I need to use a MOSFET in one of my projects but the pins are too large for breadboards.
Is there an adapter for this?
Thanks
Thanks
Solder-less breadboard ?
You might have luck turning the legs 90°.
If you use a large MOSFET you probably plan to use a lot of current. That may melt your breadboard in case of a poor connection (which is likely with a solderless BB).
I tend to temporarily solder small stiff copper wire, or spare jumpers / headers to things like this for prototyping.
As others have said, beware current limits on your breadboard
Which is to say twisting each by 90°. ![]()
Mind you, actually explaining what you are trying to do might be a good idea.
You can easy make an adpter for that, but i have used mosfets on breadboard many times and that works fine. Just push them in there.
Breadboards are cheap so no worry.
Or you vcan just solder the legs of an mosfet to a 3-pin male header like this:
