Forum Login Issues... Appear 100% solved. [NOT!]
Folks
There were threads about the odd 'token' string being appended to URLs that froze the forum (presented a blank browser window) when attempting to log on.
Lots of us did the F12 trick and cleared caches, etc...
Ultimately, I found disabling InPrivate mode worked.... so I've been fine ever since.
Today... while in InPrivate mode.... I simply navigated to the forum and logged in... completely successful... good response, no token appends, etc...
Kudos to you folks for fixing this issue (well for my particular configuration anyway)..
Windows 7 64bit Ultmate SP1, Internet Explorer 11.
It was not working yesterday. I had the same issue (clicked login, and the browser went white and nothing happened).
But now its working again.
I think the problem was due to the Title of this Thread :slight_smile:
...R
ODwyerPW:
Folks
The simple fact is, notwithstanding what browser is used, or what functions are configured or implemented in it, the appearance of the "token" suffix is an indication of some particularly stupid piece of coding in the forum software installation. The use, behaviour or configuration of any particular browser or other is simply irrelevant, nothing any user can do will have any actual effect.
There are no possible circumstances under which this should ever occur; the fact that it does indicates that there is a piece of software that desperately needs to be removed as it has been incompetently written. Whatever was in the minds at the time of those who wrote it, it was incompetence plain and simple, nothing more, nothing less. Sadly, it reflects poorly on whoever permits it to appear in a service such as this as it needs to be identified and removed; whatever module it is is responsible for the majority of all-too-frequent failures of this system and whilst interestingly less frequent, it now has "come back to bite us". and has not been exterminated in the "upgrade", effectively rendering the upgrade process rather futile overall.
I couldn't have been any more wrong.
Back to doing the F12 trick multiple times again.....
Doesn't work on Windows10 / IE11 nor Windows8.1 / IE11...
Good grief.
ODwyerPW:
It's your own fault.
If you had not said it was 100% fixed it would be working perfectly :slight_smile:
...R
I think I'll amend the subject of the first post, eh?
Yeah,
Thanks Nick.
