Float to char conversion
Hey there,
I wish to take a GPS coordinates, calculate some stuff, and send Bearing float to another Arduino using I2C. For that reason I need to master I2C, and especially float into char conversion, and vise verso. So I did Google a bit on the subject, and going around the forum came up with this:
float FltValue = 1.34567890;
char ChValue[10];
  Serial.println("");
  Serial.println("The value is: ");
  dtostrf(FltValue, 10, 8, ChValue);
  for (int i = 0; i < 10; i++)
    Serial.print(ChValue[i]);
  delay (1000);
So far it works as expected. Serial do print 1.34567890. However when I try to execute some code after, or before delay function it starts to behave oddly.
For example Serial.print("Some text"); is getting completely ignored. What am I doing wrong?
char ChValue[10];
  Serial.println("");
  delay (1000);
Up the baud rate to 115200 and try Serial.println("sometext").
or
Serial.print("efvedfvdfv");
works.
a float uses 4 byte on the Arduino UNO.
You could just send these 4 bytes with Wire.h.
But the first question might be: why do you use 2 Arduinos? Why not one Arduino?
Why do you want first convert float to char, send it and then convert vice verso? Why do not send float as float?
Thanks IdahoWalker! , I did try to change the baud rate to 115200 , as recommended, but still the code after delay is getting ignored.
You just need to change:
char ChValue[11];
If your string is 10 characters long, you can't size your buffer to 10 because of the the terminating byte, resulting in a bad program behavior flooding out of the assigned memory.
Working with char arrays, do not forget to allocate space for terminator.
To converting something to string with 10 chars you need char array with 11 elements!
Change Serial.print("Some text"); to Serial.println("\nSome text"); and see what goes..
EDIT: Added "\n" to make a new line after the for loop..
PS: besides, I don't know why you need a for() statement to print a string, just do this:
  Serial.println("");
  Serial.println(ChValue);
and what about using Serial.println() did that work?
Serial.print() and Serial.println() do different things.
Please read my post #6...
Cat helping you??
@valkan why two Arduinos, and why I2C?
a7
good one, thanks for the laugh.
Tx noiasca! It is a project, that runs a lot of things. My plan is to get dedicated Arduinos, one for managing the actuators, other for managing access to internet, and bearing calculations. So I plan when have the course established, to send it to the Arduino that will control a rudder. I will try to find out how to work whit these 4 bytes with wire.h.
I was not aware that I can send float directly via I2C. Still learning :slight_smile:
When I can give you an advise: Stay on one Controller.
"Access Internet" - honestly ... use something like an ESP8266 or an ESP32 on makerfriendly boards.
If you run out of pins - use port expanders.
here is a short demo to "transmit" a float
   send a flaot bytwise to another arduino
float fsend;
char csend[4];
char creceived[4];
float freceived;
  // "Sender Side"
  fsend = 12.34;
  Serial.println(fsend);
  memcpy(csend, &fsend, sizeof (fsend));    // send data
  for (int i = 0; i < 4; i++)
    Serial.print(byte(csend[i]), HEX);
    Serial.print(' ');
  Serial.println();      // // what have we got
  // transmit
  memcpy(creceived, csend, 4); // simulate received bytes
  // "Receiver Side"
    Serial.print(byte(creceived[i]), HEX);  // what have we got
    Serial.print(' ');
  memcpy(&freceived, creceived, sizeof (creceived));    // receive data
  Serial.println(freceived);
2 minutes research
this is the output:
12.34
A4 70 45 41
A4 70 45 41
12.34
DocDoc, and b707 thanks. What you offered seems to be just the solution.
Tx again noiasca, I will try to understand your example, and implement it. What do would you recommend for internet via GSM card?
It is OK, thanks again!
I would say that my advice is not to use the Internet via GSM as the first project.
Are there really places where there is no wi-fi?
