"
void FirstStart();
#endif
SC.cpp (Solar Check)
/////////SOLAR CHECK////////////////
#include "SC.h"
#include "FS.h"
unsigned long t1, dt; // X SOLARCHECK
void SolarCheck(){
  int LS1Val = analogRead(LS1);
  int LS2Val = analogRead(LS2);
  int LS3Val = analogRead(LS3);
  int LS4Val = analogRead(LS4);
  dt= millis() - t1;
  if(dt >= 5000)
  t1=millis();
  Serial.println("Solar Check");
  display.setCursor(0,0);
  display.println("Solar Check");
  display.println("");
  Serial.print("SX: ");
  Serial.println(LS1Val);
  display.setCursor(0,16);
  display.print("Sx: ");
  display.println(LS1Val);
  if ( LS1Val > 600 & LS1Val > (LS2Val*1.2) ) {digitalWrite ( MPO , LOW); delay(500);digitalWrite ( MPO , HIGH);}
  else {digitalWrite ( MPO , HIGH);}
  Serial.print("DX:  ");
  Serial.println(LS2Val);
  display.print("Dx: ");
  display.println(LS2Val);
  if ( LS2Val > 600 & LS2Val > (LS1Val*1.2) ) {digitalWrite ( MPA , LOW);delay(500);digitalWrite ( MPA , HIGH);}
  else {digitalWrite ( MPA , HIGH);}
Serial.print("UP:  ");
  Serial.println(LS3Val);
  display.print("UP: ");
  display.println(LS3Val);
  if ( LS3Val > 600 & LS3Val > (LS4Val*1.2) ) {digitalWrite ( MTA , LOW); delay(500);digitalWrite ( MTA , HIGH);}
  else {digitalWrite ( MTA , HIGH);}
  Serial.print("DOWN:  ");
  Serial.println(LS4Val);
  display.print("Down: ");
  display.println(LS4Val);
  if ( LS4Val > 600 & LS4Val > (LS3Val*1.2) ) {digitalWrite ( MTC , LOW); delay(500);digitalWrite ( MTC , HIGH);}
  else {digitalWrite ( MTC , HIGH);}
  display.display();
if (digitalRead(SMINPAN) == 0 & LS1Val > 200){
  Serial.print ("RO Pan..");
  display.print("RO Pan..");
  display.display();
  while(digitalRead(SMAXPAN) == 1){digitalWrite(MPA, LOW);}
  Serial.print ("Max Pan!");
  display.println("Max Pan");
  display.display();
  display.clearDisplay();} ///REOPEN
if (digitalRead(SMINTILT) == 0 & LS1Val > 200){
  Serial.print ("RO Tilt..");
  display.print("RO Tilt..");
  display.display();
  while(digitalRead(SMAXTILT) == 1){digitalWrite(MTA, LOW);}
  Serial.print ("Max Tilt!");
  display.println("Max Tilt");
  display.display();
  delay(100);
SC.h
#ifndef SC_H
#define SC_H
#include "PINOUT.h"
void SolarCheck();
#endif
displaydef.h ( i made this to just define all i need for display print one time)
#ifndef displaydef_H
#define displaydef_H
#include <SPI.h>
#include <Wire.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
#define SCREEN_WIDTH 128 // OLED display width, in pixels
#define SCREEN_HEIGHT 64 // OLED display height, in pixels
#define SCREEN_ADDRESS 0x3C
Adafruit_SSD1306 display(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, -1);
#endif
PINOUT.h (i don't now if it's good or it's better to keep it in main)
#ifndef PINOUT_h
#define PUNOUT_H
///////input///////
  ///luxmeters//
   #define LS1 33 //sx
   #define LS2 32 //dx
   #define LS3 34 //up
   #define LS4 35 //down
  ///microswitch
  #define SMAXTILT 15
  #define SMINTILT 2
  #define SMAXPAN 4
  #define SMINPAN 0
////output//////
  ///MOTORS
  #define MTC 18 //Tilt Chiudere
  #define MTA 5 //Tilt Aprire
  #define MPA 16 //Pan AntiORario
  #define MPO 17  //Pan Orario
  #endif
Print time.h ( printlocaltime() is just an example copyed from esp time library)
#ifndef PrintTime_H
#define PrintTime_H
#include "time.h"
#include <WiFi.h>
//#include "displaydef.h"
void printLocalTime();
#endif
Concentrated..
Sorry wrote it so fast..
Yep sorry, it was Definition not declaration
Have I to write it? where?
the above in displaydef.h causes display to be defined in every .ino/.cpp file displaydef.h is included in
i think display can be defined as an extern in the .h
extern Adafruit_SSD1306 display;
See My Reply #5 Here.
So like this..
Still not working
#include <SPI.h>
#include <Wire.h>
extern Adafruit_SSD1306 display(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, -1);
#endif
Error Code
Error compiling for board ESP32 Dev Module.
no
like this
OK so what I did it's basically good..I'll try to put all the include on the cpp...
Without " (SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, -1); " it's not working, it says :
sketch\Controller.ino.cpp.o:(.literal._Z5setupv+0x10): undefined reference to display'`
don't know what this means
the above, the definition/constructor is needed in the .cpp file
the above declaration is needed in the .h file so that the compiler knows about display in .ino/.cpp files referencing it.
Thanks for your patience..
I tried and i got this
SC.cpp:7:8: error: 'Adafruit_SSD1306' does not name a type
I think I'll re-put everything together and f**k the "professional Look" :joy:
First of all thanks for the answere you linked, I saved it!
Then, i tried, but if I put the include I get a thousands error becouse it doesn't recognize the display. commands ( like display.display() display.print etc)
There are proponents of this approach.
Just make the soup, everything in one pot, delicious and if you need the carrot, fish around in there and find it.
Srsly, until you understand what you did, what you did wrong and why what doing as has been suggested here worked, to the extent that it did, it makes no sense to just go about tossing extern at things and otherwise fiddling with your code.
a7
